SMESH_Mesh_i Class Reference
#include <SMESH_Mesh_i.hxx>
Inheritance diagram for SMESH_Mesh_i:
struct  TGeomGroupData
 SMESH_Mesh_i (PortableServer::POA_ptr thePOA, SMESH_Gen_i *myGen_i)
virtual ~SMESH_Mesh_i ()
void SetShape (GEOM::GEOM_Object_ptr theShapeObject)
 SetShape. More...
CORBA::Boolean HasShapeToMesh ()
 Return true if mesh has a shape to build a shape on. More...
GEOM::GEOM_Object_ptr GetShapeToMesh ()
 Return the shape to mesh. More...
virtual void ReplaceShape (GEOM::GEOM_Object_ptr theNewGeom)
 Replace a shape in the mesh upon Break Link. More...
CORBA::Boolean IsLoaded ()
 Return false if the mesh is not yet fully loaded from the study file. More...
void Load ()
 Load full mesh data from the study file. More...
void Clear ()
 Remove all nodes and elements. More...
void ClearSubMesh (CORBA::Long ShapeID)
 Remove all nodes and elements for indicated shape. More...
SMESH::Hypothesis_Status AddHypothesis (GEOM::GEOM_Object_ptr aSubShape, SMESH::SMESH_Hypothesis_ptr anHyp, CORBA::String_out anErrorText)
 AddHypothesis. More...
SMESH::Hypothesis_Status RemoveHypothesis (GEOM::GEOM_Object_ptr aSubShape, SMESH::SMESH_Hypothesis_ptr anHyp)
 Un-assign a hypothesis from a sub-mesh dedicate to the given sub-shape. More...
SMESH::ListOfHypothesis * GetHypothesisList (GEOM::GEOM_Object_ptr aSubShape)
 Return hypotheses assigned to a given sub-shape. More...
SMESH::submesh_array * GetSubMeshes ()
 Return sub-meshes. More...
SMESH::SMESH_subMesh_ptr GetSubMesh (GEOM::GEOM_Object_ptr aSubShape, const char *theName)
 Create and return a sub-mesh on the given sub-shape. More...
void RemoveSubMesh (SMESH::SMESH_subMesh_ptr theSubMesh)
 Remove a sub-mesh. More...
SMESH::SMESH_Group_ptr CreateGroup (SMESH::ElementType theElemType, const char *theName)
 Create a standalone group. More...
SMESH::SMESH_GroupOnGeom_ptr CreateGroupFromGEOM (SMESH::ElementType theElemType, const char *theName, GEOM::GEOM_Object_ptr theGeomObj)
 Create a group based on the given geometry. More...
SMESH::SMESH_GroupOnFilter_ptr CreateGroupFromFilter (SMESH::ElementType theElemType, const char *theName, SMESH::Filter_ptr theFilter)
 Creates a group whose contents is defined by filter. More...
void RemoveGroup (SMESH::SMESH_GroupBase_ptr theGroup)
 Remove a group. More...
void RemoveGroupWithContents (SMESH::SMESH_GroupBase_ptr theGroup)
 Remove group with its contents. More...
SMESH::ListOfGroups * GetGroups ()
 Get the list of groups existing in the mesh. More...
CORBA::Long NbGroups ()
 Get number of groups existing in the mesh. More...
SMESH::SMESH_Group_ptr UnionGroups (SMESH::SMESH_GroupBase_ptr theGroup1, SMESH::SMESH_GroupBase_ptr theGroup2, const char *theName)
 New group including all mesh elements present in initial groups is created. More...
SMESH::SMESH_Group_ptr UnionListOfGroups (const SMESH::ListOfGroups &theGroups, const char *theName)
SMESH::SMESH_Group_ptr IntersectGroups (SMESH::SMESH_GroupBase_ptr theGroup1, SMESH::SMESH_GroupBase_ptr theGroup2, const char *theName)
 New group is created. More...
SMESH::SMESH_Group_ptr IntersectListOfGroups (const SMESH::ListOfGroups &theGroups, const char *theName)
 Intersect list of groups. More...
SMESH::SMESH_Group_ptr CutGroups (SMESH::SMESH_GroupBase_ptr theGroup1, SMESH::SMESH_GroupBase_ptr theGroup2, const char *theName)
SMESH::SMESH_Group_ptr CutListOfGroups (const SMESH::ListOfGroups &theMainGroups, const SMESH::ListOfGroups &theToolGroups, const char *theName)
 Cut lists of groups. More...
SMESH::SMESH_Group_ptr CreateDimGroup (const SMESH::ListOfIDSources &theGroups, SMESH::ElementType theElemType, const char *theName, SMESH::NB_COMMON_NODES_ENUM theNbCommonNodes, CORBA::Boolean theUnderlyingOnly)
 Create a group of entities basing on nodes of other groups. More...
SMESH::ListOfGroups * FaceGroupsSeparatedByEdges (CORBA::Double theSharpAngle, CORBA::Boolean theCreateEdges, CORBA::Boolean theUseExistingEdges)
 Distribute all faces of the mesh between groups using sharp edges and optionally existing 1D elements as group boundaries. More...
SMESH::SMESH_Group_ptr ConvertToStandalone (SMESH::SMESH_GroupBase_ptr theGroupOn)
 Create standalone group from a group on geometry or filter. More...
SMESH::log_array * GetLog (CORBA::Boolean clearAfterGet)
 Return a log that can be used to move another mesh to the same state as this one. More...
SMESH::SMESH_MeshEditor_ptr GetMeshEditor ()
 Return mesh editor. More...
SMESH::SMESH_MeshEditor_ptr GetMeshEditPreviewer ()
 Return mesh edition previewer. More...
CORBA::Boolean HasModificationsToDiscard ()
 Return true if the mesh has been edited since a last total re-compute and those modifications may prevent successful partial re-compute. More...
void ClearLog ()
 Remove the log of commands. More...
CORBA::Long GetId ()
 Return a mesh ID. More...
void SetImpl (::SMESH_Mesh *impl)
 Set mesh implementation. More...
::SMESH_Mesh & GetImpl ()
 Return a mesh implementation. More...
SMESH_Gen_i * GetGen ()
int ImportUNVFile (const char *theFileName)
 ImportUNVFile. More...
int ImportSTLFile (const char *theFileName)
 ImportSTLFile. More...
SMESH::ComputeError * ImportGMFFile (const char *theFileName, bool theMakeRequiredGroups)
 Import data from a GMF file and return an error description. More...
SMESH::DriverMED_ReadStatus ImportMEDFile (const char *theFileName, const char *theMeshName)
 consult DriverMED_R_SMESHDS_Mesh::ReadStatus for returned value More...
SMESH::DriverMED_ReadStatus ImportCGNSFile (const char *theFileName, const int theMeshIndex, std::string &theMeshName)
 Import mesh data from the CGNS file. More...
void SetAutoColor (CORBA::Boolean theAutoColor)
 Auto color. More...
CORBA::Boolean GetAutoColor ()
 Return true if auto-color mode is on. More...
CORBA::Boolean HasDuplicatedGroupNamesMED ()
 Check group names for duplications. More...
char * GetVersionString (CORBA::Long minor, CORBA::Short nbDigits)
 Return string representation of a MED file version comprising nbDigits. More...
SMESH::long_array * GetMEDVersionsCompatibleForAppend ()
 Return the list of med versions compatibles for write/append, encoded in 10*major+minor (for instance, code for med 3.2.1 is 32) More...
void ExportMED (const char *file, CORBA::Boolean auto_groups, CORBA::Long version, CORBA::Boolean overwrite, CORBA::Boolean autoDimension=true)
 Export to MED file. More...
CORBA::LongLong ExportMEDCoupling (CORBA::Boolean auto_groups, CORBA::Boolean autoDimension=true)
void ExportDAT (const char *file, const CORBA::Boolean renumber)
 Export a mesh to a DAT file. More...
void ExportUNV (const char *file, const CORBA::Boolean renumber)
 Export a mesh to an UNV file. More...
void ExportSTL (const char *file, bool isascii)
 Export a mesh to an STL file. More...
void ExportStructuredCGNS (SMESH::SMESH_IDSource_ptr meshPart, const char *file, CORBA::Boolean overwrite)
 Export a part of mesh to an StructuredCGNS file. More...
void ExportCGNS (SMESH::SMESH_IDSource_ptr meshPart, const char *file, CORBA::Boolean overwrite, CORBA::Boolean groupElemsByType)
 Export a part of mesh to an CGNS file. More...
void ExportGMF (SMESH::SMESH_IDSource_ptr meshPart, const char *file, CORBA::Boolean withRequiredGroups)
 Export a part of mesh to a GMF file. More...
template<class SPECLS >
void ExportPartToMEDCommon (SPECLS &speCls, SMESH::SMESH_IDSource_ptr meshPart, CORBA::Boolean auto_groups, CORBA::Boolean autoDim, const GEOM::ListOfFields &fields, const char *geomAssocFields, CORBA::Double ZTolerance, CORBA::Boolean saveNumbers)
 Export a part of mesh to a med file. More...
void ExportPartToMED (SMESH::SMESH_IDSource_ptr meshPart, const char *file, CORBA::Boolean auto_groups, CORBA::Long version, CORBA::Boolean overwrite, CORBA::Boolean autoDim, const GEOM::ListOfFields &fields, const char *geomAssocFields, CORBA::Double ZTolerance, CORBA::Boolean saveNumbers)
void ExportPartToMESHIO (SMESH::SMESH_IDSource_ptr meshPart, const char *file, const char *selectedFilter, const char *converter=nullptr)
 Export a part of mesh to a file with meshio library. More...
