StdMeshers_ImportSource2D Class Reference
Redefines name and dimension of inherited StdMeshers_ImportSource1D. More...
#include <StdMeshers_ImportSource.hxx>
Inheritance diagram for StdMeshers_ImportSource2D:
enum  Hypothesis_Status {
enum  hypothesis_type {
  ALGO_3D
 StdMeshers_ImportSource2D (int hypId, SMESH_Gen *gen)
 Creates StdMeshers_ImportSource2D. More...
void SetGroups (const std::vector< SMESH_Group * > &groups)
 Sets groups to import elements from. More...
const std::vector< SMESH_Group * > & GetGroups (bool loaded=false) const
 Returns groups to import elements from. More...
void SetCopySourceMesh (bool toCopyMesh, bool toCopyGroups)
void GetCopySourceMesh (bool &toCopyMesh, bool &toCopyGroups) const
 Save _toCopyMesh and _toCopyGroups to a stream. More...
 Load _toCopyMesh and _toCopyGroups from a stream. More...
 Initialize ImportSource value by the mesh built on the geometry. More...
void RestoreGroups (const std::vector< SMESH_Group * > &groups)
 Restore source groups and result groups by _resultGroupsStorage. More...
void StoreResultGroups (const std::vector< SMESH_Group * > &groups, const SMESHDS_Mesh &srcMesh, const SMESHDS_Mesh &tgtMesh)
 Remember groups imported from other mesh. More...
std::vector< SMESH_Group * > * GetResultGroups (const SMESHDS_Mesh &srcMesh, const SMESHDS_Mesh &tgtMesh)
 Return groups imported from other mesh. More...
std::vector< SMESH_Mesh * > GetSourceMeshes () const
 Return source meshes. More...
std::vector< SMESH_subMesh * > GetSourceSubMeshes (const SMESH_Mesh *srcMesh) const
 Return submeshes whose events affect the target mesh. More...
virtual int GetDim () const
SMESH_Gen * GetGen () const
const char * GetName () const
int GetID () const
int GetType () const
 Equality. More...
SMESH_Gen * _gen
int _shapeType
int _param_algo_dim
int _hypId
hypothesis_type _type
Private Types
typedef std::map< std::pair< int, int >, std::vector< SMESH_Group * > > TResGroupMap
void resultGroupsToIntVec ()
 Convert result groups into _resultGroupsStorage. More...
std::vector< SMESH_Group * > _groups
bool _toCopyMesh
bool _toCopyGroups
TResGroupMap _resultGroups
std::vector< int > _resultGroupsStorage
std::string _libName
◆ TResGroupMap
typedef std::map< std::pair<int, int>, std::vector<SMESH_Group*> > StdMeshers_ImportSource1D::TResGroupMap
privateinherited
◆ Hypothesis_Status
HYP_OK
HYP_MISSING
HYP_CONCURRENT
HYP_BAD_PARAMETER
HYP_HIDDEN_ALGO
HYP_HIDING_ALGO
HYP_UNKNOWN_FATAL
HYP_INCOMPATIBLE
HYP_NOTCONFORM
HYP_ALREADY_EXIST
HYP_BAD_DIM
HYP_BAD_SUBSHAPE
HYP_BAD_GEOMETRY
HYP_NEED_SHAPE
HYP_INCOMPAT_HYPS
◆ hypothesis_type
PARAM_ALGO
ALGO_0D
ALGO_1D
ALGO_2D
ALGO_3D
◆ InitWay
BY_MESH
BY_GEOM
BY_AVERAGE_LENGTH
◆ StdMeshers_ImportSource2D()
StdMeshers_ImportSource2D::StdMeshers_ImportSource2D ( int  hypId,
SMESH_Gen *  gen
◆ DataDependOnParams()
virtual bool StdMeshers_ImportSource1D::DataDependOnParams ( ) const
Reimplemented from SMESH_Hypothesis.
◆ GetCopySourceMesh()
◆ GetDim()
◆ GetGen()
◆ GetGroups()
const std::vector< SMESH_Group * > & StdMeshers_ImportSource1D::GetGroups ( bool  loaded = false) const
◆ GetID()
◆ GetLibName()
◆ GetMeshByPersistentID()
◆ GetName()
◆ GetResultGroups()
std::vector< SMESH_Group * > * StdMeshers_ImportSource1D::GetResultGroups ( const SMESHDS_Mesh &  srcMesh,
const SMESHDS_Mesh &  tgtMesh
srcMesh- source mesh
tgtMesh- destination mesh
conststd::vector<SMESH_Group*>& - groups
References SMESH_Hypothesis::_gen, StdMeshers_ImportSource1D::_resultGroups, and SMESH_Gen::GetStudyContext().
