SMDS_CellOfNodes Class Referenceabstract
Base class for elements not contained in the mesh. More...
#include <SMDS_CellOfNodes.hxx>
Inheritance diagram for SMDS_CellOfNodes:
typedef SMDS_StdIterator< const SMDS_MeshNode *, SMDS_NodeIteratorPtr > iterator
virtual smIdType GetID () const
 Return ID of an element. More...
virtual int GetShapeID () const
 Return ID of a shape this element was generated on. More...
virtual void setIsMarked (bool is) const
 Mark this element. More...
virtual bool isMarked () const
 Check if this element is marked. More...
virtual VTKCellType GetVtkType () const
virtual SMDS_ElemIteratorPtr nodesIterator () const =0
virtual SMDS_NodeIteratorPtr nodeIterator () const =0
virtual SMDS_NodeIteratorPtr interlacedNodesIterator () const
virtual SMDS_NodeIteratorPtr nodesIteratorToUNV () const
iterator begin_nodes () const
iterator end_nodes () const
virtual int NbNodes () const =0
virtual int NbEdges () const =0
virtual int NbFaces () const =0
virtual SMDSAbs_ElementType GetType () const =0
virtual SMDSAbs_EntityType GetEntityType () const =0
virtual SMDSAbs_GeometryType GetGeomType () const =0
virtual bool IsPoly () const =0
virtual bool IsQuadratic () const =0
virtual bool IsMediumNode (const SMDS_MeshNode *node) const
 Check if a node is a medium node of a quadratic cell. More...
virtual int NbCornerNodes () const =0
virtual const SMDS_MeshNode * GetNode (const int ind) const =0
 Return node by its index. More...
const SMDS_MeshNode * GetNodeWrap (const int ind) const
virtual bool IsValidIndex (const int ind) const
 Return true if index of node is valid (0 <= ind < NbNodes()) More...
int WrappedIndex (const int ind) const
 Return a valid corner node index, fixing the given one if necessary. More...
virtual int GetNodeIndex (const SMDS_MeshNode *node) const
 Check if a node belongs to the element. More...
virtual vtkIdType GetVtkID () const
 Return VTK ID of this element. More...
virtual int getshapeId () const
bool IsNull () const
SMDS_Mesh * GetMesh () const
 Return the mesh this element belongs to. More...
virtual void Print (std::ostream &OS) const
 Print self. More...
Protected Types
enum  Bits { BIT_IS_MARKED = 1 , BITS_SHIFT = 1 }
 SMDS_CellOfNodes (smIdType id=-1, int shapeID=0)
virtual void setID (const smIdType id)
virtual void setShapeID (const int shapeID)
void setVtkID (const vtkIdType vtkID)
 Store VTK ID. More...
virtual void setShapeID (const int shapeID) const
 Set ID of a shape this element was generated on. More...
SMDS_UnstructuredGrid * getGrid () const
 Return a SMDS_UnstructuredGrid. More...
smIdType myID
int myShapeID
SMDS_ElementChunk * myHolder
◆ iterator
◆ Bits
enum SMDS_CellOfNodes::Bits
BIT_IS_MARKED
BITS_SHIFT
◆ SMDS_CellOfNodes()
SMDS_CellOfNodes::SMDS_CellOfNodes ( smIdType  id = -1,
int  shapeID = 0
References setShapeID().
◆ begin_nodes()
◆ end_nodes()
◆ GetEntityType()
virtual SMDSAbs_EntityType SMDS_MeshElement::GetEntityType ( ) const
pure virtualinherited
Implemented in SMDS_FaceOfNodes, SMDS_LinearEdge, SMDS_MeshCell, SMDS_MeshNode, SMDS_PolygonalFaceOfNodes, SMDS_VolumeOfNodes, and VISCOUS_3D::_TmpMeshFace.
Referenced by SMDS_MeshInfo::addWithPoly(), SMESH_MeshEditor::applyMerge(), SMESH_VisualObjDef::buildElemPrs(), StdMeshers_Import_1D2D::Compute(), SMESH_MeshEditor::convertElemToQuadratic(), SMESH_MeshEditor::ConvertToQuadratic(), SMESH_MeshEditor::DeleteDiag(), SMESH_MeshAlgos::DeMerge(), SMESH_MeshEditor::doubleNodes(), SMESH::SelectionProxy::elementEntityType(), StdMeshers_Import_1D2D::Evaluate(), SMESH_MeshEditor::ExtrusionSweep(), SMESH_MesherHelper::FixQuadraticElements(), SMESH::Controls::TSequenceOfXYZ::getElementEntity(), SMESH_Mesh_i::GetElementGeomType(), SMESHDS_GroupOnFilter::getElementIds(), VISCOUS_3D::_TmpMeshFace::GetEntityType(), SMESH::Filter_i::GetMeshInfo(), SMESH_MeshAlgos::Triangulate::GetNbTriangles(), SMESH_MeshEditor_i::GetPreviewData(), SMESH_MeshAlgos::Triangulate::GetTriangles(), SMESH::Controls::MaxElementLength3D::GetValue(), SMESH_MeshEditor::InverseDiag(), SMESH::Controls::Length2D::IsApplicable(), SMESH::Controls::ElemEntityType::IsSatisfy(), SMESH_MeshAlgos::MakeOffset(), SMESH_MeshEditor::makeWalls(), SMDS_MeshElement::EntityFilter::operator()(), DriverCGNS_Write::Perform(), DriverGMF_Write::Perform(), SMDS_MeshInfo::RemoveFace(), SMESH_MeshEditor::Reorient(), SMESH_MeshEditor::RotationSweep(), DriverMED_W_Field::Set(), SMESH_MeshEditor::SplitBiQuadraticIntoLinear(), SMESH_MeshEditor::SplitFace(), SMESH_MeshEditor::SplitVolumes(), SMESH_MeshEditor::sweepElement(), SMESH_MeshEditor::Transform(), and SMESHDS_GroupOnFilter::update().
