SMESHGUI_ElemInfo Class Referenceabstract
Base class for the mesh element information widget. More...
#include <SMESHGUI_MeshInfo.h>
Inheritance diagram for SMESHGUI_ElemInfo:
Signals
void itemInfo (int type, const QString &ids)
 SMESHGUI_ElemInfo (QWidget *=0)
 ~SMESHGUI_ElemInfo ()
void showInfo (const SMESH::SelectionProxy &, uint, bool)
 Show information on given node / element. More...
void showInfo (const SMESH::SelectionProxy &, QSet< uint >, bool)
 Show information on given nodes / elements. More...
void showInfo (const SMESH::SelectionProxy &)
 Show information on given group. More...
void clear ()
 Reset panel (clear all data). More...
void saveInfo (QTextStream &)
 Write information from panel to output stream. More...
Protected Types
enum  { ShowNone , ShowNodes , ShowElements }
QWidget * centralWidget () const
 Get central area widget. More...
SMESH::SelectionProxy proxy () const
 Get current mesh proxy object information is shown on. More...
int what () const
 Get current info mode. More...
QString type2str (int, bool=false)
 Get title for given element type. More...
QString stype2str (int)
 Get title for given shape type. More...
QString etype2str (int)
QString ctrl2str (int)
 Get title for given quality control. More...
void writeInfo (InfoWriter *, const QList< uint > &)
 Write information on given mesh nodes / elements. More...
virtual void information (const QList< uint > &)=0
 Show information on given mesh nodes / elements. More...
virtual void clearInternal ()
 Internal clean-up (reset panel). More...
Private Slots
void showPrevious ()
 Show previous chunk of information. More...
void showNext ()
 Show next chunk of information. More...
void updateControls ()
 Update control widget state. More...
QWidget * myFrame
ExtraWidget * myExtra
SMESH::SelectionProxy myProxy
int myWhat
QList< uint > myIDs
int myIndex
Displays the detail information about given mesh node(s) or element(s). Default class does not provide working implementation but onle general functionalities; main work is done in sub-classes.
◆ anonymous enum
anonymous enum
ShowNone
ShowNodes
ShowElements
◆ SMESHGUI_ElemInfo()
SMESHGUI_ElemInfo::SMESHGUI_ElemInfo ( QWidget *  parent = 0)
parentParent widget. Defaults to 0.
References clear(), myExtra, myFrame, ExtraWidget::next, ExtraWidget::prev, showNext(), showPrevious(), and SPACING.
◆ ~SMESHGUI_ElemInfo()
SMESHGUI_ElemInfo::~SMESHGUI_ElemInfo ( )
◆ centralWidget()
QWidget * SMESHGUI_ElemInfo::centralWidget ( ) const
Central widget.
References myFrame.
Referenced by SMESHGUI_SimpleElemInfo::SMESHGUI_SimpleElemInfo(), and SMESHGUI_TreeElemInfo::SMESHGUI_TreeElemInfo().
◆ clear()
void SMESHGUI_ElemInfo::clear ( )
References clearInternal(), myIDs, myIndex, and updateControls().
Referenced by SMESHGUI_MeshInfoDlg::showInfo(), showInfo(), and SMESHGUI_ElemInfo().
◆ clearInternal()
void SMESHGUI_ElemInfo::clearInternal ( )
Default implementation does nothing; the method has to be redefined in sub-classes to perform internal clean-up.
Reimplemented in SMESHGUI_SimpleElemInfo, and SMESHGUI_TreeElemInfo.
Referenced by clear().
◆ ctrl2str()
QString SMESHGUI_ElemInfo::ctrl2str ( int  control)
◆ etype2str()
◆ information()
void SMESHGUI_ElemInfo::information ( const QList< uint > &  ids)
protectedpure virtual
This function has to be redefined in sub-classes.
idsNodes / elements IDs.
Implemented in SMESHGUI_SimpleElemInfo, and SMESHGUI_TreeElemInfo.
Referenced by showInfo(), showNext(), and showPrevious().
◆ itemInfo
void SMESHGUI_ElemInfo::itemInfo ( int  type,
const QString &  ids
signal
◆ proxy()
SMESH::SelectionProxy SMESHGUI_ElemInfo::proxy ( ) const
Current proxy.
References myProxy.
Referenced by showInfo(), and writeInfo().
◆ saveInfo()
void SMESHGUI_ElemInfo::saveInfo ( QTextStream &  out)
outText stream output.
Implements SMESHGUI_Info.
References myIDs, and writeInfo().
Referenced by SMESHGUI_MeshInfoDlg::dump().
◆ showInfo() [1/3]
void SMESHGUI_ElemInfo::showInfo ( const SMESH::SelectionProxy &  proxy)
proxyObject to compute information on (group).
References SMESH::ALL, clear(), SMESH::SelectionProxy::groupElementType(), SMESH::SelectionProxy::ids(), SMESH::NODE, proxy(), and showInfo().
