SMESH_Pattern Class Reference
#include <SMESH_Pattern.hxx>
struct  TPoint
enum  ErrorCode {
  ERR_OK , ERR_READ_NB_POINTS , ERR_READ_POINT_COORDS , ERR_READ_TOO_FEW_POINTS ,
  ERR_READ_3D_COORD , ERR_READ_NO_KEYPOINT , ERR_READ_BAD_INDEX , ERR_READ_ELEM_POINTS ,
  ERR_READ_NO_ELEMS , ERR_READ_BAD_KEY_POINT , ERR_SAVE_NOT_LOADED , ERR_LOAD_EMPTY_SUBMESH ,
  ERR_LOADF_NARROW_FACE , ERR_LOADF_CLOSED_FACE , ERR_LOADF_CANT_PROJECT , ERR_LOADV_BAD_SHAPE ,
  ERR_LOADV_COMPUTE_PARAMS , ERR_APPL_NOT_COMPUTED , ERR_APPL_NOT_LOADED , ERR_APPL_BAD_DIMENTION ,
  ERR_APPL_BAD_NB_VERTICES , ERR_APPLF_BAD_TOPOLOGY , ERR_APPLF_BAD_VERTEX , ERR_APPLF_INTERNAL_EEROR ,
  ERR_APPLV_BAD_SHAPE , ERR_APPLF_BAD_FACE_GEOM , ERR_MAKEM_NOT_COMPUTED , ERR_UNEXPECTED
 SMESH_Pattern ()
void Clear ()
bool Load (const char *theFileContents)
bool Load (SMESH_Mesh *theMesh, const TopoDS_Face &theFace, bool theProject=false, TopoDS_Vertex the1stVertex=TopoDS_Vertex(), bool theKeepNodes=false)
bool Load (SMESH_Mesh *theMesh, const TopoDS_Shell &theBlock, bool theKeepNodes=false)
bool Save (std::ostream &theFile)
bool Apply (const TopoDS_Face &theFace, const TopoDS_Vertex &theVertexOnKeyPoint1, const bool theReverse)
bool Apply (const TopoDS_Shell &theBlock, const TopoDS_Vertex &theVertex000, const TopoDS_Vertex &theVertex001)
bool Apply (const SMDS_MeshFace *theFace, const int theNodeIndexOnKeyPoint1, const bool theReverse)
bool Apply (SMESH_Mesh *theMesh, const SMDS_MeshFace *theFace, const TopoDS_Shape &theSurface, const int theNodeIndexOnKeyPoint1, const bool theReverse)
bool Apply (SMESH_Mesh *theMesh, std::set< const SMDS_MeshFace * > &theFaces, const int theNodeIndexOnKeyPoint1, const bool theReverse)
bool Apply (const SMDS_MeshVolume *theVolume, const int theNode000Index, const int theNode001Index)
bool Apply (std::set< const SMDS_MeshVolume * > &theVolumes, const int theNode000Index, const int theNode001Index)
bool GetMappedPoints (std::list< const gp_XYZ * > &thePoints) const
bool MakeMesh (SMESH_Mesh *theMesh, const bool toCreatePolygons=false, const bool toCreatePolyedrs=false)
ErrorCode GetErrorCode () const
bool IsLoaded () const
bool Is2D () const
bool GetPoints (std::list< const gp_XYZ * > &thePoints) const
const std::list< int > & GetKeyPointIDs () const
const std::list< std::list< int > > & GetElementPointIDs (bool applied) const
void GetInOutNodes (std::vector< const SMDS_MeshNode * > *&inNodes, std::vector< const SMDS_MeshNode * > *&outNodes)
void DumpPoints () const
TopoDS_Shape GetSubShape (const int i) const
Private Types
typedef std::list< std::list< TopoDS_Edge > > TListOfEdgesList
typedef std::set< const SMDS_MeshNode * > TNodeSet
typedef std::list< int > TElemDef
bool setErrorCode (const ErrorCode theErrorCode)
 set ErrorCode and return true if it is Ok More...
