StdMeshers_FaceSide Class Reference
Represents a side of a quasi quadrilateral face. More...
#include <StdMeshers_FaceSide.hxx>
enum  { ALL_EDGES = -1 , LAST_EDGE = -1 }
 StdMeshers_FaceSide (const TopoDS_Face &theFace, const TopoDS_Edge &theEdge, SMESH_Mesh *theMesh, const bool theIsForward, const bool theIgnoreMediumNodes, SMESH_MesherHelper *theFaceHelper=NULL, SMESH_ProxyMesh::Ptr theProxyMesh=SMESH_ProxyMesh::Ptr())
 Wrap one edge. More...
 StdMeshers_FaceSide (const TopoDS_Face &theFace, const std::list< TopoDS_Edge > &theEdges, SMESH_Mesh *theMesh, const bool theIsForward, const bool theIgnoreMediumNodes, SMESH_MesherHelper *theFaceHelper=NULL, SMESH_ProxyMesh::Ptr theProxyMesh=SMESH_ProxyMesh::Ptr())
 Wrap several edges. More...
 StdMeshers_FaceSide (const StdMeshers_FaceSide *theSide, const SMDS_MeshNode *theNode, const gp_Pnt2d *thePnt2d1, const gp_Pnt2d *thePnt2d2=NULL, const Handle(Geom2d_Curve)&theC2d=NULL, const double theUFirst=0., const double theULast=1.)
 Simulate a side from a vertex using data from other FaceSide. More...
 StdMeshers_FaceSide (UVPtStructVec &theSideNodes, const TopoDS_Face &theFace=TopoDS_Face(), const TopoDS_Edge &theEdge=TopoDS_Edge(), SMESH_Mesh *theMesh=0)
 Create a side from an UVPtStructVec. More...
 ~StdMeshers_FaceSide ()
void Reverse ()
 Change orientation of side geometry. More...
void SetIgnoreMediumNodes (bool toIgnore)
 Make ignore medium nodes. More...
smIdType NbPoints (const bool update=false) const
 Return nb nodes on edges and vertices (+1 to be == GetUVPtStruct().size() ). More...
smIdType NbSegments (const bool update=false) const
 Return nb edges Call it with update == true if mesh of this side can be recomputed since creation of this side. More...
SMESH_Mesh * GetMesh () const
 Return mesh. More...
bool MissVertexNode () const
 Return true if there are vertices without nodes. More...
const UVPtStructVec & GetUVPtStruct (bool isXConst=0, double constValue=0) const
 Return detailed data on nodes. More...
const UVPtStructVec & SimulateUVPtStruct (int nbSeg, bool isXConst=0, double constValue=0) const
 Simulates detailed data on nodes. More...
std::vector< const SMDS_MeshNode * > GetOrderedNodes (int iE=ALL_EDGES) const
 Return nodes in the order they encounter while walking along the whole side or a specified EDGE. More...
bool GetEdgeNodes (const size_t i, std::vector< const SMDS_MeshNode * > &nodes, bool inlude1stVertex=true, bool inludeLastVertex=true) const
 Return nodes of the i-th EDGE. More...
const SMDS_MeshNode * VertexNode (std::size_t i, bool *isMoved=0) const
 Return a node from the i-th VERTEX (count starts from zero) Nodes moved to other geometry by MergeNodes() are also returned. More...
double Parameter (double U, TopoDS_Edge &edge) const
 Return an edge and parameter on the edge by a normalized parameter. More...
double Parameter (double U, int &edgeID) const
 Return an edge ID and parameter on the edge by a normalized parameter. More...
gp_Pnt2d Value2d (double U) const
 Return UV by normalized parameter. More...
gp_Pnt Value3d (double U) const
 Return XYZ by normalized parameter. More...
Adaptor2d_Curve2d * GetCurve2d () const
 Creates a Adaptor2d_Curve2d to be used in SMESH_Block. More...
BRepAdaptor_CompCurve * GetCurve3d () const
 Creates a fully functional Adaptor_Curve. More...
int NbEdges () const
 Return nb of wrapped edges. More...
const TopoDS_Edge & Edge (int i) const
 Return i-th edge (count starts from zero) More...
const std::vector< TopoDS_Edge > & Edges () const
 Return all edges. More...
const TopoDS_Face & Face () const
 Return the FACE. More...
TopoDS_Vertex FirstVertex (int i=0) const
 Return 1st vertex of the i-th edge (count starts from zero) More...
