SMESH_subMesh Class Reference
#include <SMESH_subMesh.hxx>
struct  OwnListenerData
enum  compute_state { NOT_READY , READY_TO_COMPUTE , COMPUTE_OK , FAILED_TO_COMPUTE }
enum  algo_state { NO_ALGO , MISSING_HYP , HYP_OK }
enum  algo_event {
  ADD_HYP , ADD_ALGO , REMOVE_HYP , REMOVE_ALGO ,
  ADD_FATHER_HYP , ADD_FATHER_ALGO , REMOVE_FATHER_HYP , REMOVE_FATHER_ALGO ,
  MODIF_HYP
enum  compute_event {
  MODIF_ALGO_STATE , COMPUTE , COMPUTE_SUBMESH , COMPUTE_NOGEOM ,
  COMPUTE_CANCELED , CLEAN , SUBMESH_COMPUTED , SUBMESH_RESTORED ,
  SUBMESH_LOADED , MESH_ENTITY_REMOVED , CHECK_COMPUTE_STATE
enum  event_type { ALGO_EVENT , COMPUTE_EVENT }
 SMESH_subMesh (int Id, SMESH_Mesh *father, SMESHDS_Mesh *meshDS, const TopoDS_Shape &aSubShape)
 default constructor: More...
virtual ~SMESH_subMesh ()
int GetId () const
SMESH_Mesh * GetFather ()
SMESHDS_SubMesh * GetSubMeshDS ()
const SMESHDS_SubMesh * GetSubMeshDS () const
SMESHDS_SubMesh * CreateSubMeshDS ()
SMESH_subMesh * GetFirstToCompute ()
SMESH_Algo * GetAlgo () const
 Returns a current algorithm. More...
SMESH_Algo * CopyAlgo () const
const std::map< int, SMESH_subMesh * > & DependsOn ()
 Returns all sub-meshes this one depend on. More...
bool DependsOn (const SMESH_subMesh *other) const
 Return true if this sub-mesh depends on other. More...
bool DependsOn (const int shapeID) const
 Return true if this sub-mesh depends on a shape. More...
SMESH_subMeshIteratorPtr getDependsOnIterator (const bool includeSelf, const bool complexShapeFirst=false) const
 Return iterator on the sub-meshes this one depends on. More...
const std::vector< SMESH_subMesh * > & GetAncestors () const
 Returns ancestor sub-meshes. More...
void ClearAncestors ()
 Clears the vector of ancestor sub-meshes. More...
const TopoDS_Shape & GetSubShape () const
 Return a shape of this sub-mesh. More...
void SetEventListener (EventListener *listener, EventListenerData *data, SMESH_subMesh *where)
 Set an event listener and its data to a submesh. More...
void AddOwnListener (EventListener *listener)
 Adds event listener to a submesh. More...
EventListenerData * GetEventListenerData (EventListener *listener, const bool myOwn=false) const
 Return an event listener data. More...
EventListenerData * GetEventListenerData (const std::string &listenerName, const bool myOwn=false) const
void DeleteEventListener (EventListener *listener)
 Unregister the listener and delete it and it's data. More...
SMESH_Hypothesis::Hypothesis_Status AlgoStateEngine (algo_event event, SMESH_Hypothesis *anHyp)
 Treats modification of hypotheses definition. More...
SMESH_Hypothesis::Hypothesis_Status SubMeshesAlgoStateEngine (algo_event event, SMESH_Hypothesis *anHyp, bool exitOnFatal=false)
 Send an event to sub-meshes. More...
algo_state GetAlgoState () const
compute_state GetComputeState () const
SMESH_ComputeErrorPtr & GetComputeError ()
void DumpAlgoState (bool isMain)
bool ComputeStateEngine (compute_event event)
void ComputeSubMeshStateEngine (compute_event event, const bool includeSelf=false)
bool Evaluate (MapShapeNbElems &aResMap)
bool IsConform (const SMESH_Algo *theAlgo)
bool CanAddHypothesis (const SMESH_Hypothesis *theHypothesis) const
bool IsApplicableHypothesis (const SMESH_Hypothesis *theHypothesis) const
SMESH_Hypothesis::Hypothesis_Status CheckConcurrentHypothesis (SMESH_Hypothesis *theHypothesis)
bool IsEmpty () const
 Return true if no mesh entities is bound to the submesh. More...
bool IsMeshComputed () const
bool IsComputedPartially () const
 Check if any upper level sub-shape is not computed. More...
void SetAllowedSubShapes (const TopTools_IndexedMapOfShape *subShapes)
 Set sub-shapes that are allowed to compute at once by a multidimensional algo. More...
void SetIsAlwaysComputed (bool isAlCo)
 Allow algo->Compute() if a subshape of lower dim is meshed but none mesh entity is bound to it. More...
bool IsAlwaysComputed () const
bool SubMeshesComputed (bool *isFailedToCompute=0) const
 Return true if all sub-meshes have been meshed. More...