bool setShapeToMesh (const TopoDS_Shape &theShape)
std::list< TPoint * > & getShapePoints (const TopoDS_Shape &theShape)
std::list< TPoint * > & getShapePoints (const int theShapeID)
bool findBoundaryPoints ()
void arrangeBoundaries (std::list< std::list< TPoint * > > &boundaryPoints)
void computeUVOnEdge (const TopoDS_Edge &theEdge, const std::list< TPoint * > &ePoints)
bool compUVByIsoIntersection (const std::list< std::list< TPoint * > > &boundaryPoints, const gp_XY &theInitUV, gp_XY &theUV, bool &theIsDeformed)
bool compUVByElasticIsolines (const std::list< std::list< TPoint * > > &boundaryPoints, const std::list< TPoint * > &pointsToCompute)
double setFirstEdge (std::list< TopoDS_Edge > &theWire, int theFirstEdgeID)
bool sortSameSizeWires (TListOfEdgesList &theWireList, const TListOfEdgesList::iterator &theFromWire, const TListOfEdgesList::iterator &theToWire, const int theFirstEdgeID, std::list< std::list< TPoint * > > &theEdgesPointsList)
void mergePoints (const bool uniteGroups)
void makePolyElements (const std::vector< const SMDS_MeshNode * > &theNodes, const bool toCreatePolygons, const bool toCreatePolyedrs)
void createElements (SMESH_Mesh *theMesh, const std::vector< const SMDS_MeshNode * > &theNodesVector, const std::list< std::list< int > > &theElemNodeIDs, const std::vector< const SMDS_MeshElement * > &theElements)
bool getFacesDefinition (const SMDS_MeshNode **theBndNodes, const int theNbBndNodes, const std::vector< const SMDS_MeshNode * > &theNodes, std::list< int > &theFaceDefs, std::vector< int > &theQuantity)
bool isReversed (const SMDS_MeshNode *theFirstNode, const std::list< int > &theIdsList) const
void clearMesh (SMESH_Mesh *theMesh) const
bool findExistingNodes (SMESH_Mesh *mesh, const TopoDS_Shape &S, const std::list< TPoint * > &points, std::vector< const SMDS_MeshNode * > &nodes)
static SMESHDS_SubMesh * getSubmeshWithElements (SMESH_Mesh *theMesh, const TopoDS_Shape &theShape)
bool myIs2D
std::vector< TPoint > myPoints
std::list< int > myKeyPointIDs
std::list< TElemDef > myElemPointIDs
ErrorCode myErrorCode
bool myIsComputed
bool myIsBoundaryPointsFound
TopoDS_Shape myShape
TopTools_IndexedMapOfOrientedShape myShapeIDMap
std::map< int, std::list< TPoint * > > myShapeIDToPointsMap
std::list< int > myNbKeyPntInBoundary
bool myToKeepNodes
std::vector< const SMDS_MeshNode * > myInNodes
std::vector< const SMDS_MeshNode * > myOutNodes
std::vector< gp_XYZ > myXYZ
std::list< TElemDef > myElemXYZIDs
std::map< int, const SMDS_MeshNode * > myXYZIdToNodeMap
std::vector< const SMDS_MeshElement * > myElements
std::vector< const SMDS_MeshNode * > myOrderedNodes
std::vector< const SMDS_MeshElement * > myPolyElems
std::list< TElemDef > myPolyElemXYZIDs
std::list< std::vector< int > > myPolyhedronQuantities
std::map< TNodeSet, std::list< std::list< int > > > myIdsOnBoundary
std::map< int, std::list< TElemDef * > > myReverseConnectivity
Friends
std::ostream & operator<< (std::ostream &OS, const TPoint &p)
◆ TElemDef
typedef std::list< int > SMESH_Pattern::TElemDef
◆ TListOfEdgesList
typedef std::list< std::list< TopoDS_Edge > > SMESH_Pattern::TListOfEdgesList
◆ TNodeSet
typedef std::set<const SMDS_MeshNode*> SMESH_Pattern::TNodeSet
◆ ErrorCode
ERR_OK
ERR_READ_NB_POINTS
ERR_READ_3D_COORD
ERR_READ_BAD_INDEX
ERR_READ_NO_ELEMS
ERR_SAVE_NOT_LOADED
ERR_LOADV_BAD_SHAPE
ERR_APPL_NOT_LOADED
ERR_APPLV_BAD_SHAPE
ERR_UNEXPECTED
◆ SMESH_Pattern()
SMESH_Pattern::SMESH_Pattern ( )
