StdMeshers::Cartesian3D::Hexahedron Class Reference
Class representing topology of the hexahedron and creating a mesh volume basing on analysis of hexahedron intersection with geometry. More...
#include <StdMeshers_Cartesian_3D_Hexahedron.hxx>
struct  _Face
struct  _Link
struct  _Node
 < node either at a hexahedron corner or at intersection More...
struct  _OrientedLink
struct  _SplitIterator
 set to _hexLinks splits on one side of INTERNAL FACEs More...
struct  _volumeDef
 Hexahedron (StdMeshers::Cartesian3D::Grid *grid)
 Creates topology of the hexahedron. More...
int MakeElements (SMESH_MesherHelper &helper, const TEdge2faceIDsMap &edge2faceIDsMap, const int numOfThreads=1)
 Create elements in the mesh. More...
void computeElements (const Solid *solid=0, int solidIndex=-1)
 Compute mesh volumes resulted from intersection of the Hexahedron. More...
Private Types
enum  IsInternalFlag { IS_NOT_INTERNAL , IS_INTERNAL , IS_CUT_BY_INTERNAL_FACE }
typedef std::pair< StdMeshers::Cartesian3D::TGeomID, int > TFaceOfLink
typedef boost::container::flat_map< StdMeshers::Cartesian3D::TGeomID, size_t > TID2Nb
 Hexahedron (const Hexahedron &other, size_t i, size_t j, size_t k, int cellID)
 Copy constructor. More...
void init (size_t i, size_t j, size_t k, const Solid *solid=0)
 Initializes its data by given grid cell nodes and intersections. More...
void init (size_t i)
 Initializes its data by given grid cell (countered from zero) More...
void clearNodesLinkedToNull (const Solid *solid, SMESH_MesherHelper &helper)
 Clear nodes linked to null by not splitted links. More...
bool isSplittedLink (const Solid *solid, SMESH_MesherHelper &helper, const Hexahedron::_Link &linkIn) const
 Returns true if the link will be split on the Hexaedron initialization. More...
void setIJK (size_t i)
 Initializes IJK by Hexahedron index. More...
void defineHexahedralFaces (const Solid *solid, const IsInternalFlag intFlag)
bool compute (const Solid *solid, const IsInternalFlag intFlag)
size_t getSolids (StdMeshers::Cartesian3D::TGeomID ids[])
 Return IDs of SOLIDs interfering with this Hexahedron. More...
bool isCutByInternalFace (IsInternalFlag &maxFlag)
 Count cuts by INTERNAL FACEs and set _Node::_isInternalFlags. More...
void addEdges (SMESH_MesherHelper &helper, std::vector< Hexahedron * > &intersectedHex, const TEdge2faceIDsMap &edge2faceIDsMap)
 Implements geom edges into the mesh. More...
gp_Pnt findIntPoint (double u1, double proj1, double u2, double proj2, double proj, BRepAdaptor_Curve &curve, const gp_XYZ &axis, const gp_XYZ &origin)
 Finds intersection of a curve with a plane. More...
int getEntity (const StdMeshers::Cartesian3D::E_IntersectPoint *ip, int *facets, int &sub)
 Returns indices of a hexahedron sub-entities holding a point. More...
bool addIntersection (const StdMeshers::Cartesian3D::E_IntersectPoint *ip, std::vector< Hexahedron * > &hexes, int ijk[], int dIJK[])
 Adds intersection with an EDGE. More...
bool isQuadOnFace (const size_t iQuad)
 Check if a hexahedron facet lies on a FACE Also return true if the facet does not interfere with any FACE. More...
bool findChain (_Node *n1, _Node *n2, _Face &quad, std::vector< _Node * > &chainNodes)
 Finds nodes at a path from one node to another via intersections with EDGEs. More...
bool closePolygon (_Face *polygon, std::vector< _Node * > &chainNodes) const
 Try to heal a polygon whose ends are not connected. More...
bool findChainOnEdge (const std::vector< _OrientedLink > &splits, const _OrientedLink &prevSplit, const _OrientedLink &avoidSplit, const std::set< StdMeshers::Cartesian3D::TGeomID > &concaveFaces, size_t &iS, _Face &quad, std::vector< _Node * > &chn)
 Finds nodes on the same EDGE as the first node of avoidSplit. More...