◆ GetGeomType()
◆ getGrid()
◆ GetID()
smIdType SMDS_CellOfNodes::GetID ( ) const
Reimplemented from SMDS_MeshElement.
References myID.
Referenced by SMDS_FaceOfNodes::Print(), SMDS_PolygonalFaceOfNodes::Print(), and SMDS_VolumeOfNodes::Print().
◆ GetMesh()
◆ GetNode()
virtual const SMDS_MeshNode * SMDS_MeshElement::GetNode ( const int  ind) const
ind- node index
constSMDS_MeshNode* - the node
Implemented in SMDS_FaceOfNodes, SMDS_LinearEdge, SMDS_MeshCell, SMDS_MeshNode, SMDS_MeshVolume, SMDS_PolygonalFaceOfNodes, and SMDS_VolumeOfNodes.
Referenced by SMESH_Delaunay::addCloseNodes(), StdMeshers_Quadrangle_2D::check(), StdMeshers_Prism_3D::compute(), StdMeshers_QuadToTriaAdaptor::Compute(), StdMeshers_Hexa_3D::Compute(), StdMeshers_Import_1D::Compute(), StdMeshers_Import_1D2D::Compute(), StdMeshers_Projection_3D::Compute(), StdMeshers_RadialPrism_3D::Compute(), StdMeshers_QuadToTriaAdaptor::Compute2ndPart(), SMESHDS_GroupOnGeom::Contains(), SMESH_MeshEditor::ConvertFromQuadratic(), SMESH_MeshAlgos::Intersector::Algo::Cut(), SMESH_MeshAlgos::Intersector::CutByPlanes(), StdMeshers_QuadToTriaAdaptor::DecreaseHeightDifference(), StdMeshers_Import_1D::Evaluate(), StdMeshers_Import_1D2D::Evaluate(), SMESH_MeshAlgos::FaceNormal(), SMESH_MeshAlgos::FindCoincidentFreeBorders(), findExistingTriangulation(), SMESH_MeshAlgos::FindFaceInSet(), SMESH_MeshAlgos::FindFreeBorders(), SMESH_MeshEditor::FindMatchingNodes(), StdMeshers_ProjectionUtils::FindMatchingNodesOnFaces(), VISCOUS_3D::_ViscousBuilder::findNeiborsOnEdge(), SMESH_ElementSearcherImpl::findOuterBoundary(), VISCOUS_3D::_ViscousBuilder::findShapesToSmooth(), SMESH_MeshAlgos::FindSharpEdges(), VISCOUS_3D::_ViscousBuilder::fixBadFaces(), SMESH_2D_Algo::FixInternalNodes(), SMESH_MesherHelper::FixQuadraticElements(), SMESH_MeshAlgos::Get1DBranches(), SMESH_MeshAlgos::GetCommonNodes(), VISCOUS_3D::getDistFromEdge(), StdMeshers_FaceSide::GetEdgeNodes(), SMESH_VisualObjDef::GetEdgeNodes(), SMESHGUI_PreVisualObj::GetEdgeNodes(), MeshEditor_I::getElementsAround(), SMESH_Mesh_i::GetElemNode(), getFaceID(), SMESH_ElementSearcherImpl::getIntersParamOnLine(), SMESH_Algo::GetMeshError(), _FaceSide::GetNbSegments(), VISCOUS_3D::_Simplex::GetSimplices(), SMESH_MeshAlgos::Triangulate::GetTriangles(), SMESH::Controls::Deflection2D::GetValue(), SMESH_MeshAlgos::IsOn2DBoundary(), SMESH_MesherHelper::IsQuadraticSubMesh(), SMESH_MesherHelper::IsReversedSubMesh(), SMESH::Controls::ElementsOnShape::IsSatisfy(), SMESH::Controls::CoincidentElements::IsSatisfy(), StdMeshers_QuadToTriaAdaptor::LimitHeight(), VISCOUS_3D::_ViscousBuilder::limitStepSize(), SMESH_Pattern::Load(), _QuadFaceGrid::LoadGrid(), SMESH_MeshEditor::MakeBoundaryMesh(), VISCOUS_3D::_ViscousBuilder::makeGroupOfLE(), VISCOUS_3D::_ViscousBuilder::makeLayer(), VISCOUS_3D::_ViscousBuilder::MakeN2NMap(), SMESH_MeshAlgos::MakeSlot(), StdMeshers_Penta_3D::MakeVolumeMesh(), StdMeshers_QuadToTriaAdaptor::MergeAdjacent(), StdMeshers_QuadToTriaAdaptor::MergePiramids(), SMESH_MeshAlgos::NbCommonNodes(), DriverCGNS_Write::Perform(), DriverMED_W_SMESHDS_Mesh::PerformInternal(), SMESH_Gen_i::Precompute(), StdMeshers_QuadToTriaAdaptor::Preparation(), VISCOUS_3D::_ViscousBuilder::prepareEdgeToShrink(), StdMeshers_Sweeper::prepareTopBotDelaunay(), StdMeshers_Prism_3D::projectBottomToTop(), SMESH_MeshEditor::Reorient2D(), SMESH::Controls::CoplanarFaces::SetMesh(), StdMeshers_Adaptive1D::SetParametersByMesh(), StdMeshers_SegmentLengthAroundVertex::SetParametersByMesh(), VISCOUS_2D::_ViscousBuilder2D::shrink(), VISCOUS_3D::_ViscousBuilder::shrink(), StdMeshers_Quadrangle_2D::smooth(), SMESH_MeshEditor::Smooth(), and SMESH_MeshEditor::SplitFace().
◆ GetNodeIndex()
int SMDS_MeshElement::GetNodeIndex ( const SMDS_MeshNode *  node) const
node- the node to check
int- node index within the element, -1 if not found
Reimplemented in SMDS_FaceOfNodes, SMDS_LinearEdge, SMDS_MeshCell, SMDS_MeshVolume, and SMDS_VolumeOfNodes.
