VISCOUS_3D::_TmpMeshFaceOnEdge Struct Reference
Class of temporary mesh quadrangle face storing _LayerEdge it's based on. More...
Inheritance diagram for VISCOUS_3D::_TmpMeshFaceOnEdge:
typedef SMDS_StdIterator< const SMDS_MeshNode *, SMDS_NodeIteratorPtr > iterator
 _TmpMeshFaceOnEdge (_LayerEdge *le1, _LayerEdge *le2, int ID)
const SMDS_MeshNode * n (size_t i) const
gp_XYZ GetDir () const
gp_XYZ GetDir (_LayerEdge *le1, _LayerEdge *le2)
virtual SMDSAbs_EntityType GetEntityType () const
virtual SMDSAbs_GeometryType GetGeomType () const
virtual SMDSAbs_ElementType GetType () const
virtual bool IsPoly () const
virtual bool IsQuadratic () const
virtual bool IsMediumNode (const SMDS_MeshNode *) const
 Check if a node is a medium node of a quadratic cell. More...
virtual int NbCornerNodes () const
virtual int NbNodes () const
virtual int NbEdges () const
virtual int NbFaces () const
virtual void Print (std::ostream &OS) const override
 Print self. More...
virtual const SMDS_MeshNode * GetNode (const int ind) const
 =================================================================== More...
virtual SMDS_ElemIteratorPtr nodesIterator () const
virtual SMDS_NodeIteratorPtr nodeIterator () const
virtual smIdType GetID () const
 Return ID of an element. More...
virtual int GetShapeID () const
 Return ID of a shape this element was generated on. More...
virtual void setIsMarked (bool is) const
 Mark this element. More...
virtual bool isMarked () const
 Check if this element is marked. More...
virtual VTKCellType GetVtkType () const
virtual SMDS_NodeIteratorPtr interlacedNodesIterator () const
virtual SMDS_NodeIteratorPtr nodesIteratorToUNV () const
iterator begin_nodes () const
iterator end_nodes () const
const SMDS_MeshNode * GetNodeWrap (const int ind) const
 Return node by its index. More...
virtual bool IsValidIndex (const int ind) const
 Return true if index of node is valid (0 <= ind < NbNodes()) More...
int WrappedIndex (const int ind) const
 Return a valid corner node index, fixing the given one if necessary. More...
virtual int GetNodeIndex (const SMDS_MeshNode *node) const
 Check if a node belongs to the element. More...
virtual vtkIdType GetVtkID () const
 Return VTK ID of this element. More...
virtual int getshapeId () const
bool IsNull () const
SMDS_Mesh * GetMesh () const
 Return the mesh this element belongs to. More...
Data Fields
_LayerEdge * _le1
_LayerEdge * _le2
const SMDS_MeshElement * _srcFace
Protected Types
enum  Bits { BIT_IS_MARKED = 1 , BITS_SHIFT = 1 }
virtual void setID (const smIdType id)
virtual void setShapeID (const int shapeID)
virtual void setShapeID (const int shapeID) const
 Set ID of a shape this element was generated on. More...
void setVtkID (const vtkIdType vtkID)
 Store VTK ID. More...
SMDS_UnstructuredGrid * getGrid () const
 Return a SMDS_UnstructuredGrid. More...
std::vector< const SMDS_MeshNode * > myNodes
smIdType myID
int myShapeID
SMDS_ElementChunk * myHolder
◆ iterator
◆ Bits
enum SMDS_CellOfNodes::Bits
BIT_IS_MARKED
BITS_SHIFT
◆ _TmpMeshFaceOnEdge()
VISCOUS_3D::_TmpMeshFaceOnEdge::_TmpMeshFaceOnEdge ( _LayerEdge *  le1,
_LayerEdge *  le2,
int  ID
◆ begin_nodes()
◆ end_nodes()
◆ GetDir() [1/2]
gp_XYZ VISCOUS_3D::_TmpMeshFaceOnEdge::GetDir ( ) const
◆ GetDir() [2/2]
gp_XYZ VISCOUS_3D::_TmpMeshFaceOnEdge::GetDir ( _LayerEdge *  le1,
_LayerEdge *  le2
◆ GetEntityType()
virtual SMDSAbs_EntityType VISCOUS_3D::_TmpMeshFace::GetEntityType ( ) const
◆ GetGeomType()
virtual SMDSAbs_GeometryType VISCOUS_3D::_TmpMeshFace::GetGeomType ( ) const
◆ getGrid()
◆ GetID()
smIdType SMDS_CellOfNodes::GetID ( ) const
Reimplemented from SMDS_MeshElement.
References SMDS_CellOfNodes::myID.