CORBA::LongLong ExportPartToMEDCoupling (SMESH::SMESH_IDSource_ptr meshPart, CORBA::Boolean auto_groups, CORBA::Boolean autoDim, const GEOM::ListOfFields &fields, const char *geomAssocFields, CORBA::Double ZTolerance, CORBA::Boolean saveNumbers)
 Export a part of mesh to a MEDCoupling DS. More...
void ExportPartToDAT (SMESH::SMESH_IDSource_ptr meshPart, const char *file, CORBA::Boolean renumber)
 Export a part of mesh to a DAT file. More...
void ExportPartToUNV (SMESH::SMESH_IDSource_ptr meshPart, const char *file, CORBA::Boolean renumber)
 Export a part of mesh to an UNV file. More...
void ExportPartToSTL (SMESH::SMESH_IDSource_ptr meshPart, const char *file, CORBA::Boolean isascii)
 Export a part of mesh to an STL file. More...
CORBA::Double GetComputeProgress ()
 Return computation progress [0.,1]. More...
SMESH::smIdType NbNodes ()
 Return nb of nodes. More...
SMESH::smIdType NbElements ()
 Return nb of elements. More...
SMESH::smIdType Nb0DElements ()
 Return nb of 0D elements. More...
SMESH::smIdType NbBalls ()
 Return nb of BALL elements. More...
SMESH::smIdType NbEdges ()
 Return nb of 1D elements. More...
SMESH::smIdType NbEdgesOfOrder (SMESH::ElementOrder order)
 Return nb of edges. More...
SMESH::smIdType NbFaces ()
 Return nb of faces. More...
SMESH::smIdType NbFacesOfOrder (SMESH::ElementOrder order)
SMESH::smIdType NbTriangles ()
 Return nb of tringles. More...
SMESH::smIdType NbTrianglesOfOrder (SMESH::ElementOrder order)
SMESH::smIdType NbBiQuadTriangles ()
 Return nb of bi-quadratic triangles. More...
SMESH::smIdType NbQuadrangles ()
SMESH::smIdType NbQuadranglesOfOrder (SMESH::ElementOrder order)
SMESH::smIdType NbBiQuadQuadrangles ()
SMESH::smIdType NbPolygons ()
SMESH::smIdType NbPolygonsOfOrder (SMESH::ElementOrder order=SMESH::ORDER_ANY)
SMESH::smIdType NbVolumes ()
SMESH::smIdType NbVolumesOfOrder (SMESH::ElementOrder order)
SMESH::smIdType NbTetras ()
SMESH::smIdType NbTetrasOfOrder (SMESH::ElementOrder order)
SMESH::smIdType NbHexas ()
SMESH::smIdType NbHexasOfOrder (SMESH::ElementOrder order)
SMESH::smIdType NbTriQuadraticHexas ()
SMESH::smIdType NbPyramids ()
SMESH::smIdType NbPyramidsOfOrder (SMESH::ElementOrder order)
SMESH::smIdType NbPrisms ()
SMESH::smIdType NbPrismsOfOrder (SMESH::ElementOrder order)
SMESH::smIdType NbHexagonalPrisms ()
SMESH::smIdType NbPolyhedrons ()
SMESH::smIdType NbSubMesh ()
 Return nb of published sub-meshes. More...
SMESH::smIdType_array * GetElementsId ()
 Return ids of all elements. More...
SMESH::smIdType_array * GetElementsByType (SMESH::ElementType theElemType)
 Return ids of all elements of given type. More...
SMESH::smIdType_array * GetNodesId ()
 Return ids of all nodes. More...
SMESH::ElementType GetElementType (SMESH::smIdType id, bool iselem)
 Return type of the given element. More...
SMESH::EntityType GetElementGeomType (SMESH::smIdType id)
 Return geometric type of the given element. More...
SMESH::GeometryType GetElementShape (SMESH::smIdType id)
SMESH::smIdType_array * GetSubMeshElementsId (CORBA::Long ShapeID)
 Returns ID of elements for given submesh. More...
SMESH::smIdType_array * GetSubMeshNodesId (CORBA::Long ShapeID, CORBA::Boolean all)
 Returns ID of nodes for given submesh If param all==true - returns all nodes, else - returns only nodes on shapes. More...
SMESH::ElementType GetSubMeshElementType (CORBA::Long ShapeID)
 Returns type of elements for given submesh. More...
char * Dump ()
 Dumps mesh into a string. More...
SMESH::ListOfGroups * MakeGroupsOfBadInputElements (int theSubShapeID, const char *theGroupName)
 Create a group of elements preventing computation of a sub-shape. More...
SMESH_Hypothesis::Hypothesis_Status addHypothesis (GEOM::GEOM_Object_ptr aSubShape, SMESH::SMESH_Hypothesis_ptr anHyp, std::string *anErrorText=0)
 Create a sub-mesh and add a hypothesis to it. More...
SMESH_Hypothesis::Hypothesis_Status removeHypothesis (GEOM::GEOM_Object_ptr aSubShape, SMESH::SMESH_Hypothesis_ptr anHyp)
SMESH::SMESH_subMesh_ptr createSubMesh (GEOM::GEOM_Object_ptr theSubShapeObject)
 Create a sub-mesh on a given sub-shape. More...
bool removeSubMesh (SMESH::SMESH_subMesh_ptr theSubMesh, GEOM::GEOM_Object_ptr theSubShapeObject)
 Remove a sub-mesh based on the given sub-shape. More...
SMESH::SMESH_GroupBase_ptr createGroup (SMESH::ElementType theElemType, const char *theName, const int theID=-1, const TopoDS_Shape &theShape=TopoDS_Shape(), const SMESH_PredicatePtr &thePred=SMESH_PredicatePtr())
 Create a group. More...
void removeGroup (const int theId)
 SMESH_Mesh_i::removeGroup. More...
SMESH::SMESH_subMesh_ptr getSubMesh (int shapeID)
 Return an existing sub-mesh based on a sub-shape with the given ID. More...
const std::map< int, SMESH::SMESH_GroupBase_ptr > & getGroups ()
void onHypothesisModified (int theHypID, bool updateIcons)
 callback from _impl to 1) forget not loaded mesh data (issue 0021208) 2) mark hypothesis as valid More...
void CheckGeomModif (bool isBreakLink=false)
 Update data if geometry changes. More...
void CheckGeomGroupModif ()
 Update hypotheses assigned to geom groups if the latter change. More...
CORBA::LongLong GetMeshPtr ()
 Return pointer to _impl as an integer value. More...
void CreateGroupServants ()
 Assure that all groups are published. More...
CORBA::Boolean IsComputedOK ()
 Return true if all sub-meshes are computed OK - to update an icon. More...
SMESH::ListOfGroups * GetGroups (const std::list< int > &groupIDs) const
 Return groups contained in _mapGroups by their IDs. More...
SMESH::double_array * GetNodeXYZ (SMESH::smIdType id)
 Get XYZ coordinates of node as list of double If there is not node for given ID - returns empty list. More...
SMESH::smIdType_array * GetNodeInverseElements (SMESH::smIdType id, SMESH::ElementType elemType)
 For given node returns list of IDs of inverse elements If there is not node for given ID - returns empty list. More...
SMESH::NodePosition * GetNodePosition (SMESH::smIdType NodeID)
 Return position of a node on shape. More...
SMESH::ElementPosition GetElementPosition (SMESH::smIdType ElemID)
 Return position of an element on shape. More...
CORBA::Long GetShapeID (SMESH::smIdType id)
 If given element is node returns IDs of shape from position If there is not node for given ID - returns -1. More...
CORBA::Long GetShapeIDForElem (SMESH::smIdType id)
 For given element returns ID of result shape after ::FindShape() from SMESH_MeshEditor If there is not element for given ID - returns -1. More...
CORBA::Short GetElemNbNodes (SMESH::smIdType id)
 Returns number of nodes for given element If there is not element for given ID - returns -1. More...
SMESH::smIdType_array * GetElemNodes (SMESH::smIdType id)
 Returns IDs of nodes of given element. More...
SMESH::smIdType GetElemNode (SMESH::smIdType id, CORBA::Short index)
 Returns ID of node by given index for given element If there is not element for given ID - returns -1 If there is not node for given index - returns -2. More...
CORBA::Boolean IsMediumNode (SMESH::smIdType ide, SMESH::smIdType idn)
 Returns true if given node is medium node in given quadratic element. More...
CORBA::Boolean IsMediumNodeOfAnyElem (SMESH::smIdType idn, SMESH::ElementType elemType)
 Returns true if given node is medium node in one of quadratic elements. More...
CORBA::Long ElemNbEdges (SMESH::smIdType id)
 Returns number of edges for given element. More...
CORBA::Long ElemNbFaces (SMESH::smIdType id)
 Returns number of faces for given element. More...
SMESH::smIdType_array * GetElemFaceNodes (SMESH::smIdType elemId, CORBA::Short faceIndex)
 Returns nodes of given face (counted from zero) for given element. More...
SMESH::double_array * GetFaceNormal (CORBA::Long faceId, CORBA::Boolean normalized)
 Returns three components of normal of given mesh face (or an empty array in KO case) More...
SMESH::smIdType FindElementByNodes (const SMESH::smIdType_array &nodes)
 Returns an element based on all given nodes. More...
SMESH::smIdType_array * GetElementsByNodes (const SMESH::smIdType_array &nodes, SMESH::ElementType elemType)
 Return elements including all given nodes. More...
CORBA::Boolean IsPoly (SMESH::smIdType id)
 Returns true if given element is polygon. More...
CORBA::Boolean IsQuadratic (SMESH::smIdType id)
 Returns true if given element is quadratic. More...