◆ GetShapeType()
◆ GetSourceMeshes()
◆ GetSourceSubMeshes()
◆ GetType()
◆ IsAuxiliary()
bool- auxiliary or not
◆ IsSameName()
◆ IsStatusFatal()
◆ LoadFrom()
istream & StdMeshers_ImportSource1D::LoadFrom ( std::istream &  load)
◆ LoadStringFromStream()
std::string &  txt
Referenced by SMESH_Hypothesis_i::LoadFrom(), StdMeshers_CartesianParameters3D::SetAxisDirs(), StdMeshers_BlockRenumber::SetBlocksOrientation(), StdMeshers_ViscousLayers::SetBndShapes(), StdMeshers_Geometric1D::SetCommonRatio(), StdMeshers_ImportSource1D::SetCopySourceMesh(), StdMeshers_Adaptive1D::SetDeflection(), StdMeshers_Deflection1D::SetDeflection(), StdMeshers_QuadrangleParams::SetEnforcedNodes(), StdMeshers_AutomaticLength::SetFineness(), StdMeshers_CartesianParameters3D::SetFixedPoint(), StdMeshers_CartesianParameters3D::SetGrid(), StdMeshers_CartesianParameters3D::SetGridSpacing(), StdMeshers_ViscousLayers::SetGroupName(), StdMeshers_ImportSource1D::SetGroups(), StdMeshers_LayerDistribution::SetLayerDistribution(), StdMeshers_LocalLength::SetLength(), StdMeshers_MaxLength::SetLength(), StdMeshers_SegmentLengthAroundVertex::SetLength(), StdMeshers_Arithmetic1D::SetLength(), StdMeshers_StartEndLength::SetLength(), StdMeshers_MaxElementArea::SetMaxArea(), StdMeshers_Adaptive1D::SetMaxSize(), StdMeshers_MaxElementVolume::SetMaxVolume(), StdMeshers_ViscousLayers::SetMethod(), StdMeshers_Adaptive1D::SetMinSize(), StdMeshers_LengthFromEdges::SetMode(), StdMeshers_FixedPoints1D::SetNbSegments(), StdMeshers_ViscousLayers::SetNumberLayers(), StdMeshers_NumberOfLayers::SetNumberOfLayers(), StdMeshers_FixedPoints1D::SetPoints(), StdMeshers_LocalLength::SetPrecision(), StdMeshers_QuadrangleParams::SetQuadType(), StdMeshers_CartesianParameters3D::SetQuanta(), StdMeshers_Reversible1D::SetReversedEdges(), StdMeshers_CartesianParameters3D::SetSizeThreshold(), StdMeshers_ProjectionSource3D::SetSource3DShape(), StdMeshers_ProjectionSource1D::SetSourceEdge(), StdMeshers_ProjectionSource2D::SetSourceFace(), StdMeshers_ProjectionSource1D::SetSourceMesh(), StdMeshers_ProjectionSource2D::SetSourceMesh(), StdMeshers_ProjectionSource3D::SetSourceMesh(), StdMeshers_Geometric1D::SetStartLength(), StdMeshers_ViscousLayers::SetStretchFactor(), StdMeshers_CartesianParameters3D::SetToAddEdges(), StdMeshers_CartesianParameters3D::SetToConsiderInternalFaces(), StdMeshers_CartesianParameters3D::SetToCreateFaces(), StdMeshers_ViscousLayers::SetTotalThickness(), StdMeshers_CartesianParameters3D::SetToUseQuanta(), StdMeshers_CartesianParameters3D::SetToUseThresholdForInternalFaces(), StdMeshers_QuadrangleParams::SetTriaVertex(), StdMeshers_ProjectionSource1D::SetVertexAssociation(), StdMeshers_ProjectionSource2D::SetVertexAssociation(), and StdMeshers_ProjectionSource3D::SetVertexAssociation().
◆ operator!=()
◆ operator==()
Equality.
◆ RestoreGroups()
◆ resultGroupsToIntVec()
void StdMeshers_ImportSource1D::resultGroupsToIntVec ( )
privateinherited
References StdMeshers_ImportSource1D::_resultGroups, and StdMeshers_ImportSource1D::_resultGroupsStorage.
Referenced by StdMeshers_ImportSource1D::SaveTo().