TopoDS_Vertex LastVertex (int i=LAST_EDGE) const
 Return last vertex of the i-th edge (count starts from zero) More...
bool IsClosed () const
 Return true if the chain of EDGEs is closed. More...
double Length () const
 Return side length. More...
int EdgeIndex (double U) const
 Return edge index corresponding to normalized parameter. More...
void dump (const char *msg=0) const
 Show side features. More...
int EdgeID (int i) const
 Return ID of i-th wrapped edge (count starts from zero) More...
 Handle (Geom2d_Curve) Curve2d(int i) const
 Return p-curve of i-th wrapped edge (count starts from zero) More...
double FirstParameter (int i) const
 Return first normalized parameter of the i-th edge (count starts from zero) More...
double LastParameter (int i) const
 Return last normalized parameter of the i-th edge (count starts from zero) More...
double FirstU (int i) const
 Return first parameter of the i-th edge (count starts from zero). More...
double LastU (int i) const
 Return last parameter of the i-th edge (count starts from zero). More...
double EdgeLength (int i) const
 Return length of i-th wrapped edge (count starts from zero) More...
bool IsReversed (int i) const
 Return orientation of i-th wrapped edge (count starts from zero) More...
SMESH_MesherHelper * FaceHelper () const
 Return a helper initialized with the FACE. More...
static StdMeshers_FaceSidePtr New (const TopoDS_Face &Face, const TopoDS_Edge &Edge, SMESH_Mesh *Mesh, const bool IsForward, const bool IgnoreMediumNodes, SMESH_MesherHelper *FaceHelper=NULL, SMESH_ProxyMesh::Ptr ProxyMesh=SMESH_ProxyMesh::Ptr())
static StdMeshers_FaceSidePtr New (const TopoDS_Face &Face, const std::list< TopoDS_Edge > &Edges, SMESH_Mesh *Mesh, const bool IsForward, const bool IgnoreMediumNodes, SMESH_MesherHelper *FaceHelper=NULL, SMESH_ProxyMesh::Ptr ProxyMesh=SMESH_ProxyMesh::Ptr())
static StdMeshers_FaceSidePtr New (const StdMeshers_FaceSide *Side, const SMDS_MeshNode *Node, const gp_Pnt2d *Pnt2d1, const gp_Pnt2d *Pnt2d2=NULL, const Handle(Geom2d_Curve)&C2d=NULL, const double UFirst=0., const double ULast=1.)
static StdMeshers_FaceSidePtr New (UVPtStructVec &theSideNodes, const TopoDS_Face &theFace=TopoDS_Face(), const TopoDS_Edge &theEdge=TopoDS_Edge(), SMESH_Mesh *theMesh=0)
static TSideVector GetFaceWires (const TopoDS_Face &theFace, SMESH_Mesh &theMesh, const bool theIgnoreMediumNodes, TError &theError, SMESH_MesherHelper *theFaceHelper=NULL, SMESH_ProxyMesh::Ptr theProxyMesh=SMESH_ProxyMesh::Ptr(), const bool theCheckVertexNodes=true)
 Return wires of a face as StdMeshers_FaceSide's. More...
void reverseProxySubmesh (const TopoDS_Edge &E)
 Reverse UVPtStructVec if a proxy sub-mesh of E. More...
TopoDS_Face myFace
std::vector< uvPtStruct > myPoints
std::vector< uvPtStruct > myFalsePoints
std::vector< TopoDS_Edge > myEdge
std::vector< int > myEdgeID
std::vector< Handle(Geom2d_Curve)> myC2d
std::vector< GeomAdaptor_Curve > myC3dAdaptor
std::vector< double > myFirst
std::vector< double > myLast
std::vector< double > myNormPar
std::vector< double > myEdgeLength
std::vector< int > myIsUniform
double myLength
smIdType myNbPonits
smIdType myNbSegments
SMESH_ProxyMesh::Ptr myProxyMesh
bool myMissingVertexNodes
bool myIgnoreMediumNodes
gp_Pnt2d myDefaultPnt2d
SMESH_MesherHelper * myHelper
It can be composed of several edges. Gives access to geometry and 1D mesh of a side.
◆ anonymous enum
anonymous enum
ALL_EDGES
LAST_EDGE
◆ StdMeshers_FaceSide() [1/4]
StdMeshers_FaceSide::StdMeshers_FaceSide ( const TopoDS_Face &  theFace,
const TopoDS_Edge &  theEdge,
SMESH_Mesh *  theMesh,
SMESH_MesherHelper *  theFaceHelper = NULL,
SMESH_ProxyMesh::Ptr  theProxyMesh = SMESH_ProxyMesh::Ptr()
Wrap one edge.