CORBA::Double GetBallDiameter (SMESH::smIdType id)
 Returns diameter of ball discrete element or zero in case of an invalid id. More...
SMESH::double_array * BaryCenter (SMESH::smIdType id)
 Returns bary center for given element. More...
virtual SMESH::MedFileInfo * GetMEDFileInfo ()
 Returns information about imported MED file. More...
std::string FileInfoToString ()
 Persistence of file info. More...
void FileInfoFromString (const std::string &info)
int & MainShapeTick ()
 Persistence of geometry tick. More...
void SetParameters (const char *theParameters)
 Sets list of notebook variables used for Mesh operations separated by ":" symbol. More...
char * GetParameters ()
 Returns list of notebook variables used for Mesh operations separated by ":" symbol. More...
SMESH::string_array * GetLastParameters ()
 Returns list of notebook variables used for last Mesh operation. More...
CORBA::Boolean IsUnorderedSubMesh (CORBA::Long submeshID)
 Return true if a meshing order not yet set for a concurrent sub-mesh. More...
virtual SMESH::submesh_array_array * GetMeshOrder ()
 Return submesh objects list in meshing order. More...
virtual ::CORBA::Boolean SetMeshOrder (const SMESH::submesh_array_array &theSubMeshArray)
 Set submesh object order. More...
virtual SMESH::smIdType_array * GetIDs ()
 Method of SMESH_IDSource interface. More...
virtual SMESH::smIdType_array * GetMeshInfo ()
 Returns number of mesh elements of each EntityType Result array of number of elements per EntityType Inherited from SMESH_IDSource. More...
virtual SMESH::smIdType_array * GetNbElementsByType ()
virtual SMESH::array_of_ElementType * GetTypes ()
virtual SMESH::SMESH_Mesh_ptr GetMesh ()
 Returns self. More...
bool IsMeshInfoCorrect ()
virtual SALOMEDS::TMPFile * GetVtkUgStream ()
std::string generateMeshName ()
 Return a MeshName. More...
std::string prepareMeshNameAndGroups (const char *file, CORBA::Boolean overwrite)
 Prepare a file for export and pass names of mesh groups from study to mesh DS. More...
void exportMEDFields (DriverMED_W_Field &writer, SMESHDS_Mesh *meshDS, const GEOM::ListOfFields &fields, const char *geomAssocFields)
 Write GEOM fields to MED file. More...
static SMESH::Hypothesis_Status ConvertHypothesisStatus (SMESH_Hypothesis::Hypothesis_Status theStatus)
static void PrepareForWriting (const char *file, bool overwrite=true)
 Care of a file before exporting mesh into it. More...
static void CollectMeshInfo (const SMDS_ElemIteratorPtr theItr, SMESH::smIdType_array &theInfo)
 Collect statistic of mesh elements given by iterator. More...
static SMDS_ElemIteratorPtr GetElements (SMESH::SMESH_IDSource_ptr obj, SMESH::ElementType type)
 Return iterator on elements of given type in given object. More...
Data Fields
std::map< int, SMESH_subMesh_i * > _mapSubMesh_i
std::map< int, ::SMESH_subMesh * > _mapSubMesh
::SMESH_Mesh * _impl
 SMESH_Mesh_i ()
 SMESH_Mesh_i (const SMESH_Mesh_i &)
void checkGroupNames ()
 Check and correct names of mesh groups. More...
void convertMeshOrder (const TListOfListOfInt &theIdsOrder, SMESH::submesh_array_array &theSubMeshOrder, const bool theIsDump)
 Convert submesh ids into submesh interfaces. More...
TListOfListOfInt findConcurrentSubMeshes ()
 Finds concurrent sub-meshes. More...
SMESH_PreMeshInfo *& changePreMeshInfo ()
void addGeomGroupData (GEOM::GEOM_Object_ptr theGeomObj, CORBA::Object_ptr theSmeshObj)
 Remember GEOM group data. More...
void removeGeomGroupData (CORBA::Object_ptr theSmeshObj)
 Remove GEOM group data relating to removed smesh object. More...
TopoDS_Shape newGroupShape (TGeomGroupData &groupData, int how)
 Return new group contents if it has been changed and update group data. More...
SMESH_Gen_i * _gen_i
int _id
int _nbInvalidHypos
std::map< int, SMESH::SMESH_subMesh_ptr > _mapSubMeshIor
std::map< int, SMESH::SMESH_GroupBase_ptr > _mapGroups
std::map< int, SMESH::SMESH_Hypothesis_ptr > _mapHypo
SMESH_MeshEditor_i * _editor
SMESH_MeshEditor_i * _previewEditor
SMESH::MedFileInfo_var _medFileInfo
SMESH_PreMeshInfo * _preMeshInfo
std::list< TGeomGroupData > _geomGroupData
int _mainShapeTick
Static Private Attributes
static int _idGenerator = 0
Friends
class SMESH_PreMeshInfo
◆ SMESH_Mesh_i() [1/3]
SMESH_Mesh_i::SMESH_Mesh_i ( )
◆ SMESH_Mesh_i() [2/3]
SMESH_Mesh_i::SMESH_Mesh_i ( const SMESH_Mesh_i &  )
◆ SMESH_Mesh_i() [3/3]
SMESH_Mesh_i::SMESH_Mesh_i ( PortableServer::POA_ptr  thePOA,
SMESH_Gen_i *  myGen_i
◆ ~SMESH_Mesh_i()
◆ addGeomGroupData()
void SMESH_Mesh_i::addGeomGroupData ( GEOM::GEOM_Object_ptr  theGeomObj,
◆ AddHypothesis()
SMESH::Hypothesis_Status SMESH_Mesh_i::AddHypothesis ( GEOM::GEOM_Object_ptr  aSubShape,
AddHypothesis.
Call internal addHypothesis() and then add a reference to <anHyp> under the SObject actually having a reference to <aSubShape>. NB: For this method to work, it is necessary to add a reference to sub-shape first.
References _gen_i, _preMeshInfo, addHypothesis(), SMESH_Gen_i::AddHypothesisToShape(), ConvertHypothesisStatus(), SMESH_PreMeshInfo::ForgetOrLoad(), SMESH_Hypothesis::IsStatusFatal(), MESSAGE, NbElements(), NbNodes(), and SMESH_Gen_i::UpdateIcons().
◆ addHypothesis()
SMESH_Hypothesis::Hypothesis_Status SMESH_Mesh_i::addHypothesis ( GEOM::GEOM_Object_ptr  aSubShape,
std::string *  anErrorText = 0
◆ BaryCenter()
◆ changePreMeshInfo()
◆ CheckGeomGroupModif()
void SMESH_Mesh_i::CheckGeomGroupModif ( )
Update objects depending on changed geom groups.
NPAL16168: "geometrical group edition from a submesh don't modify mesh computation"
NPAL16168: geometrical group edition from a submesh don't modify mesh computation issue 0020210: Update of a smesh group after modification of the associated geom group
References _gen_i, _geomGroupData, _impl, _mapGroups, _mapSubMesh, _mapSubMesh_i, _mapSubMeshIor, _preMeshInfo, SMESH_Mesh::AddGroup(), SMESH_Mesh::AddHypothesis(), SMESH_Mesh::Clear(), ConvertToStandalone(), SMESH_PreMeshInfo::ForgetAllData(), SMESH_PreMeshInfo::ForgetOrLoad(), SMESH_Mesh::GetGroup(), SMESH_Group::GetGroupDS(), SMESHDS_Mesh::GetGroups(), SMESHDS_Mesh::GetHypothesis(), SMESH_Mesh::GetHypothesisList(), SMESH_subMesh::GetId(), SMESHDS_GroupBase::GetID(), SMESH_GroupBase_i::GetLocalID(), SMESH_Mesh::GetMeshDS(), SMESHDS_GroupOnGeom::GetShape(), GetShapeToMesh(), SMESH_Gen_i::getStudyServant(), SMESH_Mesh::GetSubMesh(), SMESH_Mesh::HasShapeToMesh(), SMESHDS_Mesh::IndexToShape(), IsLoaded(), SMESHDS_Mesh::MaxShapeIndex(), NbElements(), NbNodes(), newGroupShape(), SMESH_Gen_i::ObjectToSObject(), ONLY_IF_CHANGED, RemoveGroup(), SMESH_Mesh::RemoveHypothesis(), RemoveSubMesh(), SMESH_Gen_i::SetPixMap(), SMESHDS_GroupOnGeom::SetShape(), SMESHDS_Mesh::ShapeToIndex(), SMESH_Mesh::ShapeToMesh(), SMESHDS_Mesh::ShapeToMesh(), SMESH_Gen_i::SObjectToObject(), SMESH::Tag_FirstSubMesh, SMESH::Tag_LastSubMesh, and SMESH::Tag_RefOnShape.
Referenced by CheckGeomModif().
◆ CheckGeomModif()
◆ checkGroupNames()
void SMESH_Mesh_i::checkGroupNames ( )
Pass names of mesh groups from study to mesh DS.
References _gen_i, GetGroups(), NbGroups(), and SMESH_Gen_i::ObjectToSObject().
Referenced by ExportDAT(), ExportSTL(), ExportUNV(), and prepareMeshNameAndGroups().
◆ Clear()
void SMESH_Mesh_i::Clear ( )
◆ ClearLog()
void SMESH_Mesh_i::ClearLog ( )
References _impl, SMESH_Mesh::ClearLog(), SMESH_CATCH, SMESH_TRY, and SMESH::throwCorbaException().
