StdMeshers_ViscousLayers2D Class Reference
Hypothesis defining parameters of viscous layers. More...
#include <StdMeshers_ViscousLayers2D.hxx>
Inheritance diagram for StdMeshers_ViscousLayers2D:
enum  ExtrusionMethod { SURF_OFFSET_SMOOTH , FACE_OFFSET , NODE_OFFSET }
enum  Hypothesis_Status {
enum  hypothesis_type {
  ALGO_3D
 StdMeshers_ViscousLayers2D (int hypId, SMESH_Gen *gen)
void RestoreListeners () const
 At study restoration, restore event listeners used to clear an inferior dim sub-mesh modified by viscous layers. More...
 Initialize my parameter values by the mesh built on the geometry. More...
virtual bool SetParametersByDefaults (const TDefaults &, const SMESH_Mesh *=0)
void SetBndShapes (const std::vector< int > &shapeIds, bool toIgnore)
std::vector< int > GetBndShapes () const
bool IsToIgnoreShapes () const
void SetTotalThickness (double thickness)
double GetTotalThickness () const
void SetNumberLayers (int nb)
int GetNumberLayers () const
void SetStretchFactor (double factor)
double GetStretchFactor () const
void SetMethod (ExtrusionMethod how)
ExtrusionMethod GetMethod () const
void SetGroupName (const std::string &name)
const std::string & GetGroupName () const
SMESH_ProxyMesh::Ptr Compute (SMESH_Mesh &theMesh, const TopoDS_Shape &theShape, const bool toMakeN2NMap=false) const
bool IsShapeWithLayers (int shapeIndex) const
virtual int GetDim () const
SMESH_Gen * GetGen () const
const char * GetName () const
int GetID () const
int GetType () const
 Equality. More...
static SMESH_ProxyMesh::Ptr Compute (SMESH_Mesh &theMesh, const TopoDS_Face &theShape)
 Computes temporary 2D mesh to be used by 2D algorithm. More...
static SMESH_ComputeErrorPtr CheckHypothesis (SMESH_Mesh &aMesh, const TopoDS_Shape &aShape, Hypothesis_Status &aStatus)
 Checks compatibility of assigned StdMeshers_ViscousLayers2D hypotheses. More...
static const char * GetHypType ()
static void SetProxyMeshOfEdge (const StdMeshers_FaceSide &edgeNodes)
static bool HasProxyMesh (const TopoDS_Face &face, SMESH_Mesh &theMesh)
static SMDS_MeshGroup * CreateGroup (const std::string &theName, SMESH_Mesh &theMesh, SMDSAbs_ElementType theType)
static double Get1stLayerThickness (double thickTotal, double factor, int nbLayers)
SMESH_Gen * _gen
int _shapeType
int _param_algo_dim
int _hypId
hypothesis_type _type
std::vector< int > _shapeIds
bool _isToIgnoreShapes
int _nbLayers
double _thickness
double _stretchFactor
ExtrusionMethod _method
std::string _groupName
std::string _libName
◆ ExtrusionMethod
SURF_OFFSET_SMOOTH
FACE_OFFSET
NODE_OFFSET
◆ Hypothesis_Status
HYP_OK
HYP_MISSING
HYP_CONCURRENT
HYP_BAD_PARAMETER
HYP_HIDDEN_ALGO
HYP_HIDING_ALGO
HYP_UNKNOWN_FATAL
HYP_INCOMPATIBLE
HYP_NOTCONFORM
HYP_ALREADY_EXIST
HYP_BAD_DIM
HYP_BAD_SUBSHAPE
HYP_BAD_GEOMETRY
HYP_NEED_SHAPE
HYP_INCOMPAT_HYPS
◆ hypothesis_type
PARAM_ALGO
ALGO_0D
ALGO_1D
ALGO_2D
ALGO_3D
◆ InitWay
BY_MESH
BY_GEOM
BY_AVERAGE_LENGTH
◆ StdMeshers_ViscousLayers2D()
StdMeshers_ViscousLayers2D::StdMeshers_ViscousLayers2D ( int  hypId,
SMESH_Gen *  gen
◆ CheckHypothesis()
◆ Compute() [1/2]
SMESH_ProxyMesh::Ptr StdMeshers_ViscousLayers2D::Compute ( SMESH_Mesh &  theMesh,
const TopoDS_Face &  theShape
◆ Compute() [2/2]
◆ CreateGroup()
SMDS_MeshGroup * StdMeshers_ViscousLayers::CreateGroup ( const std::string &  theName,
◆ DataDependOnParams()
◆ Get1stLayerThickness()
double StdMeshers_ViscousLayers::Get1stLayerThickness ( double  thickTotal,
