SMESH::Filter Interface Reference
Filter. More...
import"SMESH_Filter.idl";
Inheritance diagram for SMESH::Filter:
struct  Criterion
 Structure containing information about one criterion Type - FT_Taper, FT_Skew ... Compare - FT_LessThan, FT_MoreThan, FT_EqualTo Threshold - threshold value UnaryOp - unary logical operation: FT_LogicalNOT or FT_Undefined BinaryOp - binary logical operation FT_LogicalAND, FT_LogicalOR or (FT_Undefined must be for the last criterion) ThresholdStr - Threshold value defined as string. More...
typedef sequence< Criterion > Criteria
void SetPredicate (in Predicate thePredicate)
void SetMesh (in SMESH_Mesh theMesh)
smIdType_array GetElementsId (in SMESH_Mesh theMesh)
smIdType_array GetElementsIdFromParts (in ListOfIDSources theParts)
ElementType GetElementType ()
Predicate GetPredicate ()
boolean GetCriteria (out Criteria theCriteria)
boolean SetCriteria (in Criteria theCriteria)
smIdType_array GetIDs ()
smIdType_array GetMeshInfo ()
 Returns number of mesh elements of each EntityType. More...
smIdType_array GetNbElementsByType ()
array_of_ElementType GetTypes ()
SMESH_Mesh GetMesh ()
 Returns the mesh. More...
boolean IsMeshInfoCorrect ()
SALOMEDS::TMPFile GetVtkUgStream ()
◆ Criteria
◆ GetCriteria()
boolean SMESH::Filter::GetCriteria ( out Criteria  theCriteria)
◆ GetElementsId()
smIdType_array SMESH::Filter::GetElementsId ( in SMESH_Mesh  theMesh)
◆ GetElementsIdFromParts()
smIdType_array SMESH::Filter::GetElementsIdFromParts ( in ListOfIDSources  theParts)
◆ GetElementType()
ElementType SMESH::Filter::GetElementType ( )
◆ GetIDs()
smIdType_array SMESH::SMESH_IDSource::GetIDs ( )
◆ GetMesh()
SMESH_Mesh SMESH::SMESH_IDSource::GetMesh ( )
Returns the mesh.
◆ GetMeshInfo()
smIdType_array SMESH::SMESH_IDSource::GetMeshInfo ( )
array of number of elements per EntityType
◆ GetNbElementsByType()
smIdType_array SMESH::SMESH_IDSource::GetNbElementsByType ( )
array of number of elements per ElementType
◆ GetPredicate()
Predicate SMESH::Filter::GetPredicate ( )
◆ GetTypes()
array_of_ElementType SMESH::SMESH_IDSource::GetTypes ( )
It's empty if the SMESH_IDSource contains no IDs
◆ GetVtkUgStream()
SALOMEDS::TMPFile SMESH::SMESH_IDSource::GetVtkUgStream ( )
◆ IsMeshInfoCorrect()
boolean SMESH::SMESH_IDSource::IsMeshInfoCorrect ( )
◆ SetCriteria()
boolean SMESH::Filter::SetCriteria ( in Criteria  theCriteria)
◆ SetMesh()
void SMESH::Filter::SetMesh ( in SMESH_Mesh  theMesh)
◆ SetPredicate()
void SMESH::Filter::SetPredicate ( in Predicate  thePredicate)
