VISCOUS_3D::_SolidData Struct Reference
Data of a SOLID. More...
typedef const StdMeshers_ViscousLayers * THyp
 _SolidData (const TopoDS_Shape &s=TopoDS_Shape(), _MeshOfSolid *m=0)
 ~_SolidData ()
void SortOnEdge (const TopoDS_Edge &E, vector< _LayerEdge * > &edges)
 Sort _LayerEdge's by a parameter on a given EDGE. More...
void Sort2NeiborsOnEdge (vector< _LayerEdge * > &edges)
 Set _2neibors according to the order of _LayerEdge on EDGE. More...
_ConvexFace * GetConvexFace (const TGeomID faceID)
_EdgesOnShape * GetShapeEdges (const TGeomID shapeID)
 Return _EdgesOnShape* corresponding to the shape. More...
_EdgesOnShape * GetShapeEdges (const TopoDS_Shape &shape)
_EdgesOnShape * GetShapeEdges (const _LayerEdge *edge)
SMESH_MesherHelper & GetHelper () const
void UnmarkEdges (int flag=_LayerEdge::MARKED)
void AddShapesToSmooth (const set< _EdgesOnShape * > &shape, const set< _EdgesOnShape * > *edgesNoAnaSmooth=0)
 Add faces for smoothing. More...
void PrepareEdgesToSmoothOnFace (_EdgesOnShape *eof, bool substituteSrcNodes)
 Prepare data of the _LayerEdge for smoothing on FACE. More...
Data Fields
TopoDS_Shape _solid
TopTools_MapOfShape _before
TGeomID _index
_MeshOfSolid * _proxyMesh
bool _done
list< THyp > _hyps
list< TopoDS_Shape > _hypShapes
map< TGeomID, THyp > _face2hyp
set< TGeomID > _reversedFaceIds
set< TGeomID > _ignoreFaceIds
double _stepSize
double _stepSizeCoeff
double _geomSize
const SMDS_MeshNode * _stepSizeNodes [2]
TNode2Edge _n2eMap
map< TGeomID, TNode2Edge * > _s2neMap
vector< _EdgesOnShape > _edgesOnShape
map< TGeomID, TopoDS_Shape > _shrinkShape2Shape
map< TGeomID, _ConvexFace > _convexFaces
set< TGeomID > _noShrinkShapes
int _nbShapesToSmooth
vector< _CollisionEdges > _collisionEdges
set< TGeomID > _concaveFaces
double _maxThickness
double _minThickness
double _epsilon
SMESH_MesherHelper * _helper
Data of a SOLID.
◆ THyp
◆ _SolidData()
VISCOUS_3D::_SolidData::_SolidData ( const TopoDS_Shape &  s = TopoDS_Shape(),
_MeshOfSolid *  m = 0
◆ ~_SolidData()
VISCOUS_3D::_SolidData::~_SolidData ( )
References _helper.
◆ AddShapesToSmooth()
void _SolidData::AddShapesToSmooth ( const set< _EdgesOnShape * > &  shape,
const set< _EdgesOnShape * > *  edgesNoAnaSmooth = 0
◆ GetConvexFace()
◆ GetHelper()
◆ GetShapeEdges() [1/3]
_EdgesOnShape * VISCOUS_3D::_SolidData::GetShapeEdges ( const _LayerEdge *  edge)
◆ GetShapeEdges() [2/3]
◆ GetShapeEdges() [3/3]
_EdgesOnShape * _SolidData::GetShapeEdges ( const TopoDS_Shape &  shape)
References _proxyMesh, SMESH_ProxyMesh::GetMesh(), SMESH_Mesh::GetMeshDS(), GetShapeEdges(), and SMESHDS_Mesh::ShapeToIndex().