int GetComputeCost () const
 Return cost of computing this sub-mesh. More...
bool FindIntersection (const SMESH_subMesh *theOther, std::set< const SMESH_subMesh * > &theSetOfCommon) const
 Find common submeshes (based on shared subshapes with other. More...
static bool IsApplicableHypothesis (const SMESH_Hypothesis *theHypothesis, const TopAbs_ShapeEnum theShapeType)
void setEventListener (EventListener *listener, EventListenerData *data)
 Sets an event listener and its data to a submesh. More...
void notifyListenersOnEvent (const int event, const event_type eventType, SMESH_Hypothesis *hyp=0)
 Notify stored event listeners on the occurred event. More...
void deleteOwnListeners ()
 Delete event listeners depending on algo of this submesh. More...
void loadDependentMeshes ()
 loads dependent meshes on SUBMESH_LOADED event More...
void insertDependence (const TopoDS_Shape aShape, TopAbs_ShapeEnum aSubType, TopAbs_ShapeEnum avoidType=TopAbs_SHAPE)
 Add sub-meshes on sub-shapes of a given type into the dependence map. More...
void removeSubMeshElementsAndNodes ()
void updateDependantsState (const compute_event theEvent)
void updateSubMeshState (const compute_state theState)
void cleanDependants ()
void cleanDependsOn (SMESH_Algo *algoRequiringCleaning=0)
 Remove elements from sub-meshes. More...
void setAlgoState (algo_state state)
TopoDS_Shape getCollection (SMESH_Gen *theGen, SMESH_Algo *theAlgo, bool &theSubComputed, bool &theSubFailed, std::vector< SMESH_subMesh * > &theSubs)
 Return a shape containing all sub-shapes of the MainShape that can be meshed at once along with _subShape. More...
bool checkComputeError (SMESH_Algo *theAlgo, const bool theComputeOK, const TopoDS_Shape &theShape=TopoDS_Shape())
 Update compute_state by _computeError. More...
const SMESH_Hypothesis * getSimilarAttached (const TopoDS_Shape &theShape, const SMESH_Hypothesis *theHyp, const int theHypType=0)
 Return a hypothesis attached to theShape. More...
int computeCost () const
std::map< EventListener *, EventListenerData * > _eventListeners
 < event listeners to notify More...
std::list< OwnListenerData > _ownListeners
TopoDS_Shape _subShape
SMESHDS_SubMesh * _subMeshDS
SMESH_Mesh * _father
int _Id
std::map< int, SMESH_subMesh * > _mapDepend
bool _dependenceAnalysed
std::vector< SMESH_subMesh * > _ancestors
SMESH_Algo * _algo
TopoDS_Shape _algoShape
algo_state _algoState
compute_state _computeState
SMESH_ComputeErrorPtr _computeError
int _computeCost
int _realComputeCost
bool _alwaysComputed
const TopTools_IndexedMapOfShape * _allowedSubShapes
◆ algo_event
ADD_HYP
ADD_ALGO
REMOVE_HYP
REMOVE_ALGO
ADD_FATHER_HYP
ADD_FATHER_ALGO
REMOVE_FATHER_HYP
REMOVE_FATHER_ALGO
MODIF_HYP
◆ algo_state
NO_ALGO
MISSING_HYP
HYP_OK
◆ compute_event
MODIF_ALGO_STATE
COMPUTE
COMPUTE_SUBMESH
COMPUTE_NOGEOM
COMPUTE_CANCELED
CLEAN
SUBMESH_COMPUTED
SUBMESH_RESTORED
SUBMESH_LOADED
MESH_ENTITY_REMOVED
CHECK_COMPUTE_STATE
◆ compute_state
NOT_READY
READY_TO_COMPUTE
COMPUTE_OK
FAILED_TO_COMPUTE
◆ event_type
ALGO_EVENT
COMPUTE_EVENT
◆ SMESH_subMesh()
SMESH_subMesh::SMESH_subMesh ( int  Id,
SMESH_Mesh *  father,
SMESHDS_Mesh *  meshDS,
const TopoDS_Shape &  aSubShape
◆ ~SMESH_subMesh()
SMESH_subMesh::~SMESH_subMesh ( )
References deleteOwnListeners().
◆ AddOwnListener()
void SMESH_subMesh::AddOwnListener ( EventListener *  listener)
listener- the listener to store
It remembers the listener in order to clean it when submesh is deleted
References _ownListeners.
◆ AlgoStateEngine()
SMESH_Hypothesis::Hypothesis_Status SMESH_subMesh::AlgoStateEngine ( algo_event  event,
SMESH_Hypothesis *  anHyp
[in]event- what happens
[in]anHyp- a hypothesis
SMESH_Hypothesis::Hypothesis_Status - a treatment result.
Optional description of a problematic situation (if any) can be retrieved via GetComputeError().
