SMESHUtils::SMESH_RegularGrid Class Reference
Define a regular grid of nx,ny,nz dimension. More...
#include <SMESH_RegularGrid.hxx>
enum  EdgeType {
  BOTTOM , RIGHT , TOP , LEFT ,
  NONE
enum  VertexType {
  V0 , V1 , V2 , V3 ,
  V4 , V5 , V6 , V7
enum  FaceType {
  B_BOTTOM , B_RIGHT , B_BACK , B_LEFT ,
  B_FRONT , B_TOP , B_NONE
 SMESH_RegularGrid (const int id, const int nx, const int ny, const int nz=1)
void SetNode (const std::shared_ptr< gp_Pnt > &point, const int iIndex, const int jIndex, const int zIndex=0)
void SetNode (const SMDS_MeshNode *point, const int iIndex, const int jIndex, const int zIndex=0)
void SetNode (const SMDS_MeshNode *point, const int index)
const std::shared_ptr< gp_Pnt > GetNode (const int index) const
const std::shared_ptr< gp_Pnt > GetNode (const int iIndex, const int jIndex, const int zIndex)
int nx () const
int ny () const
int nz () const
int Size ()
NCollection_Array1< std::shared_ptr< gp_Pnt > >::Iterator CoordinateBegin ()
int id () const
void GetEdgeInterfaces (SMESH_RegularGrid *grid, std::vector< int > &interface)
void GetFaceInterfaces (SMESH_RegularGrid *grid, std::vector< int > &interface)
template<typename T >
void getAllEdgeIndexLimits (std::vector< std::vector< T > > &allRanges)
void getAllFaceIndexLimits (std::vector< std::vector< T > > &allRanges)
std::vector< T > getEdgeIndexLimits (const EdgeType edge) const
std::vector< int > getEdgeIndexLimitsInverted (const EdgeType edge) const
std::vector< T > getFaceIndexLimits (SMESH_RegularGrid::FaceType face) const
SMESH_RegularGrid::FaceType getFaceTypeByGeomFace (TopoDS_Shape shapeFace) const
SMESH_RegularGrid::EdgeType getEdgeTypeByGeomEdge (TopoDS_Shape shapeEdge) const
 ~SMESH_RegularGrid ()
void GetCommontInterface (EdgeType edge, SMESH_RegularGrid *grid, std::vector< int > &interface)
void GetCommontInterface (FaceType face, SMESH_RegularGrid *grid, std::vector< int > &interface)
bool GetPrecomputedInterface (EdgeType edge, const SMESH_RegularGrid *grid, std::vector< int > &interface)
bool GetPrecomputedInterface (FaceType face, const SMESH_RegularGrid *grid, std::vector< int > &interface)
void setInterface (SMESH_RegularGrid::EdgeType edge, const int gridId, std::vector< int > &interface)
void setInterface (SMESH_RegularGrid::FaceType face, const int gridId, std::vector< int > &interface)
std::pair< int, int > getEdgeLimits (const SMESH_RegularGrid::EdgeType edge) const
std::tuple< int, int, int, int > getFaceLimits (const SMESH_RegularGrid::FaceType face) const
std::vector< int > getEdgeIndexLimits (const int start, const int end) const
std::vector< int > getFaceIndexLimits (const int start, const int end) const
std::vector< int > computeTransformation (const SMESH_RegularGrid::EdgeType edge, SMESH_RegularGrid::EdgeType gridDonorEdge, std::vector< int > &interfaceRange, std::vector< int > &interfaceDonor) const
std::vector< int > computeTransformation (const SMESH_RegularGrid::FaceType face, SMESH_RegularGrid::FaceType gridDonorFace, std::vector< int > &interfaceRange, std::vector< int > &interfaceDonor) const
int getEdgeSize (const EdgeType edge) const
int getFaceSize (const FaceType face) const
int getFaceCoordinateIndex (const VertexType v) const
std::tuple< int, int, int > GetIJK (const int index) const
template<typename FUNCTION >
void foreachGridSide (const FUNCTION &fSide) const
void foreachGridFace (const FUNCTION &fSide) const
void foreachNodeOnSide (SMESH_RegularGrid::EdgeType edge, const std::function< void(const std::shared_ptr< gp_Pnt > point, const int index)> &function) const
void foreachNodeOnFace (SMESH_RegularGrid::FaceType face, const std::function< void(const std::shared_ptr< gp_Pnt > point, const int index)> &function) const
std::vector< int > nodesOfSide (SMESH_RegularGrid::EdgeType edge) const
std::vector< int > nodesOfFace (SMESH_RegularGrid::FaceType face) const
void transformIndexLimits (FaceType face, std::vector< int > &faceLimits, const std::shared_ptr< gp_Pnt > &V0, const std::shared_ptr< gp_Pnt > &V1, const std::shared_ptr< gp_Pnt > &V2, const std::shared_ptr< gp_Pnt > &V3)
int myId
int mnx
int mny
int mnz
int mns
NCollection_Array1< std::shared_ptr< gp_Pnt > > myCoordinates
std::map< SMESH_RegularGrid::EdgeType, std::map< int, std::vector< int > > > myInterfaceMap
std::map< SMESH_RegularGrid::FaceType, std::map< int, std::vector< int > > > myFaceInterafaceMap
A vector with gp_Pnt is defined by default by a canonical order, the canonical order is: i-index goes faster, then j-index and finally z-index. This data structure was created to index mesh nodes created by Quadrangle_2D and Prism_3D meshers. The StructuredCGNS export driver uses this data structure to define zones, grid coordinate points and interfaces.
