SMESH::SelectionProxy Class Reference
Provide operations over the selected object. More...
#include <SMESHGUI_SelectionProxy.h>
enum  Type {
  Unknown , Mesh , Submesh , Group ,
  GroupStd , GroupGeom , GroupFilter
 SelectionProxy ()
 Default constructor. More...
 SelectionProxy (const Handle(SALOME_InteractiveObject)&)
 SelectionProxy (SMESH::SMESH_IDSource_ptr)
 SelectionProxy (const SelectionProxy &)
 Copy constructor. More...
SelectionProxy & operator= (const SelectionProxy &)
 Assignment operator. More...
bool operator== (const SelectionProxy &)
 Equality comparison operator. More...
void refresh ()
 Re-initialize proxy. More...
bool isNull () const
 Check if proxy is null. More...
 operator bool () const
 Boolean conversion operator. More...
SMESH::SMESH_IDSource_ptr object () const
const Handle (SALOME_InteractiveObject) &io() const
SMESH_Actor * actor () const
bool isValid () const
void load ()
QString name () const
 Get name. More...
Type type () const
 Get type. More...
MeshInfo meshInfo () const
 Get mesh information. More...
SelectionProxy mesh () const
 Get parent mesh. More...
bool hasShapeToMesh () const
 Check if parent mesh has shape to mesh. More...
GEOM::GEOM_Object_ptr shape () const
 Get referenced GEOM object. More...
QString shapeName () const
 Get name of referenced GEOM object. More...
int shapeType () const
 Get type of referenced GEOM object. More...
bool isMeshLoaded () const
 Check if mesh has been loaded from study file. More...
bool hasNode (int)
 Check if node with given ID is present in the mesh. More...
bool nodeCoordinates (int, XYZ &)
 Get node coordinates. More...
bool nodeConnectivity (int, Connectivity &)
 Get node connectivity. More...
bool nodePosition (int, Position &)
 Get node position on a shape. More...
QList< SelectionProxy > nodeGroups (int) const
 Get groups given node belongs to. More...
bool hasElement (int)
 Check if element with given ID is present in the mesh. More...
SMESH::ElementType elementType (int) const
 Get type of given mesh element. More...
int elementEntityType (int) const
 Get entity type of given mesh element. More...
bool elementConnectivity (SMESH::smIdType, Connectivity &)
 Get element connectivity. More...
bool perFaceConnectivity (int, Connectivity &, int &)
 Get volume element connectivity. More...
bool elementPosition (int, Position &)
 Get element position on a shape. More...
bool elementGravityCenter (int, XYZ &)
 Get gravity center of given element. More...
bool elementNormal (int, XYZ &)
 Get normal vector to given element (face). More...
bool elementControl (int, int, double, double &) const
 Get quality control's value for given element. More...
QList< SelectionProxy > elementGroups (int) const
 Get groups given element belongs to. More...
MedInfo medFileInfo () const
 Get MED file information. More...
QList< SelectionProxy > submeshes () const
 Get child sub-meshes. More...
QList< SelectionProxy > groups () const
 Get child groups. More...
SMESH::ElementType groupElementType () const
 Get element type (for group). More...
QColor color () const
 Get color (for group). More...
SMESH::smIdType size (bool=false) const
 Get size (for group). More...
SMESH::smIdType nbNodes (bool=false) const
 Get number of underlying nodes (for group of elements). More...
QSet< uint > ids () const
 Get list of nodes / elements IDs for the mesh group. More...
 Handle (SALOME_InteractiveObject) myIO
void init ()
 Perform internal initialization. More...
SMESH::SMESH_IDSource_var myObject
SMESH_Actor * myActor
bool myDirty
The selection proxy class is aimed to use in dialogs to access mesh object data either from actor or directly from CORBA reference, depending on what of them is accessible. This is useful in situations when some information is needed, but an actor was not created yet.
Selection proxy can be constructed in two ways:
  • From interactive object: this performs full proxy initialization including pick-up of an actor from the current viewer if it exists.
  • From mesh source object (CORBA reference); for performance reasons in this case full initialization is not immediately done and performed only when needed.
◆ Type
Unknown
Mesh
Submesh
Group
GroupStd
GroupGeom
GroupFilter
◆ SelectionProxy() [1/4]
SMESH::SelectionProxy::SelectionProxy ( )
Creates null proxy.
