SMESHDS_Group Class Reference
#include <SMESHDS_Group.hxx>
Inheritance diagram for SMESHDS_Group:
 SMESHDS_Group (const int theID, const SMESHDS_Mesh *theMesh, const SMDSAbs_ElementType theType)
virtual void SetType (SMDSAbs_ElementType theType)
virtual smIdType Extent () const
virtual bool IsEmpty ()
virtual bool Contains (const smIdType theID)
virtual bool Contains (const SMDS_MeshElement *elem)
virtual SMDS_ElemIteratorPtr GetElements () const
virtual int GetTic () const
 Return a value allowing to find out if a group has changed or not. More...
bool Add (const smIdType theID)
bool Add (const SMDS_MeshElement *theElem)
bool Remove (const smIdType theID)
void Clear ()
SMDS_MeshGroup & SMDSGroup ()
int GetID () const
virtual smIdType GetID (const int theIndex)
 Don't use it! More...
const SMESHDS_Mesh * GetMesh () const
SMDSAbs_ElementType GetType () const
void SetStoreName (const char *theName)
const char * GetStoreName () const
void SetColor (const Quantity_Color &theColor)
Quantity_Color GetColor () const
void SetColorGroup (int theColorGroup)
int GetColorGroup () const
static void SetDefaultColor (const Quantity_Color &theColor)
const SMDS_MeshElement * findInMesh (const smIdType theID) const
void resetIterator ()
 Internal method: resets cached iterator, should be called by ancestors when they are modified (ex: Add() or Remove() ) More...
SMDS_MeshGroup myGroup
int myID
const SMESHDS_Mesh * myMesh
SMDSAbs_ElementType myType
std::string myStoreName
Quantity_Color myColor
smIdType myCurIndex
smIdType myCurID
SMDS_ElemIteratorPtr myIterator
Static Private Attributes
static Quantity_Color myDefaultColor = Quantity_Color( 0.0, 0.0, 0.0, Quantity_TOC_RGB )
◆ SMESHDS_Group()
SMESHDS_Group::SMESHDS_Group ( const int  theID,
const SMESHDS_Mesh *  theMesh,
◆ Add() [1/2]
bool SMESHDS_Group::Add ( const SMDS_MeshElement *  theElem)
◆ Add() [2/2]
◆ Clear()
void SMESHDS_Group::Clear ( )
◆ Contains() [1/2]
bool SMESHDS_Group::Contains ( const SMDS_MeshElement *  elem)
Reimplemented from SMESHDS_GroupBase.
References SMDS_MeshGroup::Contains(), and myGroup.
◆ Contains() [2/2]
bool SMESHDS_Group::Contains ( const smIdType  theID)
◆ Extent()
smIdType SMESHDS_Group::Extent ( ) const
References SMDS_MeshGroup::Extent(), and myGroup.
◆ findInMesh()
◆ GetColor()
◆ GetColorGroup()
int SMESHDS_GroupBase::GetColorGroup ( ) const
◆ GetElements()
◆ GetID() [1/2]
◆ GetID() [2/2]
smIdType SMESHDS_GroupBase::GetID ( const int  theIndex)
◆ GetMesh()
◆ GetStoreName()
◆ GetTic()
int SMESHDS_Group::GetTic ( ) const
Implements SMESHDS_GroupBase.
References myGroup, and SMDS_MeshGroup::Tic().
◆ GetType()
◆ IsEmpty()
◆ Remove()
◆ resetIterator()
void SMESHDS_GroupBase::resetIterator ( )
References SMESHDS_GroupBase::myCurID, and SMESHDS_GroupBase::myCurIndex.
Referenced by Add(), Clear(), and Remove().
◆ SetColor()
void SMESHDS_GroupBase::SetColor ( const Quantity_Color &  theColor)
◆ SetColorGroup()
void SMESHDS_GroupBase::SetColorGroup ( int  theColorGroup)
◆ SetDefaultColor()
static void SMESHDS_GroupBase::SetDefaultColor ( const Quantity_Color &  theColor)
Referenced by SMESH_Gen_i::SetOption().
◆ SetStoreName()
◆ SetType()
◆ SMDSGroup()
◆ myColor
Quantity_Color SMESHDS_GroupBase::myColor
privateinherited
◆ myCurID
smIdType SMESHDS_GroupBase::myCurID
privateinherited
◆ myCurIndex
smIdType SMESHDS_GroupBase::myCurIndex
privateinherited
◆ myDefaultColor
Quantity_Color SMESHDS_GroupBase::myDefaultColor = Quantity_Color( 0.0, 0.0, 0.0, Quantity_TOC_RGB )
staticprivateinherited
◆ myGroup
SMDS_MeshGroup SMESHDS_Group::myGroup
◆ myID
int SMESHDS_GroupBase::myID
privateinherited
◆ myIterator
SMDS_ElemIteratorPtr SMESHDS_GroupBase::myIterator
privateinherited
◆ myMesh
const SMESHDS_Mesh* SMESHDS_GroupBase::myMesh
privateinherited
◆ myStoreName
std::string SMESHDS_GroupBase::myStoreName
privateinherited
◆ myType
SMDSAbs_ElementType SMESHDS_GroupBase::myType
privateinherited
