StdMeshers_QuadToTriaAdaptor Class Reference
"Transforms" quadrilateral faces into triangular ones by creation of pyramids More...
#include <StdMeshers_QuadToTriaAdaptor.hxx>
Inheritance diagram for StdMeshers_QuadToTriaAdaptor:
typedef boost::shared_ptr< SMESH_ProxyMesh > Ptr
typedef std::map< const SMDS_MeshNode *, const SMDS_MeshNode *, TIDCompare > TN2NMap
 StdMeshers_QuadToTriaAdaptor ()
 ~StdMeshers_QuadToTriaAdaptor ()
bool Compute (SMESH_Mesh &aMesh, const TopoDS_Shape &aShape, SMESH_ProxyMesh *aProxyMesh=0)
bool Compute (SMESH_Mesh &aMesh)
 Computes pyramids in mesh with no shape. More...
const TopoDS_Shape & GetShape () const
const SMESHDS_SubMesh * GetSubMesh (const TopoDS_Shape &shape) const
 Returns the submesh of a shape; it can be a proxy sub-mesh. More...
const SMESHDS_SubMesh * GetSubMesh (const int shapeID) const
 Return a sub-mesh by a shape ID; it can be a proxy sub-mesh. More...
const SubMesh * GetProxySubMesh (const TopoDS_Shape &shape) const
 Returns the proxy sub-mesh of a shape; it can be NULL. More...
const SMDS_MeshNode * GetProxyNode (const SMDS_MeshNode *node) const
 Returns the proxy node of a node; the input node is returned if no proxy exists. More...
int NbProxySubMeshes () const
 Returns number of proxy sub-meshes. More...
SMDS_ElemIteratorPtr GetFaces () const
 Returns iterator on all faces of the mesh taking into account substitutions To be used in case of mesh without shape. More...
SMDS_ElemIteratorPtr GetFaces (const TopoDS_Shape &face) const
 Returns iterator on all faces on the shape taking into account substitutions. More...
smIdType NbFaces () const
 Return total nb of faces taking into account substitutions. More...
bool IsTemporary (const SMDS_MeshElement *elem) const
 Return true if the element is a temporary one. More...
SMDS_ElemIteratorPtr GetInverseElementIterator (const SMDS_MeshNode *node, SMDSAbs_ElementType type) const
 Return iterator on inverse elements of a node that may be a proxy one. More...
SMESH_Mesh * GetMesh () const
SMESHDS_Mesh * GetMeshDS () const
 Returns mesh DS. More...
static bool HasPrismsOnTwoSides (SMESHDS_SubMesh *faceSM)
 Check if a FACE has prisms on its both sides. More...
int Preparation (const SMDS_MeshElement *face, TColgp_Array1OfPnt &PN, TColgp_Array1OfVec &VN, std::vector< const SMDS_MeshNode * > &FNodes, gp_Pnt &PC, gp_Vec &VNorm, const SMDS_MeshElement **volumes=0)
 Retrieve data of the given face. More...
bool LimitHeight (gp_Pnt &Papex, const gp_Pnt &PC, const TColgp_Array1OfPnt &PN, const std::vector< const SMDS_MeshNode * > &FNodes, SMESH_Mesh &aMesh, const SMDS_MeshElement *NotCheckedFace, const bool UseApexRay, const TopoDS_Shape &Shape=TopoDS_Shape())
 Return allowed height of a pyramid. More...
bool Compute2ndPart (SMESH_Mesh &aMesh, const std::vector< const SMDS_MeshElement * > &pyramids)
 Update created pyramids and faces to avoid their intersection. More...
void MergePiramids (const SMDS_MeshElement *PrmI, const SMDS_MeshElement *PrmJ, std::set< const SMDS_MeshNode * > &nodesToMove)
 Merge the two pyramids (i.e. More...
void MergeAdjacent (const SMDS_MeshElement *PrmI, std::set< const SMDS_MeshNode * > &nodesToMove, const bool isRecursion=false)
 Merges adjacent pyramids. More...
bool DecreaseHeightDifference (const SMDS_MeshElement *pyram, const double h2)
 Decrease height of a given or adjacent pyramids if height difference is too large. More...
void setMesh (const SMESH_Mesh &mesh)
 Set mesh. More...
int shapeIndex (const TopoDS_Shape &shape) const
 Returns index of a shape. More...
virtual SubMesh * newSubmesh (int index=0) const
 Create a SubMesh. More...