size_t findCoplanarPolygon (const _Face &thePolygon, const size_t nbQuadPolygons, std::vector< _OrientedLink * > &freeLinks, int &nbFreeLinks, const E_IntersectPoint &ipTmp, std::set< StdMeshers::Cartesian3D::TGeomID > &usedFaceIDs, std::map< StdMeshers::Cartesian3D::TGeomID, std::vector< const B_IntersectPoint * > > &tmpAddedFace, const StdMeshers::Cartesian3D::TGeomID &curFace)
 find coplanar polygon, if any, and set it to be re-created next More...
int addVolumes (SMESH_MesherHelper &helper)
 Adds computed elements to the mesh. More...
void addFaces (SMESH_MesherHelper &helper, const std::vector< const SMDS_MeshElement * > &boundaryVolumes)
 Create mesh faces at free facets. More...
void addSegments (SMESH_MesherHelper &helper, const TEdge2faceIDsMap &edge2faceIDsMap)
 Create mesh segments. More...
void getVolumes (std::vector< const SMDS_MeshElement * > &volumes)
void getBoundaryElems (std::vector< const SMDS_MeshElement * > &boundaryVolumes)
 Return created volumes and volumes that can have free facet because of skipped small volume. More...
void removeExcessSideDivision (const std::vector< Hexahedron * > &allHexa)
 Remove edges and nodes dividing a hexa side in the case if an adjacent volume also sharing the dividing edge is missing due to its small side. More...
void removeExcessNodes (std::vector< Hexahedron * > &allHexa)
 Remove nodes splitting Cartesian cell edges in the case if a node is used in every cells only by two polygons sharing the edge Issue #19887. More...
void preventVolumesOverlapping ()
 [Issue #19913] Modify _hexLinks._splits to prevent creating overlapping volumes More...
StdMeshers::Cartesian3D::TGeomID getAnyFace () const
 Return any FACE interfering with this Hexahedron. More...
void cutByExtendedInternal (std::vector< Hexahedron * > &hexes, const TColStd_MapOfInteger &intEdgeIDs)
 Fully cut hexes that are partially cut by INTERNAL FACE. More...
gp_Pnt mostDistantInternalPnt (int hexIndex, const gp_Pnt &p1, const gp_Pnt &p2)
 Return intersection point on INTERNAL FACE most distant from given ones. More...
bool isOutPoint (_Link &link, int iP, SMESH_MesherHelper &helper, const Solid *solid) const
 Checks transition at the ginen intersection node of a link. More...
void sortVertexNodes (std::vector< _Node * > &nodes, _Node *curNode, StdMeshers::Cartesian3D::TGeomID face)
 Sort nodes on a FACE. More...
bool isInHole () const
 Return true if the element is in a hole. More...
bool hasStrangeEdge () const
 Check if a polyherdon has an edge lying on EDGE shared by strange FACE that will be meshed by other algo. More...
bool checkPolyhedronSize (bool isCutByInternalFace, double &volSize) const
 Return true if a polyhedron passes _sizeThreshold criterion. More...
int checkPolyhedronValidity (_volumeDef *volDef, std::vector< std::vector< int > > &splitQuantities, std::vector< std::vector< const SMDS_MeshNode * > > &splitNodes)
 Check that all faces in polyhedron are connected so a unique volume is defined. More...
const SMDS_MeshElement * addPolyhedronToMesh (_volumeDef *volDef, SMESH_MesherHelper &helper, const std::vector< const SMDS_MeshNode * > &nodes, const std::vector< int > &quantities)
 add original or separated polyhedrons to the mesh More...
bool addHexa ()
 Tries to create a hexahedron. More...
bool addTetra ()
 Tries to create a tetrahedron. More...
bool addPenta ()
 Tries to create a pentahedron. More...
bool addPyra ()
 Tries to create a pyramid. More...
bool debugDumpLink (_Link *link)
 Dump a link and return false. More...
