VISCOUS_3D::_LayerEdge Struct Reference
Edge normal to surface, connecting a node on solid surface (_nodes[0]) and a node of the most internal layer (_nodes.back()) More...
enum  EFlags {
  TO_SMOOTH = 0x0000001 , MOVED = 0x0000002 , SMOOTHED = 0x0000004 , DIFFICULT = 0x0000008 ,
  ON_CONCAVE_FACE = 0x0000010 , BLOCKED = 0x0000020 , INTERSECTED = 0x0000040 , NORMAL_UPDATED = 0x0000080 ,
  UPD_NORMAL_CONV = 0x0000100 , MARKED = 0x0000200 , MULTI_NORMAL = 0x0000400 , NEAR_BOUNDARY = 0x0000800 ,
  SMOOTHED_C1 = 0x0001000 , DISTORTED = 0x0002000 , RISKY_SWOL = 0x0004000 , SHRUNK = 0x0008000 ,
  UNUSED_FLAG = 0x0100000
enum  {
  FUN_LAPLACIAN , FUN_LENWEIGHTED , FUN_CENTROIDAL , FUN_NEFPOLY ,
  FUN_ANGULAR , FUN_NB
typedef gp_XYZ(_LayerEdge::* PSmooFun) ()
bool Is (int flag) const
void Set (int flag)
void Unset (int flag)
std::string DumpFlags () const
 Print flags. More...
void SetNewLength (double len, _EdgesOnShape &eos, SMESH_MesherHelper &helper)
 Add a new segment to _LayerEdge during inflation. More...
bool SetNewLength2d (Handle(Geom_Surface)&surface, const TopoDS_Face &F, _EdgesOnShape &eos, SMESH_MesherHelper &helper)
 Move target node to it's final position on the FACE during shrinking. More...
bool UpdatePositionOnSWOL (SMDS_MeshNode *n, double tol, _EdgesOnShape &eos, SMESH_MesherHelper &helper)
 Update last position on SWOL by projecting node on SWOL. More...
void SetDataByNeighbors (const SMDS_MeshNode *n1, const SMDS_MeshNode *n2, const _EdgesOnShape &eos, SMESH_MesherHelper &helper)
 Set _curvature and _2neibors->_plnNorm by 2 neighbor nodes residing the same EDGE. More...
void Block (_SolidData &data)
 Set BLOCKED flag and propagate limited _maxLen to _neibors. More...
void InvalidateStep (size_t curStep, const _EdgesOnShape &eos, bool restoreLength=false)
 Remove last inflation step. More...
void ChooseSmooFunction (const set< TGeomID > &concaveVertices, const TNode2Edge &n2eMap)
 Chooses a smoothing technique giving a position most close to an initial one. More...
void SmoothPos (const vector< double > &segLen, const double tol)
 Smooth a path formed by _pos of a _LayerEdge smoothed on FACE. More...
int GetSmoothedPos (const double tol)
 Return index of a _pos distant from _normal. More...
int Smooth (const int step, const bool isConcaveFace, bool findBest)
 Perform 'smart' 3D smooth of nodes inflated from FACE. More...
int Smooth (const int step, bool findBest, vector< _LayerEdge * > &toSmooth)
int CheckNeiborsOnBoundary (vector< _LayerEdge * > *badNeibors=0, bool *needSmooth=0)
 Checks validity of _neibors on EDGEs and VERTEXes. More...
void SmoothWoCheck ()
 Perform 3D smooth of nodes inflated from FACE. More...
bool SmoothOnEdge (Handle(ShapeAnalysis_Surface)&surface, const TopoDS_Face &F, SMESH_MesherHelper &helper)
 Perform smooth of _LayerEdge's based on EDGE's. More...
void MoveNearConcaVer (const _EdgesOnShape *eov, const _EdgesOnShape *eos, const int step, vector< _LayerEdge * > &badSmooEdges)
 _LayerEdge, located at a concave VERTEX of a FACE, moves target nodes of neighbor _LayerEdge's by it's own inflation vector. More...
bool FindIntersection (SMESH_ElementSearcher &searcher, double &distance, const double &epsilon, _EdgesOnShape &eos, const SMDS_MeshElement **face=0)
 Looks for intersection of it's last segment with faces. More...