◆ EdgeType
BOTTOM
RIGHT
TOP
LEFT
NONE
◆ FaceType
B_BOTTOM
B_RIGHT
B_BACK
B_LEFT
B_FRONT
B_TOP
B_NONE
◆ VertexType
V0
V1
V2
V3
V4
V5
V6
V7
◆ SMESH_RegularGrid()
SMESH_RegularGrid::SMESH_RegularGrid ( const int  id,
const int  nx,
const int  ny,
const int  nz = 1
References mnx, mny, mnz, and myCoordinates.
◆ ~SMESH_RegularGrid()
SMESH_RegularGrid::~SMESH_RegularGrid ( )
◆ computeTransformation() [1/2]
std::vector< int > SMESH_RegularGrid::computeTransformation ( const SMESH_RegularGrid::EdgeType  edge,
std::vector< int > &  interfaceRange,
std::vector< int > &  interfaceDonor
References BOTTOM, MESHCUT::d, LEFT, RIGHT, and TOP.
Referenced by GetCommontInterface().
◆ computeTransformation() [2/2]
std::vector< int > SMESH_RegularGrid::computeTransformation ( const SMESH_RegularGrid::FaceType  face,
◆ CoordinateBegin()
NCollection_Array1< std::shared_ptr< gp_Pnt > >::Iterator SMESHUtils::SMESH_RegularGrid::CoordinateBegin ( )
◆ foreachGridFace()
void SMESHUtils::SMESH_RegularGrid::foreachGridFace ( const FUNCTION &  fSide) const
◆ foreachGridSide()
void SMESHUtils::SMESH_RegularGrid::foreachGridSide ( const FUNCTION &  fSide) const
◆ foreachNodeOnFace()
void SMESHUtils::SMESH_RegularGrid::foreachNodeOnFace ( SMESH_RegularGrid::FaceType  face,
const std::function< void(const std::shared_ptr< gp_Pnt > point, const int index)> &  function
References myCoordinates, and nodesOfFace().
◆ foreachNodeOnSide()
void SMESHUtils::SMESH_RegularGrid::foreachNodeOnSide ( SMESH_RegularGrid::EdgeType  edge,
References myCoordinates, and nodesOfSide().
◆ getAllEdgeIndexLimits()
void SMESHUtils::SMESH_RegularGrid::getAllEdgeIndexLimits ( std::vector< std::vector< T > > &  allRanges)
References foreachGridSide().
◆ getAllFaceIndexLimits()
void SMESHUtils::SMESH_RegularGrid::getAllFaceIndexLimits ( std::vector< std::vector< T > > &  allRanges)
References foreachGridFace().
◆ GetCommontInterface() [1/2]
void SMESH_RegularGrid::GetCommontInterface ( EdgeType  edge,
SMESH_RegularGrid *  grid,
◆ GetCommontInterface() [2/2]
void SMESH_RegularGrid::GetCommontInterface ( FaceType  face,
◆ getEdgeIndexLimits() [1/2]
std::vector< T > SMESHUtils::SMESH_RegularGrid::getEdgeIndexLimits ( const EdgeType  edge) const
References mnx, and mny.
◆ getEdgeIndexLimits() [2/2]
std::vector< int > SMESH_RegularGrid::getEdgeIndexLimits ( const int  start,
const int  end
References end(), and GetIJK().
◆ getEdgeIndexLimitsInverted()
std::vector< int > SMESH_RegularGrid::getEdgeIndexLimitsInverted ( const EdgeType  edge) const
◆ GetEdgeInterfaces()
void SMESH_RegularGrid::GetEdgeInterfaces ( SMESH_RegularGrid *  grid,
◆ getEdgeLimits()
std::pair< int, int > SMESH_RegularGrid::getEdgeLimits ( const SMESH_RegularGrid::EdgeType  edge) const
Referenced by GetCommontInterface(), and getEdgeTypeByGeomEdge().
◆ getEdgeSize()
int SMESH_RegularGrid::getEdgeSize ( const EdgeType  edge) const
◆ getEdgeTypeByGeomEdge()
SMESH_RegularGrid::EdgeType SMESH_RegularGrid::getEdgeTypeByGeomEdge ( TopoDS_Shape  shapeEdge) const
◆ getFaceCoordinateIndex()
int SMESH_RegularGrid::getFaceCoordinateIndex ( const VertexType  v) const
References mnx, mny, and mnz.
Referenced by getFaceLimits().