References SMDS_MeshElement::nodesIterator().
Referenced by VISCOUS_3D::_ViscousBuilder::addBoundaryElements(), StdMeshers_QuadToTriaAdaptor::Compute2ndPart(), SMESH_MeshAlgos::Intersector::Algo::Cut(), SMESH_MeshAlgos::Intersector::CutByPlanes(), SMDS_UnstructuredGrid::extrudeVolumeFromFace(), SMDS_Mesh::FindEdge(), SMDS_Mesh::FindElement(), findExistingTriangulation(), SMESH_MeshAlgos::FindFaceInSet(), VISCOUS_3D::_LayerEdge::FindIntersection(), SMESH_MeshEditor::FindMatchingNodes(), SMESH_ElementSearcherImpl::findOuterBoundary(), findSegment(), SMESH_MeshAlgos::GetCommonNodes(), VISCOUS_3D::getDistFromEdge(), SMDS_Mesh::GetElementsByNodes(), VISCOUS_3D::_Simplex::GetSimplices(), SMESH::Controls::FreeEdges::IsFreeEdge(), SMDS_VolumeTool::IsFreeFace(), SMDS_MeshElement::IsMediumNode(), SMESH_MeshAlgos::IsOn2DBoundary(), SMESH_MeshAlgos::IsRightOrder(), SMESH::Controls::BareBorderFace::IsSatisfy(), StdMeshers_QuadToTriaAdaptor::LimitHeight(), _QuadFaceGrid::LoadGrid(), SMESH_MeshEditor::MakeBoundaryMesh(), SMESH_MeshAlgos::Intersector::Algo::MakeNewFaces(), SMESH_MeshAlgos::MakeOffset(), SMESH_MeshEditor::makeWalls(), SMESH_MeshEditor::MergeNodes(), SMESH_MeshAlgos::NbCommonNodes(), StdMeshers_QuadToTriaAdaptor::Preparation(), SMESH_MeshEditor::Reorient2DBy3D(), SMESH::Controls::CoplanarFaces::SetMesh(), SMESH_MeshEditor::SewSideElements(), StdMeshers_Quadrangle_2D::smooth(), VISCOUS_3D::_ViscousBuilder::smoothAndCheck(), and VISCOUS_3D::_Shrinker1D::SwapSrcTgtNodes().
◆ GetNodeWrap()
const SMDS_MeshNode * SMDS_MeshElement::GetNodeWrap ( const int  ind) const
ind- node index
Index is wrapped if it is out of a valid range of corner nodes
Referenced by SMESH_MeshAlgos::Intersector::Algo::Cut(), SMESH_MeshEditor::GetLinkedNodes(), and SMESH_MeshEditor::makeWalls().
◆ GetShapeID()
int SMDS_CellOfNodes::GetShapeID ( ) const
References BITS_SHIFT, and myShapeID.
◆ getshapeId()
virtual int SMDS_MeshElement::getshapeId ( ) const
Referenced by SMESH_Delaunay::addCloseNodes(), SMESHDS_SubMesh::AddNode(), areNodesBound(), StdMeshers_Quadrangle_2D::check(), SMESH_MesherHelper::CheckNodeU(), SMESH_MesherHelper::CheckNodeUV(), StdMeshers_Import_1D2D::Compute(), VISCOUS_3D::_ViscousBuilder::computeGeomSize(), SMESHDS_SubMesh::Contains(), SMESH_MeshEditor::convertElemToQuadratic(), SMESH_MeshEditor::ConvertToQuadratic(), SMESH_MeshEditor::copyPosition(), SMESH_Pattern::createElements(), SMESH_MeshEditor::CreateHoleSkin(), SMESH_MeshEditor::DeleteDiag(), SMESH_Mesh_i::exportMEDFields(), VISCOUS_3D::_ViscousBuilder::findEdgesToUpdateNormalNearConvexFace(), StdMeshers_ProjectionUtils::FindMatchingNodesOnFaces(), SMESH_MeshEditor::FindShape(), VISCOUS_3D::_ViscousBuilder::findShapesToSmooth(), SMESH_MesherHelper::FixQuadraticElements(), SMESH_MesherHelper::GetCentralNode(), VISCOUS_3D::_ViscousBuilder::getFaceNormal(), SMESH_MesherHelper::GetMediumNode(), SMESH_MesherHelper::getMediumNodeOnComposedWire(), SMESH_MesherHelper::GetMediumPos(), StdMeshers_PrismAsBlock::GetNodeColumn(), SMESH_MesherHelper::GetNodeU(), SMESH_MesherHelper::GetNodeUV(), VISCOUS_3D::_EdgesOnShape::GetNormal(), StdMeshers_FaceSide::GetOrderedNodes(), SMESH_ProxyMesh::GetProxyNode(), SMESH_Mesh_i::GetShapeID(), VISCOUS_3D::_Simplex::GetSimplices(), SMESH_MesherHelper::GetSubShapeByNode(), StdMeshers_FaceSide::GetUVPtStruct(), SMESH::Controls::Deflection2D::GetValue(), StdMeshers_PrismAsBlock::HasNodeColumn(), StdMeshers_PrismAsBlock::Init(), SMESH_MeshEditor::InsertNodesIntoLink(), SMESH_MeshEditor::InverseDiag(), SMESH_MesherHelper::IsCornerOfStructure(), SMESH::Controls::BelongToGeom::IsSatisfy(), SMESH::Controls::LyingOnGeom::IsSatisfy(), SMESH_Pattern::Load(), VISCOUS_3D::_ViscousBuilder::makeLayer(), SMESH_MeshEditor::MergeNodes(), StdMeshers_QuadToTriaAdaptor::MergePiramids(), DriverGMF_Write::Perform(), SMESH_MeshEditor::QuadTo4Tri(), SMESH_MeshEditor::Remove(), SMESHDS_Mesh::RemoveElement(), SMESHDS_SubMesh::RemoveElement(), SMESHDS_Mesh::RemoveFreeElement(), SMESHDS_Mesh::RemoveFreeNode(), SMESHDS_Mesh::RemoveNode(), SMESHDS_SubMesh::RemoveNode(), SMESH_MeshEditor::removeQuadElem(), VISCOUS_3D::_ViscousBuilder::setEdgeData(), SMESH_MeshEditor::SewSideElements(), VISCOUS_2D::_ViscousBuilder2D::shrink(), StdMeshers_Quadrangle_2D::smooth(), VISCOUS_3D::_ViscousBuilder::smoothAndCheck(), SMESH_MeshEditor::SplitBiQuadraticIntoLinear(), StdMeshers_PrismAsBlock::TPCurveOnHorFaceAdaptor::TPCurveOnHorFaceAdaptor(), SMESH_MeshEditor::TriToQuad(), SMESHDS_Mesh::UnSetElementOnShape(), SMESHDS_Mesh::UnSetNodeOnShape(), SMESH_MeshEditor::UpdateVolumes(), StdMeshers_PrismAsBlock::TSideFace::Value(), and SMESH_Algo::VertexNode().