◆ ClearSubMesh()
void SMESH_Mesh_i::ClearSubMesh ( CORBA::Long  ShapeID)
◆ CollectMeshInfo()
void SMESH_Mesh_i::CollectMeshInfo ( const SMDS_ElemIteratorPtr  theItr,
SMESH::smIdType_array &  theInfo
Referenced by SMESH_GroupBase_i::GetMeshInfo(), and SMESH_subMesh_i::GetMeshInfo().
◆ ConvertHypothesisStatus()
◆ convertMeshOrder()
void SMESH_Mesh_i::convertMeshOrder ( const TListOfListOfInt &  theIdsOrder,
SMESH::submesh_array_array &  theSubMeshOrder,
References _mapSubMeshIor.
Referenced by GetMeshOrder().
◆ ConvertToStandalone()
◆ CreateDimGroup()
SMESH::SMESH_Group_ptr SMESH_Mesh_i::CreateDimGroup ( const SMESH::ListOfIDSources &  theGroups,
const char *  theName,
[in]theGroups- list of either groups, sub-meshes or filters.
[in]anElemType- a type of elements to include to the new group.
[in]theName- a name of the new group.
[in]theNbCommonNodes- criterion of inclusion of an element to the new group.
[in]theUnderlyingOnly- if True, an element is included to the new group provided that it is based on nodes of an element of aListOfGroups
SMESH_Group - the created group
References _impl, _preMeshInfo, SMDS_MeshGroup::Add(), SMESH::ALL, SMESH::ALL_NODES, SMESH::AT_LEAST_ONE, SMDS_MeshElement::begin_nodes(), CreateGroup(), SMDS_MeshElement::end_nodes(), SMDS_Mesh::FindNode(), SMESH_PreMeshInfo::FullLoadFromFile(), GetElements(), GetGen(), GetId(), SMDS_MeshElement::GetID(), SMDS_MeshNode::GetInverseElementIterator(), SMESHDS_GroupBase::GetMesh(), SMESH_Mesh::GetMeshDS(), SMESH::MAIN, SMESH::MAJORITY, SMDS_Mesh::MaxElementID(), SMDS_MeshElement::NbCornerNodes(), SMDS_MeshElement::NbNodes(), SMESH::NODE, SMDS_MeshElement::nodeIterator(), SMDS_MeshElement::nodesIterator(), SMESH_CATCH, SMESH_TRY, SMESH::throwCorbaException(), and SMESH_Gen_i::UpdateGroupIcon().
◆ CreateGroup()
◆ createGroup()
SMESH::SMESH_GroupBase_ptr SMESH_Mesh_i::createGroup ( SMESH::ElementType  theElemType,
const int  theID = -1,
const TopoDS_Shape &  theShape = TopoDS_Shape(),
const SMESH_PredicatePtr &  thePredicate = SMESH_PredicatePtr()
◆ CreateGroupFromFilter()
SMESH::SMESH_GroupOnFilter_ptr SMESH_Mesh_i::CreateGroupFromFilter ( SMESH::ElementType  theElemType,
theElemType- group type
theName- group name
theFilter- the filter
SMESH::SMESH_GroupOnFilter_ptr- group defined by filter
References _gen_i, _preMeshInfo, SMESH_Gen_i::CanPublishInStudy(), createGroup(), SMESH_PreMeshInfo::FullLoadFromFile(), SMESH_GroupOnFilter_i::GetPredicate(), and SMESH_Gen_i::PublishGroup().
◆ CreateGroupFromGEOM()
SMESH::SMESH_GroupOnGeom_ptr SMESH_Mesh_i::CreateGroupFromGEOM ( SMESH::ElementType  theElemType,
◆ CreateGroupServants()
◆ createSubMesh()
SMESH::SMESH_subMesh_ptr SMESH_Mesh_i::createSubMesh ( GEOM::GEOM_Object_ptr  theSubShapeObject)
◆ CutGroups()
SMESH::SMESH_Group_ptr SMESH_Mesh_i::CutGroups ( SMESH::SMESH_GroupBase_ptr  theGroup1,
All mesh elements that are present in a main group but is not present in a tool group are added to the new one
References _preMeshInfo, SMDS_MeshGroup::Add(), SMESHDS_GroupBase::Contains(), CreateGroup(), SMESH_PreMeshInfo::FullLoadFromFile(), SMESHDS_GroupBase::GetElements(), GetGen(), SMESHDS_Group::SMDSGroup(), SMESH_CATCH, SMESH_TRY, SMESH::throwCorbaException(), and SMESH_Gen_i::UpdateGroupIcon().
◆ CutListOfGroups()
SMESH::SMESH_Group_ptr SMESH_Mesh_i::CutListOfGroups ( const SMESH::ListOfGroups &  theMainGroups,
const SMESH::ListOfGroups &  theToolGroups,
New group is created. All mesh elements that are present in main groups but do not present in tool groups are added to the new one
theMainGroupslist of main groups
theToolGroupslist of tool groups
theNamename of group to be created
pointer on the group
References _preMeshInfo, SMDS_MeshGroup::Add(), SMESH::ALL, CreateGroup(), SMESH_PreMeshInfo::FullLoadFromFile(), GetGen(), SMESHDS_Group::SMDSGroup(), SMESH_CATCH, SMESH_TRY, SMESH::throwCorbaException(), and SMESH_Gen_i::UpdateGroupIcon().
◆ Dump()
char * SMESH_Mesh_i::Dump ( )
References _impl, and SMESH_Mesh::Dump().
◆ ElemNbEdges()
CORBA::Long SMESH_Mesh_i::ElemNbEdges ( SMESH::smIdType  id)
Return number of edges for given element.
References _impl, _preMeshInfo, SMDS_Mesh::FindElement(), SMESH_PreMeshInfo::FullLoadFromFile(), SMESH_Mesh::GetMeshDS(), and SMDS_MeshElement::NbEdges().
◆ ElemNbFaces()
CORBA::Long SMESH_Mesh_i::ElemNbFaces ( SMESH::smIdType  id)
Return number of faces for given element.
References _impl, _preMeshInfo, SMDS_Mesh::FindElement(), SMESH_PreMeshInfo::FullLoadFromFile(), SMESH_Mesh::GetMeshDS(), and SMDS_MeshElement::NbFaces().
◆ ExportCGNS()
void SMESH_Mesh_i::ExportCGNS ( SMESH::SMESH_IDSource_ptr  meshPart,
const char *  file,
◆ ExportDAT()
void SMESH_Mesh_i::ExportDAT ( const char *  file,
◆ ExportGMF()
void SMESH_Mesh_i::ExportGMF ( SMESH::SMESH_IDSource_ptr  meshPart,
const char *  file,
◆ ExportMED()
void SMESH_Mesh_i::ExportMED ( const char *  file,
CORBA::Boolean  autoDimension = true
◆ ExportMEDCoupling()
CORBA::LongLong SMESH_Mesh_i::ExportMEDCoupling ( CORBA::Boolean  auto_groups,
◆ exportMEDFields()
◆ ExportPartToDAT()
void SMESH_Mesh_i::ExportPartToDAT ( SMESH::SMESH_IDSource_ptr  meshPart,
const char *  file,
References _impl, SMESH_Mesh::ExportDAT(), SMESH_CATCH, SMESH_TRY, and SMESH::throwCorbaException().
◆ ExportPartToMED()
void SMESH_Mesh_i::ExportPartToMED ( SMESH::SMESH_IDSource_ptr  meshPart,
const char *  file,
const GEOM::ListOfFields &  fields,
const char *  geomAssocFields,
References ExportPartToMEDCommon(), MESSAGE, SMESH_CATCH, SMESH_TRY, and SMESH::throwCorbaException().
◆ ExportPartToMEDCommon()
void SMESH_Mesh_i::ExportPartToMEDCommon ( SPECLS &  speCls,
◆ ExportPartToMEDCoupling()
CORBA::LongLong SMESH_Mesh_i::ExportPartToMEDCoupling ( SMESH::SMESH_IDSource_ptr  meshPart,
◆ ExportPartToMESHIO()
void SMESH_Mesh_i::ExportPartToMESHIO ( SMESH::SMESH_IDSource_ptr  meshPart,
const char *  file,
const char *  selectedFilter,
const char *  converter = nullptr
◆ ExportPartToSTL()
void SMESH_Mesh_i::ExportPartToSTL ( SMESH::SMESH_IDSource_ptr  meshPart,
const char *  file,
◆ ExportPartToUNV()
void SMESH_Mesh_i::ExportPartToUNV ( SMESH::SMESH_IDSource_ptr  meshPart,
const char *  file,
◆ ExportSTL()
void SMESH_Mesh_i::ExportSTL ( const char *  file,
bool  isascii
◆ ExportStructuredCGNS()
void SMESH_Mesh_i::ExportStructuredCGNS ( SMESH::SMESH_IDSource_ptr  meshPart,
const char *  file,
◆ ExportUNV()
void SMESH_Mesh_i::ExportUNV ( const char *  file,
◆ FaceGroupsSeparatedByEdges()
SMESH::ListOfGroups * SMESH_Mesh_i::FaceGroupsSeparatedByEdges ( CORBA::Double  theSharpAngle,
[in]theSharpAngle- edge is considered sharp if an angle between normals of adjacent faces is more than sharpAngle in degrees.
[in]theCreateEdges- to create 1D elements for detected sharp edges.
[in]theUseExistingEdges- to use existing edges as group boundaries
ListOfGroups - the created groups
References _editor, _impl, _preMeshInfo, SMDS_MeshGroup::Add(), SMESHDS_Mesh::AddEdge(), CreateGroup(), SMESH::FACE, SMDS_Mesh::FindElement(), SMESH_MeshAlgos::FindSharpEdges(), SMESH_PreMeshInfo::FullLoadFromFile(), SMESH_MeshEditor_i::GenerateGroupName(), SMESH_Mesh::GetMeshDS(), GetMeshEditor(), SMESH_MeshAlgos::SeparateFacesByEdges(), SMDSAbs_Edge, SMESH_CATCH, SMESH_TRY, and SMESH::throwCorbaException().