Referenced by SMDS_FaceOfNodes::Print(), SMDS_PolygonalFaceOfNodes::Print(), and SMDS_VolumeOfNodes::Print().
◆ GetMesh()
◆ GetNode()
const SMDS_MeshNode * SMDS_PolygonalFaceOfNodes::GetNode ( const int  ind) const
Iterator on edges of face ===================================================================
ind- node index
constSMDS_MeshNode* - the node
Implements SMDS_MeshElement.
References SMDS_PolygonalFaceOfNodes::myNodes, and SMDS_MeshElement::WrappedIndex().
◆ GetNodeIndex()
int SMDS_MeshElement::GetNodeIndex ( const SMDS_MeshNode *  node) const
node- the node to check
int- node index within the element, -1 if not found
Reimplemented in SMDS_FaceOfNodes, SMDS_LinearEdge, SMDS_MeshCell, SMDS_MeshVolume, and SMDS_VolumeOfNodes.
References SMDS_MeshElement::nodesIterator().
Referenced by VISCOUS_3D::_ViscousBuilder::addBoundaryElements(), StdMeshers_QuadToTriaAdaptor::Compute2ndPart(), SMESH_MeshAlgos::Intersector::Algo::Cut(), SMESH_MeshAlgos::Intersector::CutByPlanes(), SMDS_UnstructuredGrid::extrudeVolumeFromFace(), SMDS_Mesh::FindEdge(), SMDS_Mesh::FindElement(), findExistingTriangulation(), SMESH_MeshAlgos::FindFaceInSet(), VISCOUS_3D::_LayerEdge::FindIntersection(), SMESH_MeshEditor::FindMatchingNodes(), SMESH_ElementSearcherImpl::findOuterBoundary(), findSegment(), SMESH_MeshAlgos::GetCommonNodes(), VISCOUS_3D::getDistFromEdge(), SMDS_Mesh::GetElementsByNodes(), VISCOUS_3D::_Simplex::GetSimplices(), SMESH::Controls::FreeEdges::IsFreeEdge(), SMDS_VolumeTool::IsFreeFace(), SMDS_MeshElement::IsMediumNode(), SMESH_MeshAlgos::IsOn2DBoundary(), SMESH_MeshAlgos::IsRightOrder(), SMESH::Controls::BareBorderFace::IsSatisfy(), StdMeshers_QuadToTriaAdaptor::LimitHeight(), _QuadFaceGrid::LoadGrid(), SMESH_MeshEditor::MakeBoundaryMesh(), SMESH_MeshAlgos::Intersector::Algo::MakeNewFaces(), SMESH_MeshAlgos::MakeOffset(), SMESH_MeshEditor::makeWalls(), SMESH_MeshEditor::MergeNodes(), SMESH_MeshAlgos::NbCommonNodes(), StdMeshers_QuadToTriaAdaptor::Preparation(), SMESH_MeshEditor::Reorient2DBy3D(), SMESH::Controls::CoplanarFaces::SetMesh(), SMESH_MeshEditor::SewSideElements(), StdMeshers_Quadrangle_2D::smooth(), VISCOUS_3D::_ViscousBuilder::smoothAndCheck(), and VISCOUS_3D::_Shrinker1D::SwapSrcTgtNodes().
◆ GetNodeWrap()
const SMDS_MeshNode * SMDS_MeshElement::GetNodeWrap ( const int  ind) const
ind- node index
Index is wrapped if it is out of a valid range of corner nodes
Referenced by SMESH_MeshAlgos::Intersector::Algo::Cut(), SMESH_MeshEditor::GetLinkedNodes(), and SMESH_MeshEditor::makeWalls().
◆ GetShapeID()
int SMDS_CellOfNodes::GetShapeID ( ) const
References SMDS_CellOfNodes::BITS_SHIFT, and SMDS_CellOfNodes::myShapeID.
