SMESH_GroupBase_i Class Reference
#include <SMESH_Group_i.hxx>
Inheritance diagram for SMESH_GroupBase_i:
 SMESH_GroupBase_i (PortableServer::POA_ptr thePOA, SMESH_Mesh_i *theMeshServant, const int theLocalID)
virtual ~SMESH_GroupBase_i ()
void SetName (const char *name)
char * GetName ()
SMESH::ElementType GetType ()
SMESH::smIdType Size ()
CORBA::Boolean IsEmpty ()
CORBA::Boolean Contains (SMESH::smIdType elem_id)
SMESH::smIdType GetID (SMESH::smIdType elem_index)
 Return ID of theIndex-th group item. More...
SMESH::smIdType_array * GetListOfID ()
SMESH::smIdType_array * GetNodeIDs ()
 Return IDs of nodes of cells included to the group. More...
SMESH::smIdType GetNumberOfNodes ()
 return the number of nodes of cells included to the group More...
CORBA::Boolean IsNodeInfoAvailable ()
 Return true if GetNumberOfNodes() won't take a long time for computation. More...
virtual SMESH::SMESH_Mesh_ptr GetMesh ()
virtual SMESH::smIdType_array * GetMeshInfo ()
 Returns number of mesh elements of each EntityType Result array of number of elements per EntityType Inherited from SMESH_IDSource. More...
virtual SMESH::smIdType_array * GetNbElementsByType ()
virtual SMESH::smIdType_array * GetIDs ()
virtual SMESH::array_of_ElementType * GetTypes ()
 Returns types of elements it contains Inherited from SMESH_IDSource interface. More...
virtual bool IsMeshInfoCorrect ()
virtual SALOMEDS::TMPFile * GetVtkUgStream ()
virtual CORBA::Boolean IsInDependency (SMESH::SMESH_GroupBase_ptr other)
 Returns true if this group depends on the other via FT_BelongToMeshGroup predicate or vice versa. More...
int GetLocalID () const
SMESH_Mesh_i * GetMeshServant () const
SMESH_Group * GetSmeshGroup () const
SMESHDS_GroupBase * GetGroupDS () const
void SetColor (const SALOMEDS::Color &color)
SALOMEDS::Color GetColor ()
void SetColorNumber (CORBA::Long color)
CORBA::Long GetColorNumber ()
virtual void OnBaseObjModified (NotifyerAndWaiter *, bool)
void Modified (bool removed=false, NotifyerAndWaiter *who=0)
 calls OnBaseObjModified(), if who != this, and myWaiters[i]->Modified(who) More...
void AddModifWaiter (NotifyerAndWaiter *waiter)
 Stores an object to be notified on change of predicate. More...
void RemoveModifWaiter (NotifyerAndWaiter *waiter)
 Removes an object to be notified on change of predicate. More...
bool ContainModifWaiter (NotifyerAndWaiter *waiter)
 Checks if a waiter is among myWaiters, maybe nested. More...
Data Fields
std::list< NotifyerAndWaiter * > myWaiters
SMESH_PreMeshInfo *& changePreMeshInfo ()
SMESH_PreMeshInfo * myPreMeshInfo
int myNbNodes
int myGroupDSTic
void changeLocalId (int localId)
SMESH_Mesh_i * myMeshServant
int myLocalID
Friends
class SMESH_PreMeshInfo
class SMESH_Mesh_i
◆ SMESH_GroupBase_i()
SMESH_GroupBase_i::SMESH_GroupBase_i ( PortableServer::POA_ptr  thePOA,
SMESH_Mesh_i *  theMeshServant,
◆ ~SMESH_GroupBase_i()
SMESH_GroupBase_i::~SMESH_GroupBase_i ( )
References myPreMeshInfo.
◆ AddModifWaiter()
void SMESH::NotifyerAndWaiter::AddModifWaiter ( NotifyerAndWaiter *  waiter)
References SMESH::NotifyerAndWaiter::myWaiters.
Referenced by SMESH::Filter_i::FindBaseObjects().
◆ changeLocalId()
void SMESH_GroupBase_i::changeLocalId ( int  localId)
◆ changePreMeshInfo()
SMESH_PreMeshInfo *& SMESH_GroupBase_i::changePreMeshInfo ( )
◆ ContainModifWaiter()
bool SMESH::NotifyerAndWaiter::ContainModifWaiter ( NotifyerAndWaiter *  waiter)
◆ Contains()
CORBA::Boolean SMESH_GroupBase_i::Contains ( SMESH::smIdType  elem_id)
◆ GetColor()
SALOMEDS::Color SMESH_GroupBase_i::GetColor ( )
◆ GetColorNumber()
CORBA::Long SMESH_GroupBase_i::GetColorNumber ( )
◆ GetGroupDS()
◆ GetID()
SMESH::smIdType SMESH_GroupBase_i::GetID ( SMESH::smIdType  elem_index)
◆ GetIDs()
SMESH::smIdType_array * SMESH_GroupBase_i::GetIDs ( )
References GetListOfID().