◆ SaveStringToStream()
const std::string &  txt
◆ SaveTo()
ostream & StdMeshers_ImportSource1D::SaveTo ( std::ostream &  save)
◆ SetCopySourceMesh()
◆ SetGroups()
void StdMeshers_ImportSource1D::SetGroups ( const std::vector< SMESH_Group * > &  groups)
◆ SetLibName()
◆ SetParametersByDefaults()
bool StdMeshers_ImportSource1D::SetParametersByDefaults ( const TDefaults &  dflts,
Implements SMESH_Hypothesis.
◆ SetParametersByMesh()
bool StdMeshers_ImportSource1D::SetParametersByMesh ( const SMESH_Mesh *  theMesh,
theMesh- the built mesh
◆ StoreResultGroups()
void StdMeshers_ImportSource1D::StoreResultGroups ( const std::vector< SMESH_Group * > &  groups,
groups- result groups
References StdMeshers_ImportSource1D::_resultGroups.
Referenced by StdMeshers_Import_1D::importMesh().
◆ _gen
◆ _groups
◆ _hypId
◆ _libName
privateinherited
◆ _name
Referenced by SMESHDS_Hypothesis::GetName(), SMESHDS_Hypothesis::IsSameName(), SMESHDS_Hypothesis::operator==(), SMESHDS_Hypothesis::SMESHDS_Hypothesis(), StdMeshers_Adaptive1D::StdMeshers_Adaptive1D(), StdMeshers_Arithmetic1D::StdMeshers_Arithmetic1D(), StdMeshers_AutomaticLength::StdMeshers_AutomaticLength(), StdMeshers_BlockRenumber::StdMeshers_BlockRenumber(), StdMeshers_Cartesian_3D::StdMeshers_Cartesian_3D(), StdMeshers_CartesianParameters3D::StdMeshers_CartesianParameters3D(), StdMeshers_CompositeHexa_3D::StdMeshers_CompositeHexa_3D(), StdMeshers_CompositeSegment_1D::StdMeshers_CompositeSegment_1D(), StdMeshers_Deflection1D::StdMeshers_Deflection1D(), StdMeshers_FixedPoints1D::StdMeshers_FixedPoints1D(), StdMeshers_Geometric1D::StdMeshers_Geometric1D(), StdMeshers_Hexa_3D::StdMeshers_Hexa_3D(), StdMeshers_HexaFromSkin_3D::StdMeshers_HexaFromSkin_3D(), StdMeshers_Import_1D::StdMeshers_Import_1D(), StdMeshers_Import_1D2D::StdMeshers_Import_1D2D(), StdMeshers_ImportSource1D::StdMeshers_ImportSource1D(), StdMeshers_ImportSource2D(), StdMeshers_LayerDistribution::StdMeshers_LayerDistribution(), StdMeshers_LayerDistribution2D::StdMeshers_LayerDistribution2D(), StdMeshers_LengthFromEdges::StdMeshers_LengthFromEdges(), StdMeshers_LocalLength::StdMeshers_LocalLength(), StdMeshers_MaxElementArea::StdMeshers_MaxElementArea(), StdMeshers_MaxElementVolume::StdMeshers_MaxElementVolume(), StdMeshers_MaxLength::StdMeshers_MaxLength(), StdMeshers_NotConformAllowed::StdMeshers_NotConformAllowed(), StdMeshers_NumberOfLayers::StdMeshers_NumberOfLayers(), StdMeshers_NumberOfLayers2D::StdMeshers_NumberOfLayers2D(), StdMeshers_NumberOfSegments::StdMeshers_NumberOfSegments(), StdMeshers_PolygonPerFace_2D::StdMeshers_PolygonPerFace_2D(), StdMeshers_PolyhedronPerSolid_3D::StdMeshers_PolyhedronPerSolid_3D(), StdMeshers_Prism_3D::StdMeshers_Prism_3D(), StdMeshers_Projection_1D::StdMeshers_Projection_1D(), StdMeshers_Projection_1D2D::StdMeshers_Projection_1D2D(), StdMeshers_Projection_2D::StdMeshers_Projection_2D(), StdMeshers_Projection_3D::StdMeshers_Projection_3D(), StdMeshers_ProjectionSource1D::StdMeshers_ProjectionSource1D(), StdMeshers_ProjectionSource2D::StdMeshers_ProjectionSource2D(), StdMeshers_ProjectionSource3D::StdMeshers_ProjectionSource3D(), StdMeshers_Propagation::StdMeshers_Propagation