StdMeshers_ViscousLayers Class Reference
Hypothesis defining parameters of viscous layers. More...
#include <StdMeshers_ViscousLayers.hxx>
Inheritance diagram for StdMeshers_ViscousLayers:
enum  ExtrusionMethod { SURF_OFFSET_SMOOTH , FACE_OFFSET , NODE_OFFSET }
enum  Hypothesis_Status {
enum  hypothesis_type {
  ALGO_3D
 StdMeshers_ViscousLayers (int hypId, SMESH_Gen *gen)
void SetBndShapes (const std::vector< int > &shapeIds, bool toIgnore)
std::vector< int > GetBndShapes () const
bool IsToIgnoreShapes () const
void SetTotalThickness (double thickness)
double GetTotalThickness () const
void SetNumberLayers (int nb)
int GetNumberLayers () const
void SetStretchFactor (double factor)
double GetStretchFactor () const
void SetMethod (ExtrusionMethod how)
ExtrusionMethod GetMethod () const
void SetGroupName (const std::string &name)
const std::string & GetGroupName () const
SMESH_ProxyMesh::Ptr Compute (SMESH_Mesh &theMesh, const TopoDS_Shape &theShape, const bool toMakeN2NMap=false) const
bool IsShapeWithLayers (int shapeIndex) const
 Initialize my parameter values by the mesh built on the geometry. More...
virtual bool SetParametersByDefaults (const TDefaults &, const SMESH_Mesh *=0)
virtual int GetDim () const
SMESH_Gen * GetGen () const
const char * GetName () const
int GetID () const
int GetType () const
 Equality. More...
static SMDS_MeshGroup * CreateGroup (const std::string &theName, SMESH_Mesh &theMesh, SMDSAbs_ElementType theType)
static SMESH_ComputeErrorPtr CheckHypothesis (SMESH_Mesh &aMesh, const TopoDS_Shape &aShape, SMESH_Hypothesis::Hypothesis_Status &aStatus)
static double Get1stLayerThickness (double thickTotal, double factor, int nbLayers)
static const char * GetHypType ()
SMESH_Gen * _gen
int _shapeType
int _param_algo_dim
int _hypId
hypothesis_type _type
std::vector< int > _shapeIds
bool _isToIgnoreShapes
int _nbLayers
double _thickness
double _stretchFactor
ExtrusionMethod _method
std::string _groupName
std::string _libName
◆ ExtrusionMethod
SURF_OFFSET_SMOOTH
FACE_OFFSET
NODE_OFFSET
◆ Hypothesis_Status
HYP_OK
HYP_MISSING
HYP_CONCURRENT
HYP_BAD_PARAMETER
HYP_HIDDEN_ALGO
HYP_HIDING_ALGO
HYP_UNKNOWN_FATAL
HYP_INCOMPATIBLE
HYP_NOTCONFORM
HYP_ALREADY_EXIST
HYP_BAD_DIM
HYP_BAD_SUBSHAPE
HYP_BAD_GEOMETRY
HYP_NEED_SHAPE
HYP_INCOMPAT_HYPS
◆ hypothesis_type
PARAM_ALGO
ALGO_0D
ALGO_1D
ALGO_2D
ALGO_3D
◆ InitWay
BY_MESH
BY_GEOM
BY_AVERAGE_LENGTH
◆ StdMeshers_ViscousLayers()
StdMeshers_ViscousLayers::StdMeshers_ViscousLayers ( int  hypId,
SMESH_Gen *  gen
◆ CheckHypothesis()
◆ Compute()
◆ CreateGroup()
◆ DataDependOnParams()
◆ Get1stLayerThickness()
double StdMeshers_ViscousLayers::Get1stLayerThickness ( double  thickTotal,
double  factor,
int  nbLayers
◆ GetBndShapes()
◆ GetDim()
◆ GetGen()
◆ GetGroupName()
const std::string & StdMeshers_ViscousLayers::GetGroupName ( ) const
◆ GetHypType()
◆ GetID()
◆ GetLibName()
◆ GetMeshByPersistentID()
◆ GetMethod()
ExtrusionMethod StdMeshers_ViscousLayers::GetMethod ( ) const
◆ GetName()
◆ GetNumberLayers()
◆ GetShapeType()
◆ GetStretchFactor()
◆ GetTotalThickness()
double StdMeshers_ViscousLayers::GetTotalThickness ( ) const
◆ GetType()
