SMESHGUI_SplitVolumesDlg Class Reference
Class : SMESHGUI_SplitVolumesDlg Description : Split all volumes into tetrahedrons. More...
#include <SMESHGUI_MultiEditDlg.h>
Inheritance diagram for SMESHGUI_SplitVolumesDlg:
Signals
void ListContensChanged ()
 SMESHGUI_SplitVolumesDlg (SMESHGUI *)
 Class : SMESHGUI_SplitVolumesDlg Description : Spliter of volumes into tetrahedra or prisms. More...
virtual ~SMESHGUI_SplitVolumesDlg ()
void Init ()
bool eventFilter (QObject *, QEvent *)
void showPreview ()
void hidePreview ()
Protected Slots
virtual void on3d2dChanged (int)
 Slot called when a target element type changes. More...
virtual void onSelectionDone ()
 SLOT called when selection changed. More...
void onFacetSelection (bool)
 Slot called when facet selection button is clicked. More...
void onSetDir ()
 Slot called when an || axis button is clicked. More...
void updateNormalPreview (const QString &s="")
 SLOT called when a point or a normal changes. More...
void onOk ()
virtual bool onApply ()
virtual void reject ()
void onHelp ()
void onDeactivate ()
void onFilterBtn ()
void onAddBtn ()
void onRemoveBtn ()
void onSortListBtn ()
void onListSelectionChanged ()
void onSubmeshChk ()
void onGroupChk ()
virtual void onToAllChk ()
void onFilterAccepted ()
void onOpenView ()
void onCloseView ()
SMESH::NumericalFunctor_ptr getNumericalFunctor ()
void toDisplaySimulation ()
virtual void onDisplaySimulation (bool)
virtual bool process (SMESH::SMESH_MeshEditor_ptr, const SMESH::smIdType_array &, SMESH::SMESH_IDSource_ptr obj)
virtual smIdType nbElemsInMesh ()
virtual void setSelectionMode ()
 Set selection mode. More...
void showFacetByElement (int id)
 Show facet normal by a selected element. More...
bool isIntoPrisms ()
void enterEvent (QEvent *)
QWidget * createButtonFrame (QWidget *)
QWidget * createMainFrame (QWidget *, const bool)
virtual bool isValid (const bool)
SMESH::smIdType_array_var getIds (SMESH::SMESH_IDSource_var &obj)
void updateButtons ()
virtual bool isIdValid (const int) const
int entityType ()
void connectPreviewControl ()
QGroupBox * myFacetSelGrp
SMESHGUI_SpinBox * myPointSpin [3]
SMESHGUI_SpinBox * myDirSpin [3]
QPushButton * myFacetSelBtn
QPushButton * myAxisBtn [3]
QCheckBox * myAllDomainsChk
double myCellSize
QPushButton * myOkBtn
QPushButton * myApplyBtn
QPushButton * myCloseBtn
QPushButton * myHelpBtn
SMESH_Actor * myActor
SMESH::SMESH_Mesh_var myMesh
LightApp_SelectionMgr * mySelectionMgr
SVTK_Selector * mySelector
SMESHGUI * mySMESHGUI
QGroupBox * mySelGrp
QGroupBox * myCriterionGrp
QWidget * myChoiceWidget
QButtonGroup * myGroupChoice
QComboBox * myComboBoxFunctor
QListWidget * myListBox
QPushButton * myFilterBtn
QPushButton * myAddBtn
QPushButton * myRemoveBtn
QPushButton * mySortBtn
QCheckBox * myToAllChk
QButtonGroup * myEntityTypeGrp
QCheckBox * mySubmeshChk
QPushButton * mySubmeshBtn
QLineEdit * mySubmesh
QCheckBox * myGroupChk
QPushButton * myGroupBtn
QLineEdit * myGroup
SMESHGUI_FilterDlg * myFilterDlg
TColStd_MapOfInteger myIds
int myFilterType
bool myBusy
int myEntityType
QString myHelpFileName
QGroupBox * myAdvancedGrp
QCheckBox * myAvoidOverConstrainedChk