References _algo, _algoState, _computeError, _computeState, _father, _Id, _mapDepend, _realComputeCost, _subShape, ADD_ALGO, ADD_FATHER_ALGO, ADD_FATHER_HYP, ADD_HYP, SMESHDS_Mesh::AddHypothesis(), ALGO_EVENT, SMESH_HypoFilter::And(), SMESH_HypoFilter::AndNot(), CanAddHypothesis(), CHECK_COMPUTE_STATE, SMESH_Algo::CheckHypothesis(), CLEAN, cleanDependsOn(), computeCost(), ComputeStateEngine(), ComputeSubMeshStateEngine(), deleteOwnListeners(), GetAlgo(), SMESH_Gen::GetAlgo(), GetAncestors(), SMESH_Algo::GetComputeError(), SMESH_Hypothesis::GetDim(), SMESH_Mesh::GetGen(), SMESH_Mesh::GetHypothesis(), SMESH_Mesh::GetMeshDS(), SMESHDS_Hypothesis::GetName(), getSimilarAttached(), SMESHDS_Hypothesis::GetType(), SMESH_Mesh::HasShapeToMesh(), SMESH_HypoFilter::HasType(), SMESH_Hypothesis::HYP_ALREADY_EXIST, SMESH_Hypothesis::HYP_BAD_DIM, SMESH_Hypothesis::HYP_HIDDEN_ALGO, SMESH_Hypothesis::HYP_HIDING_ALGO, SMESH_Hypothesis::HYP_INCOMPATIBLE, SMESH_Hypothesis::HYP_NEED_SHAPE, SMESH_Hypothesis::HYP_NOTCONFORM, SMESH_Hypothesis::HYP_OK, HYP_OK, SMESH_HypoFilter::Init(), SMESH_Algo::InitComputeError(), SMESH_HypoFilter::Is(), SMESH_HypoFilter::IsAlgo(), IsApplicableHypothesis(), SMESH_HypoFilter::IsApplicableTo(), SMESH_Hypothesis::IsAuxiliary(), IsConform(), SMESH_Mesh::IsNotConformAllowed(), SMESH_Hypothesis::IsStatusFatal(), SMESH_MesherHelper::IsSubShape(), SMESH_Mesh::IsUsedHypothesis(), MESSAGE, MISSING_HYP, MODIF_ALGO_STATE, MODIF_HYP, SMESH_Algo::NeedDiscreteBoundary(), SMESH_Algo::NeedShape(), NO_ALGO, notifyListenersOnEvent(), SMESH_HypoFilter::Or(), READY_TO_COMPUTE, REMOVE_ALGO, REMOVE_FATHER_ALGO, REMOVE_FATHER_HYP, REMOVE_HYP, SMESHDS_Mesh::RemoveHypothesis(), setAlgoState(), SMESH_Algo::SetEventListener(), SetIsAlwaysComputed(), and SMESH_Algo::SupportSubmeshes().
Referenced by SMESH_Mesh::AddHypothesis(), SMESH_Mesh::RemoveHypothesis(), and SubMeshesAlgoStateEngine().
◆ CanAddHypothesis()
bool SMESH_subMesh::CanAddHypothesis ( const SMESH_Hypothesis *  theHypothesis) const
◆ checkComputeError()
bool SMESH_subMesh::checkComputeError ( SMESH_Algo *  theAlgo,
const TopoDS_Shape &  theShape = TopoDS_Shape()
Update compute_state by _computeError and send proper events to dependent submeshes.
bool- false if there are errors
bool- true if _computeError is NOT set
References _computeError, _computeState, _father, _Id, _subShape, checkComputeError(), COMPERR_NO_MESH_ON_SHAPE, COMPUTE_OK, Edge, FAILED_TO_COMPUTE, getDependsOnIterator(), SMESHDS_Hypothesis::GetName(), SMESH_Mesh::GetSubMesh(), GetSubShape(), SMESH_Algo::isDegenerated(), IsMeshComputed(), SMESH_Algo::NeedDiscreteBoundary(), SMESH_ComputeError::New(), SMESH_Algo::OnlyUnaryInput(), SUBMESH_COMPUTED, and updateDependantsState().
Referenced by checkComputeError(), and ComputeStateEngine().
◆ CheckConcurrentHypothesis()
◆ cleanDependants()
void SMESH_subMesh::cleanDependants ( )
◆ cleanDependsOn()
◆ ClearAncestors()
void SMESH_subMesh::ClearAncestors ( )
References _ancestors.
◆ computeCost()
int SMESH_subMesh::computeCost ( ) const
The cost depends on the shape type and number of sub-meshes this one DependsOn().
int - the computation cost in abstract units.
References _computeCost, _subShape, computeCost(), and getDependsOnIterator().
Referenced by AlgoStateEngine(), and computeCost().