◆ FileInfoFromString()
void SMESH_Mesh_i::FileInfoFromString ( const std::string &  info)
References _medFileInfo.
◆ FileInfoToString()
std::string SMESH_Mesh_i::FileInfoToString ( )
Referenced by SMESH_Gen_i::Save().
◆ findConcurrentSubMeshes()
◆ FindElementByNodes()
SMESH::smIdType SMESH_Mesh_i::FindElementByNodes ( const SMESH::smIdType_array &  nodes)
◆ generateMeshName()
◆ GetAutoColor()
CORBA::Boolean SMESH_Mesh_i::GetAutoColor ( )
References _impl, and SMESH_Mesh::GetAutoColor().
◆ GetBallDiameter()
CORBA::Double SMESH_Mesh_i::GetBallDiameter ( SMESH::smIdType  id)
Return diameter of ball discrete element or zero in case of an invalid id.
References _impl, _preMeshInfo, SMDS_Mesh::FindElement(), SMESH_PreMeshInfo::FullLoadFromFile(), and SMESH_Mesh::GetMeshDS().
◆ GetComputeProgress()
CORBA::Double SMESH_Mesh_i::GetComputeProgress ( )
References _impl, SMESH::doNothing(), SMESH_Mesh::GetComputeProgress(), SMESH_CATCH, and SMESH_TRY.
◆ GetElementGeomType()
SMESH::EntityType SMESH_Mesh_i::GetElementGeomType ( SMESH::smIdType  id)
◆ GetElementPosition()
◆ GetElements()
◆ GetElementsByNodes()
SMESH::smIdType_array * SMESH_Mesh_i::GetElementsByNodes ( const SMESH::smIdType_array &  nodes,
References _impl, _preMeshInfo, SMESH_PreMeshInfo::FullLoadFromFile(), and SMESH_Mesh::GetMeshDS().
◆ GetElementsByType()
SMESH::smIdType_array * SMESH_Mesh_i::GetElementsByType ( SMESH::ElementType  theElemType)
◆ GetElementShape()
SMESH::GeometryType SMESH_Mesh_i::GetElementShape ( SMESH::smIdType  id)
◆ GetElementsId()
SMESH::smIdType_array * SMESH_Mesh_i::GetElementsId ( )
◆ GetElementType()
◆ GetElemFaceNodes()
SMESH::smIdType_array * SMESH_Mesh_i::GetElemFaceNodes ( SMESH::smIdType  elemId,
Return nodes of given face (counted from zero) for given element.
References _impl, _preMeshInfo, SMESH_PreMeshInfo::FullLoadFromFile(), SMDS_VolumeTool::GetFaceNodes(), SMESH_Mesh::GetMeshDS(), SMDS_VolumeTool::NbFaceNodes(), and SMDS_VolumeTool::NbFaces().
◆ GetElemNbNodes()
CORBA::Short SMESH_Mesh_i::GetElemNbNodes ( SMESH::smIdType  id)
Return number of nodes for given element If there is not element for given ID - return -1.
References _impl, _preMeshInfo, SMDS_Mesh::FindElement(), SMESH_PreMeshInfo::FullLoadFromFile(), SMESH_Mesh::GetMeshDS(), and SMDS_MeshElement::NbNodes().
Referenced by RemoveGroupWithContents().
◆ GetElemNode()
SMESH::smIdType SMESH_Mesh_i::GetElemNode ( SMESH::smIdType  id,
CORBA::Short  index
Return ID of node by given index for given element If there is not element for given ID - return -1 If there is not node for given index - return -2.
References _impl, _preMeshInfo, SMDS_Mesh::FindElement(), SMESH_PreMeshInfo::FullLoadFromFile(), SMDS_MeshElement::GetID(), SMESH_Mesh::GetMeshDS(), SMDS_MeshElement::GetNode(), and SMDS_MeshElement::NbNodes().
◆ GetElemNodes()
SMESH::smIdType_array * SMESH_Mesh_i::GetElemNodes ( SMESH::smIdType  id)
Return IDs of nodes of given element.
References _impl, _preMeshInfo, SMESH_PreMeshInfo::FullLoadFromFile(), SMESH_Mesh::GetMeshDS(), and SMDS_MeshNode::GetNode().
◆ GetFaceNormal()
SMESH::double_array * SMESH_Mesh_i::GetFaceNormal ( CORBA::Long  faceId,
Return three components of normal of given mesh face.
References _impl, _preMeshInfo, SMESH_MeshAlgos::FaceNormal(), SMESH_PreMeshInfo::FullLoadFromFile(), and SMESH_Mesh::GetMeshDS().
◆ GetGen()
◆ GetGroups() [1/2]
◆ getGroups()
const std::map< int, SMESH::SMESH_GroupBase_ptr > & SMESH_Mesh_i::getGroups ( )
◆ GetGroups() [2/2]
SMESH::ListOfGroups * SMESH_Mesh_i::GetGroups ( const std::list< int > &  groupIDs) const
References _mapGroups.
◆ GetHypothesisList()
SMESH::ListOfHypothesis * SMESH_Mesh_i::GetHypothesisList ( GEOM::GEOM_Object_ptr  aSubShape)
◆ GetId()
CORBA::Long SMESH_Mesh_i::GetId ( )
Return a mesh ID.
References _id.
Referenced by CreateDimGroup(), and SMESH_MeshEditor_i::SplitBiQuadraticIntoLinear().
◆ GetIDs()
SMESH::smIdType_array * SMESH_Mesh_i::GetIDs ( )
References GetElementsId().
◆ GetImpl()
SMESH_Mesh & SMESH_Mesh_i::GetImpl ( )
References _impl.
Referenced by SMESH_Gen_i::_GetInside(), SMESH_Gen_i::AddHypothesisToShape(), StdMeshers_ViscousLayerBuilder_i::AddLayers(), SMESH_Gen_i::Compute(), SMESH_Gen_i::ConcatenateCommon(), SMESH_Gen_i::CopyMesh(), SMESH_Gen_i::CopyMeshWithGeom(), SMESH_Gen_i::CreateDualMesh(), SMESH_Gen_i::CreateMeshesFromCGNS(), SMESH_Gen_i::CreateMeshesFromGMF(), SMESH_Gen_i::CreateMeshesFromMED(), SMESH_Gen_i::CreateMeshesFromMESHIO(), SMESH_Gen_i::CreateMeshesFromSTL(), SMESH_Gen_i::CreateMeshesFromUNV(), SMESH_Gen_i::Evaluate(), ExportStructuredCGNS(), SMESH_MeshEditor_i::ExtrusionAlongPathObjects(), findConcurrentSubMeshes(), SMESH_Gen_i::FindGeometryByMeshElement(), SMESH_PreMeshInfo::FullLoadFromFile(), SMESH_Gen_i::GetAlgoState(), GetElements(), SMESH_Gen_i::GetHypothesisParameterValues(), getMesh(), SMESH_Pattern_i::getMesh(), GetMeshOrder(), SMESH_Gen_i::GetMeshOrSubmeshByShape(), StdMeshers_ViscousLayerBuilder_i::GetShrinkGeometry(), SMESH_GroupBase_i::GetSmeshGroup(), SMESH_Gen_i::GetSoleSubMeshUsingHyp(), SMESH_Gen_i::IsReadyToCompute(), IsUnorderedSubMesh(), SMESH_MeshEditor_i::LinearAnglesVariation(), SMESH_Gen_i::Load(), StdMeshers_ProjectionSource1D_i::LoadFrom(), StdMeshers_ProjectionSource2D_i::LoadFrom(), StdMeshers_ProjectionSource3D_i::LoadFrom(), SMESH_MeshEditor_i::MakeBoundaryElements(), SMESH_MeshEditor_i::MakeBoundaryMesh(), MeshPtr2SMDSMesh(), SMESH_MeshEditor_i::MirrorMakeMesh(), SMESH_MeshEditor_i::MirrorObjectMakeMesh(), SMESH_MeshEditor_i::Offset(), SMESH_Gen_i::Precompute(), SMESH_PreMeshInfo::readSubMeshes(), SMESH_PreMeshInfo::readSubMeshInfo(), SMESH_Gen_i::ReloadMeshesFromCGNS(), SMESH_Gen_i::ReloadMeshesFromGMF(), SMESH_Gen_i::ReloadMeshesFromMED(), SMESH_Gen_i::ReloadMeshesFromMESHIO(), SMESH_Gen_i::ReloadMeshesFromSTL(), SMESH_Gen_i::ReloadMeshesFromUNV(), SMESH_MeshEditor_i::RotateMakeMesh(), SMESH_MeshEditor_i::RotateObjectMakeMesh(), SMESH_Gen_i::Save(), SMESH_PreMeshInfo::SaveToFile(), SMESH_MeshEditor_i::ScaleMakeMesh(), SetMeshOrder(), StdMeshers_ProjectionSource1D_i::SetSourceMesh(), StdMeshers_ProjectionSource2D_i::SetSourceMesh(), StdMeshers_ProjectionSource3D_i::SetSourceMesh(), SMESH_MeshPartDS::SMESH_MeshPartDS(), SMESH_MeshEditor_i::TranslateMakeMesh(), SMESH_MeshEditor_i::TranslateObjectMakeMesh(), and SMESH_Gen_i::UpdateIcons().