◆ getshapeId()
virtual int SMDS_MeshElement::getshapeId ( ) const
Referenced by SMESH_Delaunay::addCloseNodes(), SMESHDS_SubMesh::AddNode(), areNodesBound(), StdMeshers_Quadrangle_2D::check(), SMESH_MesherHelper::CheckNodeU(), SMESH_MesherHelper::CheckNodeUV(), StdMeshers_Import_1D2D::Compute(), VISCOUS_3D::_ViscousBuilder::computeGeomSize(), SMESHDS_SubMesh::Contains(), SMESH_MeshEditor::convertElemToQuadratic(), SMESH_MeshEditor::ConvertToQuadratic(), SMESH_MeshEditor::copyPosition(), SMESH_Pattern::createElements(), SMESH_MeshEditor::CreateHoleSkin(), SMESH_MeshEditor::DeleteDiag(), SMESH_Mesh_i::exportMEDFields(), VISCOUS_3D::_ViscousBuilder::findEdgesToUpdateNormalNearConvexFace(), StdMeshers_ProjectionUtils::FindMatchingNodesOnFaces(), SMESH_MeshEditor::FindShape(), VISCOUS_3D::_ViscousBuilder::findShapesToSmooth(), SMESH_MesherHelper::FixQuadraticElements(), SMESH_MesherHelper::GetCentralNode(), VISCOUS_3D::_ViscousBuilder::getFaceNormal(), SMESH_MesherHelper::GetMediumNode(), SMESH_MesherHelper::getMediumNodeOnComposedWire(), SMESH_MesherHelper::GetMediumPos(), StdMeshers_PrismAsBlock::GetNodeColumn(), SMESH_MesherHelper::GetNodeU(), SMESH_MesherHelper::GetNodeUV(), VISCOUS_3D::_EdgesOnShape::GetNormal(), StdMeshers_FaceSide::GetOrderedNodes(), SMESH_ProxyMesh::GetProxyNode(), SMESH_Mesh_i::GetShapeID(), VISCOUS_3D::_Simplex::GetSimplices(), SMESH_MesherHelper::GetSubShapeByNode(), StdMeshers_FaceSide::GetUVPtStruct(), SMESH::Controls::Deflection2D::GetValue(), StdMeshers_PrismAsBlock::HasNodeColumn(), StdMeshers_PrismAsBlock::Init(), SMESH_MeshEditor::InsertNodesIntoLink(), SMESH_MeshEditor::InverseDiag(), SMESH_MesherHelper::IsCornerOfStructure(), SMESH::Controls::BelongToGeom::IsSatisfy(), SMESH::Controls::LyingOnGeom::IsSatisfy(), SMESH_Pattern::Load(), VISCOUS_3D::_ViscousBuilder::makeLayer(), SMESH_MeshEditor::MergeNodes(), StdMeshers_QuadToTriaAdaptor::MergePiramids(), DriverGMF_Write::Perform(), SMESH_MeshEditor::QuadTo4Tri(), SMESH_MeshEditor::Remove(), SMESHDS_Mesh::RemoveElement(), SMESHDS_SubMesh::RemoveElement(), SMESHDS_Mesh::RemoveFreeElement(), SMESHDS_Mesh::RemoveFreeNode(), SMESHDS_Mesh::RemoveNode(), SMESHDS_SubMesh::RemoveNode(), SMESH_MeshEditor::removeQuadElem(), VISCOUS_3D::_ViscousBuilder::setEdgeData(), SMESH_MeshEditor::SewSideElements(), VISCOUS_2D::_ViscousBuilder2D::shrink(), StdMeshers_Quadrangle_2D::smooth(), VISCOUS_3D::_ViscousBuilder::smoothAndCheck(), SMESH_MeshEditor::SplitBiQuadraticIntoLinear(), StdMeshers_PrismAsBlock::TPCurveOnHorFaceAdaptor::TPCurveOnHorFaceAdaptor(), SMESH_MeshEditor::TriToQuad(), SMESHDS_Mesh::UnSetElementOnShape(), SMESHDS_Mesh::UnSetNodeOnShape(), SMESH_MeshEditor::UpdateVolumes(), StdMeshers_PrismAsBlock::TSideFace::Value(), and SMESH_Algo::VertexNode().
◆ GetType()
SMDSAbs_ElementType SMDS_PolygonalFaceOfNodes::GetType ( ) const
References SMDSAbs_Face.
◆ GetVtkID()
vtkIdType SMDS_MeshElement::GetVtkID ( ) const
References SMDS_ElementChunk::GetVtkID(), and SMDS_MeshElement::myHolder.