◆ ComputeStateEngine()
bool SMESH_subMesh::ComputeStateEngine ( compute_event  event)
References _algo, _algoState, _alwaysComputed, _computeError, _computeState, _father, _Id, _subShape, SMESHDS_Mesh::AddNode(), SMESHDS_Hypothesis::ALGO_1D, SMESHDS_Hypothesis::ALGO_3D, SMESH_Algo::CancelCompute(), CHECK_COMPUTE_STATE, checkComputeError(), SMESH_Algo::CheckHypothesis(), SMDS_Mesh::CheckMemory(), CLEAN, cleanDependants(), cleanDependsOn(), cleanSubMesh(), COMPERR_ALGO_FAILED, COMPERR_BAD_INPUT_MESH, COMPERR_EXCEPTION, COMPERR_MEMORY_PB, COMPERR_OCC_EXCEPTION, COMPERR_OK, COMPERR_SLM_EXCEPTION, COMPERR_STD_EXCEPTION, COMPERR_WARNING, SMESH_Algo::Compute(), COMPUTE, COMPUTE_CANCELED, COMPUTE_EVENT, COMPUTE_NOGEOM, COMPUTE_OK, COMPUTE_SUBMESH, ComputeStateEngine(), ComputeSubMeshStateEngine(), Edge, FAILED_TO_COMPUTE, GetAlgo(), getCollection(), SMESH_Algo::GetComputeError(), GetComputeState(), getDependsOnIterator(), SMESH_Mesh::GetGen(), SMESH_Mesh::GetHypothesisList(), GetId(), SMESH_Mesh::GetIsModified(), SMESH_Mesh::GetMeshDS(), SMESHDS_Hypothesis::GetName(), SMESH_Mesh::GetParallelElement(), SMESH_Mesh::GetSubMesh(), GetSubMeshDS(), GetSubShape(), SMESH_Algo::GetUsedHypothesis(), SMESH_Mesh::HasShapeToMesh(), HYP_OK, SMESH_Algo::InitComputeError(), SMESH_Algo::isDegenerated(), IsEmpty(), IsMeshComputed(), SMESH_Mesh::IsNotConformAllowed(), SMESH_Mesh::IsParallel(), loadDependentMeshes(), MESH_ENTITY_REMOVED, MESSAGE, MISSING_HYP, MODIF_ALGO_STATE, SMESHDS_SubMesh::NbNodes(), SMESH_Algo::NeedDiscreteBoundary(), SMESH_ComputeError::New(), NOT_READY, notifyListenersOnEvent(), OCC_CATCH_SIGNALS, SMESH_Algo::OnlyUnaryInput(), READY_TO_COMPUTE, removeSubMeshElementsAndNodes(), setAlgoState(), SMESH_MesherHelper::SetElementsOnShape(), SMESHDS_Mesh::SetNodeOnVertex(), SMESH_Algo::setSubMeshesToCompute(), SMESH_MesherHelper::SetSubShape(), SMESH_Comment::Stream(), SUBMESH_COMPUTED, SUBMESH_LOADED, SUBMESH_RESTORED, SubMeshesComputed(), SMESH_Algo::SubMeshesToCompute(), SMESH_Algo::SubmeshRestored(), SMESH_Algo::SupportSubmeshes(), updateDependantsState(), and SMESH_ComputeError::Worst().
Referenced by AlgoStateEngine(), cleanDependsOn(), StdMeshers_Penta_3D::ClearMeshOnFxy1(), StdMeshers_Prism_3D::compute(), StdMeshers_CompositeSegment_1D::Compute(), StdMeshers_Import_1D2D::Compute(), StdMeshers_PolyhedronPerSolid_3D::Compute(), StdMeshers_Prism_3D::Compute(), StdMeshers_Prism_3D::computeBase(), ComputeStateEngine(), StdMeshers_Prism_3D::computeWalls(), SMESH_Gen_i::CopyMeshWithGeom(), SMESH_Pattern::createElements(), VISCOUS_3D::_ViscousBuilder::error(), SMESH_PreMeshInfo::FullLoadFromFile(), StdMeshers_Quadrangle_2D::getEnforcedUV(), StdMeshers_Penta_3D::MakeMeshOnFxy1(), StdMeshers_Prism_3D::makeQuadsForOutInProjection(), SMESH_Gen::parallelComputeSubMeshes(), StdMeshers_Prism_3D::project2dMesh(), VISCOUS_2D::_ViscousBuilder2D::refine(), VISCOUS_2D::_ViscousBuilder2D::removeMeshFaces(), SMESH_Gen::sequentialComputeSubMeshes(), SetIsAlwaysComputed(), and VISCOUS_3D::_ViscousBuilder::shrink().
◆ ComputeSubMeshStateEngine()
void SMESH_subMesh::ComputeSubMeshStateEngine ( compute_event  event,
const bool  includeSelf = false
◆ CopyAlgo()
SMESH_Algo * SMESH_subMesh::CopyAlgo ( ) const
◆ CreateSubMeshDS()
◆ DeleteEventListener()
void SMESH_subMesh::DeleteEventListener ( EventListener *  listener)
Unregister the listener and delete listener's data.
listener- the event listener to delete
References _eventListeners.