◆ IsAuxiliary()
bool- auxiliary or not
◆ IsSameName()
◆ IsShapeWithLayers()
bool StdMeshers_ViscousLayers::IsShapeWithLayers ( int  shapeIndex) const
◆ IsStatusFatal()
◆ IsToIgnoreShapes()
◆ LoadFrom()
std::istream & StdMeshers_ViscousLayers::LoadFrom ( std::istream &  load)
◆ LoadStringFromStream()
std::string &  txt
Referenced by SMESH_Hypothesis_i::LoadFrom(), StdMeshers_CartesianParameters3D::SetAxisDirs(), StdMeshers_BlockRenumber::SetBlocksOrientation(), SetBndShapes(), StdMeshers_Geometric1D::SetCommonRatio(), StdMeshers_ImportSource1D::SetCopySourceMesh(), StdMeshers_Adaptive1D::SetDeflection(), StdMeshers_Deflection1D::SetDeflection(), StdMeshers_QuadrangleParams::SetEnforcedNodes(), StdMeshers_AutomaticLength::SetFineness(), StdMeshers_CartesianParameters3D::SetFixedPoint(), StdMeshers_CartesianParameters3D::SetGrid(), StdMeshers_CartesianParameters3D::SetGridSpacing(), SetGroupName(), StdMeshers_ImportSource1D::SetGroups(), StdMeshers_LayerDistribution::SetLayerDistribution(), StdMeshers_LocalLength::SetLength(), StdMeshers_MaxLength::SetLength(), StdMeshers_SegmentLengthAroundVertex::SetLength(), StdMeshers_Arithmetic1D::SetLength(), StdMeshers_StartEndLength::SetLength(), StdMeshers_MaxElementArea::SetMaxArea(), StdMeshers_Adaptive1D::SetMaxSize(), StdMeshers_MaxElementVolume::SetMaxVolume(), SetMethod(), StdMeshers_Adaptive1D::SetMinSize(), StdMeshers_LengthFromEdges::SetMode(), StdMeshers_FixedPoints1D::SetNbSegments(), SetNumberLayers(), StdMeshers_NumberOfLayers::SetNumberOfLayers(), StdMeshers_FixedPoints1D::SetPoints(), StdMeshers_LocalLength::SetPrecision(), StdMeshers_QuadrangleParams::SetQuadType(), StdMeshers_CartesianParameters3D::SetQuanta(), StdMeshers_Reversible1D::SetReversedEdges(), StdMeshers_CartesianParameters3D::SetSizeThreshold(), StdMeshers_ProjectionSource3D::SetSource3DShape(), StdMeshers_ProjectionSource1D::SetSourceEdge(), StdMeshers_ProjectionSource2D::SetSourceFace(), StdMeshers_ProjectionSource1D::SetSourceMesh(), StdMeshers_ProjectionSource2D::SetSourceMesh(), StdMeshers_ProjectionSource3D::SetSourceMesh(), StdMeshers_Geometric1D::SetStartLength(), SetStretchFactor(), StdMeshers_CartesianParameters3D::SetToAddEdges(), StdMeshers_CartesianParameters3D::SetToConsiderInternalFaces(), StdMeshers_CartesianParameters3D::SetToCreateFaces(), SetTotalThickness(), StdMeshers_CartesianParameters3D::SetToUseQuanta(), StdMeshers_CartesianParameters3D::SetToUseThresholdForInternalFaces(), StdMeshers_QuadrangleParams::SetTriaVertex(), StdMeshers_ProjectionSource1D::SetVertexAssociation(), StdMeshers_ProjectionSource2D::SetVertexAssociation(), and StdMeshers_ProjectionSource3D::SetVertexAssociation().
◆ operator!=()
◆ operator==()
Equality.
◆ SaveStringToStream()
const std::string &  txt
◆ SaveTo()
std::ostream & StdMeshers_ViscousLayers::SaveTo ( std::ostream &  save)
◆ SetBndShapes()
◆ SetGroupName()
◆ SetLibName()
◆ SetMethod()
◆ SetNumberLayers()
◆ SetParametersByDefaults()
virtual bool StdMeshers_ViscousLayers::SetParametersByDefaults ( const TDefaults &  ,
const SMESH_Mesh *  = 0
Implements SMESH_Hypothesis.
Reimplemented in StdMeshers_ViscousLayers2D.