double  factor,
int  nbLayers
◆ GetBndShapes()
◆ GetDim()
◆ GetGen()
◆ GetGroupName()
const std::string & StdMeshers_ViscousLayers::GetGroupName ( ) const
◆ GetHypType()
static const char * StdMeshers_ViscousLayers2D::GetHypType ( )
◆ GetID()
◆ GetLibName()
◆ GetMeshByPersistentID()
◆ GetMethod()
ExtrusionMethod StdMeshers_ViscousLayers::GetMethod ( ) const
◆ GetName()
◆ GetNumberLayers()
◆ GetShapeType()
◆ GetStretchFactor()
◆ GetTotalThickness()
double StdMeshers_ViscousLayers::GetTotalThickness ( ) const
◆ GetType()
◆ HasProxyMesh()
bool StdMeshers_ViscousLayers2D::HasProxyMesh ( const TopoDS_Face &  face,
◆ IsAuxiliary()
bool- auxiliary or not
◆ IsSameName()
◆ IsShapeWithLayers()
bool StdMeshers_ViscousLayers::IsShapeWithLayers ( int  shapeIndex) const
◆ IsStatusFatal()
◆ IsToIgnoreShapes()
◆ LoadFrom()
◆ LoadStringFromStream()
std::string &  txt
Referenced by SMESH_Hypothesis_i::LoadFrom(), StdMeshers_CartesianParameters3D::SetAxisDirs(), StdMeshers_BlockRenumber::SetBlocksOrientation(), StdMeshers_ViscousLayers::SetBndShapes(), StdMeshers_Geometric1D::SetCommonRatio(), StdMeshers_ImportSource1D::SetCopySourceMesh(), StdMeshers_Adaptive1D::SetDeflection(), StdMeshers_Deflection1D::SetDeflection(), StdMeshers_QuadrangleParams::SetEnforcedNodes(), StdMeshers_AutomaticLength::SetFineness(), StdMeshers_CartesianParameters3D::SetFixedPoint(), StdMeshers_CartesianParameters3D::SetGrid(), StdMeshers_CartesianParameters3D::SetGridSpacing(), StdMeshers_ViscousLayers::SetGroupName(), StdMeshers_ImportSource1D::SetGroups(), StdMeshers_LayerDistribution::SetLayerDistribution(), StdMeshers_LocalLength::SetLength(), StdMeshers_MaxLength::SetLength(), StdMeshers_SegmentLengthAroundVertex::SetLength(), StdMeshers_Arithmetic1D::SetLength(), StdMeshers_StartEndLength::SetLength(), StdMeshers_MaxElementArea::SetMaxArea(), StdMeshers_Adaptive1D::SetMaxSize(), StdMeshers_MaxElementVolume::SetMaxVolume(), StdMeshers_ViscousLayers::SetMethod(), StdMeshers_Adaptive1D::SetMinSize(), StdMeshers_LengthFromEdges::SetMode(), StdMeshers_FixedPoints1D::SetNbSegments(), StdMeshers_ViscousLayers::SetNumberLayers(), StdMeshers_NumberOfLayers::SetNumberOfLayers(), StdMeshers_FixedPoints1D::SetPoints(), StdMeshers_LocalLength::SetPrecision(), StdMeshers_QuadrangleParams::SetQuadType(), StdMeshers_CartesianParameters3D::SetQuanta(), StdMeshers_Reversible1D::SetReversedEdges(), StdMeshers_CartesianParameters3D::SetSizeThreshold(), StdMeshers_ProjectionSource3D::SetSource3DShape(), StdMeshers_ProjectionSource1D::SetSourceEdge(), StdMeshers_ProjectionSource2D::SetSourceFace(), StdMeshers_ProjectionSource1D::SetSourceMesh(), StdMeshers_ProjectionSource2D::SetSourceMesh(), StdMeshers_ProjectionSource3D::SetSourceMesh(), StdMeshers_Geometric1D::SetStartLength(), StdMeshers_ViscousLayers::SetStretchFactor(), StdMeshers_CartesianParameters3D::SetToAddEdges(), StdMeshers_CartesianParameters3D::SetToConsiderInternalFaces(), StdMeshers_CartesianParameters3D::SetToCreateFaces(), StdMeshers_ViscousLayers::SetTotalThickness(), StdMeshers_CartesianParameters3D::SetToUseQuanta(), StdMeshers_CartesianParameters3D::SetToUseThresholdForInternalFaces(), StdMeshers_QuadrangleParams::SetTriaVertex(), StdMeshers_ProjectionSource1D::SetVertexAssociation(), StdMeshers_ProjectionSource2D::SetVertexAssociation(), and StdMeshers_ProjectionSource3D::SetVertexAssociation().