◆ GetListOfID()
◆ GetLocalID()
◆ GetMesh()
SMESH::SMESH_Mesh_ptr SMESH_GroupBase_i::GetMesh ( )
References myMeshServant.
◆ GetMeshInfo()
SMESH::smIdType_array * SMESH_GroupBase_i::GetMeshInfo ( )
Reimplemented in SMESH_GroupOnFilter_i.
References SMESH_Mesh_i::CollectMeshInfo(), SMESH::Entity_Last, SMESH::Entity_Node, GetGroupDS(), SMESH_PreMeshInfo::GetMeshInfo(), GetNumberOfNodes(), myPreMeshInfo, SMDSAbs_Node, and SMDSEntity_Node.
◆ GetMeshServant()
◆ GetName()
char * SMESH_GroupBase_i::GetName ( )
◆ GetNbElementsByType()
SMESH::smIdType_array * SMESH_GroupBase_i::GetNbElementsByType ( )
References GetType(), myPreMeshInfo, SMESH::NB_ELEMENT_TYPES, SMDS_MeshInfo::NbElements(), and Size().
◆ GetNodeIDs()
SMESH::smIdType_array * SMESH_GroupBase_i::GetNodeIDs ( )
References SMESH_PreMeshInfo::FullLoadFromFile(), GetGroupDS(), GetListOfID(), GetType(), myPreMeshInfo, and SMESH::NODE.
◆ GetNumberOfNodes()
SMESH::smIdType SMESH_GroupBase_i::GetNumberOfNodes ( )
References SMESH_PreMeshInfo::FullLoadFromFile(), GetGroupDS(), GetType(), myGroupDSTic, myNbNodes, myPreMeshInfo, SMESH::NODE, and Size().
Referenced by GetMeshInfo(), and SMESH_GroupOnFilter_i::GetMeshInfo().
◆ GetSmeshGroup()
SMESH_Group * SMESH_GroupBase_i::GetSmeshGroup ( ) const
◆ GetType()
◆ GetTypes()
SMESH::array_of_ElementType * SMESH_GroupBase_i::GetTypes ( )
References GetType(), and IsEmpty().
◆ GetVtkUgStream()
SALOMEDS::TMPFile * SMESH_GroupBase_i::GetVtkUgStream ( )
◆ IsEmpty()
CORBA::Boolean SMESH_GroupBase_i::IsEmpty ( )
◆ IsInDependency()
bool SMESH_GroupBase_i::IsInDependency ( SMESH::SMESH_GroupBase_ptr  other)
◆ IsMeshInfoCorrect()
bool SMESH_GroupBase_i::IsMeshInfoCorrect ( )
References SMESH_PreMeshInfo::IsMeshInfoCorrect(), and myPreMeshInfo.
◆ IsNodeInfoAvailable()
CORBA::Boolean SMESH_GroupBase_i::IsNodeInfoAvailable ( )
References GetGroupDS(), GetType(), myGroupDSTic, myNbNodes, myPreMeshInfo, and SMESH::NODE.
◆ Modified()
◆ OnBaseObjModified()
virtual void SMESH::NotifyerAndWaiter::OnBaseObjModified ( NotifyerAndWaiter *  ,
bool
Reimplemented in SMESH::Filter_i.
Referenced by SMESH::NotifyerAndWaiter::Modified().
◆ RemoveModifWaiter()
void SMESH::NotifyerAndWaiter::RemoveModifWaiter ( NotifyerAndWaiter *  waiter)
◆ SetColor()
void SMESH_GroupBase_i::SetColor ( const SALOMEDS::Color &  color)
◆ SetColorNumber()
void SMESH_GroupBase_i::SetColorNumber ( CORBA::Long  color)
◆ SetName()
◆ Size()
◆ SMESH_Mesh_i
friend class SMESH_Mesh_i
friend
◆ SMESH_PreMeshInfo
friend class SMESH_PreMeshInfo
friend
◆ myGroupDSTic
int SMESH_GroupBase_i::myGroupDSTic
◆ myLocalID
int SMESH_GroupBase_i::myLocalID
Referenced by GetSmeshGroup().
◆ myMeshServant
SMESH_Mesh_i* SMESH_GroupBase_i::myMeshServant
Referenced by GetMesh(), GetSmeshGroup(), and SetName().
◆ myNbNodes
int SMESH_GroupBase_i::myNbNodes
◆ myPreMeshInfo
◆ myWaiters