SubMesh * findProxySubMesh (int shapeIndex=0) const
 Returns a proxy sub-mesh. More...
SubMesh * getProxySubMesh (int shapeIndex)
 Returns a proxy sub-mesh; it is created if not yet exists. More...
SubMesh * getProxySubMesh (const TopoDS_Shape &shape=TopoDS_Shape())
bool takeProxySubMesh (const TopoDS_Shape &shape, SMESH_ProxyMesh *proxyMesh)
 Move proxy sub-mesh from other proxy mesh to this, returns true if sub-mesh found. More...
void takeTmpElemsInMesh (SMESH_ProxyMesh *proxyMesh)
 Move tmp elements residing the _mesh from other proxy mesh to this. More...
void removeTmpElement (const SMDS_MeshElement *elem)
 Removes tmp elements from the _mesh. More...
void storeTmpElement (const SMDS_MeshElement *elem)
 Stores tmp element residing the _mesh. More...
void setNode2Node (const SMDS_MeshNode *srcNode, const SMDS_MeshNode *proxyNode, const SubMesh *subMesh)
 Set node-node correspondence. More...
TopoDS_Shape myShape
std::set< const SMDS_MeshElement * > myRemovedTrias
std::list< const SMDS_MeshNode * > myDegNodes
const SMESH_ElementSearcher * myElemSearcher
NCollection_DataMap< const SMDS_MeshElement *, double > myPyramHeight2
std::vector< const SMDS_MeshElement * > myAdjPyrams
std::vector< const SMDS_MeshNode * > myNodes
std::vector< SMDSAbs_EntityType > _allowedTypes
Private Types
typedef NCollection_DataMap< const SMDS_MeshNode *, std::vector< const SMDS_MeshElement * >, SMESH_Hasher > TNodeElemVecMap
const SMESH_Mesh * _mesh
std::vector< SubMesh * > _subMeshes
std::set< const SMDS_MeshElement * > _elemsInMesh
TNodeElemVecMap _inverseElements
SubMesh * _subContainer
◆ Ptr
typedef boost::shared_ptr<SMESH_ProxyMesh> SMESH_ProxyMesh::Ptr
◆ TN2NMap
typedef std::map<const SMDS_MeshNode*, const SMDS_MeshNode*, TIDCompare > SMESH_ProxyMesh::TN2NMap
◆ TNodeElemVecMap
typedef NCollection_DataMap< const SMDS_MeshNode*, std::vector< const SMDS_MeshElement* >, SMESH_Hasher > SMESH_ProxyMesh::TNodeElemVecMap
privateinherited
◆ StdMeshers_QuadToTriaAdaptor()
StdMeshers_QuadToTriaAdaptor::StdMeshers_QuadToTriaAdaptor ( )
◆ ~StdMeshers_QuadToTriaAdaptor()
StdMeshers_QuadToTriaAdaptor::~StdMeshers_QuadToTriaAdaptor ( )
References myElemSearcher.
◆ Compute() [1/2]
◆ Compute() [2/2]
◆ Compute2ndPart()
◆ DecreaseHeightDifference()
bool StdMeshers_QuadToTriaAdaptor::DecreaseHeightDifference ( const SMDS_MeshElement *  thePyram,
const double  theH2
[in]pyram- a pyramid to treat
[in,out]h2- pyramid's square height
bool - true if the height changes
References SMDS_Mesh::GetElementsByNodes(), SMDS_MeshElement::GetNode(), myAdjPyrams, myNodes, myPyramHeight2, and SMDSAbs_Volume.
Referenced by Compute2ndPart().
◆ findProxySubMesh()
SMESH_ProxyMesh::SubMesh * SMESH_ProxyMesh::findProxySubMesh ( int  shapeIndex = 0) const
◆ GetFaces() [1/2]
◆ GetFaces() [2/2]
SMDS_ElemIteratorPtr SMESH_ProxyMesh::GetFaces ( const TopoDS_Shape &  face) const
◆ GetInverseElementIterator()
SMDS_ElemIteratorPtr SMESH_ProxyMesh::GetInverseElementIterator ( const SMDS_MeshNode *  node,
◆ GetMesh()
◆ GetMeshDS()
◆ GetProxyNode()
◆ GetProxySubMesh()
const SMESH_ProxyMesh::SubMesh * SMESH_ProxyMesh::GetProxySubMesh ( const TopoDS_Shape &  shape) const
References SMESH_ProxyMesh::_subMeshes, and SMESH_ProxyMesh::shapeIndex().
