DriverStructuredCGNS_Write Class Reference
Driver writinging a mesh into the CGNS file. More...
#include <DriverStructuredCGNS_Write.hxx>
Inheritance diagram for DriverStructuredCGNS_Write:
enum  Status {
  DRS_OK , DRS_EMPTY , DRS_WARN_RENUMBER , DRS_WARN_SKIP_ELEM ,
  DRS_WARN_DESCENDING , DRS_FAIL , DRS_TOO_LARGE_MESH
 DriverStructuredCGNS_Write ()
 ~DriverStructuredCGNS_Write ()
 Close the cgns file at destruction. More...
virtual Status Perform ()
 Write the mesh into the CGNS file. More...
std::string GetGroupName (const int shapeToIndex, int dim)
 Search for a SMESHDS_GroupOnGeom associated to the geometry and return his name. More...
void CheckForGroupNameOnFaceInterfaces (const SMESHUtils::SMESH_RegularGrid *grid, std::vector< std::string > &interfaceNames)
 Fill name of face interfaces associated to mesh groups. More...
void CheckForGroupNameOnEdgeInterfaces (const SMESHUtils::SMESH_RegularGrid *grid, std::vector< std::string > &interfaceNames)
 Fill name of edge interfaces associated to mesh groups. More...
void SetMesh (SMESHDS_Mesh *theMesh)
void SetMeshId (int theMeshId)
virtual void SetFile (const std::string &theFileName)
virtual void SetMeshName (const std::string &theMeshName)
virtual std::string GetMeshName () const
virtual void SetOption (const std::string &, const std::string &)
virtual SMESH_ComputeErrorPtr GetError ()
 Return a structure containing description of errors. More...
template<typename IDTYPE >
static bool IsMeshTooLarge (const SMDS_Mesh *mesh, bool checkIDs)
Status addMessage (const std::string &msg, const bool isFatal=false)
 Stores an error message. More...
static std::string fixUTF8 (const std::string &s)
 Assure a string is UTF-8 valid by replacing invalid chars. More...
SMESHDS_Mesh * myMesh
std::string myFile
std::string myMeshName
int myMeshId
std::vector< std::string > myErrorMessages
Status myStatus
void GetGroupNamesMap (const TopoDS_Shape &shape, int dim, std::map< size_t, std::string > &groupNameMapById)
 Get the map between a solid (or face) id and its unique name. More...
int _fn
 file index More...
◆ Status
enum Driver_Mesh::Status
DRS_OK
DRS_EMPTY
DRS_WARN_RENUMBER
DRS_WARN_SKIP_ELEM
DRS_WARN_DESCENDING
DRS_FAIL
DRS_TOO_LARGE_MESH
◆ DriverStructuredCGNS_Write()
DriverStructuredCGNS_Write::DriverStructuredCGNS_Write ( )
◆ ~DriverStructuredCGNS_Write()
DriverStructuredCGNS_Write::~DriverStructuredCGNS_Write ( )
References _fn.
◆ addMessage()
◆ CheckForGroupNameOnEdgeInterfaces()
void DriverStructuredCGNS_Write::CheckForGroupNameOnEdgeInterfaces ( const SMESHUtils::SMESH_RegularGrid *  grid,
std::vector< std::string > &  interfaceNames
◆ CheckForGroupNameOnFaceInterfaces()
void DriverStructuredCGNS_Write::CheckForGroupNameOnFaceInterfaces ( const SMESHUtils::SMESH_RegularGrid *  grid,
◆ fixUTF8()
std::string Driver_Mesh::fixUTF8 ( const std::string &  s)
staticprotectedinherited
Referenced by DriverMED_R_SMESHDS_Mesh::Perform().
◆ GetError()
◆ GetGroupName()
std::string DriverStructuredCGNS_Write::GetGroupName ( const int  shapeToIndex,
int  dim
shapeToIndex,theindex of the shape as given by shapeToIndex method
the name of the group if found or an empty name
References SMESHDS_Mesh::GetGroups(), SMESHDS_GroupOnGeom::GetShape(), SMESHDS_GroupBase::GetStoreName(), Driver_SMESHDS_Mesh::myMesh, and SMESHDS_Mesh::ShapeToIndex().
Referenced by GetGroupNamesMap().
◆ GetGroupNamesMap()
void DriverStructuredCGNS_Write::GetGroupNamesMap ( const TopoDS_Shape &  shape,
int  dim,
std::map< size_t, std::string > &  groupNameMapById
Add a suffix if needed to avoid duplicate group name.
References Face, GetGroupName(), Driver_SMESHDS_Mesh::myMesh, and SMESHDS_Mesh::ShapeToIndex().
Referenced by Perform().
◆ GetMeshName()
std::string Driver_Mesh::GetMeshName ( ) const
◆ IsMeshTooLarge()
static bool Driver_Mesh::IsMeshTooLarge ( const SMDS_Mesh *  mesh,
bool  checkIDs
◆ Perform()
◆ SetFile()
◆ SetMesh()
◆ SetMeshId()
◆ SetMeshName()
void Driver_Mesh::SetMeshName ( const std::string &  theMeshName)
◆ SetOption()
virtual void Driver_Mesh::SetOption ( const std::string &  ,
const std::string &
◆ _fn
int DriverStructuredCGNS_Write::_fn
file index
Referenced by Perform(), and ~DriverStructuredCGNS_Write().
◆ myErrorMessages
std::vector< std::string > Driver_Mesh::myErrorMessages
◆ myFile
◆ myMesh
◆ myMeshId
◆ myMeshName
◆ myStatus
Status Driver_Mesh::myStatus