Constructor of a side of one edge.
theFace- the face
theEdge- the edge
References myHelper.
Referenced by GetFaceWires().
◆ StdMeshers_FaceSide() [2/4]
const std::list< TopoDS_Edge > &  theEdges,
◆ StdMeshers_FaceSide() [3/4]
StdMeshers_FaceSide::StdMeshers_FaceSide ( const StdMeshers_FaceSide *  theSide,
const SMDS_MeshNode *  theNode,
const gp_Pnt2d *  thePnt2d1,
const gp_Pnt2d *  thePnt2d2 = NULL,
const Handle(Geom2d_Curve)&  theC2d = NULL,
const double  theUFirst = 0.,
const double  theULast = 1.
Constructor of a side for vertex using data from other FaceSide.
References GetUVPtStruct(), myC2d, myC3dAdaptor, myDefaultPnt2d, myEdge, myEdgeID, myFirst, myHelper, myIsUniform, myLast, myLength, myNbPonits, myNbSegments, myNormPar, myPoints, and myProxyMesh.
◆ StdMeshers_FaceSide() [4/4]
StdMeshers_FaceSide::StdMeshers_FaceSide ( UVPtStructVec &  theSideNodes,
const TopoDS_Face &  theFace = TopoDS_Face(),
const TopoDS_Edge &  theEdge = TopoDS_Edge(),
SMESH_Mesh *  theMesh = 0
◆ ~StdMeshers_FaceSide()
StdMeshers_FaceSide::~StdMeshers_FaceSide ( )
◆ dump()
void StdMeshers_FaceSide::dump ( const char *  msg = 0) const
Show side features.
References MESSAGE, myC2d, myEdge, myFalsePoints, myFirst, myLast, myNbPonits, myNormPar, myPoints, and MED::Print().
◆ Edge()
const TopoDS_Edge & StdMeshers_FaceSide::Edge ( int  i) const
◆ EdgeID()
int StdMeshers_FaceSide::EdgeID ( int  i) const
◆ EdgeIndex()
int StdMeshers_FaceSide::EdgeIndex ( double  U) const
U- the parameter
int- index
References myNormPar.
Referenced by Parameter(), SimulateUVPtStruct(), Value2d(), and Value3d().
◆ EdgeLength()
double StdMeshers_FaceSide::EdgeLength ( int  i) const
Referenced by VISCOUS_3D::ShrinkFace::SetBoundary(), and VISCOUS_2D::_ViscousBuilder2D::shrink().
◆ Edges()
const std::vector< TopoDS_Edge > & StdMeshers_FaceSide::Edges ( ) const
Return all edges.
◆ Face()
const TopoDS_Face & StdMeshers_FaceSide::Face ( ) const
Return the FACE.
Referenced by StdMeshers_ViscousLayers2D::SetProxyMeshOfEdge().
◆ FaceHelper()
SMESH_MesherHelper * StdMeshers_FaceSide::FaceHelper ( ) const
References myFace, myHelper, myProxyMesh, and SMESH_MesherHelper::SetSubShape().
Referenced by GetOrderedNodes(), GetUVPtStruct(), and NbPoints().
◆ FirstParameter()
double StdMeshers_FaceSide::FirstParameter ( int  i) const
Return first normalized parameter of the i-th edge.
Referenced by VISCOUS_2D::_ViscousBuilder2D::refine().
◆ FirstU()
double StdMeshers_FaceSide::FirstU ( int  i) const
Return first parameter of the i-th edge.
EDGE orientation is taken into account
References myFirst.
Referenced by VISCOUS_2D::_ViscousBuilder2D::refine(), and VISCOUS_2D::_ViscousBuilder2D::shrink().
◆ FirstVertex()
TopoDS_Vertex StdMeshers_FaceSide::FirstVertex ( int  i = 0) const
Return 1st vertex of the i-the edge.
References myEdge, and NbEdges().
Referenced by StdMeshers_Quadrangle_2D::getCorners(), IsClosed(), VISCOUS_2D::_ViscousBuilder2D::refine(), VISCOUS_3D::ShrinkFace::SetBoundary(), VISCOUS_2D::_ViscousBuilder2D::shrink(), and VertexNode().
◆ GetCurve2d()
Adaptor2d_Curve2d * StdMeshers_FaceSide::GetCurve2d ( ) const
◆ GetCurve3d()
BRepAdaptor_CompCurve * StdMeshers_FaceSide::GetCurve3d ( ) const
References IsClosed(), and myEdge.