SMESHGUI_MeshEditPreview * mySimulation
QCheckBox * myPreviewCheckBox
bool myIsApplyAndClose
◆ SMESHGUI_SplitVolumesDlg()
◆ ~SMESHGUI_SplitVolumesDlg()
SMESHGUI_SplitVolumesDlg::~SMESHGUI_SplitVolumesDlg ( )
◆ connectPreviewControl()
◆ createButtonFrame()
◆ createMainFrame()
◆ enterEvent()
◆ entityType()
int SMESHGUI_MultiEditDlg::entityType ( )
◆ eventFilter()
bool SMESHGUI_MultiEditDlg::eventFilter ( QObject *  object,
QEvent *  event
◆ getIds()
SMESH::smIdType_array_var SMESHGUI_MultiEditDlg::getIds ( SMESH::SMESH_IDSource_var &  obj)
◆ getNumericalFunctor
◆ hidePreview()
◆ Init()
void SMESHGUI_MultiEditDlg::Init ( )
References SMESHGUI_MultiEditDlg::ListContensChanged(), SMESHGUI_MultiEditDlg::myActor, SMESHGUI_MultiEditDlg::myAddBtn, SMESHGUI_MultiEditDlg::myApplyBtn, SMESHGUI_MultiEditDlg::myBusy, SMESHGUI_MultiEditDlg::myCloseBtn, SMESHGUI_MultiEditDlg::myEntityTypeGrp, SMESHGUI_MultiEditDlg::myFilterBtn, SMESHGUI_MultiEditDlg::myGroupChk, SMESHGUI_MultiEditDlg::myHelpBtn, SMESHGUI_MultiEditDlg::myIds, SMESHGUI_MultiEditDlg::myListBox, SMESHGUI_MultiEditDlg::myOkBtn, SMESHGUI_MultiEditDlg::myRemoveBtn, SMESHGUI_MultiEditDlg::mySelectionMgr, SMESHGUI_MultiEditDlg::mySMESHGUI, SMESHGUI_MultiEditDlg::mySortBtn, SMESHGUI_MultiEditDlg::mySubmeshChk, SMESHGUI_MultiEditDlg::myToAllChk, SMESHGUI_MultiEditDlg::on3d2dChanged(), SMESHGUI_MultiEditDlg::onAddBtn(), SMESHGUI_MultiEditDlg::onApply(), SMESHGUI_MultiEditDlg::onCloseView(), SMESHGUI_MultiEditDlg::onDeactivate(), SMESHGUI_MultiEditDlg::onFilterBtn(), SMESHGUI_MultiEditDlg::onGroupChk(), SMESHGUI_MultiEditDlg::onHelp(), SMESHGUI_MultiEditDlg::onListSelectionChanged(), SMESHGUI_MultiEditDlg::onOk(), SMESHGUI_MultiEditDlg::onOpenView(), SMESHGUI_MultiEditDlg::onRemoveBtn(), SMESHGUI_MultiEditDlg::onSelectionDone(), SMESHGUI_MultiEditDlg::onSortListBtn(), SMESHGUI_MultiEditDlg::onSubmeshChk(), SMESHGUI_MultiEditDlg::onToAllChk(), SMESHGUI_MultiEditDlg::reject(), SMESHGUI::SetActiveDialogBox(), SMESHGUI_MultiEditDlg::setSelectionMode(), and SMESHGUI_MultiEditDlg::updateButtons().
Referenced by SMESHGUI_MultiEditDlg::SMESHGUI_MultiEditDlg(), and SMESHGUI_SplitVolumesDlg().
◆ isApplyAndClose()
bool SMESHGUI_PreviewDlg::isApplyAndClose ( ) const
◆ isIdValid()
bool SMESHGUI_MultiEditDlg::isIdValid ( const int  theId) const
◆ isIntoPrisms()
bool SMESHGUI_SplitVolumesDlg::isIntoPrisms ( )
◆ isValid()
◆ keyPressEvent()
void SMESHGUI_MultiEditDlg::keyPressEvent ( QKeyEvent *  e)
◆ ListContensChanged
◆ nbElemsInMesh()
smIdType SMESHGUI_SplitVolumesDlg::nbElemsInMesh ( )
◆ on3d2dChanged
void SMESHGUI_SplitVolumesDlg::on3d2dChanged ( int  isPrism)
protectedvirtualslot
◆ onAddBtn
◆ onApply
◆ onCloseView
void SMESHGUI_MultiEditDlg::onCloseView ( )
protectedslotinherited
◆ onDeactivate
void SMESHGUI_MultiEditDlg::onDeactivate ( )
◆ onDisplaySimulation
void SMESHGUI_PreviewDlg::onDisplaySimulation ( bool  )
protectedvirtualslotinherited
◆ onFacetSelection
void SMESHGUI_SplitVolumesDlg::onFacetSelection ( bool  isFacetSelection)
protectedslot
References SMESHGUI_MultiEditDlg::mySelGrp, onSelectionDone(), and setSelectionMode().