_Node * findEqualNode (std::vector< _Node * > &nodes, const StdMeshers::Cartesian3D::E_IntersectPoint *ip, const double tol2)
bool isCorner (const _Node *node) const
bool hasEdgesAround (const ConcaveFace *cf) const
 Return true if there are _eIntPoints at EDGEs forming a concave corner. More...
bool isImplementEdges () const
bool isOutParam (const double uvw[3]) const
 Classify a point by grid parameters. More...
static TFaceOfLink findStartLink (const std::vector< _OrientedLink * > &freeLinks, std::set< StdMeshers::Cartesian3D::TGeomID > &usedFaceIDs)
 get a remaining link to start from, one lying on minimal nb of FACEs More...
static void insertAndIncrement (StdMeshers::Cartesian3D::TGeomID id, TID2Nb &id2nbMap)
_Node _hexNodes [HEX_NODES_NUM]
_Link _hexLinks [HEX_LINKS_NUM]
_Face _hexQuads [HEX_QUADS_NUM]
std::vector< _Face > _polygons
std::vector< const StdMeshers::Cartesian3D::E_IntersectPoint * > _eIntPoints
std::vector< _Node > _intNodes
std::vector< _Node * > _vIntNodes
_volumeDef _volumeDefs
StdMeshers::Cartesian3D::Grid * _grid
double _sideLength [3]
int _nbCornerNodes
int _nbFaceIntNodes
int _nbBndNodes
int _origNodeInd
size_t _i
size_t _j
size_t _k
bool _hasTooSmall
int _cellID
Static Private Attributes
static const std::size_t HEX_NODES_NUM = 8
static const std::size_t HEX_LINKS_NUM = 12
static const std::size_t HEX_QUADS_NUM = 6
◆ TFaceOfLink
◆ TID2Nb
◆ IsInternalFlag
IS_NOT_INTERNAL
IS_INTERNAL
◆ Hexahedron() [1/2]
◆ Hexahedron() [2/2]
◆ addEdges()
◆ addFaces()
void Hexahedron::addFaces ( SMESH_MesherHelper &  helper,
const std::vector< const SMDS_MeshElement * > &  boundaryVolumes
References StdMeshers::Cartesian3D::Grid::_geometry, _grid, StdMeshers::Cartesian3D::Geometry::_mainShape, StdMeshers::Cartesian3D::Geometry::_soleSolid, StdMeshers::Cartesian3D::Grid::_toCreateFaces, StdMeshers::Cartesian3D::Grid::_toUseQuanta, StdMeshers::Cartesian3D::Grid::_toUseThresholdForInternalFaces, SMDS_VolumeTool::Element(), findCommonFace(), SMDS_Mesh::FindElement(), SMESHDS_SubMesh::GetElements(), SMDS_VolumeTool::GetFaceNodes(), SMESH_MesherHelper::GetMesh(), SMESH_MesherHelper::GetMeshDS(), StdMeshers::Cartesian3D::Grid::GetOneOfSolids(), SMDS_MeshElement::GetShapeID(), StdMeshers::Cartesian3D::Solid::HasInternalFaces(), StdMeshers::Cartesian3D::Grid::IsBoundaryFace(), SMDS_VolumeTool::IsFreeFace(), SMDS_VolumeTool::IsFreeFaceCheckAllNodes(), StdMeshers::Cartesian3D::Grid::IsInternal(), SMDS_MeshElement::isMarked(), StdMeshers::Cartesian3D::Geometry::IsOneSolid(), StdMeshers::Cartesian3D::Solid::IsOutsideOriented(), SMDS_VolumeTool::IsPoly(), StdMeshers::Cartesian3D::Grid::IsShared(), StdMeshers::Cartesian3D::Grid::IsSolid(), SMESHDS_Mesh::MeshElements(), SMESH_MeshEditor::ElemFeatures::myNodes, SMDS_VolumeTool::NbFaceNodes(), SMDS_VolumeTool::NbFaces(), SMESH::SMESH_MeshEditor::Reorient(), SMESH::SMESH_MeshEditor::Reorient2D(), reverse(), SMDS_VolumeTool::Set(), SMDS_VolumeTool::SetExternalNormal(), SMESHDS_Mesh::SetMeshElementOnShape(), SMESH_MeshEditor::ElemFeatures::SetPoly(), StdMeshers::Cartesian3D::Grid::Shape(), SMDSAbs_Face, splitPolygon(), and SMESHDS_Mesh::UnSetMeshElementOnShape().
Referenced by MakeElements().
