SMESHGUI_SimpleElemInfo Class Reference
Show mesh element information in the simple text area. More...
#include <SMESHGUI_MeshInfo.h>
Inheritance diagram for SMESHGUI_SimpleElemInfo:
Signals
void itemInfo (int type, const QString &ids)
 SMESHGUI_SimpleElemInfo (QWidget *=0)
void showInfo (const SMESH::SelectionProxy &, uint, bool)
 Show information on given node / element. More...
void showInfo (const SMESH::SelectionProxy &, QSet< uint >, bool)
 Show information on given nodes / elements. More...
void showInfo (const SMESH::SelectionProxy &)
 Show information on given group. More...
void clear ()
 Reset panel (clear all data). More...
void saveInfo (QTextStream &)
 Write information from panel to output stream. More...
Protected Types
enum  { ShowNone , ShowNodes , ShowElements }
void information (const QList< uint > &)
 Show mesh element information. More...
void clearInternal ()
 Internal clean-up (reset widget) More...
QWidget * centralWidget () const
 Get central area widget. More...
SMESH::SelectionProxy proxy () const
 Get current mesh proxy object information is shown on. More...
int what () const
 Get current info mode. More...
QString type2str (int, bool=false)
 Get title for given element type. More...
QString stype2str (int)
 Get title for given shape type. More...
QString etype2str (int)
QString ctrl2str (int)
 Get title for given quality control. More...
void writeInfo (InfoWriter *, const QList< uint > &)
 Write information on given mesh nodes / elements. More...
Private Slots
void connectivityClicked (const QUrl &)
void showPrevious ()
 Show previous chunk of information. More...
void showNext ()
 Show next chunk of information. More...
void updateControls ()
 Update control widget state. More...
QTextBrowser * myInfo
QWidget * myFrame
ExtraWidget * myExtra
SMESH::SelectionProxy myProxy
int myWhat
QList< uint > myIDs
int myIndex
◆ anonymous enum
anonymous enum
ShowNone
ShowNodes
ShowElements
◆ SMESHGUI_SimpleElemInfo()
SMESHGUI_SimpleElemInfo::SMESHGUI_SimpleElemInfo ( QWidget *  parent = 0)
parentParent widget. Defaults to 0.
References SMESHGUI_ElemInfo::centralWidget(), connectivityClicked(), and myInfo.
◆ centralWidget()
QWidget * SMESHGUI_ElemInfo::centralWidget ( ) const
Central widget.
References SMESHGUI_ElemInfo::myFrame.
Referenced by SMESHGUI_SimpleElemInfo(), and SMESHGUI_TreeElemInfo::SMESHGUI_TreeElemInfo().
◆ clear()
◆ clearInternal()
void SMESHGUI_SimpleElemInfo::clearInternal ( )
Reimplemented from SMESHGUI_ElemInfo.
References myInfo.
Referenced by information().
◆ connectivityClicked
void SMESHGUI_SimpleElemInfo::connectivityClicked ( const QUrl &  url)
privateslot
◆ ctrl2str()
QString SMESHGUI_ElemInfo::ctrl2str ( int  control)
◆ etype2str()
◆ information()
void SMESHGUI_SimpleElemInfo::information ( const QList< uint > &  ids)
idsNodes / elements IDs.
Implements SMESHGUI_ElemInfo.
References clearInternal(), myInfo, and SMESHGUI_ElemInfo::writeInfo().
◆ itemInfo
void SMESHGUI_ElemInfo::itemInfo ( int  type,
const QString &  ids
signalinherited
◆ proxy()
SMESH::SelectionProxy SMESHGUI_ElemInfo::proxy ( ) const
Current proxy.
References SMESHGUI_ElemInfo::myProxy.
Referenced by SMESHGUI_ElemInfo::showInfo(), and SMESHGUI_ElemInfo::writeInfo().
◆ saveInfo()
void SMESHGUI_ElemInfo::saveInfo ( QTextStream &  out)
outText stream output.
Implements SMESHGUI_Info.
References SMESHGUI_ElemInfo::myIDs, and SMESHGUI_ElemInfo::writeInfo().
Referenced by SMESHGUI_MeshInfoDlg::dump().
◆ showInfo() [1/3]
void SMESHGUI_ElemInfo::showInfo ( const SMESH::SelectionProxy &  proxy)
proxyObject to compute information on (group).
References SMESH::ALL, SMESHGUI_ElemInfo::clear(), SMESH::SelectionProxy::groupElementType(), SMESH::SelectionProxy::ids(), SMESH::NODE, SMESHGUI_ElemInfo::proxy(), and SMESHGUI_ElemInfo::showInfo().
◆ showInfo() [2/3]
void SMESHGUI_ElemInfo::showInfo ( const SMESH::SelectionProxy &  proxy,
QSet< uint >  ids,
bool  isElement
proxyObject to compute information on (mesh, sub-mesh, group, ID source).
idsMesh nodes / elements IDs.
isElementIf true, show element info; otherwise show node info.