◆ GetType()
virtual SMDSAbs_ElementType SMDS_MeshElement::GetType ( ) const
Implemented in SMDS_FaceOfNodes, SMDS_LinearEdge, SMDS_MeshCell, SMDS_MeshEdge, SMDS_MeshFace, SMDS_MeshNode, SMDS_MeshVolume, SMDS_PolygonalFaceOfNodes, and SMDS_VolumeOfNodes.
Referenced by SMDS_MeshInfo::add(), SMESHDS_SubMesh::add(), SMDS_MeshGroup::Add(), SMDS_Mesh::addChildrenWithNodes(), SMESHDS_SubMesh::AddElement(), SMESH_MeshEditor_i::AddNodeOnFace(), SMESH_MeshEditor_i::AffectedElemGroupsInRegion(), SMESH_Pattern_i::ApplyToHexahedrons(), SMESH_Pattern_i::ApplyToMeshFaces(), SMESH_Mesh_i::BaryCenter(), SMDS_ElementHolder::beforeCompacting(), SMESH_MeshEditor::BestSplit(), SMESH_MeshEditor_i::BestSplit(), DriverMED::buildMeshGrille(), StdMeshers_Prism_3D::compute(), StdMeshers_Projection_2D::Compute(), StdMeshers_Projection_3D::Compute(), StdMeshers_RadialPrism_3D::Compute(), SMDS_Mesh::Contains(), SMESH_ProxyMesh::SubMesh::Contains(), SMESH_MeshEditor::convertElemToQuadratic(), SMESH_MeshEditor::ConvertFromQuadratic(), SMESH_MeshEditor::ConvertToQuadratic(), MeshEditor_I::TPreviewMesh::Copy(), SMESH_Gen_i::CopyMesh(), SMESH_MeshAlgos::DeMerge(), SMESH_MeshEditor::DoubleElements(), SMDS_Mesh::DownCast(), SMESH::SelectionProxy::elementControl(), SMESH::SelectionProxy::elementNormal(), SMESH::SelectionProxy::elementType(), SMESH_MeshEditor::ExtrusionSweep(), SMESH_MeshAlgos::FaceNormal(), SMESHDS_GroupBase::findInMesh(), SMESH_MeshEditor::FindShape(), findTriangles(), SMESH_MeshEditor::generateGroups(), SMESH_MeshAlgos::Get1DBranches(), SMESH_Gen_i::GetBadInputElements(), SMESH_MeshAlgos::GetDistance(), StdMeshers_FaceSide::GetEdgeNodes(), SMESHGUI_PreVisualObj::GetEdgeNodes(), SMESH_MeshObj::GetElemDimension(), SMESH_subMesh_i::GetElementsByType(), SMESH::Controls::Filter::GetElementsId(), SMDS_Mesh::GetElementType(), DriverMED_R_SMESHDS_Mesh::GetGroup(), SMESH_MeshEditor::GetLinkedNodes(), SMESH_MeshEditor_i::GetPreviewData(), SMESH_Mesh_i::GetSubMeshElementType(), SMESH_MeshAlgos::Triangulate::GetTriangles(), SMESH::Controls::MultiConnection2D::GetValue(), StdMeshers_Import_1D::importMesh(), SMESH_MeshEditor::ElemFeatures::Init(), SMESH_MeshEditor::InsertNodesIntoLink(), SMESH_MeshEditor::InverseDiag(), SMESH::Controls::NumericalFunctor::IsApplicable(), SMESHGUI_PredicateFilter::IsObjValid(), SMESHGUI_QuadrangleFilter::IsObjValid(), SMESHGUI_TriangleFilter::IsObjValid(), SMESHGUI_FacesFilter::IsObjValid(), SMESHGUI_VolumesFilter::IsObjValid(), SMESH_MeshAlgos::IsOut(), SMESH_MesherHelper::IsQuadraticSubMesh(), SMESH::Controls::FreeEdges::IsSatisfy(), SMESH::Controls::BelongToGeom::IsSatisfy(), SMESH::Controls::LyingOnGeom::IsSatisfy(), SMESH::Controls::FreeFaces::IsSatisfy(), SMESH::Controls::LinearOrQuadratic::IsSatisfy(), SMESH::Controls::ElemGeomType::IsSatisfy(), SMESH::Controls::ConnectedElements::IsSatisfy(), SMESH::Controls::RangeOfIds::IsSatisfy(), SMESHGUI_PredicateFilter::IsValid(), SMESHGUI_QuadrangleFilter::IsValid(), SMESHGUI_TriangleFilter::IsValid(), SMESHGUI_FacesFilter::IsValid(), SMESHGUI_VolumesFilter::IsValid(), StdMeshers_Penta_3D::LoadIJNodes(), StdMeshers_Penta_3D::MakeBlock(), SMESH_MeshEditor::MakeBoundaryMesh(), SMESH_Mesh_i::MakeGroupsOfBadInputElements(), StdMeshers_Penta_3D::MakeMeshOnFxy1(), SMESH_MeshAlgos::MakeOffset(), SMESH_MeshAlgos::MakeSlot(), SMESH_MeshEditor::makeWalls(), StdMeshers_QuadToTriaAdaptor::MergePiramids(), SMDS_MeshNode::NbInverseElements(), SMESH::Predicate_i::NbSatisfying(), MyIterator< VALUE >::next(), SMESH::SelectionProxy::nodeConnectivity(), SMESHGUI_3TypesSelector::onTextChange(), SMESHGUI_MeshPatternDlg::onTextChanged(), SMDS_MeshElement::TypeFilter::operator()(), TIDTypeCompare::operator()(), DriverCGNS_Read::Perform(), DriverMED_R_SMESHDS_Mesh::Perform(), DriverUNV_R_SMDS_Mesh::Perform(), StdMeshers_Prism_3D::projectBottomToTop(), SMESH_MeshEditor::QuadToTri(), SMDS_MeshInfo::remove(), SMESHDS_Mesh::RemoveElement(), SMDS_Mesh::RemoveElement(), SMESHDS_SubMesh::RemoveElement(), SMESHDS_Mesh::RemoveFreeElement(), SMDS_Mesh::RemoveFreeElement(), SMESH_MeshEditor::Reorient(), SMESH_MeshEditor_i::Reorient2D(), SMESH_MeshEditor::Reorient2DBy3D(), SMESH_MeshEditor::RotationSweep(), SMDS_VolumeTool::Set(), SMESH::Controls::CoplanarFaces::SetMesh(), StdMeshers_MaxElementArea::SetParametersByMesh(), StdMeshers_MaxElementVolume::SetParametersByMesh(), SMESH_MeshEditor::SewFreeBorder(), SMESH_MeshEditor::SewSideElements(), SMESHGUI_SplitVolumesDlg::showFacetByElement(), SMESH_MeshEditor::Smooth(), DriverMED_Family::SplitByType(), SMESH_MeshEditor::SplitFace(), SMESH_MeshEditor::SplitVolumes(), SMESH_MeshEditor::sweepElement(), SMESH_MeshEditor::TriToQuad(), and SMESH_Algo::VertexNode().
◆ GetVtkID()
vtkIdType SMDS_MeshElement::GetVtkID ( ) const
References SMDS_ElementChunk::GetVtkID(), and SMDS_MeshElement::myHolder.
Referenced by SMDS_MeshNode::AddInverseElement(), SMDS_ElementHolder::beforeCompacting(), SMDS_MeshCell::ChangeNodes(), SMDS_MeshVolume::ChangeNodes(), SMDS_MeshNode::ClearInverseElements(), SMDS_ElementFactory::Compact(), SMESH_MeshEditor::CreateHoleSkin(), SMESH_MeshEditor::DoubleNodesOnGroupBoundaries(), SMDS_UnstructuredGrid::extrudeVolumeFromFace(), SMDS_ElementFactory::Free(), SMDS_MeshNode::getCoord(), SMDS_BallElement::GetDiameter(), SMESH_VisualObjDef::GetElemVTKId(), SMESHGUI_PreVisualObj::GetElemVTKId(), SMDS_MeshVolume::GetFaceNode(), SMDS_MeshNode::GetInverseElementIterator(), SMDS_MeshCell::GetNode(), SMDS_MeshVolume::GetNode(), SMDS_MeshCell::GetNodeIndex(), SMDS_MeshVolume::GetNodeIndex(), SMESH_VisualObjDef::GetNodeVTKId(), SMDS_MeshVolume::GetQuantities(), SMESH::Controls::AspectRatio3D::GetValue(), SMDS_MeshCell::GetVtkType(), SMDS_MeshNode::GetXYZ(), SMDS_BallElement::init(), SMDS_MeshNode::init(), SMDS_MeshCell::init(), SMDS_MeshVolume::NbEdges(), SMDS_MeshVolume::NbFaceNodes(), SMDS_MeshVolume::NbFaces(), SMDS_MeshNode::NbInverseElements(), SMDS_MeshCell::NbNodes(), SMDS_MeshVolume::NbNodes(), SMDS_MeshCell::nodeIterator(), SMDS_MeshVolume::nodeIterator(), SMDS_MeshCell::nodesIterator(), SMDS_MeshVolume::nodesIterator(), SMDS_MeshCell::nodesIteratorToUNV(), SMDS_Mesh::RemoveFreeElement(), SMDS_MeshNode::RemoveInverseElement(), SMDS_BallElement::SetDiameter(), and SMDS_MeshNode::setXYZ().
◆ GetVtkType()
virtual VTKCellType SMDS_CellOfNodes::GetVtkType ( ) const
Implements SMDS_MeshElement.
◆ interlacedNodesIterator()
◆ isMarked()
bool SMDS_CellOfNodes::isMarked ( ) const
References BIT_IS_MARKED, and myShapeID.
◆ IsMediumNode()
◆ IsNull()
◆ IsPoly()
◆ IsQuadratic()
virtual bool SMDS_MeshElement::IsQuadratic ( ) const
Implemented in SMDS_FaceOfNodes, SMDS_LinearEdge, SMDS_MeshCell, SMDS_MeshNode, SMDS_PolygonalFaceOfNodes, and SMDS_VolumeOfNodes.