◆ SelectionProxy() [2/4]
SMESH::SelectionProxy::SelectionProxy ( const Handle(SALOME_InteractiveObject)&  io)
ioInteractive object.
References init(), and myObject.
◆ SelectionProxy() [3/4]
SMESH::SelectionProxy::SelectionProxy ( SMESH::SMESH_IDSource_ptr  object)
objectMesh source.
References myObject.
◆ SelectionProxy() [4/4]
SMESH::SelectionProxy::SelectionProxy ( const SelectionProxy &  other)
Copy constructor.
otherProxy being copied.
References myActor, myDirty, and myObject.
◆ actor()
SMESH_Actor * SMESH::SelectionProxy::actor ( ) const
◆ color()
QColor SMESH::SelectionProxy::color ( ) const
For other mesh objects result is undefined.
Group's color.
Referenced by SMESHGUI_AddInfo::groupInfo(), and SMESHGUI_ElemInfo::writeInfo().
◆ elementConnectivity()
bool SMESH::SelectionProxy::elementConnectivity ( SMESH::smIdType  id,
Connectivity &  connectivity
idMesh element ID.
connectivityReturn element connectivity.
true if result is valid; false otherwise.
References SMDS_Mesh::FindElement(), SMDS_MeshElement::GetID(), SMDS_MeshElement::GetMesh(), SMDS_MeshElement::nodeIterator(), and SMDSAbs_Node.
Referenced by SMESHGUI_ElemInfo::writeInfo().
◆ elementControl()
bool SMESH::SelectionProxy::elementControl ( int  id,
int  control,
double  precision,
double &  value
idMesh element ID.
controlQuality control type.
precisionPrecision for control's value.
valueReturned quality control's value.
References SMDS_Mesh::FindElement(), SMESH::FT_Area, SMESH::FT_AspectRatio, SMESH::FT_AspectRatio3D, SMESH::FT_BallDiameter, SMESH::FT_Length, SMESH::FT_Length2D, SMESH::FT_Length3D, SMESH::FT_MaxElementLength2D, SMESH::FT_MaxElementLength3D, SMESH::FT_MinimumAngle, SMESH::FT_ScaledJacobian, SMESH::FT_Skew, SMESH::FT_Taper, SMESH::FT_Volume3D, SMESH::FT_Warping, SMESH::FT_Warping3D, SMDS_MeshElement::GetMesh(), SMESHGUI::GetSMESHGen(), and SMDS_MeshElement::GetType().
◆ elementEntityType()
int SMESH::SelectionProxy::elementEntityType ( int  id) const
idMesh element ID.
Entity type.
References SMESH::Entity_Last, SMDS_Mesh::FindElement(), SMDS_MeshElement::GetEntityType(), and SMDS_MeshElement::GetMesh().
◆ elementGravityCenter()
bool SMESH::SelectionProxy::elementGravityCenter ( int  id,
SMESH::XYZ &  xyz
idMesh element ID.
xyzReturned gravity center.
References SMESH::XYZ::add(), SMESH::XYZ::divide(), SMDS_Mesh::FindElement(), SMDS_MeshElement::GetMesh(), SMDS_MeshElement::NbNodes(), SMDS_MeshElement::nodesIterator(), SMDS_MeshNode::X(), SMDS_MeshNode::Y(), and SMDS_MeshNode::Z().
Referenced by SMESHGUI_MeshInfoDlg::idChanged(), and SMESHGUI_ElemInfo::writeInfo().
◆ elementGroups()
QList< SMESH::SelectionProxy > SMESH::SelectionProxy::elementGroups ( int  id) const
idMesh element ID.
List of groups containing element.
References SMESH::NODE.
◆ elementNormal()
bool SMESH::SelectionProxy::elementNormal ( int  id,
SMESH::XYZ &  xyz
idMesh element ID.
xyzReturned normal vector.
References SMDS_Mesh::FindElement(), SMDS_MeshElement::GetMesh(), SMESH::getNormale(), SMDS_MeshElement::GetType(), and SMDSAbs_Face.
◆ elementPosition()
bool SMESH::SelectionProxy::elementPosition ( int  id,
Position &  position
idMesh element ID.
positionReturned element position.
