SMESH_Group_i.hxx
24// File : SMESH_Group_i.hxx
25// Author : Sergey ANIKIN, OCC
26// Module : SMESH
27//
28#ifndef SMESH_Group_i_HeaderFile
29#define SMESH_Group_i_HeaderFile
30
31#include "SMESH.hxx"
32#include "SMESH_Mesh_i.hxx"
33#include "SMESH_Filter_i.hxx"
34
35#include <SALOMEconfig.h>
36#include CORBA_SERVER_HEADER(SMESH_Group)
37#include CORBA_SERVER_HEADER(SMESH_Mesh)
38#include CORBA_CLIENT_HEADER(GEOM_Gen)
39
40#include "SALOME_GenericObj_i.hh"
41
42class SMESH_Group;
45
46// ===========
47// Group Base
48// ===========
50 public virtual POA_SMESH::SMESH_GroupBase,
51 public virtual SALOME::GenericObj_i,
52 public SMESH::NotifyerAndWaiter // defined in SMESH_Filter_i.hxx
53{
54 public:
55 SMESH_GroupBase_i(PortableServer::POA_ptr thePOA,
56 SMESH_Mesh_i* theMeshServant,
57 const int theLocalID );
58 virtual ~SMESH_GroupBase_i();
59
60 // CORBA interface implementation
61 void SetName(const char* name);
62 char* GetName();
63 SMESH::ElementType GetType();
64 SMESH::smIdType Size();
65 CORBA::Boolean IsEmpty();
66 CORBA::Boolean Contains(SMESH::smIdType elem_id);
67 SMESH::smIdType GetID(SMESH::smIdType elem_index);
68 SMESH::smIdType_array* GetListOfID();
69 SMESH::smIdType_array* GetNodeIDs();
70 SMESH::smIdType GetNumberOfNodes();
71 CORBA::Boolean IsNodeInfoAvailable(); // for gui
72
73 virtual SMESH::SMESH_Mesh_ptr GetMesh();
74
80 virtual SMESH::smIdType_array* GetMeshInfo();
84 virtual SMESH::smIdType_array* GetNbElementsByType();
88 virtual SMESH::smIdType_array* GetIDs();
93 virtual SMESH::array_of_ElementType* GetTypes();
98 virtual bool IsMeshInfoCorrect();
102 virtual SALOMEDS::TMPFile* GetVtkUgStream();
103
108 virtual CORBA::Boolean IsInDependency( SMESH::SMESH_GroupBase_ptr other );
109
110
111 // Internal C++ interface
112 int GetLocalID() const { return myLocalID; } // return group persistent ID
113 SMESH_Mesh_i* GetMeshServant() const { return myMeshServant; }
114 SMESH_Group* GetSmeshGroup() const;
115 SMESHDS_GroupBase* GetGroupDS() const;
116
117 void SetColor(const SALOMEDS::Color& color);
118 SALOMEDS::Color GetColor();
119
120 void SetColorNumber(CORBA::Long color);
121 CORBA::Long GetColorNumber();
122
123protected:
124
125 SMESH_PreMeshInfo* & changePreMeshInfo() { return myPreMeshInfo; }
126 SMESH_PreMeshInfo* myPreMeshInfo; // mesh info before full loading from study file
127 friend class SMESH_PreMeshInfo;
128
130
131private:
134
135 void changeLocalId(int localId) { myLocalID = localId; }
136 friend class SMESH_Mesh_i;
137};
138
139// ======
140// Group
141// ======
142
144 public virtual POA_SMESH::SMESH_Group,
145 public SMESH_GroupBase_i
146{
147 public:
148 SMESH_Group_i( PortableServer::POA_ptr thePOA,
149 SMESH_Mesh_i* theMeshServant,
150 const int theLocalID );
151 // CORBA interface implementation
152 void Clear();
153 SMESH::smIdType Add( const SMESH::smIdType_array& theIDs );
154 SMESH::smIdType Remove( const SMESH::smIdType_array& theIDs );
155
156 SMESH::smIdType AddByPredicate( SMESH::Predicate_ptr thePredicate );
157 SMESH::smIdType RemoveByPredicate( SMESH::Predicate_ptr thePredicate );
158
159 SMESH::smIdType AddFrom( SMESH::SMESH_IDSource_ptr theSource );
160};
161
162// =========================
163// Group linked to geometry
164// =========================
165
167 public virtual POA_SMESH::SMESH_GroupOnGeom,
168 public SMESH_GroupBase_i
169{