Referenced by averageByElement(), SMESH_MeshEditor::BestSplit(), centroidalSmooth(), StdMeshers_Projection_3D::Compute(), StdMeshers_RadialPrism_3D::Compute(), SMESH_MeshEditor::convertElemToQuadratic(), SMESH_MeshEditor::ConvertFromQuadratic(), SMESH_MeshEditor::ConvertToQuadratic(), SMESH_MeshAlgos::DeMerge(), StdMeshers_Import_1D::Evaluate(), StdMeshers_Import_1D2D::Evaluate(), StdMeshers_Projection_3D::Evaluate(), SMESH_MeshEditor::ExtrusionSweep(), SMESH_MeshAlgos::FindFaceInSet(), SMESH_MeshEditor::FindMatchingNodes(), StdMeshers_ProjectionUtils::FindMatchingNodesOnFaces(), SMESH_MeshAlgos::FindSharpEdges(), SMESH_MesherHelper::FixQuadraticElements(), getAngle(), SMESH_ElementSearcherImpl::getIntersParamOnLine(), SMESH_MeshEditor::GetLinkedNodes(), SMESH_MesherHelper::GetMediumPos(), SMESH::Controls::AspectRatio3D::GetValue(), SMESH_MeshEditor::ElemFeatures::Init(), SMESH_MeshEditor::InsertNodesIntoLink(), SMDS_VolumeTool::IsFreeFace(), SMDS_VolumeTool::IsFreeFaceCheckAllNodes(), SMDS_VolumeTool::IsLinked(), SMESHGUI_QuadrangleFilter::IsObjValid(), SMESHGUI_TriangleFilter::IsObjValid(), SMESH_Mesh_i::IsQuadratic(), SMESH_MesherHelper::IsQuadraticSubMesh(), SMESH_MeshAlgos::IsRightOrder(), SMESH::Controls::LinearOrQuadratic::IsSatisfy(), SMESHGUI_QuadrangleFilter::IsValid(), SMESHGUI_TriangleFilter::IsValid(), StdMeshers_Penta_3D::MakeBlock(), SMESH_MeshEditor::MakeBoundaryMesh(), SMESH_MeshEditor::makeWalls(), SMDS_VolumeTool::MaxLinearSize2(), SMDS_VolumeTool::MinLinearSize2(), DriverCGNS_Read::Perform(), SMESH_MeshEditor::QuadToTri(), SMDS_MeshInfo::RemoveEdge(), SMESH_MeshEditor::RemoveNodeWithReconnection(), SMESH_MeshEditor::removeQuadElem(), SMESH_MeshEditor::RotationSweep(), SMESH_MeshEditor::Smooth(), SMESH_MeshEditor::SplitFace(), SMESH_MeshEditor::SplitVolumes(), and SMESH_MeshEditor::sweepElement().
◆ IsValidIndex()
bool SMDS_MeshElement::IsValidIndex ( const int  ind) const
ind- node index
bool- index check result
References SMDS_MeshElement::NbNodes().
◆ NbCornerNodes()
virtual int SMDS_MeshElement::NbCornerNodes ( ) const
Referenced by StdMeshers_Quadrangle_2D::check(), StdMeshers_Prism_3D::compute(), StdMeshers_Import_1D2D::Compute(), StdMeshers_QuadToTriaAdaptor::Compute(), SMESH_MeshEditor::convertElemToQuadratic(), SMESH_MeshEditor::ConvertFromQuadratic(), SMESH_MeshEditor::ConvertToQuadratic(), SMESH_Mesh_i::CreateDimGroup(), SMESH_MeshAlgos::Intersector::CutByPlanes(), StdMeshers_Import_1D2D::Evaluate(), SMESH_MeshAlgos::FaceNormal(), SMDS_Mesh::FindElement(), findExistingTriangulation(), VISCOUS_3D::_LayerEdge::FindIntersection(), SMESH_ElementSearcherImpl::findOuterBoundary(), SMESH_MeshAlgos::FindSharpEdges(), findTriangles(), VISCOUS_3D::_ViscousBuilder::fixBadFaces(), SMESH_2D_Algo::FixInternalNodes(), SMESH_MesherHelper::FixQuadraticElements(), VISCOUS_3D::getDistFromEdge(), SMESH_VisualObjDef::GetEdgeNodes(), SMESHGUI_PreVisualObj::GetEdgeNodes(), MeshEditor_I::getElementsAround(), SMESH_Algo::GetMeshError(), VISCOUS_3D::_Simplex::GetSimplices(), StdMeshers_Prism_3D::getSweepTolerance(), SMESH_ProxyMesh::HasPrismsOnTwoSides(), SMESH_MesherHelper::IsDistorted2D(), SMDS_VolumeTool::IsLinked(), SMDS_MeshElement::IsMediumNode(), SMESH_MeshAlgos::IsOn2DBoundary(), SMESH_MesherHelper::IsQuadraticSubMesh(), SMESH_MesherHelper::IsReversedSubMesh(), StdMeshers_QuadToTriaAdaptor::LimitHeight(), VISCOUS_3D::_ViscousBuilder::limitStepSize(), SMESH_Pattern::Load(), SMESH_MeshEditor::MakeBoundaryMesh(), VISCOUS_3D::_ViscousBuilder::makeGroupOfLE(), VISCOUS_3D::_ViscousBuilder::makeLayer(), SMESH_MeshAlgos::MakeSlot(), StdMeshers_QuadToTriaAdaptor::MergeAdjacent(), StdMeshers_QuadToTriaAdaptor::MergePiramids(), StdMeshers_QuadToTriaAdaptor::Preparation(), StdMeshers_Sweeper::prepareTopBotDelaunay(), StdMeshers_Prism_3D::projectBottomToTop(), SMESH_MeshEditor::QuadTo4Tri(), SMESH_MeshEditor::QuadToTri(), VISCOUS_3D::_ViscousBuilder::refine(), SMESH_MeshEditor::removeQuadElem(), SMESH_MeshEditor::Reorient2D(), SMESH_MeshEditor::Reorient2DBy3D(), SMESH_MeshAlgos::SeparateFacesByEdges(), SMDS_VolumeTool::Set(), SMESH::Controls::CoplanarFaces::SetMesh(), StdMeshers_Quadrangle_2D::smooth(), SMESH_MeshEditor::Smooth(), SMESH_MeshEditor::SplitFace(), SMESH_MeshEditor::sweepElement(), SMESH_MeshEditor::TriToQuad(), and SMDS_MeshElement::WrappedIndex().