bool SegTriaInter (const gp_Ax1 &lastSegment, const gp_XYZ &p0, const gp_XYZ &p1, const gp_XYZ &p2, double &dist, const double &epsilon) const
 Test intersection of the last segment with a given triangle using Moller-Trumbore algorithm Intersection is detected if distance to intersection is less than _LayerEdge._len. More...
bool SegTriaInter (const gp_Ax1 &lastSegment, const SMDS_MeshNode *n0, const SMDS_MeshNode *n1, const SMDS_MeshNode *n2, double &dist, const double &epsilon) const
const gp_XYZ & PrevPos () const
gp_XYZ PrevCheckPos (_EdgesOnShape *eos=0) const
 Returns a point used to check orientation of _simplices. More...
gp_Ax1 LastSegment (double &segLen, _EdgesOnShape &eos) const
 Returns size and direction of the last segment. More...
gp_XY LastUV (const TopoDS_Face &F, _EdgesOnShape &eos, int which=-1) const
 Return the last (or which) position of the target node on a FACE. More...
bool IsOnEdge () const
bool IsOnFace () const
int BaseShapeDim () const
gp_XYZ Copy (_LayerEdge &other, _EdgesOnShape &eos, SMESH_MesherHelper &helper)
 Copy data from a _LayerEdge of other SOLID and based on the same node; this and the other _LayerEdge are inflated along a FACE or an EDGE. More...
double SetCosin (double cosin)
 Set _cosin and _lenFactor. More...
void SetNormal (const gp_XYZ &n)
void SetMaxLen (double l)
int NbSteps () const
bool IsNeiborOnEdge (const _LayerEdge *edge) const
 Check if another _LayerEdge is a neighbor on EDGE. More...
void SetSmooLen (double len)
double GetSmooLen ()
gp_XYZ smoothLaplacian ()
 Computes a new node position using Laplacian smoothing. More...
gp_XYZ smoothAngular ()
 Computes a new node position using angular-based smoothing. More...
gp_XYZ smoothLengthWeighted ()
 Computes a new node position using weighted node positions. More...
gp_XYZ smoothCentroidal ()
gp_XYZ smoothNefPolygon ()
 Computes a new node position located inside a Nef polygon. More...
int smooFunID (PSmooFun fun=0) const
 Returns a name of _SmooFunction. More...
Data Fields
vector< const SMDS_MeshNode * > _nodes
gp_XYZ _normal
vector< gp_XYZ > _pos
double _len
double _maxLen
double _cosin
double _minAngle
double _lenFactor
int _flags
vector< _Simplex > _simplices
vector< _LayerEdge * > _neibors
PSmooFun _smooFunction
_Curvature * _curvature
_2NearEdges * _2neibors
Static Public Attributes
static const int theNbSmooFuns = FUN_NB
static PSmooFun _funs [theNbSmooFuns]
static const char * _funNames [theNbSmooFuns+1]
◆ PSmooFun
typedef gp_XYZ(_LayerEdge::* VISCOUS_3D::_LayerEdge::PSmooFun) ()
◆ anonymous enum
anonymous enum
FUN_LAPLACIAN
FUN_LENWEIGHTED
FUN_CENTROIDAL
FUN_NEFPOLY
FUN_ANGULAR
FUN_NB
◆ EFlags
TO_SMOOTH
MOVED
SMOOTHED
DIFFICULT
ON_CONCAVE_FACE
BLOCKED
INTERSECTED
NORMAL_UPDATED
UPD_NORMAL_CONV
MARKED
MULTI_NORMAL
NEAR_BOUNDARY
SMOOTHED_C1
DISTORTED
RISKY_SWOL
SHRUNK
UNUSED_FLAG
◆ BaseShapeDim()
int VISCOUS_3D::_LayerEdge::BaseShapeDim ( ) const
◆ Block()
◆ CheckNeiborsOnBoundary()
int _LayerEdge::CheckNeiborsOnBoundary ( vector< _LayerEdge * > *  badNeibors = 0,
bool *  needSmooth = 0
References _neibors, _nodes, _pos, _simplices, BLOCKED, debugMsg, Is(), NEAR_BOUNDARY, and NORMAL_UPDATED.