◆ operator!=()
◆ operator==()
Equality.
◆ RestoreListeners()
void StdMeshers_ViscousLayers2D::RestoreListeners ( ) const
◆ SaveStringToStream()
const std::string &  txt
◆ SaveTo()
◆ SetBndShapes()
◆ SetGroupName()
◆ SetLibName()
◆ SetMethod()
◆ SetNumberLayers()
◆ SetParametersByDefaults()
virtual bool StdMeshers_ViscousLayers2D::SetParametersByDefaults ( const TDefaults &  ,
const SMESH_Mesh *  = 0
Reimplemented from StdMeshers_ViscousLayers.
◆ SetParametersByMesh()
bool StdMeshers_ViscousLayers2D::SetParametersByMesh ( const SMESH_Mesh *  theMesh,
theMesh- the built mesh
Just return false as this hypothesis does not have parameters values
◆ SetProxyMeshOfEdge()
◆ SetStretchFactor()
◆ SetTotalThickness()
◆ _gen
◆ _groupName
std::string StdMeshers_ViscousLayers::_groupName
privateinherited
◆ _hypId
◆ _isToIgnoreShapes
bool StdMeshers_ViscousLayers::_isToIgnoreShapes
privateinherited
◆ _libName
privateinherited
◆ _method
◆ _name
Referenced by SMESHDS_Hypothesis::GetName(), SMESHDS_Hypothesis::IsSameName(), SMESHDS_Hypothesis::operator==(), SMESHDS_Hypothesis::SMESHDS_Hypothesis(), StdMeshers_Adaptive1D::StdMeshers_Adaptive1D(), StdMeshers_Arithmetic1D::StdMeshers_Arithmetic1D(), StdMeshers_AutomaticLength::StdMeshers_AutomaticLength(), StdMeshers_BlockRenumber::StdMeshers_BlockRenumber(), StdMeshers_Cartesian_3D::StdMeshers_Cartesian_3D(), StdMeshers_CartesianParameters3D::StdMeshers_CartesianParameters3D(), StdMeshers_CompositeHexa_3D::StdMeshers_CompositeHexa_3D(), StdMeshers_CompositeSegment_1D::StdMeshers_CompositeSegment_1D(), StdMeshers_Deflection1D::StdMeshers_Deflection1D(), StdMeshers_FixedPoints1D::StdMeshers_FixedPoints1D(), StdMeshers_Geometric1D::StdMeshers_Geometric1D(), StdMeshers_Hexa_3D::StdMeshers_Hexa_3D(), StdMeshers_HexaFromSkin_3D::StdMeshers_HexaFromSkin_3D(), StdMeshers_Import_1D::StdMeshers_Import_1D(), StdMeshers_Import_1D2D::StdMeshers_Import_1D2D(), StdMeshers_ImportSource1D::StdMeshers_ImportSource1D(), StdMeshers_ImportSource2D::StdMeshers_ImportSource2D(), StdMeshers_LayerDistribution::StdMeshers_LayerDistribution(), StdMeshers_LayerDistribution2D::StdMeshers_LayerDistribution2D(), StdMeshers_LengthFromEdges::StdMeshers_LengthFromEdges(), StdMeshers_LocalLength::StdMeshers_LocalLength(), StdMeshers_MaxElementArea::StdMeshers_MaxElementArea(), StdMeshers_MaxElementVolume::StdMeshers_MaxElementVolume(), StdMeshers_MaxLength::StdMeshers_MaxLength(), StdMeshers_NotConformAllowed::StdMeshers_NotConformAllowed(), StdMeshers_NumberOfLayers::StdMeshers_NumberOfLayers(), StdMeshers_NumberOfLayers2D::StdMeshers_NumberOfLayers2D(), StdMeshers_NumberOfSegments::StdMeshers_NumberOfSegments(), StdMeshers_PolygonPerFace_2D::StdMeshers_PolygonPerFace_2D(), StdMeshers_PolyhedronPerSolid_3D::StdMeshers_PolyhedronPerSolid_3D(), StdMeshers_Prism_3D::StdMeshers_Prism_3D(), StdMeshers_Projection_1D::StdMeshers_Projection_1D(), StdMeshers_Projection_1D2D::StdMeshers_Projection_1D2D(), StdMeshers_Projection_2D::StdMeshers_Projection_2D(), StdMeshers_Projection_3D::StdMeshers_Projection_3D(), StdMeshers_ProjectionSource1D::StdMeshers_ProjectionSource1D(), StdMeshers_ProjectionSource2D::StdMeshers_ProjectionSource2D(), StdMeshers_ProjectionSource3D::StdMeshers_ProjectionSource3D(), StdMeshers