Referenced by VISCOUS_3D::_ViscousListener::ProcessEvent(), and VISCOUS_3D::_ViscousListener::RemoveSolidMesh().
◆ deleteOwnListeners()
void SMESH_subMesh::deleteOwnListeners ( )
References _father, _ownListeners, MESHCUT::d, SMESH_Mesh::FindMesh(), and SMESH_Mesh::GetSubMeshContaining().
Referenced by AlgoStateEngine(), and ~SMESH_subMesh().
◆ DependsOn() [1/3]
◆ DependsOn() [2/3]
bool SMESH_subMesh::DependsOn ( const int  shapeID) const
References _father, DependsOn(), and SMESH_Mesh::GetSubMeshContaining().
◆ DependsOn() [3/3]
bool SMESH_subMesh::DependsOn ( const SMESH_subMesh *  other) const
References _mapDepend.
◆ DumpAlgoState()
◆ Evaluate()
◆ FindIntersection()
bool SMESH_subMesh::FindIntersection ( const SMESH_subMesh *  theOther,
std::set< const SMESH_subMesh * > &  theSetOfCommon
Find common submeshes (based on shared sub-shapes with other.
theOthersubmesh to check
theCommonIdsset of common submesh IDs NOTE: this method does not cleat set before collect common IDs
theSetOfCommonset of common submesh
References _mapDepend, and GetId().
◆ GetAlgo()
◆ GetAlgoState()
◆ GetAncestors()
◆ getCollection()
TopoDS_Shape SMESH_subMesh::getCollection ( SMESH_Gen *  theGen,
bool &  theSubComputed,
bool &  theSubFailed,
std::vector< SMESH_subMesh * > &  theSubs
◆ GetComputeCost()
int SMESH_subMesh::GetComputeCost ( ) const
If hypotheses are not well defined, zero is returned
References _realComputeCost.
Referenced by SMESH_Mesh::GetComputeProgress().
◆ GetComputeError()
◆ GetComputeState()
◆ getDependsOnIterator()
SMESH_subMeshIteratorPtr SMESH_subMesh::getDependsOnIterator ( const bool  includeSelf,
const bool  reverse = false
Return iterator on the submeshes this one depends on.
By default most simple sub-meshes go first.
includeSelf- this submesh to be returned also
reverse- if true, complex shape submeshes go first
References DependsOn(), and reverse().
Referenced by SMESH_Mesh::AddHypothesis(), checkComputeError(), checkConformIgnoredAlgos(), SMESH_Mesh::CheckHypothesesOnSubMeshes(), checkMissing(), cleanDependsOn(), StdMeshers_Prism_3D::compute(), StdMeshers_PolyhedronPerSolid_3D::Compute(), StdMeshers_Prism_3D::Compute(), StdMeshers_Projection_2D::Compute(), StdMeshers_Prism_3D::computeBase(), computeCost(), VISCOUS_3D::_ViscousBuilder::computeGeomSize(), ComputeStateEngine(), ComputeSubMeshStateEngine(), StdMeshers_Prism_3D::computeWalls(), SMESH_Gen_i::CopyMeshWithGeom(), Evaluate(), StdMeshers_PolyhedronPerSolid_3D::Evaluate(), StdMeshers_Projection_1D2D::Evaluate(), VISCOUS_3D::_ViscousBuilder::findCollisionEdges(), VISCOUS_3D::_ViscousBuilder::findShapesToSmooth(), VISCOUS_3D::_ViscousBuilder::findSolidsWithLayers(), SMESH_Gen::GetAlgoState(), getCollection(), SMESH_Gen_i::GetComputeErrors(), GetFirstToCompute(), VISCOUS_3D::_ConvexFace::GetMaxCurvature(), SMESH_subMesh_i::GetNumberOfNodes(), SMESH_Mesh::GetSubMesh(), getSubMeshes(), StdMeshers_Prism_3D::initPrism(), IsComputedPartially(), SMESH_MesherHelper::IsDistorted2D(), SMESH_Gen::parallelComputeSubMeshes(), SMESH_Gen_i::Precompute(), VISCOUS_3D::_ViscousBuilder::putOnOffsetSurface(), SMESH_Mesh::RemoveHypothesis(), SMESH_Gen::sequentialComputeSubMeshes(), MeshEditor_I::TSearchersDeleter::Set(), StdMeshers_CompositeSegment_1D::SetEventListener(), VISCOUS_3D::_ViscousBuilder::shrink(), SubMeshesAlgoStateEngine(), SubMeshesComputed(), and updateSubMeshState().
◆ GetEventListenerData() [1/2]
EventListenerData * SMESH_subMesh::GetEventListenerData ( const std::string &  listenerName,
const bool  myOwn = false
listenerName- the listener name
myOwn- if true, returns a listener set by this sub-mesh, else returns a listener listening to events of this sub-mesh
EventListenerData*- found data, maybe NULL
References _eventListeners, _father, _ownListeners, MESHCUT::d, and SMESH_Mesh::MeshExists().
