SMDS_VolumeTool Class Reference
#include <SMDS_VolumeTool.hxx>
struct  Facet
struct  SaveFacet
 Saver/restorer of a SMDS_VolumeTool::myCurFace. More...
enum  VolumeType {
  UNKNOWN = -1 , TETRA = 0 , PYRAM , PENTA ,
  HEXA , HEX_PRISM , QUAD_TETRA , QUAD_PYRAM ,
  QUAD_PENTA , QUAD_HEXA , POLYHEDA , NB_VOLUME_TYPES
 SMDS_VolumeTool ()
 ~SMDS_VolumeTool ()
 SMDS_VolumeTool (const SMDS_MeshElement *theVolume, const bool ignoreCentralNodes=true)
bool Set (const SMDS_MeshElement *theVolume, const bool ignoreCentralNodes=true, const std::vector< const SMDS_MeshNode * > *nodes=0)
const SMDS_MeshVolume * Element () const
smIdType ID () const
bool IsPoly () const
VolumeType GetVolumeType () const
bool IsForward () const
void Inverse ()
const SMDS_MeshNode ** GetNodes () const
int NbNodes () const
double GetSize () const
double GetScaledJacobian () const
bool GetBaryCenter (double &X, double &Y, double &Z) const
bool IsOut (double X, double Y, double Z, double tol) const
 Classify a point. More...
bool IsLinked (const SMDS_MeshNode *theNode1, const SMDS_MeshNode *theNode2, const bool theIgnoreMediumNodes=false) const
bool IsLinked (const int theNode1Index, const int theNode2Index, bool theIgnoreMediumNodes=false) const
int GetNodeIndex (const SMDS_MeshNode *theNode) const
int GetAllExistingEdges (std::vector< const SMDS_MeshElement * > &edges) const
 Fill vector with boundary edges existing in the mesh. More...
double MinLinearSize2 () const
 Return minimal square distance between connected corner nodes. More...
double MaxLinearSize2 () const
 Return maximal square distance between connected corner nodes. More...
void SetExternalNormal ()
int NbFaces () const
int NbFaceNodes (int faceIndex) const
const int * GetFaceNodesIndices (int faceIndex) const
const SMDS_MeshNode ** GetFaceNodes (int faceIndex) const
bool GetFaceNodes (int faceIndex, std::set< const SMDS_MeshNode * > &theFaceNodes) const
bool IsFaceExternal (int faceIndex) const
bool IsFreeFace (int faceIndex, const SMDS_MeshElement **otherVol=0) const
 Fast quickly check that only one volume is built on the face nodes This check is valid for conformal meshes only. More...
bool IsFreeFaceCheckAllNodes (int faceIndex, const SMDS_MeshElement **otherVol=0) const
 Check that only one volume is built on the face nodes Different to IsFreeFace function, all nodes of the face are checked. More...
bool IsFreeFaceAdv (int faceIndex, const SMDS_MeshElement **otherVol=0) const
 Thorough check that only one volume is built on the face nodes. More...
bool GetFaceNormal (int faceIndex, double &X, double &Y, double &Z) const
bool GetFaceBaryCenter (int faceIndex, double &X, double &Y, double &Z) const
 Return barycenter of a face. More...
bool AllFacesSameOriented () const
 Check that all the faces in a polyhedron follow the same orientation. More...
double GetFaceArea (int faceIndex) const
int GetOppFaceIndex (int faceIndex) const
int GetCenterNodeIndex (int faceIndex) const
 Return index of the node located at face center of a quadratic element like HEX27. More...
int GetFaceIndex (const std::set< const SMDS_MeshNode * > &theFaceNodes, const int theFaceIndexHint=-1) const
int GetAllExistingFaces (std::vector< const SMDS_MeshElement * > &faces) const
 Fill vector with boundary faces existing in the mesh. More...
static VolumeType GetType (int nbNodes)
static int NbFaces (VolumeType type)
static const int * GetFaceNodesIndices (VolumeType type, int faceIndex, bool external)
static int NbFaceNodes (VolumeType type, int faceIndex)
static int NbCornerNodes (VolumeType type)
 Useful to know nb of corner nodes of a quadratic volume. More...