Referenced by SMDS_MeshNode::AddInverseElement(), SMDS_ElementHolder::beforeCompacting(), SMDS_MeshCell::ChangeNodes(), SMDS_MeshVolume::ChangeNodes(), SMDS_MeshNode::ClearInverseElements(), SMDS_ElementFactory::Compact(), SMESH_MeshEditor::CreateHoleSkin(), SMESH_MeshEditor::DoubleNodesOnGroupBoundaries(), SMDS_UnstructuredGrid::extrudeVolumeFromFace(), SMDS_ElementFactory::Free(), SMDS_MeshNode::getCoord(), SMDS_BallElement::GetDiameter(), SMESH_VisualObjDef::GetElemVTKId(), SMESHGUI_PreVisualObj::GetElemVTKId(), SMDS_MeshVolume::GetFaceNode(), SMDS_MeshNode::GetInverseElementIterator(), SMDS_MeshCell::GetNode(), SMDS_MeshVolume::GetNode(), SMDS_MeshCell::GetNodeIndex(), SMDS_MeshVolume::GetNodeIndex(), SMESH_VisualObjDef::GetNodeVTKId(), SMDS_MeshVolume::GetQuantities(), SMESH::Controls::AspectRatio3D::GetValue(), SMDS_MeshCell::GetVtkType(), SMDS_MeshNode::GetXYZ(), SMDS_BallElement::init(), SMDS_MeshNode::init(), SMDS_MeshCell::init(), SMDS_MeshVolume::NbEdges(), SMDS_MeshVolume::NbFaceNodes(), SMDS_MeshVolume::NbFaces(), SMDS_MeshNode::NbInverseElements(), SMDS_MeshCell::NbNodes(), SMDS_MeshVolume::NbNodes(), SMDS_MeshCell::nodeIterator(), SMDS_MeshVolume::nodeIterator(), SMDS_MeshCell::nodesIterator(), SMDS_MeshVolume::nodesIterator(), SMDS_MeshCell::nodesIteratorToUNV(), SMDS_Mesh::RemoveFreeElement(), SMDS_MeshNode::RemoveInverseElement(), SMDS_BallElement::SetDiameter(), and SMDS_MeshNode::setXYZ().
◆ GetVtkType()
virtual VTKCellType SMDS_CellOfNodes::GetVtkType ( ) const
◆ interlacedNodesIterator()
◆ isMarked()
bool SMDS_CellOfNodes::isMarked ( ) const
References SMDS_CellOfNodes::BIT_IS_MARKED, and SMDS_CellOfNodes::myShapeID.
◆ IsMediumNode()
virtual bool SMDS_PolygonalFaceOfNodes::IsMediumNode ( const SMDS_MeshNode *  node) const
◆ IsNull()
◆ IsPoly()
virtual bool SMDS_PolygonalFaceOfNodes::IsPoly ( ) const
◆ IsQuadratic()
virtual bool SMDS_PolygonalFaceOfNodes::IsQuadratic ( ) const
◆ IsValidIndex()
bool SMDS_MeshElement::IsValidIndex ( const int  ind) const
ind- node index
bool- index check result
References SMDS_MeshElement::NbNodes().
◆ n()
const SMDS_MeshNode * VISCOUS_3D::_TmpMeshFaceOnEdge::n ( size_t  i) const
◆ NbCornerNodes()
virtual int SMDS_PolygonalFaceOfNodes::NbCornerNodes ( ) const
◆ NbEdges()
int SMDS_PolygonalFaceOfNodes::NbEdges ( ) const
◆ NbFaces()
int SMDS_PolygonalFaceOfNodes::NbFaces ( ) const
◆ NbNodes()
int SMDS_PolygonalFaceOfNodes::NbNodes ( ) const
◆ nodeIterator()
SMDS_NodeIteratorPtr SMDS_PolygonalFaceOfNodes::nodeIterator ( ) const
◆ nodesIterator()
SMDS_ElemIteratorPtr SMDS_PolygonalFaceOfNodes::nodesIterator ( ) const
◆ nodesIteratorToUNV()
virtual SMDS_NodeIteratorPtr SMDS_MeshElement::nodesIteratorToUNV ( ) const
Reimplemented in SMDS_MeshCell.
◆ Print()
void SMDS_PolygonalFaceOfNodes::Print ( std::ostream &  OS) const
overridevirtualinherited
Print self.
References SMDS_CellOfNodes::GetID(), and SMDS_PolygonalFaceOfNodes::myNodes.
◆ setID()
void SMDS_CellOfNodes::setID ( const smIdType  id)
◆ setIsMarked()
void SMDS_CellOfNodes::setIsMarked ( bool  is) const
Mark this element.
◆ setShapeID() [1/2]
void SMDS_CellOfNodes::setShapeID ( const int  shapeID)
◆ setShapeID() [2/2]
void SMDS_MeshElement::setShapeID ( const int  shapeID) const
◆ setVtkID()
void SMDS_MeshElement::setVtkID ( const vtkIdType  vtkID)
◆ WrappedIndex()
int SMDS_MeshElement::WrappedIndex ( const int  ind) const
ind- node index
int- valid node index
References SMDS_MeshElement::NbCornerNodes().
Referenced by SMDS_PolygonalFaceOfNodes::GetNode().
◆ _le1
_LayerEdge* VISCOUS_3D::_TmpMeshFaceOnEdge::_le1
◆ _le2
_LayerEdge * VISCOUS_3D::_TmpMeshFaceOnEdge::_le2
◆ _srcFace
const SMDS_MeshElement* VISCOUS_3D::_TmpMeshFace::_srcFace
◆ myHolder
◆ myID
smIdType SMDS_CellOfNodes::myID
◆ myNodes
◆ myShapeID