◆ addHexa()
◆ addIntersection()
bool Hexahedron::addIntersection ( const StdMeshers::Cartesian3D::E_IntersectPoint *  ip,
std::vector< Hexahedron * > &  hexes,
int  ijk[],
int  dIJK[]
◆ addPenta()
◆ addPolyhedronToMesh()
const SMDS_MeshElement * Hexahedron::addPolyhedronToMesh ( _volumeDef *  volDef,
const std::vector< const SMDS_MeshNode * > &  nodes,
const std::vector< int > &  quantities
◆ addPyra()
◆ addSegments()
◆ addTetra()
◆ addVolumes()
◆ checkPolyhedronSize()
◆ checkPolyhedronValidity()
int Hexahedron::checkPolyhedronValidity ( _volumeDef *  volDef,
std::vector< std::vector< int > > &  splitQuantities,
std::vector< std::vector< const SMDS_MeshNode * > > &  splitNodes
We test that it is possible to go from any node to all nodes in the polyhedron. The set of nodes that can be visit within then defines a unique element. In case more than one polyhedron is detected. The function return the set of quantities and nodes defining separates elements. Reference to issue #bos[38521][EDF] Generate polyhedron with separate volume.
References StdMeshers::Cartesian3D::Hexahedron::_volumeDef::_nodes, and StdMeshers::Cartesian3D::Hexahedron::_volumeDef::_quantities.
Referenced by addVolumes().
◆ clearNodesLinkedToNull()
void Hexahedron::clearNodesLinkedToNull ( const Solid *  solid,
Exclude from computation all nodes those linked to null without any splits in links. This prevents building non-planar faces in cases when the source geometry surface coincident with an intermediate grid plane.
References _hexLinks, StdMeshers::Cartesian3D::Hexahedron::_Node::_node, StdMeshers::Cartesian3D::Hexahedron::_Link::_nodes, StdMeshers::Cartesian3D::Hexahedron::_Link::clear(), HEX_LINKS_NUM, and isSplittedLink().
◆ closePolygon()
bool Hexahedron::closePolygon ( _Face *  polygon,
std::vector< _Node * > &  chainNodes
References StdMeshers::Cartesian3D::Hexahedron::_Face::_links, and StdMeshers::Cartesian3D::Hexahedron::_Node::IsLinked().
Referenced by defineHexahedralFaces().
◆ compute()
bool Hexahedron::compute ( const Solid *  solid,
References StdMeshers::Cartesian3D::Grid::_axes, StdMeshers::Cartesian3D::Grid::_coords, _eIntPoints, StdMeshers::Cartesian3D::B_IntersectPoint::_faceIDs, _grid, _hasTooSmall, _hexNodes, _i, _intNodes, StdMeshers::Cartesian3D::Hexahedron::_Node::_intPoint, _j, _k, StdMeshers::Cartesian3D::Hexahedron::_Face::_links, StdMeshers::Cartesian3D::Hexahedron::_Face::_name, StdMeshers::Cartesian3D::Hexahedron::_volumeDef::_names, _nbFaceIntNodes, StdMeshers::Cartesian3D::Hexahedron::_volumeDef::_nodes, _polygons, StdMeshers::Cartesian3D::Hexahedron::_volumeDef::_quantities, _sideLength, StdMeshers::Cartesian3D::Hexahedron::_volumeDef::_size, StdMeshers::Cartesian3D::Hexahedron::_volumeDef::_solidID, StdMeshers::Cartesian3D::Grid::_toAddEdges, StdMeshers::Cartesian3D::Grid::_tol, _vIntNodes, _volumeDefs, addHexa(), addPenta(), StdMeshers::Cartesian3D::Hexahedron::_Face::AddPolyLink(), addPyra(), addTetra(), checkPolyhedronSize(), StdMeshers::Cartesian3D::Grid::ComputeUVW(), defineHexahedralFaces(), findCoplanarPolygon(), findEqualNode(), findStartLink(), StdMeshers::Cartesian3D::Hexahedron::_OrientedLink::FirstNode(), StdMeshers::Cartesian3D::Solid::ID(), SMESH_Block::ID_F0yz, SMESH_Block::ID_F1yz, SMESH_Block::ID_Fx0z, SMESH_Block::ID_Fx1z, SMESH_Block::ID_Fxy0, SMESH_Block::ID_Fxy1, SMESH_Block::ID_NONE, IS_CUT_BY_INTERNAL_FACE, StdMeshers::Cartesian3D::Grid::IsToRemoveExcessEntities(), StdMeshers::Cartesian3D::Hexahedron::_OrientedLink::LastNode(), StdMeshers::Cartesian3D::Hexahedron::_Node::Node(), preventVolumesOverlapping(), StdMeshers::Cartesian3D::Grid::PseudoIntExtFaceID(), reverse(), and sortVertexNodes().