◆ NbEdges()
virtual int SMDS_MeshElement::NbEdges ( ) const
◆ NbFaces()
◆ NbNodes()
virtual int SMDS_MeshElement::NbNodes ( ) const
Referenced by SMDS_MeshInfo::add(), SMESH_Delaunay::addCloseNodes(), SMESH_MeshEditor_i::AddPolyhedralVolumeByFaces(), SMESH_MeshEditor::applyMerge(), SMESH_Pattern_i::ApplyToHexahedrons(), averageByElement(), SMESH_MeshEditor::BestSplit(), SMESH_MeshEditor_i::BestSplit(), SMESH_VisualObjDef::buildElemPrs(), centroidalSmooth(), ComparableElement::ComparableElement(), StdMeshers_Import_1D::Compute(), StdMeshers_Import_1D2D::Compute(), StdMeshers_Projection_3D::Compute(), StdMeshers_RadialPrism_3D::Compute(), SMESH_Gen_i::ConcatenateCommon(), SMESH_MeshEditor::ConvertFromQuadratic(), MeshEditor_I::TPreviewMesh::Copy(), SMESH_Gen_i::CopyMesh(), SMESH_Gen_i::CopyMeshWithGeom(), SMESH_Mesh_i::CreateDimGroup(), SMESHGUI_CuttingOfQuadsDlg::displayPreview(), SMESH_MeshEditor::doubleNodes(), SMESH::SelectionProxy::elementGravityCenter(), StdMeshers_Import_1D2D::Evaluate(), StdMeshers_Projection_3D::Evaluate(), SMESH_MeshEditor::ExtrusionSweep(), SMDS_Mesh::Find0DElement(), SMESH_ElementSearcherImpl::FindClosestTo(), SMESH_MeshAlgos::FindCoincidentFreeBorders(), SMDS_Mesh::FindEdge(), SMDS_Mesh::FindElement(), SMDS_Mesh::FindFace(), SMESH_MeshAlgos::FindFaceInSet(), SMESH_MeshAlgos::FindFreeBorders(), SMESH_MeshEditor::FindMatchingNodes(), StdMeshers_ProjectionUtils::FindMatchingNodesOnFaces(), SMESH_MesherHelper::FixQuadraticElements(), SMESH_Gen_i::GetBadInputElements(), getBadRate(), SMESH_MeshAlgos::GetCommonNodes(), SMESH_Mesh_i::GetElemNbNodes(), SMESH_Mesh_i::GetElemNode(), getFinitElements(), SMESH_ElementSearcherImpl::getIntersParamOnLine(), SMESH_MeshEditor::GetLinkedNodes(), SMESH_MeshAlgos::Triangulate::GetNbTriangles(), SMESH::Controls::NumericalFunctor::GetPoints(), SMESH_MeshEditor_i::GetPreviewData(), getQuadrangleNodes(), SMESH_MeshAlgos::Triangulate::GetTriangles(), SMESH::Controls::MultiConnection2D::GetValue(), StdMeshers_Import_1D::importMesh(), SMESH_MeshEditor::InsertNodesIntoLink(), SMESH::Controls::Warping::IsApplicable(), SMESH::Controls::Taper::IsApplicable(), SMESH::Controls::Skew::IsApplicable(), SMESHGUI_QuadrangleFilter::IsObjValid(), SMESHGUI_TriangleFilter::IsObjValid(), SMESH_MeshAlgos::IsOut(), SMESH_MeshAlgos::IsRightOrder(), SMESH::Controls::ElementsOnShape::IsSatisfy(), SMESH::Controls::CoincidentElements::IsSatisfy(), SMESH::Controls::FreeEdges::IsSatisfy(), SMESH::Controls::FreeFaces::IsSatisfy(), SMESHGUI_QuadrangleFilter::IsValid(), SMESHGUI_TriangleFilter::IsValid(), SMDS_MeshElement::IsValidIndex(), _QuadFaceGrid::LoadGrid(), StdMeshers_Penta_3D::LoadIJNodes(), StdMeshers_Penta_3D::MakeBlock(), SMESH_MeshEditor::MakeBoundaryMesh(), StdMeshers_Penta_3D::MakeMeshOnFxy1(), VISCOUS_3D::_ViscousBuilder::MakeN2NMap(), SMESH_Pattern::makePolyElements(), StdMeshers_Penta_3D::MakeVolumeMesh(), StdMeshers_QuadToTriaAdaptor::MergePiramids(), SMESH_MeshAlgos::NbCommonNodes(), SMDS_FaceOfNodes::NbCornerNodes(), SMDS_LinearEdge::NbCornerNodes(), SMDS_PolygonalFaceOfNodes::NbCornerNodes(), SMDS_VolumeOfNodes::NbCornerNodes(), DriverCGNS_Read::Perform(), DriverCGNS_Write::Perform(), DriverDAT_W_SMDS_Mesh::Perform(), DriverMED_W_SMESHDS_Mesh::PerformInternal(), SMESH_Gen_i::Precompute(), StdMeshers_QuadToTriaAdaptor::Preparation(), StdMeshers_Sweeper::prepareTopBotDelaunay(), SMESH_MeshEditor::QuadToTri(), SMDS_MeshInfo::remove(), SMESH_MeshEditor::RotationSweep(), SMDS_VolumeTool::Set(), SMESH_MeshEditor::SewFreeBorder(), SMESH_MeshEditor::SewSideElements(), SMESHGUI_SplitVolumesDlg::showFacetByElement(), VISCOUS_2D::_ViscousBuilder2D::shrink(), VISCOUS_3D::_ViscousBuilder::shrink(), SMESH_MeshEditor::Smooth(), SMESH_MeshEditor::SplitFace(), SMESH_MeshEditor::SplitVolumes(), VISCOUS_3D::_Shrinker1D::SwapSrcTgtNodes(), SMESH_MeshEditor::sweepElement(), SMESH_MeshEditor::Transform(), and SMESH_MeshEditor::TriToQuad().