static int GetOppFaceIndexOfHex (int faceIndex)
Private Types
typedef std::pair< int, int > Link
bool setFace (int faceIndex) const
bool projectNodesToNormal (int faceIndex, double &minProj, double &maxProj, double *normal=0) const
const SMDS_MeshElement * myVolume
const SMDS_MeshVolume * myPolyedre
bool myIgnoreCentralNodes
bool myVolForward
int myNbFaces
std::vector< const SMDS_MeshNode * > myVolumeNodes
std::vector< int > myPolyIndices
std::vector< int > myPolyQuantities
std::vector< int > myPolyFacetOri
std::map< Link, int > myFwdLinks
bool myExternalFaces
const int * myAllFacesNodeIndices_F
const int * myAllFacesNodeIndices_RE
const int * myAllFacesNbNodes
int myMaxFaceNbNodes
Facet myCurFace
◆ Link
typedef std::pair<int,int> SMDS_VolumeTool::Link
◆ VolumeType
UNKNOWN
TETRA
PYRAM
PENTA
HEXA
HEX_PRISM
QUAD_TETRA
QUAD_PYRAM
QUAD_PENTA
QUAD_HEXA
POLYHEDA
NB_VOLUME_TYPES
◆ SMDS_VolumeTool() [1/2]
SMDS_VolumeTool::SMDS_VolumeTool ( )
References Set().
◆ ~SMDS_VolumeTool()
SMDS_VolumeTool::~SMDS_VolumeTool ( )
◆ SMDS_VolumeTool() [2/2]
SMDS_VolumeTool::SMDS_VolumeTool ( const SMDS_MeshElement *  theVolume,
const bool  ignoreCentralNodes = true
References Set().
◆ AllFacesSameOriented()
bool SMDS_VolumeTool::AllFacesSameOriented ( ) const
Remarks
there is no differentiation for outward and inward face orientation.
References myCurFace, myExternalFaces, myFwdLinks, SMDS_VolumeTool::Facet::myNbNodes, SMDS_VolumeTool::Facet::myNodes, NbFaces(), and setFace().
Referenced by GetSize().
◆ Element()
const SMDS_MeshVolume * SMDS_VolumeTool::Element ( ) const
◆ GetAllExistingEdges()
int SMDS_VolumeTool::GetAllExistingEdges ( std::vector< const SMDS_MeshElement * > &  edges) const
edges- vector of found edges
int- nb of found faces
References SMDS_Mesh::FindEdge(), IsLinked(), and myVolumeNodes.
◆ GetAllExistingFaces()
int SMDS_VolumeTool::GetAllExistingFaces ( std::vector< const SMDS_MeshElement * > &  faces) const
faces- vector of found nodes
References SMDS_Mesh::FindFace(), GetFaceNodes(), IsPoly(), myCurFace, SMDS_VolumeTool::Facet::myNodes, NbFaceNodes(), NbFaces(), and setFace().
◆ GetBaryCenter()
bool SMDS_VolumeTool::GetBaryCenter ( double &  X,
double &  Y,
double &  Z
◆ GetCenterNodeIndex()
int SMDS_VolumeTool::GetCenterNodeIndex ( int  faceIndex) const
References myAllFacesNbNodes, and myVolumeNodes.
Referenced by SMESH_MesherHelper::AddTLinks(), SMESH_MeshEditor::MakeBoundaryMesh(), and SMESH_MeshEditor::SplitVolumes().
◆ GetFaceArea()
double SMDS_VolumeTool::GetFaceArea ( int  faceIndex) const
◆ GetFaceBaryCenter()
bool SMDS_VolumeTool::GetFaceBaryCenter ( int  faceIndex,
double &  X,
double &  Y,
double &  Z
◆ GetFaceIndex()
int SMDS_VolumeTool::GetFaceIndex ( const std::set< const SMDS_MeshNode * > &  theFaceNodes,
const int  theFaceIndexHint = -1
◆ GetFaceNodes() [1/2]
◆ GetFaceNodes() [2/2]
bool SMDS_VolumeTool::GetFaceNodes ( int  faceIndex,
◆ GetFaceNodesIndices() [1/2]
◆ GetFaceNodesIndices() [2/2]
const int * SMDS_VolumeTool::GetFaceNodesIndices ( VolumeType  type,
int  faceIndex,
bool  external
◆ GetFaceNormal()
◆ GetNodeIndex()
int SMDS_VolumeTool::GetNodeIndex ( const SMDS_MeshNode *  theNode) const
References myVolume, and myVolumeNodes.