◆ GetLastParameters()
SMESH::string_array * SMESH_Mesh_i::GetLastParameters ( )
Return list of notebook variables used for last Mesh operation.
References GetParameters(), SMESH_Gen_i::GetSMESHGen(), and SMESH_Gen_i::getStudyServant().
◆ GetLog()
◆ GetMEDFileInfo()
SMESH::MedFileInfo * SMESH_Mesh_i::GetMEDFileInfo ( )
Return information about imported file.
References _medFileInfo, and SMESH::MedFileInfo::fileName.
◆ GetMEDVersionsCompatibleForAppend()
SMESH::long_array * SMESH_Mesh_i::GetMEDVersionsCompatibleForAppend ( )
References MED::GetMEDVersionsAppendCompatible().
Referenced by ExportPartToMESHIO().
◆ GetMesh()
SMESH::SMESH_Mesh_ptr SMESH_Mesh_i::GetMesh ( )
Returns self.
Return self.
◆ GetMeshEditor()
◆ GetMeshEditPreviewer()
SMESH::SMESH_MeshEditor_ptr SMESH_Mesh_i::GetMeshEditPreviewer ( )
◆ GetMeshInfo()
SMESH::smIdType_array * SMESH_Mesh_i::GetMeshInfo ( )
Return number of mesh elements per each EntityType.
References _impl, _preMeshInfo, SMESH::Entity_Last, SMESH::Entity_Node, SMESH_Mesh::GetMeshDS(), SMDS_Mesh::GetMeshInfo(), SMESH_PreMeshInfo::GetMeshInfo(), and SMDS_MeshInfo::NbEntities().
Referenced by SMESH_PreMeshInfo::SaveToFile().
◆ GetMeshOrder()
SMESH::submesh_array_array * SMESH_Mesh_i::GetMeshOrder ( )
Return sub-mesh objects list in meshing order.
References _impl, convertMeshOrder(), findConcurrentSubMeshes(), GetImpl(), SMESH_Mesh::GetMeshDS(), and SMESH_Mesh::GetMeshOrder().
◆ GetMeshPtr()
CORBA::LongLong SMESH_Mesh_i::GetMeshPtr ( )
Is called from constructor of SMESH_Client
References _impl, _preMeshInfo, SMESH_PreMeshInfo::FullLoadFromFile(), and MESSAGE.
◆ GetNbElementsByType()
SMESH::smIdType_array * SMESH_Mesh_i::GetNbElementsByType ( )
Return number of mesh elements per each ElementType.
References _impl, _preMeshInfo, SMESH_Mesh::GetMeshDS(), SMESH::NB_ELEMENT_TYPES, and SMDS_MeshInfo::NbElements().
◆ GetNodeInverseElements()
SMESH::smIdType_array * SMESH_Mesh_i::GetNodeInverseElements ( SMESH::smIdType  id,
For given node return list of IDs of inverse elements If there is not node for given ID - return empty list.
References _impl, _preMeshInfo, SMDS_Mesh::FindNode(), SMESH_PreMeshInfo::FullLoadFromFile(), SMDS_MeshElement::GetID(), SMDS_MeshNode::GetInverseElementIterator(), SMESH_Mesh::GetMeshDS(), and SMDS_MeshNode::NbInverseElements().
◆ GetNodePosition()
◆ GetNodesId()
◆ GetNodeXYZ()
SMESH::double_array * SMESH_Mesh_i::GetNodeXYZ ( SMESH::smIdType  id)
Get XYZ coordinates of node as list of double If there is not node for given ID - return empty list.
References _impl, _preMeshInfo, SMDS_Mesh::FindNode(), SMESH_PreMeshInfo::FullLoadFromFile(), SMESH_Mesh::GetMeshDS(), SMDS_MeshNode::X(), SMDS_MeshNode::Y(), and SMDS_MeshNode::Z().
◆ GetParameters()
char * SMESH_Mesh_i::GetParameters ( )
Return list of notebook variables used for Mesh operations separated by ":" symbol.
References SMESH_Gen_i::GetParameters(), and SMESH_Gen_i::GetSMESHGen().
Referenced by GetLastParameters().
◆ GetShapeID()
CORBA::Long SMESH_Mesh_i::GetShapeID ( SMESH::smIdType  id)
If given element is node return IDs of shape from position If there is not node for given ID - return -1.
References _impl, _preMeshInfo, SMDS_Mesh::FindNode(), SMESH_PreMeshInfo::FullLoadFromFile(), SMESH_Mesh::GetMeshDS(), and SMDS_MeshElement::getshapeId().
◆ GetShapeIDForElem()
CORBA::Long SMESH_Mesh_i::GetShapeIDForElem ( SMESH::smIdType  id)
For given element return ID of result shape after ::FindShape() from SMESH_MeshEditor If there is not element for given ID - return -1.
References _impl, _preMeshInfo, SMDS_Mesh::FindElement(), SMESH_MeshEditor::FindShape(), SMESH_PreMeshInfo::FullLoadFromFile(), and SMESH_Mesh::GetMeshDS().
◆ GetShapeToMesh()
◆ GetSubMesh()
SMESH::SMESH_subMesh_ptr SMESH_Mesh_i::GetSubMesh ( GEOM::GEOM_Object_ptr  aSubShape,
◆ getSubMesh()
SMESH::SMESH_subMesh_ptr SMESH_Mesh_i::getSubMesh ( int  shapeID)
Referenced by SMESH_Gen_i::AddHypothesisToShape(), SMESH_Gen_i::GetMeshOrSubmeshByShape(), and GetSubMesh().
◆ GetSubMeshElementsId()
SMESH::smIdType_array * SMESH_Mesh_i::GetSubMeshElementsId ( CORBA::Long  ShapeID)
◆ GetSubMeshElementType()
◆ GetSubMeshes()
SMESH::submesh_array * SMESH_Mesh_i::GetSubMeshes ( )
Return sub-meshes.
References _mapSubMeshIor, and MESSAGE.
◆ GetSubMeshNodesId()
SMESH::smIdType_array * SMESH_Mesh_i::GetSubMeshNodesId ( CORBA::Long  ShapeID,
CORBA::Boolean  all
Return ID of nodes for given sub-mesh If param all==true - return all nodes, else - Return only nodes on shapes.
References _impl, _preMeshInfo, SMESH_PreMeshInfo::FullLoadFromFile(), SMESHDS_SubMesh::GetElements(), SMDS_MeshElement::GetID(), SMESHDS_SubMesh::GetNodes(), SMESH_Mesh::GetSubMeshContaining(), SMESH_subMesh::GetSubMeshDS(), SMESHDS_SubMesh::NbElements(), SMDS_MeshElement::nodesIterator(), SMESH_CATCH, SMESH_TRY, and SMESH::throwCorbaException().
◆ GetTypes()
◆ GetVersionString()
char * SMESH_Mesh_i::GetVersionString ( CORBA::Long  minor,
References DriverMED_W_SMESHDS_Mesh::GetVersionString().
◆ GetVtkUgStream()
SALOMEDS::TMPFile * SMESH_Mesh_i::GetVtkUgStream ( )
References _impl, and SMESH_Mesh::GetMeshDS().
◆ HasDuplicatedGroupNamesMED()
CORBA::Boolean SMESH_Mesh_i::HasDuplicatedGroupNamesMED ( )
Check if there are groups with equal names.
Consider maximum group name length stored in MED file.
References _impl, and SMESH_Mesh::HasDuplicatedGroupNamesMED().
◆ HasModificationsToDiscard()
CORBA::Boolean SMESH_Mesh_i::HasModificationsToDiscard ( )
References _impl, and SMESH_Mesh::HasModificationsToDiscard().
◆ HasShapeToMesh()
CORBA::Boolean SMESH_Mesh_i::HasShapeToMesh ( )
◆ ImportCGNSFile()
SMESH::DriverMED_ReadStatus SMESH_Mesh_i::ImportCGNSFile ( const char *  theFileName,
std::string &  theMeshName
◆ ImportGMFFile()
SMESH::ComputeError * SMESH_Mesh_i::ImportGMFFile ( const char *  theFileName,
◆ ImportMEDFile()
SMESH::DriverMED_ReadStatus SMESH_Mesh_i::ImportMEDFile ( const char *  theFileName,
const char *  theMeshName
◆ ImportSTLFile()
int SMESH_Mesh_i::ImportSTLFile ( const char *  theFileName)
◆ ImportUNVFile()
int SMESH_Mesh_i::ImportUNVFile ( const char *  theFileName)
◆ IntersectGroups()
SMESH::SMESH_Group_ptr SMESH_Mesh_i::IntersectGroups ( SMESH::SMESH_GroupBase_ptr  theGroup1,
◆ IntersectListOfGroups()
SMESH::SMESH_Group_ptr SMESH_Mesh_i::IntersectListOfGroups ( const SMESH::ListOfGroups &  theGroups,
New group is created. All mesh elements that are present in all initial groups simultaneously are added to the new one.
theGroupslist of groups
References _preMeshInfo, SMDS_MeshGroup::Add(), SMESH::ALL, CreateGroup(), SMESH_PreMeshInfo::FullLoadFromFile(), SMESHDS_Group::GetElements(), GetGen(), SMESHDS_Group::SMDSGroup(), SMESH_CATCH, SMESH_TRY, SMESH::throwCorbaException(), and SMESH_Gen_i::UpdateGroupIcon().
◆ IsComputedOK()
CORBA::Boolean SMESH_Mesh_i::IsComputedOK ( )
References _impl, and SMESH_Mesh::IsComputedOK().
Referenced by SMESH_Gen_i::UpdateIcons().