◆ SetParametersByMesh()
bool StdMeshers_ViscousLayers::SetParametersByMesh ( const SMESH_Mesh *  theMesh,
theMesh- the built mesh
◆ SetStretchFactor()
◆ SetTotalThickness()
◆ _gen
◆ _groupName
std::string StdMeshers_ViscousLayers::_groupName
Referenced by LoadFrom(), SaveTo(), and SetGroupName().
◆ _hypId
◆ _isToIgnoreShapes
bool StdMeshers_ViscousLayers::_isToIgnoreShapes
Referenced by LoadFrom(), SaveTo(), and SetBndShapes().
◆ _libName
privateinherited
◆ _method
ExtrusionMethod StdMeshers_ViscousLayers::_method
Referenced by LoadFrom(), SaveTo(), and SetMethod().
◆ _name
Referenced by SMESHDS_Hypothesis::GetName(), SMESHDS_Hypothesis::IsSameName(), SMESHDS_Hypothesis::operator==(), SMESHDS_Hypothesis::SMESHDS_Hypothesis(), StdMeshers_Adaptive1D::StdMeshers_Adaptive1D(), StdMeshers_Arithmetic1D::StdMeshers_Arithmetic1D(), StdMeshers_AutomaticLength::StdMeshers_AutomaticLength(), StdMeshers_BlockRenumber::StdMeshers_BlockRenumber(), StdMeshers_Cartesian_3D::StdMeshers_Cartesian_3D(), StdMeshers_CartesianParameters3D::StdMeshers_CartesianParameters3D(), StdMeshers_CompositeHexa_3D::StdMeshers_CompositeHexa_3D(), StdMeshers_CompositeSegment_1D::StdMeshers_CompositeSegment_1D(), StdMeshers_Deflection1D::StdMeshers_Deflection1D(), StdMeshers_FixedPoints1D::StdMeshers_FixedPoints1D(), StdMeshers_Geometric1D::StdMeshers_Geometric1D(), StdMeshers_Hexa_3D::StdMeshers_Hexa_3D(), StdMeshers_HexaFromSkin_3D::StdMeshers_HexaFromSkin_3D(), StdMeshers_Import_1D::StdMeshers_Import_1D(), StdMeshers_Import_1D2D::StdMeshers_Import_1D2D(), StdMeshers_ImportSource1D::StdMeshers_ImportSource1D(), StdMeshers_ImportSource2D::StdMeshers_ImportSource2D(), StdMeshers_LayerDistribution::StdMeshers_LayerDistribution(), StdMeshers_LayerDistribution2D::StdMeshers_LayerDistribution2D(), StdMeshers_LengthFromEdges::StdMeshers_LengthFromEdges(), StdMeshers_LocalLength::StdMeshers_LocalLength(), StdMeshers_MaxElementArea::StdMeshers_MaxElementArea(), StdMeshers_MaxElementVolume::StdMeshers_MaxElementVolume(), StdMeshers_MaxLength::StdMeshers_MaxLength(), StdMeshers_NotConformAllowed::StdMeshers_NotConformAllowed(), StdMeshers_NumberOfLayers::StdMeshers_NumberOfLayers(), StdMeshers_NumberOfLayers2D::StdMeshers_NumberOfLayers2D(), StdMeshers_NumberOfSegments::StdMeshers_NumberOfSegments(), StdMeshers_PolygonPerFace_2D::StdMeshers_PolygonPerFace_2D(), StdMeshers_PolyhedronPerSolid_3D::StdMeshers_PolyhedronPerSolid_3D(), StdMeshers_Prism_3D::StdMeshers_Prism_3D(), StdMeshers_Projection_1D::StdMeshers_Projection_1D(), StdMeshers_Projection_1D2D::StdMeshers_Projection_1D2D(), StdMeshers_Projection_2D::StdMeshers_Projection_2D(), StdMeshers_Projection_3D::StdMeshers_Projection_3D(), StdMeshers_ProjectionSource1D::StdMeshers_ProjectionSource1D(), StdMeshers_ProjectionSource2D::StdMeshers_ProjectionSource2D(), StdMeshers_ProjectionSource3D::StdMeshers_ProjectionSource3D(), StdMeshers_Propagation::StdMeshers_Propagation(), StdMeshers_PropagOfDistribution::StdMeshers_PropagOfDistribution(), StdMeshers_QuadFromMedialAxis_1D2D::StdMeshers_QuadFromMedialAxis_1D2D(), StdMeshers_Quadrangle_2D::StdMeshers_Quadrangle_2D(), StdMeshers_QuadrangleParams::StdMeshers_QuadrangleParams(), StdMeshers_QuadranglePreference::StdMeshers_QuadranglePreference(), StdMeshers_QuadraticMesh::StdMeshers_QuadraticMesh(), StdMeshers_RadialPrism_3D::StdMeshers_RadialPrism_3D(), StdMeshers_RadialQuadrangle_1D2D::StdMeshers_RadialQuadrangle_1D2D(), StdMeshers_Regular_1D::StdMeshers_Regular_1D(), StdMeshers_SegmentAroundVertex_0D::StdMeshers_SegmentAroundVertex_0D(), StdMeshers_SegmentLengthAroundVertex::StdMeshers_SegmentLengthAroundVertex(), StdMeshers_StartEndLength::StdMeshers_StartEndLength(), StdMeshers_UseExisting_1D::StdMeshers_UseExisting_1D(), StdMeshers_UseExisting_2D::StdMeshers_UseExisting_2D(), StdMeshers_ViscousLayerBuilder::StdMeshers_ViscousLayerBuilder(), StdMeshers_ViscousLayers(), and StdMeshers_ViscousLayers2D::StdMeshers_ViscousLayers2D().