◆ GetNodes()
◆ GetOppFaceIndex()
int SMDS_VolumeTool::GetOppFaceIndex ( int  faceIndex) const
◆ GetOppFaceIndexOfHex()
int SMDS_VolumeTool::GetOppFaceIndexOfHex ( int  faceIndex)
◆ GetScaledJacobian()
◆ GetSize()
◆ GetType()
◆ GetVolumeType()
◆ ID()
smIdType SMDS_VolumeTool::ID ( ) const
◆ Inverse()
◆ IsFaceExternal()
◆ IsForward()
◆ IsFreeFace()
◆ IsFreeFaceAdv()
bool SMDS_VolumeTool::IsFreeFaceAdv ( int  faceIndex,
const SMDS_MeshElement **  otherVol = 0
◆ IsFreeFaceCheckAllNodes()
bool SMDS_VolumeTool::IsFreeFaceCheckAllNodes ( int  faceIndex,
For non conforming meshes, the face that is not conform with the neighbor will be identify as free.
References GetFaceNodes(), SMDS_MeshNode::GetInverseElementIterator(), IsFreeFace(), SMDS_MeshElement::IsQuadratic(), myCurFace, SMDS_VolumeTool::Facet::myNbNodes, myVolume, setFace(), and SMDSAbs_Volume.
Referenced by StdMeshers::Cartesian3D::Hexahedron::addFaces().
◆ IsLinked() [1/2]
bool SMDS_VolumeTool::IsLinked ( const int  theNode1Index,
bool  theIgnoreMediumNodes = false
◆ IsLinked() [2/2]
◆ IsOut()
bool SMDS_VolumeTool::IsOut ( double  X,
double  Y,
double  Z,
double  tol
Classify a point.
tol- thickness of faces
References GetFaceNormal(), IsFaceExternal(), myCurFace, myNbFaces, and SMDS_VolumeTool::Facet::myNodes.
Referenced by SMESH_MeshAlgos::IsOut().
◆ IsPoly()
◆ MaxLinearSize2()
double SMDS_VolumeTool::MaxLinearSize2 ( ) const
◆ MinLinearSize2()
double SMDS_VolumeTool::MinLinearSize2 ( ) const
◆ NbCornerNodes()
int SMDS_VolumeTool::NbCornerNodes ( VolumeType  type)
type- volume type
int- nb of corner nodes
References HEX_PRISM, HEXA, PENTA, PYRAM, QUAD_HEXA, QUAD_PENTA, QUAD_PYRAM, QUAD_TETRA, and TETRA.
Referenced by StdMeshers_Projection_3D::Compute().
◆ NbFaceNodes() [1/2]
◆ NbFaceNodes() [2/2]
int SMDS_VolumeTool::NbFaceNodes ( VolumeType  type,
int  faceIndex
◆ NbFaces() [1/2]
◆ NbFaces() [2/2]
int SMDS_VolumeTool::NbFaces ( VolumeType  type)
◆ NbNodes()
◆ projectNodesToNormal()
bool SMDS_VolumeTool::projectNodesToNormal ( int  faceIndex,
double &  minProj,
double &  maxProj,
double *  normal = 0
◆ Set()
bool SMDS_VolumeTool::Set ( const SMDS_MeshElement *  theVolume,
const bool  ignoreCentralNodes = true,
const std::vector< const SMDS_MeshNode * > *  nodes = 0
References SMDS_MeshElement::begin_nodes(), SMDS_MeshElement::end_nodes(), GetFaceNormal(), SMDS_MeshElement::GetType(), IsLinked(), SMDS_MeshElement::IsPoly(), myAllFacesNbNodes, myAllFacesNodeIndices_F, myAllFacesNodeIndices_RE, myCurFace, myExternalFaces, myFwdLinks, myIgnoreCentralNodes, SMDS_VolumeTool::Facet::myIndex, myNbFaces, SMDS_VolumeTool::Facet::myNodeIndices, SMDS_VolumeTool::Facet::myNodes, myPolyedre, myPolyFacetOri, myPolyIndices, myPolyQuantities, myVolForward, myVolume, myVolumeNodes, SMDS_MeshElement::NbCornerNodes(), SMDS_MeshElement::NbFaces(), SMDS_MeshElement::NbNodes(), setFace(), SMDSAbs_Volume, SMDS_MeshNode::X(), SMDS_MeshNode::Y(), and SMDS_MeshNode::Z().