◆ IsLoaded()
CORBA::Boolean SMESH_Mesh_i::IsLoaded ( )
References _preMeshInfo.
Referenced by CheckGeomGroupModif().
◆ IsMediumNode()
CORBA::Boolean SMESH_Mesh_i::IsMediumNode ( SMESH::smIdType  ide,
SMESH::smIdType  idn
Return true if given node is medium node in given quadratic element.
References _impl, _preMeshInfo, SMDS_Mesh::FindElement(), SMDS_Mesh::FindNode(), SMESH_PreMeshInfo::FullLoadFromFile(), SMESH_Mesh::GetMeshDS(), and SMDS_MeshElement::IsMediumNode().
◆ IsMediumNodeOfAnyElem()
CORBA::Boolean SMESH_Mesh_i::IsMediumNodeOfAnyElem ( SMESH::smIdType  idn,
Return true if given node is medium node in one of quadratic elements.
References _impl, _preMeshInfo, SMESH::EDGE, SMESH::FACE, SMDS_Mesh::FindNode(), SMESH_PreMeshInfo::FullLoadFromFile(), SMESH_Mesh::GetMeshDS(), SMESH_MesherHelper::IsMedium(), SMDSAbs_All, SMDSAbs_Edge, SMDSAbs_Face, SMDSAbs_Volume, and SMESH::VOLUME.
◆ IsMeshInfoCorrect()
bool SMESH_Mesh_i::IsMeshInfoCorrect ( )
Return false if GetMeshInfo() return incorrect information that may happen if mesh data is not yet fully loaded from the file of study.
References _preMeshInfo, and SMESH_PreMeshInfo::IsMeshInfoCorrect().
◆ IsPoly()
CORBA::Boolean SMESH_Mesh_i::IsPoly ( SMESH::smIdType  id)
Return true if given element is polygon.
References _impl, _preMeshInfo, SMDS_Mesh::FindElement(), SMESH_PreMeshInfo::FullLoadFromFile(), SMESH_Mesh::GetMeshDS(), and SMDS_MeshElement::IsPoly().
◆ IsQuadratic()
CORBA::Boolean SMESH_Mesh_i::IsQuadratic ( SMESH::smIdType  id)
Return true if given element is quadratic.
References _impl, _preMeshInfo, SMDS_Mesh::FindElement(), SMESH_PreMeshInfo::FullLoadFromFile(), SMESH_Mesh::GetMeshDS(), and SMDS_MeshElement::IsQuadratic().
◆ IsUnorderedSubMesh()
CORBA::Boolean SMESH_Mesh_i::IsUnorderedSubMesh ( CORBA::Long  submeshID)
References findConcurrentSubMeshes(), GetImpl(), and SMESH_Mesh::GetMeshOrder().
◆ Load()
◆ MainShapeTick()
int & SMESH_Mesh_i::MainShapeTick ( )
Referenced by SMESH_Gen_i::Load(), and SMESH_Gen_i::Save().
◆ MakeGroupsOfBadInputElements()
◆ Nb0DElements()
SMESH::smIdType SMESH_Mesh_i::Nb0DElements ( )
References _impl, _preMeshInfo, SMDS_MeshInfo::Nb0DElements(), and SMESH_Mesh::Nb0DElements().
Referenced by NbElements().
◆ NbBalls()
SMESH::smIdType SMESH_Mesh_i::NbBalls ( )
References _impl, _preMeshInfo, SMDS_MeshInfo::NbBalls(), and SMESH_Mesh::NbBalls().
◆ NbBiQuadQuadrangles()
SMESH::smIdType SMESH_Mesh_i::NbBiQuadQuadrangles ( )
◆ NbBiQuadTriangles()
SMESH::smIdType SMESH_Mesh_i::NbBiQuadTriangles ( )
References _impl, _preMeshInfo, SMDS_MeshInfo::NbBiQuadTriangles(), and SMESH_Mesh::NbBiQuadTriangles().
◆ NbEdges()
SMESH::smIdType SMESH_Mesh_i::NbEdges ( )
References _impl, _preMeshInfo, SMDS_MeshInfo::NbEdges(), and SMESH_Mesh::NbEdges().
◆ NbEdgesOfOrder()
SMESH::smIdType SMESH_Mesh_i::NbEdgesOfOrder ( SMESH::ElementOrder  order)
Return nb of edges.
◆ NbElements()
SMESH::smIdType SMESH_Mesh_i::NbElements ( )
◆ NbFaces()
SMESH::smIdType SMESH_Mesh_i::NbFaces ( )
Return nb of faces.
References _impl, _preMeshInfo, SMDS_MeshInfo::NbFaces(), and SMESH_Mesh::NbFaces().
◆ NbFacesOfOrder()
SMESH::smIdType SMESH_Mesh_i::NbFacesOfOrder ( SMESH::ElementOrder  order)
◆ NbGroups()
CORBA::Long SMESH_Mesh_i::NbGroups ( )
Referenced by checkGroupNames().
◆ NbHexagonalPrisms()
SMESH::smIdType SMESH_Mesh_i::NbHexagonalPrisms ( )
◆ NbHexas()
SMESH::smIdType SMESH_Mesh_i::NbHexas ( )
◆ NbHexasOfOrder()
SMESH::smIdType SMESH_Mesh_i::NbHexasOfOrder ( SMESH::ElementOrder  order)
◆ NbNodes()
◆ NbPolygons()
SMESH::smIdType SMESH_Mesh_i::NbPolygons ( )
◆ NbPolygonsOfOrder()
SMESH::smIdType SMESH_Mesh_i::NbPolygonsOfOrder ( SMESH::ElementOrder  order = SMESH::ORDER_ANY)
◆ NbPolyhedrons()
SMESH::smIdType SMESH_Mesh_i::NbPolyhedrons ( )
◆ NbPrisms()
SMESH::smIdType SMESH_Mesh_i::NbPrisms ( )
◆ NbPrismsOfOrder()
SMESH::smIdType SMESH_Mesh_i::NbPrismsOfOrder ( SMESH::ElementOrder  order)
◆ NbPyramids()
SMESH::smIdType SMESH_Mesh_i::NbPyramids ( )
◆ NbPyramidsOfOrder()
SMESH::smIdType SMESH_Mesh_i::NbPyramidsOfOrder ( SMESH::ElementOrder  order)
◆ NbQuadrangles()
SMESH::smIdType SMESH_Mesh_i::NbQuadrangles ( )
◆ NbQuadranglesOfOrder()
SMESH::smIdType SMESH_Mesh_i::NbQuadranglesOfOrder ( SMESH::ElementOrder  order)
◆ NbSubMesh()
SMESH::smIdType SMESH_Mesh_i::NbSubMesh ( )
References _mapSubMesh_i.
◆ NbTetras()
SMESH::smIdType SMESH_Mesh_i::NbTetras ( )
◆ NbTetrasOfOrder()
SMESH::smIdType SMESH_Mesh_i::NbTetrasOfOrder ( SMESH::ElementOrder  order)
◆ NbTriangles()
SMESH::smIdType SMESH_Mesh_i::NbTriangles ( )
References _impl, _preMeshInfo, SMDS_MeshInfo::NbTriangles(), and SMESH_Mesh::NbTriangles().
◆ NbTrianglesOfOrder()
SMESH::smIdType SMESH_Mesh_i::NbTrianglesOfOrder ( SMESH::ElementOrder  order)
◆ NbTriQuadraticHexas()
SMESH::smIdType SMESH_Mesh_i::NbTriQuadraticHexas ( )
◆ NbVolumes()
SMESH::smIdType SMESH_Mesh_i::NbVolumes ( )
◆ NbVolumesOfOrder()
SMESH::smIdType SMESH_Mesh_i::NbVolumesOfOrder ( SMESH::ElementOrder  order)
◆ newGroupShape()
◆ onHypothesisModified()
void SMESH_Mesh_i::onHypothesisModified ( int  theHypID,
bool  updateIcons
◆ PrepareForWriting()
void SMESH_Mesh_i::PrepareForWriting ( const char *  file,
bool  overwrite = true
◆ prepareMeshNameAndGroups()
string SMESH_Mesh_i::prepareMeshNameAndGroups ( const char *  file,
file- file name
overwrite- to erase the file or not
string- mesh name
References _gen_i, checkGroupNames(), generateMeshName(), SMESH_Gen_i::GetSMESHGen(), SMESH_Gen_i::getStudyServant(), SMESH_Gen_i::ObjectToSObject(), and PrepareForWriting().
Referenced by ExportMED(), and MEDFileSpeCls::prepareMeshNameAndGroups().
◆ removeGeomGroupData()
void SMESH_Mesh_i::removeGeomGroupData ( CORBA::Object_ptr  theSmeshObj)
References _geomGroupData.
Referenced by ConvertToStandalone(), removeGroup(), and removeSubMesh().
◆ removeGroup()
void SMESH_Mesh_i::removeGroup ( const int  theId)
Should be called by ~SMESH_Group_i()
References _impl, _mapGroups, MESSAGE, removeGeomGroupData(), SMESH_Mesh::RemoveGroup(), and RemoveGroup().
Referenced by RemoveGroup().
◆ RemoveGroup()
◆ RemoveGroupWithContents()
◆ RemoveHypothesis()
SMESH::Hypothesis_Status SMESH_Mesh_i::RemoveHypothesis ( GEOM::GEOM_Object_ptr  aSubShape,
◆ removeHypothesis()
SMESH_Hypothesis::Hypothesis_Status SMESH_Mesh_i::removeHypothesis ( GEOM::GEOM_Object_ptr  aSubShape,
◆ RemoveSubMesh()
◆ removeSubMesh()
bool SMESH_Mesh_i::removeSubMesh ( SMESH::SMESH_subMesh_ptr  theSubMesh,
◆ ReplaceShape()
◆ SetAutoColor()
void SMESH_Mesh_i::SetAutoColor ( CORBA::Boolean  theAutoColor)
Auto color.
