VISCOUS_2D::_ProxyMeshOfFace::_EdgeSubMesh Struct Reference
Inheritance diagram for VISCOUS_2D::_ProxyMeshOfFace::_EdgeSubMesh:
 _EdgeSubMesh (const SMDS_Mesh *mesh, int index=0)
virtual smIdType NbNodes () const
 Return number of nodes in a proxy sub-mesh. More...
void SetUVPtStructVec (UVPtStructVec &vec)
UVPtStructVec & GetUVPtStructVec ()
const TN2NMap * GetNodeNodeMap () const
const SMDS_MeshNode * GetProxyNode (const SMDS_MeshNode *n) const
 Return a proxy node or an input node. More...
const UVPtStructVec & GetUVPtStructVec () const
virtual void AddElement (const SMDS_MeshElement *e)
 Store an element. More...
virtual smIdType NbElements () const
 Return number of elements in a proxy sub-mesh. More...
virtual SMDS_ElemIteratorPtr GetElements () const
 Return elements of a proxy sub-mesh. More...
virtual SMDS_NodeIteratorPtr GetNodes () const
 Return nodes of a proxy sub-mesh. More...
virtual void Clear ()
 Deletes temporary elements. More...
virtual bool Contains (const SMDS_MeshElement *ME) const
 Check presence of element inside it-self. More...
template<class ITERATOR >
void ChangeElements (ITERATOR it, ITERATOR end)
virtual bool IsComplexSubmesh () const
virtual bool RemoveElement (const SMDS_MeshElement *ME)
virtual void AddNode (const SMDS_MeshNode *ME)
virtual bool RemoveNode (const SMDS_MeshNode *ME)
void AddSubMesh (const SMESHDS_SubMesh *theSubMesh)
bool RemoveSubMesh (const SMESHDS_SubMesh *theSubMesh)
void RemoveAllSubmeshes ()
bool ContainsSubMesh (const SMESHDS_SubMesh *theSubMesh) const
size_t NbSubMeshes () const
SMESHDS_SubMeshIteratorPtr GetSubMeshIterator () const
virtual bool IsQuadratic () const
SMESHDS_Mesh * GetParent () const
int GetID () const
virtual SMDS_ElemIteratorPtr getElements ()
 < the descendant object return its elements just before the mesh compacting More...
virtual void tmpClear ()
 the descendant object re-add its elements after the mesh compacting More...
virtual void add (const SMDS_MeshElement *)
 the descendant squeeze its element storage after re-adding elements More...
virtual void compact ()
 allow the descendant treat its elements before mesh clearing More...
virtual void clear ()
std::vector< const SMDS_MeshElement * > _elements
TN2NMap * _n2n
UVPtStructVec _uvPtStructVec
SMDS_Mesh * myMesh
void beforeCompacting ()
 store vtkIDs of elements More...
void restoreElements (const std::vector< smIdType > &idNodessOldToNew, const std::vector< smIdType > &idCellsOldToNew)
 restore pointers to elements More...
int myIndex
smIdType myNbElements
smIdType myNbNodes
const SMDS_MeshElement * my1stElemNode [2]
const SMESHDS_Mesh * myParent
TSubMeshSet mySubMeshes
std::vector< const SMDS_MeshElement * > myExternalElems
 elements not contained in the mesh More...
std::vector< vtkIdType > myVtkIDs
 vtk IDs of elements More...
std::vector< bool > myIsNode
std::set< SMDS_ElementHolder * >::iterator myPtrInMesh
◆ _EdgeSubMesh()
VISCOUS_2D::_ProxyMeshOfFace::_EdgeSubMesh::_EdgeSubMesh ( const SMDS_Mesh *  mesh,
int  index = 0
◆ add()
virtual void SMESH_ProxyMesh::SubMesh::add ( const SMDS_MeshElement *  element)
Reimplemented from SMESHDS_SubMesh.
◆ AddElement()
void SMESH_ProxyMesh::SubMesh::AddElement ( const SMDS_MeshElement *  e)
◆ AddNode()
◆ AddSubMesh()
void SMESHDS_SubMesh::AddSubMesh ( const SMESHDS_SubMesh *  theSubMesh)
◆ beforeCompacting()
◆ ChangeElements()
void SMESH_ProxyMesh::SubMesh::ChangeElements ( ITERATOR  it,
ITERATOR  end
References end().
Referenced by StdMeshers_QuadToTriaAdaptor::Compute().
◆ Clear()
void SMESH_ProxyMesh::SubMesh::Clear ( )
◆ clear()
virtual void SMESH_ProxyMesh::SubMesh::clear ( )
Reimplemented from SMDS_ElementHolder.