◆ Apply() [1/7]
◆ Apply() [2/7]
◆ Apply() [3/7]
◆ Apply() [4/7]
bool SMESH_Pattern::Apply ( const TopoDS_Shell &  theBlock,
const TopoDS_Vertex &  theVertex000,
const TopoDS_Vertex &  theVertex001
◆ Apply() [5/7]
◆ Apply() [6/7]
◆ Apply() [7/7]
◆ arrangeBoundaries()
void SMESH_Pattern::arrangeBoundaries ( std::list< std::list< TPoint * > > &  boundaryPoints)
◆ Clear()
◆ clearMesh()
void SMESH_Pattern::clearMesh ( SMESH_Mesh *  theMesh) const
◆ computeUVOnEdge()
void SMESH_Pattern::computeUVOnEdge ( const TopoDS_Edge &  theEdge,
const std::list< TPoint * > &  ePoints
◆ compUVByElasticIsolines()
bool SMESH_Pattern::compUVByElasticIsolines ( const std::list< std::list< TPoint * > > &  boundaryPoints,
const std::list< TPoint * > &  pointsToCompute
◆ compUVByIsoIntersection()
bool SMESH_Pattern::compUVByIsoIntersection ( const std::list< std::list< TPoint * > > &  boundaryPoints,
const gp_XY &  theInitUV,
gp_XY &  theUV,
bool &  theIsDeformed
◆ createElements()
◆ DumpPoints()
void SMESH_Pattern::DumpPoints ( ) const
References myPoints.
◆ findBoundaryPoints()
◆ findExistingNodes()
bool SMESH_Pattern::findExistingNodes ( SMESH_Mesh *  mesh,
const TopoDS_Shape &  S,
const std::list< TPoint * > &  points,
std::vector< const SMDS_MeshNode * > &  nodes
◆ GetElementPointIDs()
const std::list< std::list< int > > & SMESH_Pattern::GetElementPointIDs ( bool  applied) const
◆ GetErrorCode()
ErrorCode SMESH_Pattern::GetErrorCode ( ) const
◆ getFacesDefinition()
bool SMESH_Pattern::getFacesDefinition ( const SMDS_MeshNode **  theBndNodes,
const std::vector< const SMDS_MeshNode * > &  theNodes,
std::list< int > &  theFaceDefs,
std::vector< int > &  theQuantity
◆ GetInOutNodes()
void SMESH_Pattern::GetInOutNodes ( std::vector< const SMDS_MeshNode * > *&  inNodes,
std::vector< const SMDS_MeshNode * > *&  outNodes
◆ GetKeyPointIDs()
const std::list< int > & SMESH_Pattern::GetKeyPointIDs ( ) const
◆ GetMappedPoints()
bool SMESH_Pattern::GetMappedPoints ( std::list< const gp_XYZ * > &  thePoints) const
◆ GetPoints()
bool SMESH_Pattern::GetPoints ( std::list< const gp_XYZ * > &  thePoints) const
References IsLoaded(), and myPoints.
Referenced by SMESH_Pattern_i::GetPoints().
◆ getShapePoints() [1/2]
list< SMESH_Pattern::TPoint * > & SMESH_Pattern::getShapePoints ( const int  theShapeID)
References myShapeIDToPointsMap.
◆ getShapePoints() [2/2]
list< SMESH_Pattern::TPoint * > & SMESH_Pattern::getShapePoints ( const TopoDS_Shape &  theShape)
◆ getSubmeshWithElements()
SMESHDS_SubMesh * SMESH_Pattern::getSubmeshWithElements ( SMESH_Mesh *  theMesh,
staticprivate
◆ GetSubShape()
TopoDS_Shape SMESH_Pattern::GetSubShape ( const int  i) const
◆ Is2D()
bool SMESH_Pattern::Is2D ( ) const
Referenced by SMESH_Pattern_i::Is2D().
◆ IsLoaded()
bool SMESH_Pattern::IsLoaded ( ) const
◆ isReversed()
bool SMESH_Pattern::isReversed ( const SMDS_MeshNode *  theFirstNode,
const std::list< int > &  theIdsList
◆ Load() [1/3]
◆ Load() [2/3]
bool SMESH_Pattern::Load ( SMESH_Mesh *  theMesh,
const TopoDS_Face &  theFace,
bool  theProject = false,
TopoDS_Vertex  the1stVertex = TopoDS_Vertex(),
bool  theKeepNodes = false
◆ Load() [3/3]
◆ MakeMesh()
◆ makePolyElements()
◆ mergePoints()
void SMESH_Pattern::mergePoints ( const bool  uniteGroups)
◆ Save()
bool SMESH_Pattern::Save ( std::ostream &  theFile)
◆ setErrorCode()
bool SMESH_Pattern::setErrorCode ( const ErrorCode  theErrorCode)
References ERR_OK, and myErrorCode.