170 public:
171 SMESH_GroupOnGeom_i( PortableServer::POA_ptr thePOA,
172 SMESH_Mesh_i* theMeshServant,
173 const int theLocalID );
174 // CORBA interface implementation
175 GEOM::GEOM_Object_ptr GetShape();
176};
177
178// =========================
179// Group denied by filter
180// =========================
181
183 public virtual POA_SMESH::SMESH_GroupOnFilter,
184 public SMESH_GroupBase_i
185{
186 public:
187 SMESH_GroupOnFilter_i( PortableServer::POA_ptr thePOA,
188 SMESH_Mesh_i* theMeshServant,
189 const int theLocalID );
191
192 // Persistence
193 static SMESH::Filter_ptr StringToFilter(const std::string& thePersistentString );
194 std::string FilterToString() const;
195
196 static SMESH_PredicatePtr GetPredicate( SMESH::Filter_ptr );
197
198 // CORBA interface implementation
199 void SetFilter(SMESH::Filter_ptr theFilter);
200 SMESH::Filter_ptr GetFilter();
201 virtual CORBA::Boolean IsUpToDate();
202 virtual SMESH::smIdType_array* GetListOfID();
203 virtual SMESH::smIdType_array* GetMeshInfo();
206 virtual bool IsMeshInfoCorrect();
207
208 // method of SMESH::NotifyerAndWaiter to update self when myFilter changes
209 virtual void OnBaseObjModified(NotifyerAndWaiter* filter, bool);
210
211 private:
212 SMESH::Filter_var myFilter;
213};
214#endif
#define SMESH_I_EXPORT
Definition: SMESH.hxx:39
SMESH::Controls::PredicatePtr SMESH_PredicatePtr
Definition: SMESH_Controls.hxx:81
smIdType myNbNodes
Definition: SMDS_MeshInfo.hxx:89
Definition: SMESHDS_GroupBase.hxx:42
Definition: SMESH_Group_i.hxx:53
SMESH_PreMeshInfo * myPreMeshInfo
Definition: SMESH_Group_i.hxx:126
SMESH_Mesh_i * myMeshServant
Definition: SMESH_Group_i.hxx:132
int myGroupDSTic
Definition: SMESH_Group_i.hxx:129
int myLocalID
Definition: SMESH_Group_i.hxx:133
SMESH_PreMeshInfo *& changePreMeshInfo()
Definition: SMESH_Group_i.hxx:125
Definition: SMESH_Group_i.hxx:135
SMESH_Mesh_i * GetMeshServant() const
Definition: SMESH_Group_i.hxx:113
Definition: SMESH_Group_i.hxx:112
Definition: SMESH_Group_i.hxx:185
Definition: SMESH_Group_i.hxx:212
Definition: SMESH_Group_i.hxx:169
Definition: SMESH_Group_i.hxx:146
Definition: SMESH_Group.hxx:43
Definition: SMESH_Mesh_i.hxx:57
Class loading and holding information of a mesh object (mesh, group, submesh) not yet loaded from HDF...
Definition: SMESH_PreMeshInfo.hxx:54
ENUM Add(ENUM v, int delta)
Return incremented enum value.
Definition: SMESH_TypeDefs.hxx:140
QString GetName(const Handle(SALOME_InteractiveObject)&theIO)
Definition: SMESHGUI_Utils.cxx:252
QColor GetColor(const QString &theSect, const QString &theName, const QColor &def)
Definition: SMESH_ActorUtils.cxx:97
sequence< ElementType > array_of_ElementType
Definition: SMESH_Mesh.idl:138
void SetFilter(const Handle(VTKViewer_Filter)&theFilter, SVTK_Selector *theSelector)
Definition: SMESHGUI_VTKUtils.cxx:1115
sequence< smIdType > smIdType_array
Definition: SMESH_Mesh.idl:45
ElementType
Enumeration for element type, like in SMDS.
Definition: SMESH_Mesh.idl:128
Predicate_i * GetPredicate(Predicate_ptr thePredicate)
Definition: SMESH_Filter_i.cxx:70
void SetName(_PTR(SObject) theSObject, const QString &theName)
Definition: SMESHGUI_Utils.cxx:134
Object notified on change of base objects and notifying dependent objects in its turn.
Definition: SMESH_Filter_i.hxx:57
virtual void OnBaseObjModified(NotifyerAndWaiter *, bool)
Definition: SMESH_Filter_i.hxx:58