_Propagation::StdMeshers_Propagation(), StdMeshers_PropagOfDistribution::StdMeshers_PropagOfDistribution(), StdMeshers_QuadFromMedialAxis_1D2D::StdMeshers_QuadFromMedialAxis_1D2D(), StdMeshers_Quadrangle_2D::StdMeshers_Quadrangle_2D(), StdMeshers_QuadrangleParams::StdMeshers_QuadrangleParams(), StdMeshers_QuadranglePreference::StdMeshers_QuadranglePreference(), StdMeshers_QuadraticMesh::StdMeshers_QuadraticMesh(), StdMeshers_RadialPrism_3D::StdMeshers_RadialPrism_3D(), StdMeshers_RadialQuadrangle_1D2D::StdMeshers_RadialQuadrangle_1D2D(), StdMeshers_Regular_1D::StdMeshers_Regular_1D(), StdMeshers_SegmentAroundVertex_0D::StdMeshers_SegmentAroundVertex_0D(), StdMeshers_SegmentLengthAroundVertex::StdMeshers_SegmentLengthAroundVertex(), StdMeshers_StartEndLength::StdMeshers_StartEndLength(), StdMeshers_UseExisting_1D::StdMeshers_UseExisting_1D(), StdMeshers_UseExisting_2D::StdMeshers_UseExisting_2D(), StdMeshers_ViscousLayerBuilder::StdMeshers_ViscousLayerBuilder(), StdMeshers_ViscousLayers::StdMeshers_ViscousLayers(), and StdMeshers_ViscousLayers2D().
◆ _nbLayers
int StdMeshers_ViscousLayers::_nbLayers
privateinherited
◆ _param_algo_dim
Referenced by SMESH_Hypothesis::GetDim(), SMESH_Hypothesis::SMESH_Hypothesis(), StdMeshers_Adaptive1D::StdMeshers_Adaptive1D(), StdMeshers_Arithmetic1D::StdMeshers_Arithmetic1D(), StdMeshers_AutomaticLength::StdMeshers_AutomaticLength(), StdMeshers_BlockRenumber::StdMeshers_BlockRenumber(), StdMeshers_CartesianParameters3D::StdMeshers_CartesianParameters3D(), StdMeshers_Deflection1D::StdMeshers_Deflection1D(), StdMeshers_FixedPoints1D::StdMeshers_FixedPoints1D(), StdMeshers_ImportSource1D::StdMeshers_ImportSource1D(), StdMeshers_ImportSource2D::StdMeshers_ImportSource2D(), StdMeshers_LayerDistribution::StdMeshers_LayerDistribution(), StdMeshers_LayerDistribution2D::StdMeshers_LayerDistribution2D(), StdMeshers_LengthFromEdges::StdMeshers_LengthFromEdges(), StdMeshers_LocalLength::StdMeshers_LocalLength(), StdMeshers_MaxElementArea::StdMeshers_MaxElementArea(), StdMeshers_MaxElementVolume::StdMeshers_MaxElementVolume(), StdMeshers_MaxLength::StdMeshers_MaxLength(), StdMeshers_NotConformAllowed::StdMeshers_NotConformAllowed(), StdMeshers_NumberOfLayers::StdMeshers_NumberOfLayers(), StdMeshers_NumberOfLayers2D::StdMeshers_NumberOfLayers2D(), StdMeshers_NumberOfSegments::StdMeshers_NumberOfSegments(), StdMeshers_ProjectionSource1D::StdMeshers_ProjectionSource1D(), StdMeshers_ProjectionSource2D::StdMeshers_ProjectionSource2D(), StdMeshers_ProjectionSource3D::StdMeshers_ProjectionSource3D(), StdMeshers_Propagation::StdMeshers_Propagation(), StdMeshers_QuadrangleParams::StdMeshers_QuadrangleParams(), StdMeshers_QuadranglePreference::StdMeshers_QuadranglePreference(), StdMeshers_QuadraticMesh::StdMeshers_QuadraticMesh(), StdMeshers_Reversible1D::StdMeshers_Reversible1D(), StdMeshers_SegmentLengthAroundVertex::StdMeshers_SegmentLengthAroundVertex(), StdMeshers_StartEndLength::StdMeshers_StartEndLength(), StdMeshers_ViscousLayers::StdMeshers_ViscousLayers(), and StdMeshers_ViscousLayers2D().
◆ _shapeIds
◆ _shapeType
◆ _stretchFactor
double StdMeshers_ViscousLayers::_stretchFactor
privateinherited
◆ _thickness
double StdMeshers_ViscousLayers::_thickness
privateinherited
◆ _type