Referenced by SMESHGUI_SplitVolumesDlg().
◆ onFilterAccepted
◆ onFilterBtn
◆ onGroupChk
◆ onHelp
void SMESHGUI_MultiEditDlg::onHelp ( )
◆ onListSelectionChanged
◆ onOk
void SMESHGUI_MultiEditDlg::onOk ( )
◆ onOpenView
void SMESHGUI_MultiEditDlg::onOpenView ( )
◆ onRemoveBtn
◆ onSelectionDone
◆ onSetDir
void SMESHGUI_SplitVolumesDlg::onSetDir ( )
protectedslot
◆ onSortListBtn
void SMESHGUI_MultiEditDlg::onSortListBtn ( )
◆ onSubmeshChk
◆ onToAllChk
◆ process()
bool SMESHGUI_SplitVolumesDlg::process ( SMESH::SMESH_MeshEditor_ptr  theEditor,
const SMESH::smIdType_array &  theIds,
◆ reject
◆ setIsApplyAndClose()
void SMESHGUI_PreviewDlg::setIsApplyAndClose ( const bool  theFlag)
◆ setSelectionMode()
◆ showFacetByElement()
◆ showPreview()
◆ toDisplaySimulation
◆ updateButtons()
◆ updateNormalPreview
◆ myActor
◆ myAddBtn
QPushButton* SMESHGUI_MultiEditDlg::myAddBtn
◆ myAdvancedGrp
QGroupBox* SMESHGUI_MultiEditDlg::myAdvancedGrp
◆ myAllDomainsChk
QCheckBox* SMESHGUI_SplitVolumesDlg::myAllDomainsChk
◆ myApplyBtn
QPushButton* SMESHGUI_MultiEditDlg::myApplyBtn
◆ myAvoidOverConstrainedChk
QCheckBox* SMESHGUI_MultiEditDlg::myAvoidOverConstrainedChk
◆ myAxisBtn
QPushButton* SMESHGUI_SplitVolumesDlg::myAxisBtn[3]
◆ myBusy
◆ myCellSize
double SMESHGUI_SplitVolumesDlg::myCellSize
◆ myChoiceWidget
◆ myCloseBtn
QPushButton* SMESHGUI_MultiEditDlg::myCloseBtn
◆ myComboBoxFunctor
◆ myCriterionGrp
◆ myDirSpin
SMESHGUI_SpinBox* SMESHGUI_SplitVolumesDlg::myDirSpin[3]
◆ myEntityType
◆ myEntityTypeGrp
QButtonGroup* SMESHGUI_MultiEditDlg::myEntityTypeGrp
◆ myFacetSelBtn
QPushButton* SMESHGUI_SplitVolumesDlg::myFacetSelBtn
◆ myFacetSelGrp
QGroupBox* SMESHGUI_SplitVolumesDlg::myFacetSelGrp
◆ myFilterBtn
QPushButton* SMESHGUI_MultiEditDlg::myFilterBtn
◆ myFilterDlg
◆ myFilterType
◆ myGroup
◆ myGroupBtn
QPushButton* SMESHGUI_MultiEditDlg::myGroupBtn
◆ myGroupChk
◆ myGroupChoice
◆ myHelpBtn
QPushButton* SMESHGUI_MultiEditDlg::myHelpBtn
◆ myHelpFileName
◆ myIds
◆ myIsApplyAndClose
bool SMESHGUI_PreviewDlg::myIsApplyAndClose
◆ myListBox
◆ myMesh
◆ myOkBtn
QPushButton* SMESHGUI_MultiEditDlg::myOkBtn
◆ myPointSpin
SMESHGUI_SpinBox* SMESHGUI_SplitVolumesDlg::myPointSpin[3]
◆ myPreviewCheckBox
◆ myRemoveBtn
◆ mySelectionMgr
◆ mySelector
◆ mySelGrp
◆ mySimulation
◆ mySMESHGUI
◆ mySortBtn
QPushButton* SMESHGUI_MultiEditDlg::mySortBtn
◆ mySubmesh
◆ mySubmeshBtn
QPushButton* SMESHGUI_MultiEditDlg::mySubmeshBtn
◆ mySubmeshChk
◆ myToAllChk