Referenced by VISCOUS_3D::_ViscousBuilder::makeGroupOfLE(), and VISCOUS_3D::_ViscousBuilder::MakeN2NMap().
◆ getProxySubMesh() [1/2]
SMESH_ProxyMesh::SubMesh * SMESH_ProxyMesh::getProxySubMesh ( const TopoDS_Shape &  shape = TopoDS_Shape())
References SMESH_ProxyMesh::getProxySubMesh(), and SMESH_ProxyMesh::shapeIndex().
◆ getProxySubMesh() [2/2]
SMESH_ProxyMesh::SubMesh * SMESH_ProxyMesh::getProxySubMesh ( int  shapeIndex)
◆ GetShape()
const TopoDS_Shape & StdMeshers_QuadToTriaAdaptor::GetShape ( ) const
◆ GetSubMesh() [1/2]
const SMESHDS_SubMesh * SMESH_ProxyMesh::GetSubMesh ( const int  shapeID) const
References SMESH_ProxyMesh::_subMeshes, SMESH_ProxyMesh::GetMeshDS(), and SMESHDS_Mesh::MeshElements().
◆ GetSubMesh() [2/2]
◆ HasPrismsOnTwoSides()
bool SMESH_ProxyMesh::HasPrismsOnTwoSides ( SMESHDS_SubMesh *  smFace)
[in]smFace- sub-mesh of the FACE. NOT a proxy sub-mesh!
bool - true if there are prisms on the two sides
References SMDS_MeshElement::begin_nodes(), SMDS_MeshElement::end_nodes(), SMESHDS_SubMesh::GetElements(), SMDS_Mesh::GetElementsByNodes(), SMDS_MeshElement::NbCornerNodes(), SMESHDS_SubMesh::NbElements(), and SMDSAbs_Volume.
Referenced by Compute().
◆ IsTemporary()
bool SMESH_ProxyMesh::IsTemporary ( const SMDS_MeshElement *  elem) const
References SMESH_ProxyMesh::_elemsInMesh, and SMDS_MeshElement::GetID().
Referenced by _QuadFaceGrid::LoadGrid(), and SMESH_MesherHelper::LoadNodeColumns().
◆ LimitHeight()
bool StdMeshers_QuadToTriaAdaptor::LimitHeight ( gp_Pnt &  Papex,
const gp_Pnt &  PC,
const TColgp_Array1OfPnt &  PN,
const std::vector< const SMDS_MeshNode * > &  FNodes,
SMESH_Mesh &  aMesh,
const SMDS_MeshElement *  NotCheckedFace,
const TopoDS_Shape &  Shape = TopoDS_Shape()
Papex- optimal pyramid apex
PC- gravity center of a quadrangle
PN- four nodes of the quadrangle
aMesh- mesh
NotCheckedFace- the quadrangle face
Shape- the shape being meshed
falseif mesh invalidity detected
References SMESH_MeshAlgos::GetElementSearcher(), SMESH_ElementSearcher::GetElementsInSphere(), SMESH_ElementSearcher::GetElementsNearLine(), SMESH_Mesh::GetMeshDS(), SMDS_MeshElement::GetNode(), SMDS_MeshElement::GetNodeIndex(), HasIntersection(), HasIntersection3(), myElemSearcher, SMDS_MeshElement::NbCornerNodes(), and SMDSAbs_Face.
◆ MergeAdjacent()
void StdMeshers_QuadToTriaAdaptor::MergeAdjacent ( const SMDS_MeshElement *  PrmI,
std::set< const SMDS_MeshNode * > &  nodesToMove,
const bool  isRecursion = false
◆ MergePiramids()
◆ NbFaces()
◆ NbProxySubMeshes()
int SMESH_ProxyMesh::NbProxySubMeshes ( ) const
References SMESH_ProxyMesh::_subMeshes.
Referenced by SMESH_ProxyMesh::GetInverseElementIterator().
◆ newSubmesh()
SMESH_ProxyMesh::SubMesh * SMESH_ProxyMesh::newSubmesh ( int  index = 0) const
Create a SubMesh.
[ino]index - shape index
SubMesh* - new SubMesh
Reimplemented in VISCOUS_2D::_ProxyMeshOfFace.