◆ showInfo() [2/3]
void SMESHGUI_ElemInfo::showInfo ( const SMESH::SelectionProxy &  proxy,
QSet< uint >  ids,
bool  isElement
proxyObject to compute information on (mesh, sub-mesh, group, ID source).
idsMesh nodes / elements IDs.
isElementIf true, show element info; otherwise show node info.
References clear(), information(), myIDs, myIndex, myProxy, myWhat, proxy(), SMESH::SelectionProxy::refresh(), ShowElements, ShowNodes, updateControls(), and what().
◆ showInfo() [3/3]
uint  id,
bool  isElement
idMesh node / element ID.
References proxy(), and showInfo().
Referenced by SMESHGUI_MeshInfoDlg::idChanged(), SMESHGUI_MeshInfoDlg::showInfo(), and showInfo().
◆ showNext
void SMESHGUI_ElemInfo::showNext ( )
privateslot
References information(), myIDs, myIndex, and updateControls().
Referenced by SMESHGUI_ElemInfo().
◆ showPrevious
void SMESHGUI_ElemInfo::showPrevious ( )
privateslot
◆ stype2str()
QString SMESHGUI_ElemInfo::stype2str ( int  type)
typeShape type.
Shape type's title.
References EDGE, and FACE.
Referenced by writeInfo().
◆ type2str()
QString SMESHGUI_ElemInfo::type2str ( int  type,
bool  multiple = false
typeMesh element type.
multipleUse plural form. Defaults to false.
Element type's title.
References SMDSAbs_0DElement, SMDSAbs_Ball, SMDSAbs_Edge, SMDSAbs_Face, and SMDSAbs_Volume.
◆ updateControls
void SMESHGUI_ElemInfo::updateControls ( )
privateslot
References myExtra, myIDs, myIndex, and ExtraWidget::updateControls().
Referenced by clear(), showInfo(), showNext(), and showPrevious().
◆ what()
int SMESHGUI_ElemInfo::what ( ) const
Current panel mode.
References myWhat.
Referenced by SMESHGUI_TreeElemInfo::expandedResource(), showInfo(), and writeInfo().
◆ writeInfo()
void SMESHGUI_ElemInfo::writeInfo ( InfoWriter *  writer,
writerInformation writer.
References SMESH::ALL, SMESH::SelectionProxy::color(), ctrl2str(), SMESH::SelectionProxy::elementConnectivity(), SMESH::SelectionProxy::elementEntityType(), SMESH::SelectionProxy::elementGravityCenter(), SMESH::SelectionProxy::elementGroups(), SMESH::SelectionProxy::elementNormal(), SMESH::SelectionProxy::elementPosition(), SMESH::SelectionProxy::elementType(), SMESH::Entity_Polyhedra, SMESH::Entity_Quad_Polyhedra, etype2str(), SMESH::FT_AspectRatio, SMESH::FT_Undefined, SMESH::SelectionProxy::GroupFilter, SMESH::SelectionProxy::GroupGeom, SMESH::SelectionProxy::GroupStd, SMESH::Position::hasU(), SMESH::Position::hasV(), InfoWriter::indent(), SMESH::Position::isValid(), SMESH::SelectionProxy::name(), SMESH::SelectionProxy::nodeConnectivity(), SMESH::SelectionProxy::nodeCoordinates(), SMESH::SelectionProxy::nodeGroups(), SMESH::SelectionProxy::nodePosition(), SMESH::SelectionProxy::perFaceConnectivity(), proxy(), SMESHGUI::resourceMgr(), InfoWriter::separator(), SMESH::Position::shapeId(), SMESH::SelectionProxy::shapeName(), SMESH::Position::shapeType(), ShowElements, ShowNodes, SMESH::SelectionProxy::size(), SMDSAbs_Ball, SMDSAbs_Edge, SMDSAbs_Face, SMDSAbs_Node, stype2str(), SMESH::SelectionProxy::type(), type2str(), SMESH::Position::u(), InfoWriter::unindent(), SMESH::Position::v(), what(), and InfoWriter::write().
Referenced by SMESHGUI_SimpleElemInfo::information(), SMESHGUI_TreeElemInfo::information(), and saveInfo().
◆ myExtra
ExtraWidget* SMESHGUI_ElemInfo::myExtra
◆ myFrame
QWidget* SMESHGUI_ElemInfo::myFrame
Referenced by centralWidget(), and SMESHGUI_ElemInfo().
◆ myIDs
QList<uint> SMESHGUI_ElemInfo::myIDs
◆ myIndex
int SMESHGUI_ElemInfo::myIndex
◆ myProxy
SMESH::SelectionProxy SMESHGUI_ElemInfo::myProxy
Referenced by proxy(), and showInfo().
◆ myWhat
int SMESHGUI_ElemInfo::myWhat
Referenced by showInfo(), and what().