◆ GetEdgeNodes()
bool StdMeshers_FaceSide::GetEdgeNodes ( const size_t  i,
std::vector< const SMDS_MeshNode * > &  nodes,
bool  inlude1stVertex = true,
bool  inludeLastVertex = true
◆ GetFaceWires()
◆ GetMesh()
SMESH_Mesh * StdMeshers_FaceSide::GetMesh ( ) const
◆ GetOrderedNodes()
std::vector< const SMDS_MeshNode * > StdMeshers_FaceSide::GetOrderedNodes ( int  iE = ALL_EDGES) const
◆ GetUVPtStruct()
◆ Handle()
StdMeshers_FaceSide::Handle ( Geom2d_Curve  ) const
Referenced by Reverse(), and StdMeshers_FaceSide().
◆ IsClosed()
bool StdMeshers_FaceSide::IsClosed ( ) const
References FirstVertex(), LastVertex(), and myEdge.
Referenced by GetCurve3d(), GetOrderedNodes(), GetUVPtStruct(), NbPoints(), and VertexNode().
◆ IsReversed()
bool StdMeshers_FaceSide::IsReversed ( int  i) const
◆ LastParameter()
double StdMeshers_FaceSide::LastParameter ( int  i) const
Return ast normalized parameter of the i-th edge.
◆ LastU()
double StdMeshers_FaceSide::LastU ( int  i) const
Return last parameter of the i-th edge.
References myLast.
◆ LastVertex()
TopoDS_Vertex StdMeshers_FaceSide::LastVertex ( int  i = LAST_EDGE) const
Return last vertex of the i-the edge.
Referenced by IsClosed(), VISCOUS_2D::_ViscousBuilder2D::refine(), VISCOUS_3D::ShrinkFace::SetBoundary(), VISCOUS_2D::_ViscousBuilder2D::shrink(), and VertexNode().
◆ Length()
double StdMeshers_FaceSide::Length ( ) const
Return side length.
◆ MissVertexNode()
bool StdMeshers_FaceSide::MissVertexNode ( ) const
◆ NbEdges()
int StdMeshers_FaceSide::NbEdges ( ) const
◆ NbPoints()
smIdType StdMeshers_FaceSide::NbPoints ( const bool  update = false) const
◆ NbSegments()
smIdType StdMeshers_FaceSide::NbSegments ( const bool  update = false) const
References myNbSegments, and NbPoints().
Referenced by StdMeshers_Quadrangle_2D::getCorners(), and VISCOUS_3D::ShrinkFace::SetBoundary().
◆ New() [1/4]
static StdMeshers_FaceSidePtr StdMeshers_FaceSide::New ( const StdMeshers_FaceSide *  Side,
const SMDS_MeshNode *  Node,
const gp_Pnt2d *  Pnt2d1,
const gp_Pnt2d *  Pnt2d2 = NULL,
const Handle(Geom2d_Curve)&  C2d = NULL,
const double  UFirst = 0.,
const double  ULast = 1.
References Node.
◆ New() [2/4]
static StdMeshers_FaceSidePtr StdMeshers_FaceSide::New ( const TopoDS_Face &  Face,
const std::list< TopoDS_Edge > &  Edges,
SMESH_Mesh *  Mesh,
SMESH_MesherHelper *  FaceHelper = NULL,
SMESH_ProxyMesh::Ptr  ProxyMesh = SMESH_ProxyMesh::Ptr()
References Face.
◆ New() [3/4]
◆ New() [4/4]
static StdMeshers_FaceSidePtr StdMeshers_FaceSide::New ( UVPtStructVec &  theSideNodes,
◆ Parameter() [1/2]
double StdMeshers_FaceSide::Parameter ( double  U,
int &  edgeID
U- normalized parameter
double- pameter on a curve \ warning The returned parameter can be inaccurate if the edge is non-uniformly parametrized. Use Value2d() to get a precise point on the edge
References EdgeIndex(), myEdgeID, myFirst, myLast, and myNormPar.
◆ Parameter() [2/2]
TopoDS_Edge &  edge
References EdgeIndex(), myEdge, myFirst, myLast, and myNormPar.
◆ Reverse()
void StdMeshers_FaceSide::Reverse ( )
◆ reverseProxySubmesh()
void StdMeshers_FaceSide::reverseProxySubmesh ( const TopoDS_Edge &  E)
References myProxyMesh, uvPtStruct::normParam, reverse(), uvPtStruct::x, and uvPtStruct::y.
