SMESH::Filter_i Class Reference
#include <SMESH_Filter_i.hxx>
Inheritance diagram for SMESH::Filter_i:
 Filter_i ()
 ~Filter_i ()
virtual void SetPredicate (Predicate_ptr)
virtual void SetMesh (SMESH_Mesh_ptr)
virtual smIdType_array * GetElementsId (SMESH_Mesh_ptr)
virtual smIdType_array * GetElementsIdFromParts (const ListOfIDSources &theParts)
virtual ElementType GetElementType ()
virtual CORBA::Boolean GetCriteria (SMESH::Filter::Criteria_out theCriteria)
virtual CORBA::Boolean SetCriteria (const SMESH::Filter::Criteria &theCriteria)
virtual Predicate_ptr GetPredicate ()
Predicate_i * GetPredicate_i ()
void FindBaseObjects ()
 Find groups it depends on. More...
virtual void OnBaseObjModified (NotifyerAndWaiter *group, bool removed)
 When notified on removal of myBaseGroups[i], remove a reference to a group from a predicate. More...
virtual SMESH::smIdType_array * GetIDs ()
virtual SMESH::smIdType_array * GetMeshInfo ()
 Returns number of mesh elements per each EntityType. More...
virtual SMESH::smIdType_array * GetNbElementsByType ()
virtual SMESH::array_of_ElementType * GetTypes ()
 Return GetElementType() within an array Implement SMESH_IDSource interface. More...
virtual SMESH::SMESH_Mesh_ptr GetMesh ()
virtual bool IsMeshInfoCorrect ()
virtual SALOMEDS::TMPFile * GetVtkUgStream ()
void Modified (bool removed=false, NotifyerAndWaiter *who=0)
 calls OnBaseObjModified(), if who != this, and myWaiters[i]->Modified(who) More...
void AddModifWaiter (NotifyerAndWaiter *waiter)
 Stores an object to be notified on change of predicate. More...
void RemoveModifWaiter (NotifyerAndWaiter *waiter)
 Removes an object to be notified on change of predicate. More...
bool ContainModifWaiter (NotifyerAndWaiter *waiter)
 Checks if a waiter is among myWaiters, maybe nested. More...
static void GetElementsId (Predicate_i *, const SMDS_Mesh *, Controls::Filter::TIdSequence &)
static void GetElementsId (Predicate_i *, SMESH_Mesh_ptr, Controls::Filter::TIdSequence &)
Data Fields
std::list< NotifyerAndWaiter * > myWaiters
Controls::Filter myFilter
Predicate_i * myPredicate
SMESH_Mesh_var myMesh
std::vector< SMESH_GroupBase_i * > myBaseGroups
◆ Filter_i()
SMESH::Filter_i::Filter_i ( )
◆ ~Filter_i()
SMESH::Filter_i::~Filter_i ( )
◆ AddModifWaiter()
void SMESH::NotifyerAndWaiter::AddModifWaiter ( NotifyerAndWaiter *  waiter)
References SMESH::NotifyerAndWaiter::myWaiters.
Referenced by FindBaseObjects().
◆ ContainModifWaiter()
bool SMESH::NotifyerAndWaiter::ContainModifWaiter ( NotifyerAndWaiter *  waiter)
◆ FindBaseObjects()
void SMESH::Filter_i::FindBaseObjects ( )
◆ GetCriteria()
CORBA::Boolean SMESH::Filter_i::GetCriteria ( SMESH::Filter::Criteria_out  theCriteria)
◆ GetElementsId() [1/3]
void SMESH::Filter_i::GetElementsId ( Predicate_i *  thePredicate,
const SMDS_Mesh *  theMesh,
Controls::Filter::TIdSequence &  theSequence
◆ GetElementsId() [2/3]
SMESH_Mesh_ptr  theMesh,
◆ GetElementsId() [3/3]
SMESH::smIdType_array * SMESH::Filter_i::GetElementsId ( SMESH_Mesh_ptr  theMesh)
References GetElementsId(), and myPredicate.
◆ GetElementsIdFromParts()
◆ GetElementType()
◆ GetIDs()
SMESH::smIdType_array * SMESH::Filter_i::GetIDs ( )
References GetElementsId(), and myMesh.
◆ GetMesh()
SMESH::SMESH_Mesh_ptr SMESH::Filter_i::GetMesh ( )
References myMesh.
◆ GetMeshInfo()
◆ GetNbElementsByType()
SMESH::smIdType_array * SMESH::Filter_i::GetNbElementsByType ( )
◆ GetPredicate()
Predicate_ptr SMESH::Filter_i::GetPredicate ( )
References myPredicate.
◆ GetPredicate_i()
Predicate_i * SMESH::Filter_i::GetPredicate_i ( )
◆ GetTypes()
SMESH::array_of_ElementType * SMESH::Filter_i::GetTypes ( )
◆ GetVtkUgStream()
SALOMEDS::TMPFile * SMESH::Filter_i::GetVtkUgStream ( )
◆ IsMeshInfoCorrect()
virtual bool SMESH::Filter_i::IsMeshInfoCorrect ( )
◆ Modified()
◆ OnBaseObjModified()
void SMESH::Filter_i::OnBaseObjModified ( NotifyerAndWaiter *  group,
bool  removed
Reimplemented from SMESH::NotifyerAndWaiter.
References FindBaseObjects(), SMESH::getPrediacates(), and myPredicate.
◆ RemoveModifWaiter()
void SMESH::NotifyerAndWaiter::RemoveModifWaiter ( NotifyerAndWaiter *  waiter)
◆ SetCriteria()
◆ SetMesh()
void SMESH::Filter_i::SetMesh ( SMESH_Mesh_ptr  theMesh)
◆ SetPredicate()
◆ myBaseGroups
std::vector< SMESH_GroupBase_i* > SMESH::Filter_i::myBaseGroups
◆ myFilter
Controls::Filter SMESH::Filter_i::myFilter
Referenced by SetPredicate().
◆ myMesh
SMESH_Mesh_var SMESH::Filter_i::myMesh
◆ myPredicate
◆ myWaiters