Referenced by Apply(), compUVByIsoIntersection(), findBoundaryPoints(), Load(), MakeMesh(), Save(), and setShapeToMesh().
◆ setFirstEdge()
double SMESH_Pattern::setFirstEdge ( std::list< TopoDS_Edge > &  theWire,
int  theFirstEdgeID
◆ setShapeToMesh()
bool SMESH_Pattern::setShapeToMesh ( const TopoDS_Shape &  theShape)
◆ sortSameSizeWires()
bool SMESH_Pattern::sortSameSizeWires ( TListOfEdgesList &  theWireList,
const TListOfEdgesList::iterator &  theFromWire,
const TListOfEdgesList::iterator &  theToWire,
std::list< std::list< TPoint * > > &  theEdgesPointsList
◆ operator<<
std::ostream & operator<< ( std::ostream &  OS,
const TPoint &  p
friend
◆ myElements
std::vector<const SMDS_MeshElement*> SMESH_Pattern::myElements
◆ myElemPointIDs
std::list< TElemDef > SMESH_Pattern::myElemPointIDs
◆ myElemXYZIDs
std::list< TElemDef > SMESH_Pattern::myElemXYZIDs
Referenced by Apply(), Clear(), MakeMesh(), and setShapeToMesh().
◆ myErrorCode
ErrorCode SMESH_Pattern::myErrorCode
Referenced by setErrorCode().
◆ myIdsOnBoundary
std::map<TNodeSet,std::list<std::list<int> > > SMESH_Pattern::myIdsOnBoundary
◆ myInNodes
std::vector< const SMDS_MeshNode* > SMESH_Pattern::myInNodes
Referenced by Load().
◆ myIs2D
◆ myIsBoundaryPointsFound
bool SMESH_Pattern::myIsBoundaryPointsFound
Referenced by Clear(), findBoundaryPoints(), and Load().
◆ myIsComputed
bool SMESH_Pattern::myIsComputed
◆ myKeyPointIDs
std::list< int > SMESH_Pattern::myKeyPointIDs
◆ myNbKeyPntInBoundary
std::list< int > SMESH_Pattern::myNbKeyPntInBoundary
◆ myOrderedNodes
std::vector<const SMDS_MeshNode*> SMESH_Pattern::myOrderedNodes
Referenced by Apply(), and Clear().
◆ myOutNodes
std::vector< const SMDS_MeshNode* > SMESH_Pattern::myOutNodes
Referenced by MakeMesh().
◆ myPoints
◆ myPolyElems
std::vector<const SMDS_MeshElement*> SMESH_Pattern::myPolyElems
Referenced by Clear(), MakeMesh(), and makePolyElements().
◆ myPolyElemXYZIDs
std::list< TElemDef > SMESH_Pattern::myPolyElemXYZIDs
◆ myPolyhedronQuantities
std::list< std::vector<int> > SMESH_Pattern::myPolyhedronQuantities
◆ myReverseConnectivity
std::map< int, std::list< TElemDef* > > SMESH_Pattern::myReverseConnectivity
◆ myShape
TopoDS_Shape SMESH_Pattern::myShape
◆ myShapeIDMap
TopTools_IndexedMapOfOrientedShape SMESH_Pattern::myShapeIDMap
◆ myShapeIDToPointsMap
std::map< int, std::list< TPoint*> > SMESH_Pattern::myShapeIDToPointsMap
Referenced by Apply(), Clear(), getShapePoints(), and MakeMesh().
◆ myToKeepNodes
bool SMESH_Pattern::myToKeepNodes
Referenced by Load(), and MakeMesh().
◆ myXYZ
std::vector<gp_XYZ> SMESH_Pattern::myXYZ
◆ myXYZIdToNodeMap
std::map< int, const SMDS_MeshNode*> SMESH_Pattern::myXYZIdToNodeMap