References SMESH::Position::setShapeId(), and SMESH::Position::setShapeType().
◆ elementType()
SMESH::ElementType SMESH::SelectionProxy::elementType ( int  id) const
idMesh element ID.
Element type.
References SMESH::ALL, SMDS_Mesh::FindElement(), SMDS_MeshElement::GetMesh(), and SMDS_MeshElement::GetType().
◆ groupElementType()
SMESH::ElementType SMESH::SelectionProxy::groupElementType ( ) const
Group's element type.
References SMESH::ALL.
Referenced by SMESHGUI_AddInfo::groupInfo(), SMESHGUI_AddInfo::showGroups(), SMESHGUI_BaseInfo::showInfo(), and SMESHGUI_ElemInfo::showInfo().
◆ groups()
QList< SMESH::SelectionProxy > SMESH::SelectionProxy::groups ( ) const
Get child groups.
List of groups for mesh object; empty list for other types.
Referenced by SMESHGUI_AddInfo::meshInfo(), and GroupCombo::setSource().
◆ Handle() [1/2]
const SMESH::SelectionProxy::Handle ( SALOME_InteractiveObject  ) const &
◆ Handle() [2/2]
◆ hasElement()
bool SMESH::SelectionProxy::hasElement ( int  id)
idMesh element ID.
true if mesh contains element; false otherwise.
References SMDS_Mesh::FindElement(), and SMDS_MeshElement::GetMesh().
Referenced by SMESHGUI_MeshInfoDlg::idChanged().
◆ hasNode()
bool SMESH::SelectionProxy::hasNode ( int  id)
idMesh node ID.
true if mesh contains node; false otherwise.
References SMDS_Mesh::FindNode(), and SMDS_MeshElement::GetMesh().
◆ hasShapeToMesh()
bool SMESH::SelectionProxy::hasShapeToMesh ( ) const
true if Parent mesh is built on a shape; false otherwise.
For group or submesh, this method checks that parent mesh has a shape.
◆ ids()
QSet< uint > SMESH::SelectionProxy::ids ( ) const
List of IDs for group object; empty list for other types.
Referenced by SMESHGUI_ElemInfo::showInfo().
◆ init()
void SMESH::SelectionProxy::init ( )
References SMESH::_PTR(), and SMESH::FindActorByEntry().
Referenced by SelectionProxy().
◆ isMeshLoaded()
bool SMESH::SelectionProxy::isMeshLoaded ( ) const
true if mesh was loaded; false otherwise.
Referenced by SMESHGUI_AddInfo::groupInfo().
◆ isNull()
bool SMESH::SelectionProxy::isNull ( ) const
true if proxy is null; false otherwise.
◆ isValid()
bool SMESH::SelectionProxy::isValid ( ) const
◆ load()
void SMESH::SelectionProxy::load ( )
◆ medFileInfo()
SMESH::MedInfo SMESH::SelectionProxy::medFileInfo ( ) const
The result contains valid data only if proxy refers to mesh object which has been imported from the MED file.
References SMESH::MedInfo::setFileName(), SMESH::MedInfo::setSize(), and SMESH::MedInfo::setVersion().
Referenced by SMESHGUI_AddInfo::meshInfo().
◆ mesh()
SMESH::SelectionProxy SMESH::SelectionProxy::mesh ( ) const
Get parent mesh.
Proxy object that stores parent mesh object.
For proxy that stores a mesh, returns its copy.
Referenced by SMESHGUI_AddInfo::groupInfo(), and SMESHGUI_AddInfo::subMeshInfo().
◆ meshInfo()
SMESH::MeshInfo SMESH::SelectionProxy::meshInfo ( ) const
Statistics on stored mesh object.
References SMESH::MeshInfo::addInfo(), SMESH::Entity_Last, and SMESH::Entity_Node.
Referenced by SMESHGUI_BaseInfo::showInfo().
◆ nbNodes()
SMESH::smIdType SMESH::SelectionProxy::nbNodes ( bool  autoCompute = false) const
autoComputeCompute size if it is unavailable. Defaults to false.
Number of nodes contained in group.
References SMESHGUI::resourceMgr().
Referenced by InfoComputor::compute(), and SMESHGUI_AddInfo::groupInfo().