Referenced by StdMeshers::Cartesian3D::Hexahedron::addFaces(), StdMeshers_Prism_3D::AddPrisms(), SMESH_Mesh_i::BaryCenter(), SMESH_MeshAlgos::DeMerge(), DriverSTL_W_SMDS_Mesh::findVolumeTriangles(), SMESH_MesherHelper::FixQuadraticElements(), SMESH_MeshEditor::GetHexaFacetsToSplit(), SMESH_Algo::GetMeshError(), SMESH::Controls::Volume::GetValue(), SMESH::Controls::ScaledJacobian::GetValue(), SMESH_MeshAlgos::IntersectRayVolume(), SMESH::Controls::BareBorderVolume::IsSatisfy(), SMESH::Controls::OverConstrainedVolume::IsSatisfy(), SMESH_Block::LoadMeshBlock(), SMESH_MeshEditor::MakeBoundaryMesh(), SMESH_Pattern::makePolyElements(), StdMeshers_Penta_3D::MakeVolumeMesh(), SMESH_MeshEditor::makeWalls(), StdMeshers_QuadToTriaAdaptor::MergePiramids(), SMESH::SelectionProxy::perFaceConnectivity(), DriverCGNS_Write::Perform(), SMESH_MeshEditor::Reorient2DBy3D(), SMESH_MeshEditor::SewFreeBorder(), SMDS_VolumeTool(), splitPolygon(), and SMESH_MeshEditor::SplitVolumes().
◆ SetExternalNormal()
◆ setFace()
◆ myAllFacesNbNodes
const int* SMDS_VolumeTool::myAllFacesNbNodes
mutableprivate
◆ myAllFacesNodeIndices_F
const int* SMDS_VolumeTool::myAllFacesNodeIndices_F
mutableprivate
Referenced by Set(), and setFace().
◆ myAllFacesNodeIndices_RE
const int* SMDS_VolumeTool::myAllFacesNodeIndices_RE
mutableprivate
◆ myCurFace
◆ myExternalFaces
bool SMDS_VolumeTool::myExternalFaces
mutableprivate
◆ myFwdLinks
std::map<Link, int> SMDS_VolumeTool::myFwdLinks
◆ myIgnoreCentralNodes
bool SMDS_VolumeTool::myIgnoreCentralNodes
◆ myMaxFaceNbNodes
int SMDS_VolumeTool::myMaxFaceNbNodes
mutableprivate
Referenced by setFace().
◆ myNbFaces
int SMDS_VolumeTool::myNbFaces
◆ myPolyedre
const SMDS_MeshVolume* SMDS_VolumeTool::myPolyedre
◆ myPolyFacetOri
std::vector< int > SMDS_VolumeTool::myPolyFacetOri
Referenced by IsFaceExternal(), and Set().
◆ myPolyIndices
std::vector< int > SMDS_VolumeTool::myPolyIndices
◆ myPolyQuantities
std::vector<int> SMDS_VolumeTool::myPolyQuantities
Referenced by IsLinked(), Set(), and setFace().
◆ myVolForward
bool SMDS_VolumeTool::myVolForward
Referenced by Inverse(), Set(), and setFace().
◆ myVolume
◆ myVolumeNodes