(), StdMeshers_PropagOfDistribution::StdMeshers_PropagOfDistribution(), StdMeshers_QuadFromMedialAxis_1D2D::StdMeshers_QuadFromMedialAxis_1D2D(), StdMeshers_Quadrangle_2D::StdMeshers_Quadrangle_2D(), StdMeshers_QuadrangleParams::StdMeshers_QuadrangleParams(), StdMeshers_QuadranglePreference::StdMeshers_QuadranglePreference(), StdMeshers_QuadraticMesh::StdMeshers_QuadraticMesh(), StdMeshers_RadialPrism_3D::StdMeshers_RadialPrism_3D(), StdMeshers_RadialQuadrangle_1D2D::StdMeshers_RadialQuadrangle_1D2D(), StdMeshers_Regular_1D::StdMeshers_Regular_1D(), StdMeshers_SegmentAroundVertex_0D::StdMeshers_SegmentAroundVertex_0D(), StdMeshers_SegmentLengthAroundVertex::StdMeshers_SegmentLengthAroundVertex(), StdMeshers_StartEndLength::StdMeshers_StartEndLength(), StdMeshers_UseExisting_1D::StdMeshers_UseExisting_1D(), StdMeshers_UseExisting_2D::StdMeshers_UseExisting_2D(), StdMeshers_ViscousLayerBuilder::StdMeshers_ViscousLayerBuilder(), StdMeshers_ViscousLayers::StdMeshers_ViscousLayers(), and StdMeshers_ViscousLayers2D::StdMeshers_ViscousLayers2D().
◆ _param_algo_dim
Referenced by SMESH_Hypothesis::GetDim(), SMESH_Hypothesis::SMESH_Hypothesis(), StdMeshers_Adaptive1D::StdMeshers_Adaptive1D(), StdMeshers_Arithmetic1D::StdMeshers_Arithmetic1D(), StdMeshers_AutomaticLength::StdMeshers_AutomaticLength(), StdMeshers_BlockRenumber::StdMeshers_BlockRenumber(), StdMeshers_CartesianParameters3D::StdMeshers_CartesianParameters3D(), StdMeshers_Deflection1D::StdMeshers_Deflection1D(), StdMeshers_FixedPoints1D::StdMeshers_FixedPoints1D(), StdMeshers_ImportSource1D::StdMeshers_ImportSource1D(), StdMeshers_ImportSource2D(), StdMeshers_LayerDistribution::StdMeshers_LayerDistribution(), StdMeshers_LayerDistribution2D::StdMeshers_LayerDistribution2D(), StdMeshers_LengthFromEdges::StdMeshers_LengthFromEdges(), StdMeshers_LocalLength::StdMeshers_LocalLength(), StdMeshers_MaxElementArea::StdMeshers_MaxElementArea(), StdMeshers_MaxElementVolume::StdMeshers_MaxElementVolume(), StdMeshers_MaxLength::StdMeshers_MaxLength(), StdMeshers_NotConformAllowed::StdMeshers_NotConformAllowed(), StdMeshers_NumberOfLayers::StdMeshers_NumberOfLayers(), StdMeshers_NumberOfLayers2D::StdMeshers_NumberOfLayers2D(), StdMeshers_NumberOfSegments::StdMeshers_NumberOfSegments(), StdMeshers_ProjectionSource1D::StdMeshers_ProjectionSource1D(), StdMeshers_ProjectionSource2D::StdMeshers_ProjectionSource2D(), StdMeshers_ProjectionSource3D::StdMeshers_ProjectionSource3D(), StdMeshers_Propagation::StdMeshers_Propagation(), StdMeshers_QuadrangleParams::StdMeshers_QuadrangleParams(), StdMeshers_QuadranglePreference::StdMeshers_QuadranglePreference(), StdMeshers_QuadraticMesh::StdMeshers_QuadraticMesh(), StdMeshers_Reversible1D::StdMeshers_Reversible1D(), StdMeshers_SegmentLengthAroundVertex::StdMeshers_SegmentLengthAroundVertex(), StdMeshers_StartEndLength::StdMeshers_StartEndLength(), StdMeshers_ViscousLayers::StdMeshers_ViscousLayers(), and StdMeshers_ViscousLayers2D::StdMeshers_ViscousLayers2D().
◆ _resultGroups
◆ _resultGroupsStorage
std::vector<int> StdMeshers_ImportSource1D::_resultGroupsStorage
privateinherited
◆ _shapeType
◆ _toCopyGroups
◆ _toCopyMesh
◆ _type