◆ GetEventListenerData() [2/2]
EventListenerData * SMESH_subMesh::GetEventListenerData ( EventListener *  listener,
listener- the listener whose data is
Referenced by VISCOUS_2D::_ProxyMeshHolder::FindProxyMeshOfFace(), VISCOUS_3D::_ViscousListener::GetSolidMesh(), StdMeshers_ProjectionUtils::SetEventListener(), and VISCOUS_3D::ToClearSubWithMain().
◆ GetFather()
◆ GetFirstToCompute()
SMESH_subMesh * SMESH_subMesh::GetFirstToCompute ( )
◆ GetId()
◆ getSimilarAttached()
const SMESH_Hypothesis * SMESH_subMesh::getSimilarAttached ( const TopoDS_Shape &  theShape,
const SMESH_Hypothesis *  theHyp,
const int  theHypType = 0
◆ GetSubMeshDS() [1/2]
SMESHDS_SubMesh * SMESH_subMesh::GetSubMeshDS ( )
References _father, _subMeshDS, _subShape, SMESH_Mesh::GetMeshDS(), and SMESHDS_Mesh::MeshElements().
Referenced by StdMeshers_Prism_3D::assocOrProjBottom2Top(), cleanSubMesh(), StdMeshers_Prism_3D::Compute(), StdMeshers_Projection_1D::Compute(), StdMeshers_Projection_2D::Compute(), StdMeshers_Projection_3D::Compute(), StdMeshers_Regular_1D::computeInternalParameters(), ComputePentahedralMesh(), ComputeStateEngine(), StdMeshers_Prism_3D::computeWalls(), SMESH_MeshEditor::ConvertFromQuadratic(), SMESH_MeshEditor::ConvertToQuadratic(), SMESH_Gen_i::CopyMeshWithGeom(), CreateSubMeshDS(), Evaluate(), StdMeshers_Projection_1D::Evaluate(), StdMeshers_Projection_1D2D::Evaluate(), StdMeshers_Projection_2D::Evaluate(), StdMeshers_Projection_3D::Evaluate(), SMESH_MeshEditor_i::ExtrusionAlongPathObjects(), VISCOUS_3D::_ViscousBuilder::findNeiborsOnEdge(), StdMeshers_Penta_3D::FindNodeOnShape(), VISCOUS_3D::_ViscousBuilder::findSolidsWithLayers(), SMESH_MesherHelper::FixQuadraticElements(), VISCOUS_3D::ShrinkFace::GetElements(), SMESH_Mesh::GetGroupSubMeshesContaining(), SMESH_Algo::GetMeshError(), SMESH_subMesh_i::GetNumberOfNodes(), SMESH_Mesh_i::GetSubMeshElementsId(), SMESH_Mesh_i::GetSubMeshElementType(), getSubMeshes(), SMESH_Mesh_i::GetSubMeshNodesId(), Handle(), StdMeshers_Prism_3D::initPrism(), IsEmpty(), VISCOUS_3D::ShrinkFace::IsSameNbElements(), SMESH_MesherHelper::IsStructured(), SMESH_MeshEditor_i::LinearAnglesVariation(), StdMeshers_Penta_3D::MakeBlock(), VISCOUS_3D::_ViscousBuilder::makeLayer(), StdMeshers_Penta_3D::MakeMeshOnFxy1(), StdMeshers_Penta_3D::MakeNodes(), StdMeshers_Penta_3D::MakeVolumeMesh(), SMESH_Algo::NumberOfPoints(), StdMeshers_ProjectionUtils::Morph::Perform(), SMESH_Gen_i::Precompute(), VISCOUS_3D::_SolidData::PrepareEdgesToSmoothOnFace(), StdMeshers_Prism_3D::project2dMesh(), StdMeshers_Prism_3D::projectBottomToTop(), VISCOUS_2D::_ViscousBuilder2D::removeMeshFaces(), StdMeshers_ProjectionUtils::SetEventListener(), VISCOUS_3D::_ViscousBuilder::setShapeData(), VISCOUS_3D::_ViscousBuilder::shrink(), and SubMeshesComputed().
◆ GetSubMeshDS() [2/2]
const SMESHDS_SubMesh * SMESH_subMesh::GetSubMeshDS ( ) const
◆ GetSubShape()
const TopoDS_Shape & SMESH_subMesh::GetSubShape ( ) const
References _subShape.