Referenced by computeElements().
◆ computeElements()
◆ cutByExtendedInternal()
◆ debugDumpLink()
bool Hexahedron::debugDumpLink ( Hexahedron::_Link *  link)
◆ defineHexahedralFaces()
◆ findChain()
bool Hexahedron::findChain ( _Node *  n1,
_Node *  n2,
_Face &  quad,
◆ findChainOnEdge()
bool Hexahedron::findChainOnEdge ( const std::vector< _OrientedLink > &  splits,
const _OrientedLink &  prevSplit,
const _OrientedLink &  avoidSplit,
const std::set< StdMeshers::Cartesian3D::TGeomID > &  concaveFaces,
size_t &  iS,
_Face &  quad,
std::vector< _Node * > &  chn
◆ findCoplanarPolygon()
size_t Hexahedron::findCoplanarPolygon ( const _Face &  thePolygon,
std::vector< _OrientedLink * > &  freeLinks,
int &  nbFreeLinks,
const E_IntersectPoint &  ipTmp,
std::set< StdMeshers::Cartesian3D::TGeomID > &  usedFaceIDs,
std::map< StdMeshers::Cartesian3D::TGeomID, std::vector< const B_IntersectPoint * > > &  tmpAddedFace,
const StdMeshers::Cartesian3D::TGeomID &  curFace
◆ findEqualNode()
_Node * StdMeshers::Cartesian3D::Hexahedron::findEqualNode ( std::vector< _Node * > &  nodes,
const double  tol2
◆ findIntPoint()
gp_Pnt Hexahedron::findIntPoint ( double  u1,
double  proj1,
double  u2,
double  proj2,
double  proj,
BRepAdaptor_Curve &  curve,
const gp_XYZ &  axis,
const gp_XYZ &  origin
[in]u1- parameter of one curve point
[in]proj1- projection of the curve point to the plane normal
[in]u2- parameter of another curve point
[in]proj2- projection of the other curve point to the plane normal
[in]proj- projection of a point where the curve intersects the plane
[in]curve- the curve
[in]axis- the plane normal
[in]origin- the plane origin
gp_Pnt - the found intersection point
References _grid, StdMeshers::Cartesian3D::Grid::_tol, and findIntPoint().
Referenced by addEdges(), and findIntPoint().
◆ findStartLink()
Hexahedron::TFaceOfLink Hexahedron::findStartLink ( const std::vector< _OrientedLink * > &  freeLinks,
staticprivate
◆ getAnyFace()
TGeomID Hexahedron::getAnyFace ( ) const
◆ getBoundaryElems()
◆ getEntity()
int Hexahedron::getEntity ( const StdMeshers::Cartesian3D::E_IntersectPoint *  ip,
int *  facets,
int &  sub
◆ getSolids()
◆ getVolumes()
void StdMeshers::Cartesian3D::Hexahedron::getVolumes ( std::vector< const SMDS_MeshElement * > &  volumes)
◆ hasEdgesAround()
◆ hasStrangeEdge()
bool Hexahedron::hasStrangeEdge ( ) const
References _eIntPoints, _grid, StdMeshers::Cartesian3D::Grid::_helper, SMESH_MesherHelper::GetAncestors(), SMESH_MesherHelper::GetMesh(), StdMeshers::Cartesian3D::Grid::IsStrangeEdge(), and StdMeshers::Cartesian3D::Grid::Shape().
Referenced by checkPolyhedronSize().
◆ init() [1/2]
void Hexahedron::init ( size_t  i)
References _i, _j, _k, init(), and setIJK().