◆ nodeConnectivity()
bool SMESH::SelectionProxy::nodeConnectivity ( int  id,
SMESH::Connectivity &  connectivity
idMesh node ID.
connectivityReturned node connectivity.
References SMESH::ALL, SMDS_Mesh::FindNode(), SMDS_MeshElement::GetID(), SMDS_MeshNode::GetInverseElementIterator(), SMDS_MeshElement::GetMesh(), and SMDS_MeshElement::GetType().
◆ nodeCoordinates()
bool SMESH::SelectionProxy::nodeCoordinates ( int  id,
SMESH::XYZ &  xyz
idMesh node ID.
xyzReturned node coordinates.
References SMDS_Mesh::FindNode(), SMDS_MeshElement::GetMesh(), SMDS_MeshNode::X(), SMDS_MeshNode::Y(), and SMDS_MeshNode::Z().
◆ nodeGroups()
QList< SMESH::SelectionProxy > SMESH::SelectionProxy::nodeGroups ( int  id) const
idMesh node ID.
List of groups containing given node.
◆ nodePosition()
bool SMESH::SelectionProxy::nodePosition ( int  id,
Position &  position
idMesh node ID.
positionReturned node position.
References EDGE, FACE, SMESH::Position::setShapeId(), SMESH::Position::setShapeType(), SMESH::Position::setU(), and SMESH::Position::setV().
◆ object()
◆ operator bool()
SMESH::SelectionProxy::operator bool ( ) const
true if proxy is not null; false otherwise.
◆ operator=()
SMESH::SelectionProxy & SMESH::SelectionProxy::operator= ( const SelectionProxy &  other)
◆ operator==()
bool SMESH::SelectionProxy::operator== ( const SelectionProxy &  other)
otherProxy to compare with.
true if two proxies are equal; false otherwise.
◆ perFaceConnectivity()
bool SMESH::SelectionProxy::perFaceConnectivity ( int  id,
Connectivity &  connectivity,
int &  nbNodes
idMesh element ID.
connectivityReturn nodal connectivity of each facet numbered from 1
nbNodesReturn number of unique nodes.
References SMDS_Mesh::FindElement(), SMDS_VolumeTool::GetFaceNodes(), SMDS_MeshElement::GetID(), SMDS_MeshElement::GetMesh(), SMDS_VolumeTool::NbFaceNodes(), SMDS_VolumeTool::NbFaces(), and SMDS_VolumeTool::Set().
◆ refresh()
void SMESH::SelectionProxy::refresh ( )
◆ shape()
GEOM::GEOM_Object_ptr SMESH::SelectionProxy::shape ( ) const
GEOM object referenced by selection proxy.
The result contains valid pointer only if proxy refers to mesh, sub-mesh or group created on a geometry.
◆ shapeName()
QString SMESH::SelectionProxy::shapeName ( ) const
Name of GEOM object referenced by selection proxy.
The result contains non-empty name only if proxy refers to mesh, sub-mesh or group created on a geometry, and if that geometry has valid name.
References SMESH::_PTR().
Referenced by SMESHGUI_AddInfo::groupInfo(), SMESHGUI_AddInfo::meshInfo(), SMESHGUI_AddInfo::subMeshInfo(), and SMESHGUI_ElemInfo::writeInfo().
◆ shapeType()
int SMESH::SelectionProxy::shapeType ( ) const
Type of GEOM object referenced by selection proxy.
The result contains valid type only if proxy refers to mesh, sub-mesh or group created on a geometry.
Referenced by SMESHGUI_AddInfo::showSubMeshes().
◆ size()
SMESH::smIdType SMESH::SelectionProxy::size ( bool  autoCompute = false) const
Group's size.
Referenced by InfoComputor::compute(), SMESHGUI_AddInfo::groupInfo(), and SMESHGUI_ElemInfo::writeInfo().
◆ submeshes()
QList< SMESH::SelectionProxy > SMESH::SelectionProxy::submeshes ( ) const
List of sub-meshes for mesh object; empty list for other types.
◆ type()
◆ myActor
SMESH_Actor* SMESH::SelectionProxy::myActor
Referenced by operator=(), and SelectionProxy().
◆ myDirty
bool SMESH::SelectionProxy::myDirty
◆ myObject
SMESH::SMESH_IDSource_var SMESH::SelectionProxy::myObject
