StdMeshers::Cartesian3D Namespace Reference
struct  B_IntersectPoint
 Common data of any intersection between a Grid and a shape. More...
struct  CellsAroundLink
 Return cells sharing a link. More...
struct  ConcaveFace
 Sub-entities of a FACE neighboring its concave VERTEX. More...
struct  E_IntersectPoint
 Data of intersection between GridPlanes and a TopoDS_EDGE. More...
struct  F_IntersectPoint
 Data of intersection between a GridLine and a TopoDS_Face. More...
struct  FaceGridIntersector
 Intersector of TopoDS_Face with all GridLine's. More...
struct  FaceLineIntersector
 Intersector of a surface with a GridLine. More...
struct  Geometry
 Geom data. More...
class  GeomIDVecHelder
 Hold a vector of TGeomID and clear it at destruction. More...
class  Grid
struct  GridLine
 A line of the grid and its intersections with 2D geometry. More...
struct  GridPlanes
 Planes of the grid used to find intersections of an EDGE with a hexahedron. More...
class  Hexahedron
 Class representing topology of the hexahedron and creating a mesh volume basing on analysis of hexahedron intersection with geometry. More...
struct  LineIndexer
 Iterator on the parallel grid lines of one direction. More...
class  OneOfSolids
class  Solid
 Container of IDs of SOLID sub-shapes. More...
class  Tools
Typedefs
typedef int TGeomID
typedef TopTools_ShapeMapHasher TShapeHasher
typedef std::array< int, 3 > TIJK
typedef std::map< TGeomID, std::vector< TGeomID > > TEdge2faceIDsMap
typedef NCollection_DataMap< TGeomID, ConcaveFace > TConcaveVertex2Face
Enumerations
enum  Transition {
  Trans_TANGENT = IntCurveSurface_Tangent , Trans_IN = IntCurveSurface_In , Trans_OUT = IntCurveSurface_Out , Trans_APEX ,
  Trans_INTERNAL
template<typename Iterator , class Function >
void parallel_for (const Iterator &first, const Iterator &last, Function &&f, const unsigned int nthreads=1)
template<typename Type >
void computeGridIntersection (Type faceGridIntersector)
Variables
const TGeomID theUndefID = 1e+9
Typedef Documentation
◆ TConcaveVertex2Face
◆ TEdge2faceIDsMap
typedef std::map< TGeomID, std::vector< TGeomID > > StdMeshers::Cartesian3D::TEdge2faceIDsMap
◆ TGeomID
◆ TIJK
typedef std::array< int, 3 > StdMeshers::Cartesian3D::TIJK
◆ TShapeHasher
typedef TopTools_ShapeMapHasher StdMeshers::Cartesian3D::TShapeHasher
◆ Transition
Trans_TANGENT
Trans_IN
Trans_OUT
Trans_APEX
Trans_INTERNAL
◆ computeGridIntersection()
void StdMeshers::Cartesian3D::computeGridIntersection ( Type  faceGridIntersector)
◆ parallel_for()
void StdMeshers::Cartesian3D::parallel_for ( const Iterator &  first,
const Iterator &  last,
Function &&  f,
const unsigned int  nthreads = 1
Variable Documentation
◆ theUndefID