Referenced by Smooth(), and VISCOUS_3D::_ViscousBuilder::smoothAndCheck().
◆ ChooseSmooFunction()
void _LayerEdge::ChooseSmooFunction ( const set< TGeomID > &  concaveVertices,
const TNode2Edge &  n2eMap
For a correct result, _simplices must contain nodes lying on geometry.
References _funs, _neibors, _nodes, _simplices, _smooFunction, FUN_CENTROIDAL, FUN_LAPLACIAN, FUN_NEFPOLY, ON_CONCAVE_FACE, and Set().
Referenced by VISCOUS_3D::_SolidData::PrepareEdgesToSmoothOnFace().
◆ Copy()
gp_XYZ _LayerEdge::Copy ( _LayerEdge &  other,
_EdgesOnShape &  eos,
SMESH_MesherHelper &  helper
◆ DumpFlags()
◆ FindIntersection()
bool _LayerEdge::FindIntersection ( SMESH_ElementSearcher &  searcher,
double &  distance,
const double &  epsilon,
const SMDS_MeshElement **  intFace = 0
distance- returns shortest distance from the last node to intersection
References _len, _lenFactor, _nodes, SMDS_MeshElement::begin_nodes(), MESHCUT::epsilon, SMESH_ElementSearcher::GetElementsNearLine(), SMDS_MeshElement::GetNodeIndex(), LastSegment(), SMDS_MeshElement::NbCornerNodes(), SegTriaInter(), and SMDSAbs_Face.
◆ GetSmooLen()
double VISCOUS_3D::_LayerEdge::GetSmooLen ( )
References _cosin.
◆ GetSmoothedPos()
int _LayerEdge::GetSmoothedPos ( const double  tol)
References _normal, and _pos.
Referenced by VISCOUS_3D::_ViscousBuilder::refine(), and SmoothPos().
◆ InvalidateStep()
◆ Is()
◆ IsNeiborOnEdge()
bool _LayerEdge::IsNeiborOnEdge ( const _LayerEdge *  edge) const
References _2neibors, and VISCOUS_3D::_2NearEdges::include().
◆ IsOnEdge()
◆ IsOnFace()
bool VISCOUS_3D::_LayerEdge::IsOnFace ( ) const
References _nodes.
Referenced by InvalidateStep(), PrevCheckPos(), and SmoothPos().
◆ LastSegment()
gp_Ax1 _LayerEdge::LastSegment ( double &  segLen,
_EdgesOnShape &  eos
◆ LastUV()
gp_XY _LayerEdge::LastUV ( const TopoDS_Face &  F,
int  which = -1
[in]F- the FACE this _LayerEdge is inflated along
[in]which- index of position
gp_XY - result UV
References _pos, VISCOUS_3D::_EdgesOnShape::_sWOL, Edge, Handle(), and VISCOUS_3D::_EdgesOnShape::SWOLType().
Referenced by VISCOUS_3D::_ViscousBuilder::prepareEdgeToShrink(), and VISCOUS_3D::_Smoother1D::smoothAnalyticEdge().
◆ MoveNearConcaVer()
void _LayerEdge::MoveNearConcaVer ( const _EdgesOnShape *  eov,
const _EdgesOnShape *  eos,
const int  step,
vector< _LayerEdge * > &  badSmooEdges
[in]eov- EOS of the VERTEX
[in]eos- EOS of the FACE
[in]step- inflation step
[in,out]badSmooEdges- tangled _LayerEdge's
References _curvature, VISCOUS_3D::_Curvature::_h2lenRatio, VISCOUS_3D::_Curvature::_k, _neibors, _nodes, _pos, VISCOUS_3D::_Curvature::_r, VISCOUS_3D::_EdgesOnShape::_shapeID, VISCOUS_3D::_EdgesOnShape::_sWOL, VISCOUS_3D::_Curvature::_uv, dumpMoveComm, Edge, Face, VISCOUS_3D::_Factory::NewCurvature(), PrevPos(), SMDS_MeshNode::setXYZ(), Smooth(), SMOOTHED, VISCOUS_3D::_EdgesOnShape::SWOLType(), and Unset().