Referenced by StdMeshers_Prism_3D::assocOrProjBottom2Top(), checkComputeError(), checkConformIgnoredAlgos(), checkMissing(), cleanDependsOn(), StdMeshers_PolyhedronPerSolid_3D::Compute(), StdMeshers_Projection_2D::Compute(), StdMeshers_Prism_3D::computeBase(), VISCOUS_3D::_ViscousBuilder::computeGeomSize(), ComputeStateEngine(), StdMeshers_Prism_3D::computeWalls(), SMESH_MeshEditor::ConvertToQuadratic(), SMESH_Gen_i::CopyMeshWithGeom(), VISCOUS_3D::_ViscousBuilder::error(), Evaluate(), StdMeshers_PolyhedronPerSolid_3D::Evaluate(), StdMeshers_Projection_1D2D::Evaluate(), SMESH_Mesh_i::findConcurrentSubMeshes(), VISCOUS_3D::_ViscousBuilder::findShapesToSmooth(), VISCOUS_3D::_ViscousBuilder::findSolidsWithLayers(), SMESH_Gen::GetAlgo(), SMESH_Gen::GetAlgoState(), SMESH_Mesh::GetGroupSubMeshesContaining(), SMESH_Mesh::GetHypotheses(), SMESH_Mesh::GetHypothesis(), SMESH_Algo::GetMeshError(), SMESH_Mesh_i::GetSubMeshElementType(), getSubMeshes(), SMESH_Mesh::HasModificationsToDiscard(), StdMeshers_Prism_3D::initPrism(), IsComputedPartially(), SMESH_MesherHelper::IsDistorted2D(), VISCOUS_3D::ShrinkFace::IsSame(), VISCOUS_3D::ShrinkFace::IsShrunk(), SMESH_MesherHelper::IsStructured(), StdMeshers_ProjectionUtils::MakeComputed(), VISCOUS_3D::_ViscousBuilder::MakeN2NMap(), SMESH_Mesh::NotifySubMeshesHypothesisModification(), SMESH_Gen::parallelComputeSubMeshes(), SMESH_Gen_i::Precompute(), SMESH_Mesh_i::removeSubMesh(), SMESH_Gen::sequentialComputeSubMeshes(), VISCOUS_3D::ShrinkFace::SetBoundary(), StdMeshers_CompositeSegment_1D::SetEventListener(), StdMeshers_Import_1D::SetEventListener(), StdMeshers_Import_1D2D::SetEventListener(), StdMeshers_RadialQuadrangle_1D2D::SetEventListener(), StdMeshers_ProjectionUtils::SetEventListener(), VISCOUS_3D::_ViscousBuilder::setShapeData(), VISCOUS_3D::_ViscousBuilder::shrink(), StdMeshers_ProjectionUtils::SourceNotComputedError(), and SubMeshesComputed().
◆ insertDependence()
void SMESH_subMesh::insertDependence ( const TopoDS_Shape  aShape,
TopAbs_ShapeEnum  avoidType = TopAbs_SHAPE
References _father, _mapDepend, DependsOn(), GetId(), and SMESH_Mesh::GetSubMesh().
Referenced by DependsOn().
◆ IsAlwaysComputed()
bool SMESH_subMesh::IsAlwaysComputed ( ) const
◆ IsApplicableHypothesis() [1/2]
bool SMESH_subMesh::IsApplicableHypothesis ( const SMESH_Hypothesis *  theHypothesis) const
◆ IsApplicableHypothesis() [2/2]
◆ IsComputedPartially()
bool SMESH_subMesh::IsComputedPartially ( ) const
Used to update a sub-mesh icon
References COMPUTE_OK, FAILED_TO_COMPUTE, GetComputeState(), getDependsOnIterator(), GetSubShape(), NOT_READY, and READY_TO_COMPUTE.
◆ IsConform()
◆ IsEmpty()
◆ IsMeshComputed()
◆ loadDependentMeshes()
void SMESH_subMesh::loadDependentMeshes ( )
References _father, _ownListeners, MESHCUT::d, and SMESH_Mesh::FindMesh().
Referenced by ComputeStateEngine().
◆ notifyListenersOnEvent()
void SMESH_subMesh::notifyListenersOnEvent ( const int  event,
SMESH_Hypothesis *  hyp = 0
event- algo_event or compute_event itself
eventType- algo_event or compute_event
hyp- hypothesis, if eventType is algo_event
Referenced by AlgoStateEngine(), and ComputeStateEngine().
◆ removeSubMeshElementsAndNodes()
void SMESH_subMesh::removeSubMeshElementsAndNodes ( )
◆ setAlgoState()
void SMESH_subMesh::setAlgoState ( algo_state  state)
References _algoState.
◆ SetAllowedSubShapes()
void SMESH_subMesh::SetAllowedSubShapes ( const TopTools_IndexedMapOfShape *  subShapes)
Referenced by SMESH_Gen::sequentialComputeSubMeshes(), and VISCOUS_3D::_ViscousBuilder::shrink().
◆ setEventListener()
void SMESH_subMesh::setEventListener ( EventListener *  listener,
EventListenerData *  data
data- the listener data to store
After being set, event listener is notified on each event of a submesh.