◆ init() [2/2]
void Hexahedron::init ( size_t  i,
size_t  j,
size_t  k,
const Solid *  solid = 0
References StdMeshers::Cartesian3D::Grid::_allBorderNodes, StdMeshers::Cartesian3D::Hexahedron::_Node::_boundaryCornerNode, StdMeshers::Cartesian3D::Grid::_coords, StdMeshers::Cartesian3D::Hexahedron::_Face::_eIntNodes, _eIntPoints, StdMeshers::Cartesian3D::B_IntersectPoint::_faceIDs, StdMeshers::Cartesian3D::Hexahedron::_Link::_fIntNodes, StdMeshers::Cartesian3D::Hexahedron::_Link::_fIntPoints, StdMeshers::Cartesian3D::Grid::_geometry, _grid, StdMeshers::Cartesian3D::Grid::_gridIntP, StdMeshers::Cartesian3D::Grid::_helper, _hexLinks, _hexNodes, _hexQuads, _i, _intNodes, StdMeshers::Cartesian3D::Hexahedron::_Node::_intPoint, StdMeshers::Cartesian3D::Hexahedron::_Node::_isInternalFlags, _j, _k, _nbBndNodes, _nbCornerNodes, _nbFaceIntNodes, StdMeshers::Cartesian3D::Hexahedron::_Node::_node, StdMeshers::Cartesian3D::Grid::_nodes, StdMeshers::Cartesian3D::Hexahedron::_Link::_nodes, StdMeshers::Cartesian3D::Grid::_nodeShift, _origNodeInd, _sideLength, StdMeshers::Cartesian3D::Hexahedron::_Link::_splits, StdMeshers::Cartesian3D::Grid::_tol, _vIntNodes, StdMeshers::Cartesian3D::B_IntersectPoint::Add(), StdMeshers::Cartesian3D::Hexahedron::_Node::Add(), StdMeshers::Cartesian3D::Solid::Contains(), StdMeshers::Cartesian3D::Solid::ContainsAny(), findEqualNode(), getEntity(), SMESH_MesherHelper::GetMesh(), SMDS_MeshElement::GetShapeID(), StdMeshers::Cartesian3D::Grid::GetSolid(), SMESH_Block::ID_FirstE, SMESH_Block::ID_FirstF, SMESH_Block::ID_FirstV, StdMeshers::Cartesian3D::Grid::IsCorrectTransition(), StdMeshers::Cartesian3D::Grid::IsInternal(), StdMeshers::Cartesian3D::Geometry::IsOneSolid(), isOutPoint(), StdMeshers::Cartesian3D::Hexahedron::_Node::Node(), StdMeshers::Cartesian3D::Grid::NodeIndex(), StdMeshers::Cartesian3D::Grid::ShapeType(), StdMeshers::Cartesian3D::Trans_IN, and StdMeshers::Cartesian3D::Trans_OUT.
Referenced by computeElements(), init(), and MakeElements().
◆ insertAndIncrement()
static void StdMeshers::Cartesian3D::Hexahedron::insertAndIncrement ( StdMeshers::Cartesian3D::TGeomID  id,
TID2Nb &  id2nbMap
staticprivate
◆ isCorner()
bool StdMeshers::Cartesian3D::Hexahedron::isCorner ( const _Node *  node) const
Referenced by findChainOnEdge().
◆ isCutByInternalFace()
◆ isImplementEdges()
bool StdMeshers::Cartesian3D::Hexahedron::isImplementEdges ( ) const
◆ isInHole()
◆ isOutParam()
bool Hexahedron::isOutParam ( const double  uvw[3]) const
References StdMeshers::Cartesian3D::Grid::_coords, _grid, _i, _j, _k, and StdMeshers::Cartesian3D::Grid::_tol.
Referenced by addIntersection(), and sortVertexNodes().
◆ isOutPoint()
◆ isQuadOnFace()
bool Hexahedron::isQuadOnFace ( const size_t  iQuad)
References _hexQuads, and StdMeshers::Cartesian3D::Hexahedron::_Face::_links.
◆ isSplittedLink()
◆ MakeElements()
int Hexahedron::MakeElements ( SMESH_MesherHelper &  helper,
const TEdge2faceIDsMap &  edge2faceIDsMap,
const int  numOfThreads = 1
References _eIntPoints, StdMeshers::Cartesian3D::Hexahedron::_Link::_fIntPoints, StdMeshers::Cartesian3D::Grid::_geometry, _grid, _hexLinks, _hexNodes, _i, StdMeshers::Cartesian3D::GridLine::_intPoints, _j, _k, StdMeshers::Cartesian3D::Grid::_lines, _nbBndNodes, StdMeshers::Cartesian3D::CellsAroundLink::_nbCells, _nbCornerNodes, _nbFaceIntNodes, StdMeshers::Cartesian3D::Geometry::_shape2NbNodes, StdMeshers::Cartesian3D::Grid::_toCreateFaces, StdMeshers::Cartesian3D::Grid::_tol, addEdges(), addFaces(), addSegments(), SMESHDS_Mesh::AddVolume(), SMESH::SMESH_MeshEditor::FindCoincidentNodes(), StdMeshers::Cartesian3D::CellsAroundLink::GetCell(), StdMeshers::Cartesian3D::Grid::GetLineIndexer(), SMESH_MesherHelper::GetMesh(), SMESH_MesherHelper::GetMeshDS(), SMDS_MeshElement::GetShapeID(), getSolids(), Hexahedron(), StdMeshers::Cartesian3D::LineIndexer::I(), StdMeshers::Cartesian3D::CellsAroundLink::Init(), init(), isInHole(), StdMeshers::Cartesian3D::Grid::IsToRemoveExcessEntities(), StdMeshers::Cartesian3D::LineIndexer::J(), StdMeshers::Cartesian3D::LineIndexer::K(), StdMeshers::Cartesian3D::LineIndexer::LineIndex(), SMESH::SMESH_MeshEditor::MergeNodes(), SMESHDS_Mesh::MeshElements(), StdMeshers::Cartesian3D::LineIndexer::More(), Node, StdMeshers::Cartesian3D::Hexahedron::_Node::Node(), StdMeshers::Cartesian3D::parallel_for(), StdMeshers::Cartesian3D::LineIndexer::SetIndexOnLine(), SMDS_MeshElement::setIsMarked(), and SMESHDS_Mesh::SetMeshElementOnShape().