◆ NbSteps()
int VISCOUS_3D::_LayerEdge::NbSteps ( ) const
◆ PrevCheckPos()
◆ PrevPos()
const gp_XYZ & VISCOUS_3D::_LayerEdge::PrevPos ( ) const
◆ SegTriaInter() [1/2]
bool _LayerEdge::SegTriaInter ( const gp_Ax1 &  lastSegment,
const gp_XYZ &  p0,
const gp_XYZ &  p1,
const gp_XYZ &  p2,
double &  dist,
Referenced by VISCOUS_3D::_ViscousBuilder::findCollisionEdges(), FindIntersection(), SegTriaInter(), and VISCOUS_3D::_ViscousBuilder::updateNormals().
◆ SegTriaInter() [2/2]
bool VISCOUS_3D::_LayerEdge::SegTriaInter ( const gp_Ax1 &  lastSegment,
const SMDS_MeshNode *  n0,
const SMDS_MeshNode *  n1,
const SMDS_MeshNode *  n2,
double &  dist,
References MESHCUT::epsilon, and SegTriaInter().
◆ Set()
◆ SetCosin()
double _LayerEdge::SetCosin ( double  cosin)
◆ SetDataByNeighbors()
◆ SetMaxLen()
◆ SetNewLength()
◆ SetNewLength2d()
bool _LayerEdge::SetNewLength2d ( Handle(Geom_Surface)&  surface,
◆ SetNormal()
void VISCOUS_3D::_LayerEdge::SetNormal ( const gp_XYZ &  n)
◆ SetSmooLen()
void VISCOUS_3D::_LayerEdge::SetSmooLen ( double  len)
◆ smooFunID()
int _LayerEdge::smooFunID ( _LayerEdge::PSmooFun  fun = 0) const
References _funs, _smooFunction, and theNbSmooFuns.
Referenced by Smooth(), and SmoothWoCheck().
◆ Smooth() [1/2]
int _LayerEdge::Smooth ( const int  step,
bool  findBest,
vector< _LayerEdge * > &  toSmooth
◆ Smooth() [2/2]
bool  findBest
◆ smoothAngular()
gp_XYZ _LayerEdge::smoothAngular ( )
References _simplices.
◆ smoothCentroidal()
gp_XYZ _LayerEdge::smoothCentroidal ( )
References _nodes, and _simplices.
◆ smoothLaplacian()
gp_XYZ _LayerEdge::smoothLaplacian ( )
◆ smoothLengthWeighted()
gp_XYZ _LayerEdge::smoothLengthWeighted ( )
◆ smoothNefPolygon()
gp_XYZ _LayerEdge::smoothNefPolygon ( )
References SMESH_MeshAlgos::IsOut(), and SMESH_MesherHelper::WrapIndex().
◆ SmoothOnEdge()
bool _LayerEdge::SmoothOnEdge ( Handle(ShapeAnalysis_Surface)&  surface,
◆ SmoothPos()
void _LayerEdge::SmoothPos ( const vector< double > &  segLen,
const double  tol
References _neibors, _normal, _pos, GetSmoothedPos(), Is(), IsOnFace(), and NORMAL_UPDATED.
Referenced by VISCOUS_3D::_ViscousBuilder::refine().
◆ SmoothWoCheck()
void _LayerEdge::SmoothWoCheck ( )
No check of validity
References _funNames, _neibors, _nodes, _pos, _smooFunction, DIFFICULT, dumpMoveComm, Is(), SMDS_MeshNode::setXYZ(), smooFunID(), and SMOOTHED.
◆ Unset()
◆ UpdatePositionOnSWOL()
◆ _2neibors
◆ _cosin
◆ _curvature
◆ _flags
◆ _funNames
const char * VISCOUS_3D::_LayerEdge::_funNames
Initial value:
= { "Laplacian",
"LengthWeighted",
"Centroidal",
"NefPolygon",
"Angular",
"None"}
◆ _funs
_LayerEdge::PSmooFun VISCOUS_3D::_LayerEdge::_funs
Initial value:
gp_XYZ smoothLengthWeighted()
Definition: StdMeshers_ViscousLayers.cxx:9500
gp_XYZ smoothCentroidal()
Definition: StdMeshers_ViscousLayers.cxx:9539
gp_XYZ smoothAngular()
Definition: StdMeshers_ViscousLayers.cxx:9405
gp_XYZ smoothLaplacian()
Definition: StdMeshers_ViscousLayers.cxx:9389
gp_XYZ smoothNefPolygon()
Definition: StdMeshers_ViscousLayers.cxx:9565
Referenced by ChooseSmooFunction(), smooFunID(), and Smooth().