◆ SetIgnoreMediumNodes()
void StdMeshers_FaceSide::SetIgnoreMediumNodes ( bool  toIgnore)
References myIgnoreMediumNodes, myPoints, and NbPoints().
◆ SimulateUVPtStruct()
const vector< UVPtStruct > & StdMeshers_FaceSide::SimulateUVPtStruct ( int  nbSeg,
bool  isXConst = 0,
double  constValue = 0
Falsificate info on nodes.
isXConst- true if normalized parameter X is constant
constValue- constant parameter value
nbSeg- nb of segments on the side
UVPtStruct*- array of data structures
References EdgeIndex(), myC2d, myFalsePoints, myFirst, myLast, myNormPar, NbEdges(), uvPtStruct::node, uvPtStruct::normParam, uvPtStruct::param, uvPtStruct::u, uvPtStruct::v, Value2d(), uvPtStruct::x, and uvPtStruct::y.
◆ Value2d()
gp_Pnt2d StdMeshers_FaceSide::Value2d ( double  U) const
Return 2D point by normalized parameter.
U- normalized parameter value
gp_Pnt2d- point
References EdgeIndex(), myC2d, myC3dAdaptor, myDefaultPnt2d, myEdgeLength, myFirst, myIsUniform, myLast, myNormPar, and myPoints.
Referenced by SimulateUVPtStruct(), and Adaptor2dCurve2d::Value().
◆ Value3d()
gp_Pnt StdMeshers_FaceSide::Value3d ( double  U) const
gp_Pnt- point
References EdgeIndex(), myC3dAdaptor, myEdgeLength, myFirst, myIsUniform, myLast, and myNormPar.
◆ VertexNode()
const SMDS_MeshNode * StdMeshers_FaceSide::VertexNode ( std::size_t  i,
bool *  isMoved = 0
[in]i- the VERTEX index
[out]isMoved- returns true if the found node is moved by MergeNodes()
const SMDS_MeshNode* - the found node
References FirstVertex(), SMDS_MeshNode::GetPosition(), SMESH_MesherHelper::GetSubShapeByNode(), IsClosed(), SMESH_MesherHelper::IsSubShape(), LastVertex(), myEdge, myEdgeID, myFace, myProxyMesh, NbEdges(), SMESH_Algo::VertexNode(), and SMESH_MesherHelper::WrapIndex().
Referenced by StdMeshers_Quadrangle_2D::getCorners(), GetEdgeNodes(), GetOrderedNodes(), GetUVPtStruct(), and NbPoints().
◆ myC2d
std::vector<Handle(Geom2d_Curve)> StdMeshers_FaceSide::myC2d
◆ myC3dAdaptor
std::vector<GeomAdaptor_Curve> StdMeshers_FaceSide::myC3dAdaptor
◆ myDefaultPnt2d
gp_Pnt2d StdMeshers_FaceSide::myDefaultPnt2d
Referenced by StdMeshers_FaceSide(), and Value2d().
◆ myEdge
std::vector<TopoDS_Edge> StdMeshers_FaceSide::myEdge
◆ myEdgeID
std::vector<int> StdMeshers_FaceSide::myEdgeID
◆ myEdgeLength
std::vector<double> StdMeshers_FaceSide::myEdgeLength
◆ myFace
TopoDS_Face StdMeshers_FaceSide::myFace
◆ myFalsePoints
std::vector<uvPtStruct> StdMeshers_FaceSide::myFalsePoints
Referenced by dump(), Reverse(), and SimulateUVPtStruct().
◆ myFirst
std::vector<double> StdMeshers_FaceSide::myFirst
◆ myHelper
SMESH_MesherHelper* StdMeshers_FaceSide::myHelper
◆ myIgnoreMediumNodes
bool StdMeshers_FaceSide::myIgnoreMediumNodes
◆ myIsUniform
std::vector<int> StdMeshers_FaceSide::myIsUniform
◆ myLast
std::vector<double> StdMeshers_FaceSide::myLast
◆ myLength
double StdMeshers_FaceSide::myLength
Referenced by StdMeshers_FaceSide().
◆ myMissingVertexNodes
bool StdMeshers_FaceSide::myMissingVertexNodes
Referenced by NbPoints(), and StdMeshers_FaceSide().
◆ myNbPonits
smIdType StdMeshers_FaceSide::myNbPonits
◆ myNbSegments
smIdType StdMeshers_FaceSide::myNbSegments
◆ myNormPar
◆ myPoints
std::vector<uvPtStruct> StdMeshers_FaceSide::myPoints
◆ myProxyMesh