References _eventListeners, SMESH_subMeshEventListener::GetName(), SMESH_subMeshEventListener::IsDeletable(), and SMESH_subMeshEventListenerData::IsDeletable().
Referenced by SetEventListener().
◆ SetEventListener()
void SMESH_subMesh::SetEventListener ( EventListener *  listener,
EventListenerData *  data,
SMESH_subMesh *  where
where- the submesh to store the listener and it's data
The method remembers the submesh \awhere it puts the listener in order to delete it when HYP_OK algo_state is lost After being set, event listener is notified on each event of \awhere submesh.
It remembers the submesh where it puts the listener in order to delete them when HYP_OK algo_state is lost After being set, event listener is notified on each event of where submesh.
References _ownListeners, and setEventListener().
Referenced by VISCOUS_2D::_ProxyMeshHolder::_ProxyMeshHolder(), VISCOUS_3D::_ViscousListener::GetSolidMesh(), StdMeshers_Penta_3D::MakeMeshOnFxy1(), MeshEditor_I::TSearchersDeleter::Set(), StdMeshers_CompositeSegment_1D::SetEventListener(), StdMeshers_QuadFromMedialAxis_1D2D::SetEventListener(), StdMeshers_ProjectionUtils::SetEventListener(), and VISCOUS_3D::ToClearSubWithMain().
◆ SetIsAlwaysComputed()
void SMESH_subMesh::SetIsAlwaysComputed ( bool  isAlCo)
Allow algo->Compute() if a sub-shape of lower dim is meshed but none mesh entity is bound to it (PAL13615, 2nd part)
References _alwaysComputed, _computeState, CHECK_COMPUTE_STATE, COMPUTE_OK, and ComputeStateEngine().
Referenced by AlgoStateEngine(), StdMeshers_CompositeSegment_1D::Compute(), StdMeshers_UseExisting_2D::Compute(), StdMeshers_UseExisting_1D::Compute(), and StdMeshers_CompositeSegment_1D::SetEventListener().
◆ SubMeshesAlgoStateEngine()
SMESH_Hypothesis::Hypothesis_Status SMESH_subMesh::SubMeshesAlgoStateEngine ( algo_event  event,
SMESH_Hypothesis *  anHyp,
bool  exitOnFatal = false
[in]event- the event
[in]anHyp- an hypothesis
[in]exitOnFatal- to stop iteration on sub-meshes if a sub-mesh reports a fatal result
SMESH_Hypothesis::Hypothesis_Status - the worst result
References _computeError, AlgoStateEngine(), getDependsOnIterator(), SMESH_Hypothesis::HYP_OK, and SMESH_Hypothesis::IsStatusFatal().
Referenced by SMESH_Mesh::AddHypothesis(), SMESH_Mesh::CheckHypothesesOnSubMeshes(), and SMESH_Mesh::RemoveHypothesis().
◆ SubMeshesComputed()
◆ updateDependantsState()
void SMESH_subMesh::updateDependantsState ( const compute_event  theEvent)
References GetAncestors().
◆ updateSubMeshState()
void SMESH_subMesh::updateSubMeshState ( const compute_state  theState)
◆ _algo
SMESH_Algo* SMESH_subMesh::_algo
◆ _algoShape
TopoDS_Shape SMESH_subMesh::_algoShape
Referenced by GetAlgo(), and getCollection().
◆ _algoState
algo_state SMESH_subMesh::_algoState
◆ _allowedSubShapes
const TopTools_IndexedMapOfShape* SMESH_subMesh::_allowedSubShapes
Referenced by getCollection(), and SMESH_subMesh().
◆ _alwaysComputed
bool SMESH_subMesh::_alwaysComputed
◆ _ancestors
std::vector< SMESH_subMesh * > SMESH_subMesh::_ancestors
Referenced by ClearAncestors(), and GetAncestors().
◆ _computeCost
int SMESH_subMesh::_computeCost
Referenced by computeCost(), and SMESH_subMesh().
◆ _computeError
◆ _computeState
◆ _dependenceAnalysed
bool SMESH_subMesh::_dependenceAnalysed
Referenced by DependsOn(), and SMESH_subMesh().
◆ _eventListeners
std::map< EventListener*, EventListenerData* > SMESH_subMesh::_eventListeners
event listeners to delete when HYP_OK algo_state is lost
Referenced by DeleteEventListener(), GetEventListenerData(), notifyListenersOnEvent(), and setEventListener().
◆ _father
◆ _Id
int SMESH_subMesh::_Id
◆ _mapDepend
std::map< int, SMESH_subMesh * > SMESH_subMesh::_mapDepend
◆ _ownListeners
std::list< OwnListenerData > SMESH_subMesh::_ownListeners
◆ _realComputeCost
int SMESH_subMesh::_realComputeCost
◆ _subMeshDS
SMESHDS_SubMesh* SMESH_subMesh::_subMeshDS
Referenced by GetSubMeshDS(), and SMESH_subMesh().
◆ _subShape
