SMESHGUI_3TypesSelector Class Reference
#include <SMESHGUI_ExtrusionDlg.h>
Inheritance diagram for SMESHGUI_3TypesSelector:
Signals
void selectionChanged ()
 SMESHGUI_3TypesSelector (QWidget *parent=0)
 ~SMESHGUI_3TypesSelector ()
void Clear ()
 Clear selection. More...
void SetEnabled (bool enable, SMESH::ElementType type)
 Enable/disable controls of a type. More...
bool IsAnythingSelected (SMESH::ElementType type=SMESH::ALL)
 Checks if anything is selected. More...
SMESH::ElementType GetSelected (SMESH::ListOfIDSources &nodes, SMESH::ListOfIDSources &edges, SMESH::ListOfIDSources &faces)
 Returns selected elements and most complex type of selected elements. More...
SMESH::SMESH_Mesh_var GetMesh ()
SMESH_Actor * GetActor ()
 Handle (SALOME_InteractiveObject) GetIO()
QButtonGroup * GetButtonGroup ()
Private Slots
void selectionIntoArgument ()
 Slot called when selection changes. More...
void onTextChange (const QString &)
 Slot called when text changes in myLineEdit. More...
void onSelectMesh (bool on)
 Slot called when myMeshChk is checked. More...
void setFilters ()
 Slot called when "Set filter" is clicked. More...
void onSelectType (int iType)
 Slot called when a selection button is clicked. More...
void addTmpIdSource (SMESH::smIdType_array_var &ids, int iType, int index)
 Creates from ids and stores a temporary IDSource. More...
 Handle (SALOME_InteractiveObject) myIO
QGroupBox * myGroups [3]
QLabel * myLabel [3]
QLineEdit * myLineEdit [3]
QCheckBox * myMeshChk [3]
QPushButton * myFilterBtn [3]
QButtonGroup * mySelectBtnGrp
SMESHGUI_FilterDlg * myFilterDlg
SUIT_SelectionFilter * myFilter [3]
SMESHGUI_IdValidator * myIdValidator
bool myBusy
SMESH::SMESH_Mesh_var myMesh
SMESH_Actor * myActor
SMESH::ListOfIDSources_var myIDSource [3]
QList< SMESH::IDSource_wrap > myTmpIDSourceList
LightApp_SelectionMgr * mySelectionMgr
SVTK_Selector * mySelector
◆ SMESHGUI_3TypesSelector()
◆ ~SMESHGUI_3TypesSelector()
SMESHGUI_3TypesSelector::~SMESHGUI_3TypesSelector ( )
References myFilter, myFilterDlg, myIDSource, and mySelectionMgr.
◆ addTmpIdSource()
void SMESHGUI_3TypesSelector::addTmpIdSource ( SMESH::smIdType_array_var &  ids,
int  iType,
int  index
References myIDSource, myMesh, and myTmpIDSourceList.
Referenced by onTextChange(), and selectionIntoArgument().
◆ Clear()
◆ GetActor()
◆ GetButtonGroup()
◆ GetMesh()
◆ GetSelected()
◆ Handle() [1/2]
SMESHGUI_3TypesSelector::Handle ( SALOME_InteractiveObject  )
Referenced by selectionIntoArgument().
◆ Handle() [2/2]
◆ IsAnythingSelected()
◆ onSelectMesh
void SMESHGUI_3TypesSelector::onSelectMesh ( bool  on)
privateslot
References myBusy, myFilterBtn, myIDSource, myIdValidator, myLabel, myLineEdit, myMeshChk, and mySelectBtnGrp.
Referenced by SMESHGUI_3TypesSelector().
◆ onSelectType
void SMESHGUI_3TypesSelector::onSelectType ( int  iType)
privateslot
◆ onTextChange
void SMESHGUI_3TypesSelector::onTextChange ( const QString &  theNewText)
privateslot
◆ selectionChanged
void SMESHGUI_3TypesSelector::selectionChanged ( )
signal
◆ selectionIntoArgument
◆ SetEnabled()
void SMESHGUI_3TypesSelector::SetEnabled ( bool  enable,
References SMESH::ALL, myBusy, myGroups, myIDSource, myLineEdit, and selectionIntoArgument().
Referenced by SMESHGUI_ExtrusionDlg::ClickOnRadio().
◆ setFilters
◆ myActor
SMESH_Actor* SMESHGUI_3TypesSelector::myActor
◆ myBusy
bool SMESHGUI_3TypesSelector::myBusy
◆ myFilter
SUIT_SelectionFilter* SMESHGUI_3TypesSelector::myFilter[3]
◆ myFilterBtn
QPushButton* SMESHGUI_3TypesSelector::myFilterBtn[3]
◆ myFilterDlg
SMESHGUI_FilterDlg* SMESHGUI_3TypesSelector::myFilterDlg
◆ myGroups
QGroupBox* SMESHGUI_3TypesSelector::myGroups[3]
◆ myIDSource
◆ myIdValidator
SMESHGUI_IdValidator* SMESHGUI_3TypesSelector::myIdValidator
◆ myLabel
QLabel* SMESHGUI_3TypesSelector::myLabel[3]
◆ myLineEdit
QLineEdit* SMESHGUI_3TypesSelector::myLineEdit[3]
◆ myMesh
SMESH::SMESH_Mesh_var SMESHGUI_3TypesSelector::myMesh
◆ myMeshChk
QCheckBox* SMESHGUI_3TypesSelector::myMeshChk[3]
◆ mySelectBtnGrp
QButtonGroup* SMESHGUI_3TypesSelector::mySelectBtnGrp
◆ mySelectionMgr
LightApp_SelectionMgr* SMESHGUI_3TypesSelector::mySelectionMgr
◆ mySelector
SVTK_Selector* SMESHGUI_3TypesSelector::mySelector
◆ myTmpIDSourceList
QList<SMESH::IDSource_wrap> SMESHGUI_3TypesSelector::myTmpIDSourceList
Referenced by addTmpIdSource().