Referenced by StdMeshers_Cartesian_3D::Compute(), testNRTJ4(), testNRTM1(), and testShape().
◆ mostDistantInternalPnt()
◆ preventVolumesOverlapping()
◆ removeExcessNodes()
◆ removeExcessSideDivision()
void Hexahedron::removeExcessSideDivision ( const std::vector< Hexahedron * > &  allHexa)
Issue #19887.
References _grid, _hexQuads, _i, _j, _k, StdMeshers::Cartesian3D::Hexahedron::_Face::_name, StdMeshers::Cartesian3D::Hexahedron::_volumeDef::_next, _volumeDefs, StdMeshers::Cartesian3D::Grid::CellIndex(), and StdMeshers::Cartesian3D::Hexahedron::_volumeDef::IsPolyhedron().
◆ setIJK()
void Hexahedron::setIJK ( size_t  i)
References StdMeshers::Cartesian3D::Grid::_coords, _grid, _i, _j, and _k.
Referenced by init(), and mostDistantInternalPnt().
◆ sortVertexNodes()
◆ _cellID
int StdMeshers::Cartesian3D::Hexahedron::_cellID
Referenced by addPolyhedronToMesh(), and Hexahedron().
◆ _eIntPoints
◆ _grid
◆ _hasTooSmall
bool StdMeshers::Cartesian3D::Hexahedron::_hasTooSmall
Referenced by compute(), and getBoundaryElems().
◆ _hexLinks
◆ _hexNodes
◆ _hexQuads
_Face StdMeshers::Cartesian3D::Hexahedron::_hexQuads[HEX_QUADS_NUM]
◆ _i
◆ _intNodes
std::vector< _Node > StdMeshers::Cartesian3D::Hexahedron::_intNodes
◆ _j
◆ _k
◆ _nbBndNodes
int StdMeshers::Cartesian3D::Hexahedron::_nbBndNodes
◆ _nbCornerNodes
int StdMeshers::Cartesian3D::Hexahedron::_nbCornerNodes
◆ _nbFaceIntNodes
int StdMeshers::Cartesian3D::Hexahedron::_nbFaceIntNodes
◆ _origNodeInd
int StdMeshers::Cartesian3D::Hexahedron::_origNodeInd
◆ _polygons
std::vector< _Face > StdMeshers::Cartesian3D::Hexahedron::_polygons
◆ _sideLength
double StdMeshers::Cartesian3D::Hexahedron::_sideLength[3]
◆ _vIntNodes
std::vector< _Node* > StdMeshers::Cartesian3D::Hexahedron::_vIntNodes
Referenced by compute(), init(), and isInHole().
◆ _volumeDefs
◆ HEX_LINKS_NUM
const std::size_t StdMeshers::Cartesian3D::Hexahedron::HEX_LINKS_NUM = 12
staticprivate
Referenced by clearNodesLinkedToNull().
◆ HEX_NODES_NUM
const std::size_t StdMeshers::Cartesian3D::Hexahedron::HEX_NODES_NUM = 8
staticprivate
◆ HEX_QUADS_NUM
const std::size_t StdMeshers::Cartesian3D::Hexahedron::HEX_QUADS_NUM = 6
staticprivate