◆ getFaceIndexLimits() [1/2]
std::vector< int > SMESH_RegularGrid::getFaceIndexLimits ( const int  start,
const int  end
◆ getFaceIndexLimits() [2/2]
std::vector< T > SMESHUtils::SMESH_RegularGrid::getFaceIndexLimits ( SMESH_RegularGrid::FaceType  face) const
References B_BACK, B_BOTTOM, B_FRONT, B_LEFT, B_RIGHT, B_TOP, mnx, mny, and mnz.
◆ GetFaceInterfaces()
void SMESH_RegularGrid::GetFaceInterfaces ( SMESH_RegularGrid *  grid,
◆ getFaceLimits()
std::tuple< int, int, int, int > SMESH_RegularGrid::getFaceLimits ( const SMESH_RegularGrid::FaceType  face) const
◆ getFaceSize()
int SMESH_RegularGrid::getFaceSize ( const FaceType  face) const
◆ getFaceTypeByGeomFace()
SMESH_RegularGrid::FaceType SMESH_RegularGrid::getFaceTypeByGeomFace ( TopoDS_Shape  shapeFace) const
◆ GetIJK()
std::tuple< int, int, int > SMESH_RegularGrid::GetIJK ( const int  index) const
Referenced by getEdgeIndexLimits(), and getFaceIndexLimits().
◆ GetNode() [1/2]
const std::shared_ptr< gp_Pnt > SMESH_RegularGrid::GetNode ( const int  iIndex,
const int  jIndex,
const int  zIndex
References mns, mnx, mny, and myCoordinates.
◆ GetNode() [2/2]
const std::shared_ptr< gp_Pnt > SMESHUtils::SMESH_RegularGrid::GetNode ( const int  index) const
◆ GetPrecomputedInterface() [1/2]
bool SMESH_RegularGrid::GetPrecomputedInterface ( EdgeType  edge,
const SMESH_RegularGrid *  grid,
References id(), and myInterfaceMap.
Referenced by GetEdgeInterfaces(), and GetFaceInterfaces().
◆ GetPrecomputedInterface() [2/2]
bool SMESH_RegularGrid::GetPrecomputedInterface ( FaceType  face,
References id(), and myFaceInterafaceMap.
◆ id()
int SMESHUtils::SMESH_RegularGrid::id ( ) const
◆ nodesOfFace()
std::vector< int > SMESH_RegularGrid::nodesOfFace ( SMESH_RegularGrid::FaceType  face) const
◆ nodesOfSide()
std::vector< int > SMESH_RegularGrid::nodesOfSide ( SMESH_RegularGrid::EdgeType  edge) const
References BOTTOM, mnx, mny, and TOP.
Referenced by foreachNodeOnSide().
◆ nx()
int SMESHUtils::SMESH_RegularGrid::nx ( ) const
◆ ny()
int SMESHUtils::SMESH_RegularGrid::ny ( ) const
◆ nz()
int SMESHUtils::SMESH_RegularGrid::nz ( ) const
◆ setInterface() [1/2]
void SMESH_RegularGrid::setInterface ( SMESH_RegularGrid::EdgeType  edge,
const int  gridId,
References myInterfaceMap.
◆ setInterface() [2/2]
void SMESH_RegularGrid::setInterface ( SMESH_RegularGrid::FaceType  face,
const int  gridId,
References myFaceInterafaceMap.
◆ SetNode() [1/3]
void SMESH_RegularGrid::SetNode ( const SMDS_MeshNode *  point,
const int  iIndex,
const int  jIndex,
const int  zIndex = 0
◆ SetNode() [2/3]
const int  index
◆ SetNode() [3/3]
void SMESH_RegularGrid::SetNode ( const std::shared_ptr< gp_Pnt > &  point,
const int  iIndex,
const int  jIndex,
◆ Size()
int SMESHUtils::SMESH_RegularGrid::Size ( )
◆ transformIndexLimits()
void SMESH_RegularGrid::transformIndexLimits ( FaceType  face,
std::vector< int > &  faceLimits,
const std::shared_ptr< gp_Pnt > &  V0,
const std::shared_ptr< gp_Pnt > &  V1,
const std::shared_ptr< gp_Pnt > &  V2,
const std::shared_ptr< gp_Pnt > &  V3
◆ mns
int SMESHUtils::SMESH_RegularGrid::mns
Referenced by GetNode(), and SetNode().
◆ mnx
◆ mny
◆ mnz
int SMESHUtils::SMESH_RegularGrid::mnz
◆ myCoordinates
NCollection_Array1<std::shared_ptr<gp_Pnt> > SMESHUtils::SMESH_RegularGrid::myCoordinates
◆ myFaceInterafaceMap
std::map<SMESH_RegularGrid::FaceType,std::map<int,std::vector<int> > > SMESHUtils::SMESH_RegularGrid::myFaceInterafaceMap
◆ myId
int SMESHUtils::SMESH_RegularGrid::myId
◆ myInterfaceMap
std::map<SMESH_RegularGrid::EdgeType,std::map<int,std::vector<int> > > SMESHUtils::SMESH_RegularGrid::myInterfaceMap