References SMESH_ProxyMesh::GetMeshDS().
Referenced by SMESH_ProxyMesh::getProxySubMesh().
◆ Preparation()
int StdMeshers_QuadToTriaAdaptor::Preparation ( const SMDS_MeshElement *  face,
TColgp_Array1OfVec &  VN,
gp_Pnt &  PC,
gp_Vec &  VNorm,
const SMDS_MeshElement **  volumes = 0
PN- coordinates of face nodes
VN- cross products of vectors (PC-PN(i)) ^ (PC-PN(i+1))
FNodes- face nodes
PC- gravity center of nodes
VNorm- face normal (sum of VN)
volumes- two volumes sharing the given face, the first is in VNorm direction
int- 0 if given face is not quad, 1 if given face is quad, 2 if given face is degenerate quad (two nodes are coincided)
References DEGEN_QUAD, SMDS_MeshElement::GetNode(), SMDS_MeshElement::GetNodeIndex(), myDegNodes, SMDS_MeshElement::NbCornerNodes(), SMDS_MeshElement::NbNodes(), SMDS_MeshElement::nodesIterator(), NOT_QUAD, QUAD, SMDSAbs_Volume, SMDS_MeshNode::X(), SMDS_MeshNode::Y(), and SMDS_MeshNode::Z().
◆ removeTmpElement()
void SMESH_ProxyMesh::removeTmpElement ( const SMDS_MeshElement *  elem)
◆ setMesh()
void SMESH_ProxyMesh::setMesh ( const SMESH_Mesh &  mesh)
◆ setNode2Node()
void SMESH_ProxyMesh::setNode2Node ( const SMDS_MeshNode *  srcNode,
const SMDS_MeshNode *  proxyNode,
const SubMesh *  subMesh
References SMESH_ProxyMesh::SubMesh::_n2n.
Referenced by VISCOUS_3D::_MeshOfSolid::setNode2Node().
◆ shapeIndex()
◆ storeTmpElement()
void SMESH_ProxyMesh::storeTmpElement ( const SMDS_MeshElement *  elem)
References SMESH_ProxyMesh::_elemsInMesh.
◆ takeProxySubMesh()
bool SMESH_ProxyMesh::takeProxySubMesh ( const TopoDS_Shape &  shape,
SMESH_ProxyMesh *  proxyMesh
References SMESH_ProxyMesh::_mesh, SMESH_ProxyMesh::_subMeshes, SMESH_ProxyMesh::findProxySubMesh(), and SMESH_ProxyMesh::shapeIndex().
◆ takeTmpElemsInMesh()
void SMESH_ProxyMesh::takeTmpElemsInMesh ( SMESH_ProxyMesh *  proxyMesh)
Referenced by Compute(), and SMESH_ProxyMesh::SMESH_ProxyMesh().
◆ _allowedTypes
std::vector< SMDSAbs_EntityType> SMESH_ProxyMesh::_allowedTypes
◆ _elemsInMesh
◆ _inverseElements
TNodeElemVecMap SMESH_ProxyMesh::_inverseElements
privateinherited
◆ _mesh
◆ _subContainer
SubMesh* SMESH_ProxyMesh::_subContainer
mutableprivateinherited
◆ _subMeshes
◆ myAdjPyrams
std::vector< const SMDS_MeshElement* > StdMeshers_QuadToTriaAdaptor::myAdjPyrams
◆ myDegNodes
std::list< const SMDS_MeshNode* > StdMeshers_QuadToTriaAdaptor::myDegNodes
Referenced by Compute2ndPart(), and Preparation().
◆ myElemSearcher
const SMESH_ElementSearcher* StdMeshers_QuadToTriaAdaptor::myElemSearcher
◆ myNodes
std::vector<const SMDS_MeshNode *> StdMeshers_QuadToTriaAdaptor::myNodes
◆ myPyramHeight2
NCollection_DataMap< const SMDS_MeshElement*, double > StdMeshers_QuadToTriaAdaptor::myPyramHeight2
◆ myRemovedTrias
std::set<const SMDS_MeshElement*> StdMeshers_QuadToTriaAdaptor::myRemovedTrias
Referenced by Compute2ndPart(), and MergePiramids().
◆ myShape
TopoDS_Shape StdMeshers_QuadToTriaAdaptor::myShape