Set auto-color mode.
If it is on, groups get unique random colors
References _impl, _mapGroups, getUniqueColor(), and SMESH_Mesh::SetAutoColor().
◆ SetImpl()
void SMESH_Mesh_i::SetImpl ( ::SMESH_Mesh *  impl)
References _impl, and SMESH_Mesh::SetCallUp().
Referenced by SMESH_Gen_i::createMesh(), and SMESH_Gen_i::createParallelMesh().
◆ SetMeshOrder()
CORBA::Boolean SMESH_Mesh_i::SetMeshOrder ( const SMESH::submesh_array_array &  theSubMeshArray)
◆ SetParameters()
void SMESH_Mesh_i::SetParameters ( const char *  theParameters)
Set list of notebook variables used for Mesh operations separated by ":" symbol.
References SMESH_Gen_i::GetSMESHGen(), and SMESH_Gen_i::UpdateParameters().
◆ SetShape()
void SMESH_Mesh_i::SetShape ( GEOM::GEOM_Object_ptr  theShapeObject)
SetShape.
Associate <this> mesh with <theShape> and put a reference to <theShape> into the current study; the previous shape is substituted by the new one.
References _gen_i, _impl, _mainShapeTick, addGeomGroupData(), SMESH_Gen_i::GeomObjectToShape(), and SMESH_Mesh::ShapeToMesh().
Referenced by SMESH_Gen_i::CreateMesh(), SMESH_Gen_i::CreateParallelMesh(), and SMESH_Gen_i::Load().
◆ UnionGroups()
SMESH::SMESH_Group_ptr SMESH_Mesh_i::UnionGroups ( SMESH::SMESH_GroupBase_ptr  theGroup1,
References _preMeshInfo, CreateGroup(), SMESH_PreMeshInfo::FullLoadFromFile(), SMESH_CATCH, SMESH_TRY, and SMESH::throwCorbaException().
◆ UnionListOfGroups()
SMESH::SMESH_Group_ptr SMESH_Mesh_i::UnionListOfGroups ( const SMESH::ListOfGroups &  theGroups,
pointer to the new group
References _preMeshInfo, SMESH::ALL, CreateGroup(), SMESH_PreMeshInfo::FullLoadFromFile(), SMESH_CATCH, SMESH_TRY, and SMESH::throwCorbaException().
◆ SMESH_PreMeshInfo
friend class SMESH_PreMeshInfo
friend
◆ _editor
◆ _gen_i
◆ _geomGroupData
std::list<TGeomGroupData> SMESH_Mesh_i::_geomGroupData
◆ _id
int SMESH_Mesh_i::_id
Referenced by GetId(), and SMESH_Mesh_i().
◆ _idGenerator
int SMESH_Mesh_i::_idGenerator = 0
staticprivate
Referenced by SMESH_Mesh_i().
◆ _impl
::SMESH_Mesh* SMESH_Mesh_i::_impl
Referenced by addHypothesis(), BaryCenter(), CheckGeomGroupModif(), CheckGeomModif(), Clear(), ClearLog(), ClearSubMesh(), ConvertToStandalone(), CreateDimGroup(), createGroup(), CreateGroupServants(), createSubMesh(), SMESH_ParallelMesh_i::DownCast(), Dump(), ElemNbEdges(), ElemNbFaces(), ExportCGNS(), ExportDAT(), ExportGMF(), ExportMED(), ExportMEDCoupling(), ExportPartToDAT(), ExportPartToMEDCommon(), ExportPartToSTL(), ExportPartToUNV(), ExportSTL(), ExportStructuredCGNS(), ExportUNV(), FaceGroupsSeparatedByEdges(), FindElementByNodes(), GetAutoColor(), GetBallDiameter(), GetComputeProgress(), GetElementGeomType(), GetElementPosition(), GetElementsByNodes(), GetElementsByType(), GetElementShape(), GetElementsId(), GetElementType(), GetElemFaceNodes(), GetElemNbNodes(), GetElemNode(), GetElemNodes(), GetFaceNormal(), GetHypothesisList(), GetImpl(), GetLog(), GetMeshInfo(), GetMeshOrder(), GetMeshPtr(), GetNbElementsByType(), GetNodeInverseElements(), GetNodePosition(), GetNodesId(), GetNodeXYZ(), GetShapeID(), GetShapeIDForElem(), GetShapeToMesh(), GetSubMesh(), GetSubMeshElementsId(), GetSubMeshElementType(), GetSubMeshNodesId(), GetTypes(), GetVtkUgStream(), HasDuplicatedGroupNamesMED(), HasModificationsToDiscard(), HasShapeToMesh(), ImportCGNSFile(), ImportGMFFile(), ImportMEDFile(), ImportSTLFile(), ImportUNVFile(), IsComputedOK(), IsMediumNode(), IsMediumNodeOfAnyElem(), IsPoly(), IsQuadratic(), MakeGroupsOfBadInputElements(), Nb0DElements(), NbBalls(), NbBiQuadQuadrangles(), NbBiQuadTriangles(), NbEdges(), NbEdgesOfOrder(), NbFaces(), NbFacesOfOrder(), NbHexagonalPrisms(), NbHexas(), NbHexasOfOrder(), NbNodes(), NbPolygons(), NbPolygonsOfOrder(), NbPolyhedrons(), NbPrisms(), NbPrismsOfOrder(), NbPyramids(), NbPyramidsOfOrder(), NbQuadrangles(), NbQuadranglesOfOrder(), NbTetras(), NbTetrasOfOrder(), NbTriangles(), NbTrianglesOfOrder(), NbTriQuadraticHexas(), NbVolumes(), NbVolumesOfOrder(), newGroupShape(), removeGroup(), RemoveGroupWithContents(), RemoveHypothesis(), removeHypothesis(), removeSubMesh(), ReplaceShape(), SetAutoColor(), SetImpl(), SetShape(), SMESH_Mesh_i(), and ~SMESH_Mesh_i().
◆ _mainShapeTick
int SMESH_Mesh_i::_mainShapeTick
◆ _mapGroups
◆ _mapHypo
std::map<int, SMESH::SMESH_Hypothesis_ptr> SMESH_Mesh_i::_mapHypo
◆ _mapSubMesh
◆ _mapSubMesh_i
◆ _mapSubMeshIor
◆ _medFileInfo
SMESH::MedFileInfo_var SMESH_Mesh_i::_medFileInfo
◆ _nbInvalidHypos
int SMESH_Mesh_i::_nbInvalidHypos
◆ _preMeshInfo
SMESH_PreMeshInfo* SMESH_Mesh_i::_preMeshInfo
Referenced by AddHypothesis(), BaryCenter(), CheckGeomGroupModif(), CheckGeomModif(), Clear(), ClearSubMesh(), ConvertToStandalone(), CreateDimGroup(), CreateGroup(), CreateGroupFromFilter(), CreateGroupFromGEOM(), CutGroups(), CutListOfGroups(), ElemNbEdges(), ElemNbFaces(), ExportCGNS(), ExportDAT(), ExportGMF(), ExportMED(), ExportMEDCoupling(), ExportPartToMEDCommon(), ExportPartToSTL(), ExportPartToUNV(), ExportSTL(), ExportStructuredCGNS(), ExportUNV(), FaceGroupsSeparatedByEdges(), FindElementByNodes(), GetBallDiameter(), GetElementGeomType(), GetElementPosition(), GetElementsByNodes(), GetElementsByType(), GetElementShape(), GetElementsId(), GetElementType(), GetElemFaceNodes(), GetElemNbNodes(), GetElemNode(), GetElemNodes(), GetFaceNormal(), GetLog(), GetMeshEditor(), GetMeshEditPreviewer(), GetMeshInfo(), GetMeshPtr(), GetNbElementsByType(), GetNodeInverseElements(), GetNodePosition(), GetNodesId(), GetNodeXYZ(), GetShapeID(), GetShapeIDForElem(), GetSubMeshElementsId(), GetSubMeshElementType(), GetSubMeshNodesId(), GetTypes(), IntersectGroups(), IntersectListOfGroups(), IsLoaded(), IsMediumNode(), IsMediumNodeOfAnyElem(), IsMeshInfoCorrect(), IsPoly(), IsQuadratic(), Load(), Nb0DElements(), NbBalls(), NbBiQuadQuadrangles(), NbBiQuadTriangles(), NbEdges(), NbEdgesOfOrder(), NbElements(), NbFaces(), NbFacesOfOrder(), NbHexagonalPrisms(), NbHexas(), NbHexasOfOrder(), NbNodes(), NbPolygons(), NbPolygonsOfOrder(), NbPolyhedrons(), NbPrisms(), NbPrismsOfOrder(), NbPyramids(), NbPyramidsOfOrder(), NbQuadrangles(), NbQuadranglesOfOrder(), NbTetras(), NbTetrasOfOrder(), NbTriangles(), NbTrianglesOfOrder(), NbTriQuadraticHexas(), NbVolumes(), NbVolumesOfOrder(), onHypothesisModified(), RemoveGroupWithContents(), RemoveHypothesis(), removeHypothesis(), RemoveSubMesh(), removeSubMesh(), SetMeshOrder(), SMESH_Mesh_i(), UnionGroups(), UnionListOfGroups(), and ~SMESH_Mesh_i().
◆ _previewEditor
SMESH_MeshEditor_i* SMESH_Mesh_i::_previewEditor