◆ PrepareEdgesToSmoothOnFace()
void _SolidData::PrepareEdgesToSmoothOnFace ( _EdgesOnShape *  eof,
References _concaveFaces, VISCOUS_3D::_LayerEdge::_cosin, VISCOUS_3D::_LayerEdge::_curvature, VISCOUS_3D::_EdgesOnShape::_edgeForOffset, VISCOUS_3D::_EdgesOnShape::_edges, VISCOUS_3D::_EdgesOnShape::_eosConcaVer, VISCOUS_3D::_Curvature::_h2lenRatio, VISCOUS_3D::_Curvature::_k, VISCOUS_3D::_EdgesOnShape::_mapper2D, _n2eMap, VISCOUS_3D::_LayerEdge::_neibors, VISCOUS_3D::_Simplex::_nNext, VISCOUS_3D::_LayerEdge::_nodes, VISCOUS_3D::_LayerEdge::_normal, VISCOUS_3D::_Simplex::_nPrev, VISCOUS_3D::_LayerEdge::_pos, _proxyMesh, VISCOUS_3D::_Curvature::_r, VISCOUS_3D::_EdgesOnShape::_shape, VISCOUS_3D::_EdgesOnShape::_shapeID, VISCOUS_3D::_LayerEdge::_simplices, VISCOUS_3D::_EdgesOnShape::_subMesh, VISCOUS_3D::_EdgesOnShape::_sWOL, VISCOUS_3D::_Curvature::_uv, VISCOUS_3D::_LayerEdge::BaseShapeDim(), VISCOUS_3D::_LayerEdge::ChooseSmooFunction(), VISCOUS_3D::_LayerEdge::DIFFICULT, Face, VISCOUS_3D::_EdgesOnShape::GetData(), SMESHDS_SubMesh::GetElements(), SMESH_ProxyMesh::GetMesh(), SMESH_MesherHelper::GetMeshDS(), SMESH_MesherHelper::GetNodeUV(), SMESH_Block::GetOrderedEdges(), GetShapeEdges(), SMESH_subMesh::GetSubMeshDS(), VISCOUS_3D::_LayerEdge::Is(), VISCOUS_3D::isConcave(), SMESH_MesherHelper::IsCornerOfStructure(), SMESH_MesherHelper::IthVertex(), SMESH_MesherHelper::LoadNodeColumns(), VISCOUS_3D::_LayerEdge::NEAR_BOUNDARY, VISCOUS_3D::_Curvature::New(), VISCOUS_3D::_Factory::NewCurvature(), VISCOUS_3D::_LayerEdge::RISKY_SWOL, VISCOUS_3D::_LayerEdge::Set(), VISCOUS_3D::_EdgesOnShape::ShapeType(), VISCOUS_3D::_LayerEdge::SMOOTHED_C1, VISCOUS_3D::_Simplex::SortSimplices(), VISCOUS_3D::_LayerEdge::TO_SMOOTH, and SMESH_Algo::VertexNode().
Referenced by AddShapesToSmooth(), and VISCOUS_3D::_ViscousBuilder::findShapesToSmooth().
◆ Sort2NeiborsOnEdge()
void _SolidData::Sort2NeiborsOnEdge ( vector< _LayerEdge * > &  edges)
References VISCOUS_3D::_2NearEdges::tgtNode().
Referenced by SortOnEdge().
◆ SortOnEdge()
void _SolidData::SortOnEdge ( const TopoDS_Edge &  E,
◆ UnmarkEdges()
void VISCOUS_3D::_SolidData::UnmarkEdges ( int  flag = _LayerEdge::MARKED)
◆ _before
TopTools_MapOfShape VISCOUS_3D::_SolidData::_before
◆ _collisionEdges
vector< _CollisionEdges > VISCOUS_3D::_SolidData::_collisionEdges
◆ _concaveFaces
set< TGeomID > VISCOUS_3D::_SolidData::_concaveFaces
◆ _convexFaces
◆ _done
bool VISCOUS_3D::_SolidData::_done
◆ _edgesOnShape
◆ _epsilon
◆ _face2hyp
map< TGeomID, THyp > VISCOUS_3D::_SolidData::_face2hyp
◆ _geomSize
double VISCOUS_3D::_SolidData::_geomSize
◆ _helper
◆ _hyps
◆ _hypShapes
list< TopoDS_Shape > VISCOUS_3D::_SolidData::_hypShapes
◆ _ignoreFaceIds
◆ _index
◆ _maxThickness
double VISCOUS_3D::_SolidData::_maxThickness
◆ _minThickness
double VISCOUS_3D::_SolidData::_minThickness
◆ _n2eMap
◆ _nbShapesToSmooth
◆ _noShrinkShapes
◆ _proxyMesh
◆ _reversedFaceIds
set< TGeomID > VISCOUS_3D::_SolidData::_reversedFaceIds
◆ _s2neMap
map< TGeomID, TNode2Edge* > VISCOUS_3D::_SolidData::_s2neMap
◆ _shrinkShape2Shape
◆ _solid
◆ _stepSize
◆ _stepSizeCoeff
double VISCOUS_3D::_SolidData::_stepSizeCoeff
◆ _stepSizeNodes