◆ _nbLayers
int StdMeshers_ViscousLayers::_nbLayers
Referenced by LoadFrom(), SaveTo(), and SetNumberLayers().
◆ _param_algo_dim
Referenced by SMESH_Hypothesis::GetDim(), SMESH_Hypothesis::SMESH_Hypothesis(), StdMeshers_Adaptive1D::StdMeshers_Adaptive1D(), StdMeshers_Arithmetic1D::StdMeshers_Arithmetic1D(), StdMeshers_AutomaticLength::StdMeshers_AutomaticLength(), StdMeshers_BlockRenumber::StdMeshers_BlockRenumber(), StdMeshers_CartesianParameters3D::StdMeshers_CartesianParameters3D(), StdMeshers_Deflection1D::StdMeshers_Deflection1D(), StdMeshers_FixedPoints1D::StdMeshers_FixedPoints1D(), StdMeshers_ImportSource1D::StdMeshers_ImportSource1D(), StdMeshers_ImportSource2D::StdMeshers_ImportSource2D(), StdMeshers_LayerDistribution::StdMeshers_LayerDistribution(), StdMeshers_LayerDistribution2D::StdMeshers_LayerDistribution2D(), StdMeshers_LengthFromEdges::StdMeshers_LengthFromEdges(), StdMeshers_LocalLength::StdMeshers_LocalLength(), StdMeshers_MaxElementArea::StdMeshers_MaxElementArea(), StdMeshers_MaxElementVolume::StdMeshers_MaxElementVolume(), StdMeshers_MaxLength::StdMeshers_MaxLength(), StdMeshers_NotConformAllowed::StdMeshers_NotConformAllowed(), StdMeshers_NumberOfLayers::StdMeshers_NumberOfLayers(), StdMeshers_NumberOfLayers2D::StdMeshers_NumberOfLayers2D(), StdMeshers_NumberOfSegments::StdMeshers_NumberOfSegments(), StdMeshers_ProjectionSource1D::StdMeshers_ProjectionSource1D(), StdMeshers_ProjectionSource2D::StdMeshers_ProjectionSource2D(), StdMeshers_ProjectionSource3D::StdMeshers_ProjectionSource3D(), StdMeshers_Propagation::StdMeshers_Propagation(), StdMeshers_QuadrangleParams::StdMeshers_QuadrangleParams(), StdMeshers_QuadranglePreference::StdMeshers_QuadranglePreference(), StdMeshers_QuadraticMesh::StdMeshers_QuadraticMesh(), StdMeshers_Reversible1D::StdMeshers_Reversible1D(), StdMeshers_SegmentLengthAroundVertex::StdMeshers_SegmentLengthAroundVertex(), StdMeshers_StartEndLength::StdMeshers_StartEndLength(), StdMeshers_ViscousLayers(), and StdMeshers_ViscousLayers2D::StdMeshers_ViscousLayers2D().
◆ _shapeIds
std::vector<int> StdMeshers_ViscousLayers::_shapeIds
◆ _shapeType
◆ _stretchFactor
double StdMeshers_ViscousLayers::_stretchFactor
Referenced by LoadFrom(), SaveTo(), and SetStretchFactor().
◆ _thickness
double StdMeshers_ViscousLayers::_thickness
Referenced by LoadFrom(), SaveTo(), and SetTotalThickness().
◆ _type