◆ compact()
virtual void SMESH_ProxyMesh::SubMesh::compact ( )
◆ Contains()
bool SMESH_ProxyMesh::SubMesh::Contains ( const SMDS_MeshElement *  ME) const
References SMDS_MeshElement::GetType(), and SMDSAbs_Node.
◆ ContainsSubMesh()
bool SMESHDS_SubMesh::ContainsSubMesh ( const SMESHDS_SubMesh *  theSubMesh) const
◆ getElements()
virtual SMDS_ElemIteratorPtr SMESH_ProxyMesh::SubMesh::getElements ( )
the descendant object temporary remove its elements
◆ GetElements()
SMDS_ElemIteratorPtr SMESH_ProxyMesh::SubMesh::GetElements ( ) const
The method is meaningful for a sub-mesh containing tmp faces.
Referenced by VISCOUS_3D::_ViscousBuilder::MakeN2NMap(), and VISCOUS_3D::_ViscousBuilder::shrink().
◆ GetID()
◆ GetNodeNodeMap()
const TN2NMap * SMESH_ProxyMesh::SubMesh::GetNodeNodeMap ( ) const
◆ GetNodes()
SMDS_NodeIteratorPtr SMESH_ProxyMesh::SubMesh::GetNodes ( ) const
The method is meaningful for a sub-mesh containing nodes of 2D viscous layer.
◆ GetParent()
SMESHDS_Mesh * SMESHDS_SubMesh::GetParent ( ) const
◆ GetProxyNode()
const SMDS_MeshNode * SMESH_ProxyMesh::SubMesh::GetProxyNode ( const SMDS_MeshNode *  n) const
◆ GetSubMeshIterator()
SMESHDS_SubMeshIteratorPtr SMESHDS_SubMesh::GetSubMeshIterator ( ) const
◆ GetUVPtStructVec() [1/2]
UVPtStructVec & VISCOUS_2D::_ProxyMeshOfFace::_EdgeSubMesh::GetUVPtStructVec ( )
◆ GetUVPtStructVec() [2/2]
const UVPtStructVec & SMESH_ProxyMesh::SubMesh::GetUVPtStructVec ( ) const
◆ IsComplexSubmesh()
◆ IsQuadratic()
◆ NbElements()
smIdType SMESH_ProxyMesh::SubMesh::NbElements ( ) const
Referenced by VISCOUS_3D::_ViscousBuilder::addBoundaryElements(), VISCOUS_3D::_ViscousBuilder::MakeN2NMap(), and VISCOUS_3D::_ViscousBuilder::shrink().
◆ NbNodes()
virtual smIdType VISCOUS_2D::_ProxyMeshOfFace::_EdgeSubMesh::NbNodes ( ) const
Reimplemented from SMESH_ProxyMesh::SubMesh.
References SMESH_ProxyMesh::SubMesh::_uvPtStructVec.
◆ NbSubMeshes()
size_t SMESHDS_SubMesh::NbSubMeshes ( ) const
◆ RemoveAllSubmeshes()
void SMESHDS_SubMesh::RemoveAllSubmeshes ( )
◆ RemoveElement()
◆ RemoveNode()
◆ RemoveSubMesh()
bool SMESHDS_SubMesh::RemoveSubMesh ( const SMESHDS_SubMesh *  theSubMesh)
◆ restoreElements()
void SMDS_ElementHolder::restoreElements ( const std::vector< smIdType > &  idNodessOldToNew,
const std::vector< smIdType > &  idCellsOldToNew
privateinherited
◆ SetUVPtStructVec()
void VISCOUS_2D::_ProxyMeshOfFace::_EdgeSubMesh::SetUVPtStructVec ( UVPtStructVec &  vec)
◆ tmpClear()
virtual void SMESH_ProxyMesh::SubMesh::tmpClear ( )
◆ _elements
std::vector<const SMDS_MeshElement *> SMESH_ProxyMesh::SubMesh::_elements
◆ _n2n
TN2NMap* SMESH_ProxyMesh::SubMesh::_n2n
◆ _uvPtStructVec
UVPtStructVec SMESH_ProxyMesh::SubMesh::_uvPtStructVec
◆ my1stElemNode
◆ myExternalElems
std::vector<const SMDS_MeshElement*> SMDS_ElementHolder::myExternalElems
privateinherited
Referenced by SMDS_ElementHolder::beforeCompacting(), and SMDS_ElementHolder::restoreElements().
◆ myIndex
◆ myIsNode
std::vector< bool > SMDS_ElementHolder::myIsNode
privateinherited
◆ myMesh
◆ myNbElements
◆ myNbNodes
◆ myParent
◆ myPtrInMesh
std::set<SMDS_ElementHolder*>::iterator SMDS_ElementHolder::myPtrInMesh
privateinherited
◆ mySubMeshes
◆ myVtkIDs
std::vector< vtkIdType > SMDS_ElementHolder::myVtkIDs
privateinherited