◆ _len
◆ _lenFactor
◆ _maxLen
◆ _minAngle
double VISCOUS_3D::_LayerEdge::_minAngle
◆ _neibors
◆ _nodes
vector< const SMDS_MeshNode*> VISCOUS_3D::_LayerEdge::_nodes
Referenced by VISCOUS_3D::_TmpMeshFaceOnEdge::_TmpMeshFaceOnEdge(), VISCOUS_3D::_ViscousBuilder::addBoundaryElements(), VISCOUS_3D::_Shrinker1D::AddEdge(), BaseShapeDim(), Block(), CheckNeiborsOnBoundary(), VISCOUS_3D::_ConvexFace::CheckPrisms(), ChooseSmooFunction(), Copy(), VISCOUS_3D::_ViscousBuilder::findCollisionEdges(), VISCOUS_3D::_ViscousBuilder::findEdgesToUpdateNormalNearConvexFace(), FindIntersection(), VISCOUS_3D::_ViscousBuilder::findNeiborsOnEdge(), VISCOUS_3D::_ConvexFace::GetCenterOfCurvature(), VISCOUS_3D::_TmpMeshFaceOnEdge::GetDir(), VISCOUS_3D::_ViscousBuilder::getNormalByOffset(), VISCOUS_3D::_SolidData::GetShapeEdges(), VISCOUS_3D::_ViscousBuilder::getWeigthedNormal(), VISCOUS_3D::_ViscousBuilder::invalidateBadSmooth(), InvalidateStep(), VISCOUS_3D::_ViscousBuilder::isNewNormalOk(), IsOnFace(), VISCOUS_3D::_Smoother1D::isToSmooth(), LastSegment(), VISCOUS_3D::_ViscousBuilder::limitMaxLenByCurvature(), VISCOUS_3D::_ViscousBuilder::limitStepSizeByCurvature(), VISCOUS_3D::_ViscousBuilder::makeGroupOfLE(), VISCOUS_3D::_ViscousBuilder::makeLayer(), VISCOUS_3D::_ViscousBuilder::makeOffsetSurface(), MoveNearConcaVer(), VISCOUS_3D::PeriodicFaces::MoveNodes(), VISCOUS_3D::_LayerEdgeCmp::operator()(), VISCOUS_3D::_Smoother1D::prepare(), VISCOUS_3D::_SolidData::PrepareEdgesToSmoothOnFace(), VISCOUS_3D::_ViscousBuilder::prepareEdgeToShrink(), VISCOUS_3D::_ViscousBuilder::putOnOffsetSurface(), VISCOUS_3D::_ViscousBuilder::refine(), VISCOUS_3D::_ViscousBuilder::restoreNoShrink(), SetDataByNeighbors(), VISCOUS_3D::_ViscousBuilder::setEdgeData(), SetNewLength(), SetNewLength2d(), VISCOUS_3D::_ViscousBuilder::shrink(), Smooth(), VISCOUS_3D::_Smoother1D::smoothAnalyticEdge(), VISCOUS_3D::_ViscousBuilder::smoothAndCheck(), smoothCentroidal(), SmoothOnEdge(), SmoothWoCheck(), VISCOUS_3D::_2NearEdges::srcNode(), VISCOUS_3D::_Shrinker1D::SrcNode(), VISCOUS_3D::_Shrinker1D::SwapSrcTgtNodes(), VISCOUS_3D::_2NearEdges::tgtNode(), VISCOUS_3D::_Shrinker1D::TgtNode(), VISCOUS_3D::_ViscousBuilder::updateNormals(), VISCOUS_3D::_ViscousBuilder::updateNormalsOfConvexFaces(), and UpdatePositionOnSWOL().
◆ _normal
◆ _pos
◆ _simplices
◆ _smooFunction
◆ theNbSmooFuns
const int VISCOUS_3D::_LayerEdge::theNbSmooFuns = FUN_NB
Referenced by smooFunID(), and Smooth().