References SMESHGUI_ElemInfo::clear(), SMESHGUI_ElemInfo::information(), SMESHGUI_ElemInfo::myIDs, SMESHGUI_ElemInfo::myIndex, SMESHGUI_ElemInfo::myProxy, SMESHGUI_ElemInfo::myWhat, SMESHGUI_ElemInfo::proxy(), SMESH::SelectionProxy::refresh(), SMESHGUI_ElemInfo::ShowElements, SMESHGUI_ElemInfo::ShowNodes, SMESHGUI_ElemInfo::updateControls(), and SMESHGUI_ElemInfo::what().
◆ showInfo() [3/3]
uint  id,
bool  isElement
idMesh node / element ID.
References SMESHGUI_ElemInfo::proxy(), and SMESHGUI_ElemInfo::showInfo().
Referenced by SMESHGUI_MeshInfoDlg::idChanged(), SMESHGUI_MeshInfoDlg::showInfo(), and SMESHGUI_ElemInfo::showInfo().
◆ showNext
void SMESHGUI_ElemInfo::showNext ( )
privateslotinherited
◆ showPrevious
void SMESHGUI_ElemInfo::showPrevious ( )
◆ stype2str()
QString SMESHGUI_ElemInfo::stype2str ( int  type)
typeShape type.
Shape type's title.
References EDGE, and FACE.
Referenced by SMESHGUI_ElemInfo::writeInfo().
◆ type2str()
QString SMESHGUI_ElemInfo::type2str ( int  type,
bool  multiple = false
typeMesh element type.
multipleUse plural form. Defaults to false.
Element type's title.
References SMDSAbs_0DElement, SMDSAbs_Ball, SMDSAbs_Edge, SMDSAbs_Face, and SMDSAbs_Volume.
◆ updateControls
◆ what()
int SMESHGUI_ElemInfo::what ( ) const
Current panel mode.
References SMESHGUI_ElemInfo::myWhat.
Referenced by SMESHGUI_TreeElemInfo::expandedResource(), SMESHGUI_ElemInfo::showInfo(), and SMESHGUI_ElemInfo::writeInfo().
◆ writeInfo()
void SMESHGUI_ElemInfo::writeInfo ( InfoWriter *  writer,
writerInformation writer.
References SMESH::ALL, SMESH::SelectionProxy::color(), SMESHGUI_ElemInfo::ctrl2str(), SMESH::SelectionProxy::elementConnectivity(), SMESH::SelectionProxy::elementEntityType(), SMESH::SelectionProxy::elementGravityCenter(), SMESH::SelectionProxy::elementGroups(), SMESH::SelectionProxy::elementNormal(), SMESH::SelectionProxy::elementPosition(), SMESH::SelectionProxy::elementType(), SMESH::Entity_Polyhedra, SMESH::Entity_Quad_Polyhedra, SMESHGUI_ElemInfo::etype2str(), SMESH::FT_AspectRatio, SMESH::FT_Undefined, SMESH::SelectionProxy::GroupFilter, SMESH::SelectionProxy::GroupGeom, SMESH::SelectionProxy::GroupStd, SMESH::Position::hasU(), SMESH::Position::hasV(), InfoWriter::indent(), SMESH::Position::isValid(), SMESH::SelectionProxy::name(), SMESH::SelectionProxy::nodeConnectivity(), SMESH::SelectionProxy::nodeCoordinates(), SMESH::SelectionProxy::nodeGroups(), SMESH::SelectionProxy::nodePosition(), SMESH::SelectionProxy::perFaceConnectivity(), SMESHGUI_ElemInfo::proxy(), SMESHGUI::resourceMgr(), InfoWriter::separator(), SMESH::Position::shapeId(), SMESH::SelectionProxy::shapeName(), SMESH::Position::shapeType(), SMESHGUI_ElemInfo::ShowElements, SMESHGUI_ElemInfo::ShowNodes, SMESH::SelectionProxy::size(), SMDSAbs_Ball, SMDSAbs_Edge, SMDSAbs_Face, SMDSAbs_Node, SMESHGUI_ElemInfo::stype2str(), SMESH::SelectionProxy::type(), SMESHGUI_ElemInfo::type2str(), SMESH::Position::u(), InfoWriter::unindent(), SMESH::Position::v(), SMESHGUI_ElemInfo::what(), and InfoWriter::write().
Referenced by information(), SMESHGUI_TreeElemInfo::information(), and SMESHGUI_ElemInfo::saveInfo().
◆ myExtra
ExtraWidget* SMESHGUI_ElemInfo::myExtra
privateinherited
◆ myFrame
QWidget* SMESHGUI_ElemInfo::myFrame
privateinherited
◆ myIDs
◆ myIndex
◆ myInfo
QTextBrowser* SMESHGUI_SimpleElemInfo::myInfo
◆ myProxy
SMESH::SelectionProxy SMESHGUI_ElemInfo::myProxy
privateinherited
◆ myWhat
int SMESHGUI_ElemInfo::myWhat
privateinherited