◆ nodeIterator()
◆ nodesIterator()
virtual SMDS_ElemIteratorPtr SMDS_MeshElement::nodesIterator ( ) const
Implemented in SMDS_FaceOfNodes, SMDS_LinearEdge, SMDS_MeshCell, SMDS_MeshNode, SMDS_PolygonalFaceOfNodes, SMDS_VolumeOfNodes, and SMDS_MeshVolume.
Referenced by SMDS_Mesh::addChildrenWithNodes(), SMESH_MeshEditor_i::AddPolyhedralVolumeByFaces(), SMESH_MeshEditor::AffectedElemGroupsInRegion(), SMESH_MeshEditor::applyMerge(), averageByElement(), SMESH_Mesh_i::BaryCenter(), SMESH_MeshEditor::BestSplit(), SMESH_VisualObjDef::buildElemPrs(), ComparableElement::ComparableElement(), StdMeshers_Projection_2D::Compute(), MeshEditor_I::TPreviewMesh::Copy(), SMESH_Gen_i::CopyMesh(), SMESH_MeshEditor::Create0DElementsOnAllNodes(), SMESH_Mesh_i::CreateDimGroup(), SMESH_Pattern::createElements(), SMESHGUI_CuttingOfQuadsDlg::displayPreview(), SMESHGUI_CreatePolyhedralVolumeDlg::displaySimulation(), SMESH_MeshEditor::doubleNodes(), SMESH_MeshEditor::DoubleNodesInRegion(), SMESH::SelectionProxy::elementGravityCenter(), StdMeshers_Import_1D2D::Evaluate(), SMESH_ElementSearcherImpl::FindClosestTo(), SMDS_Mesh::FindEdge(), VISCOUS_3D::_ViscousBuilder::findEdgesToUpdateNormalNearConvexFace(), SMDS_Mesh::FindFace(), SMESHGUI_MergeDlg::FindGravityCenter(), SMESH_MeshEditor::FindShape(), getAngle(), SMESH_subMesh_i::GetElementsByType(), SMESH_MeshEditor::GetLinkedNodes(), SMDS_MeshElement::GetNodeIndex(), getNodesFromElems(), getQuadrangleNodes(), SMESH_Mesh_i::GetSubMeshNodesId(), StdMeshers_Prism_3D::getSweepTolerance(), SMESH_ElementSearcherImpl::getTolerance(), SMESH::Controls::MultiConnection2D::GetValue(), SMESH_MeshEditor::InverseDiag(), SMESH_MesherHelper::IsReversedSubMesh(), SMESH::Controls::LyingOnGeom::IsSatisfy(), SMESH::Controls::FreeFaces::IsSatisfy(), SMESH::Controls::ConnectedElements::IsSatisfy(), SMESH_Pattern::Load(), StdMeshers_Penta_3D::LoadIJNodes(), StdMeshers_Penta_3D::MakeMeshOnFxy1(), SMESH_MeshEditor::ExtrusParam::makeNodesByNormal2D(), SMESH_MeshAlgos::MakeOffset(), SMESH_Pattern::makePolyElements(), SMESH_MeshAlgos::MarkElemNodes(), SMESH_MeshEditor::MergeNodes(), DriverDAT_W_SMDS_Mesh::Perform(), DriverMED_W_SMESHDS_Mesh::PerformInternal(), StdMeshers_QuadToTriaAdaptor::Preparation(), SMESH::Controls::ElementsOnSurface::process(), SMESH_MeshEditor::QuadToTri(), SMESH_MeshEditor::Reorient(), SMESH_MeshEditor::RotationSweep(), SMESH_MeshEditor::ExtrusParam::SetElementsToUse(), SMESH_MeshEditor::SewSideElements(), SMESH_MeshEditor::Smooth(), VISCOUS_3D::_ViscousBuilder::smoothAndCheck(), VISCOUS_3D::_Shrinker1D::SwapSrcTgtNodes(), and SMESH_MeshEditor::Transform().
◆ nodesIteratorToUNV()
virtual SMDS_NodeIteratorPtr SMDS_MeshElement::nodesIteratorToUNV ( ) const
Reimplemented in SMDS_MeshCell.
◆ Print()
void SMDS_MeshElement::Print ( std::ostream &  OS) const
Print self.
Reimplemented in SMDS_FaceOfNodes, SMDS_MeshNode, SMDS_PolygonalFaceOfNodes, and SMDS_VolumeOfNodes.
Referenced by operator<<().
◆ setID()
void SMDS_CellOfNodes::setID ( const smIdType  id)
References myID.
Referenced by VISCOUS_3D::_TmpMeshFace::_TmpMeshFace().
◆ setIsMarked()
void SMDS_CellOfNodes::setIsMarked ( bool  is) const
Mark this element.
◆ setShapeID() [1/2]
void SMDS_CellOfNodes::setShapeID ( const int  shapeID)
◆ setShapeID() [2/2]
void SMDS_MeshElement::setShapeID ( const int  shapeID) const
◆ setVtkID()
void SMDS_MeshElement::setVtkID ( const vtkIdType  vtkID)
◆ WrappedIndex()
int SMDS_MeshElement::WrappedIndex ( const int  ind) const
ind- node index
int- valid node index
References SMDS_MeshElement::NbCornerNodes().
Referenced by SMDS_PolygonalFaceOfNodes::GetNode().
◆ myHolder
◆ myID
smIdType SMDS_CellOfNodes::myID
Referenced by GetID(), and setID().
◆ myShapeID
int SMDS_CellOfNodes::myShapeID
