import"SMESH_Mesh.idl";
| boolean | HasShapeToMesh () raises (SALOME::SALOME_Exception) |
| Return true if there is a geometry to be meshed. More... | |
| GEOM::GEOM_Object | GetShapeToMesh () raises (SALOME::SALOME_Exception) |
| Get geom shape to mesh. More... | |
| void | ReplaceShape (in GEOM::GEOM_Object theNewGeom) raises (SALOME::SALOME_Exception) |
| Replaces a shape in the mesh. More... | |
| boolean | IsLoaded () raises (SALOME::SALOME_Exception) |
| Return false if the mesh is not yet fully loaded from the study file. More... | |
| void | Load () raises (SALOME::SALOME_Exception) |
| Load full mesh data from the study file. More... | |
| void | Clear () raises (SALOME::SALOME_Exception) |
| Remove all nodes and elements. More... | |
| submesh_array | GetSubMeshes () raises (SALOME::SALOME_Exception) |
| Get the list of sub-meshes existing in the mesh. More... | |
| void | ClearSubMesh (in long ShapeID) raises (SALOME::SALOME_Exception) |
| Remove all nodes and elements of submesh. More... | |
| SMESH_subMesh | GetSubMesh (in GEOM::GEOM_Object aSubObject, in string name) raises (SALOME::SALOME_Exception) |
| Get the subMesh object associated to a Sub-shape. More... | |
| void | RemoveSubMesh (in SMESH_subMesh aSubMesh) raises (SALOME::SALOME_Exception) |
| Remove a submesh. More... | |
| SMESH_Group | CreateGroup (in ElementType elem_type, in string name) raises (SALOME::SALOME_Exception) |
| Create a group. More... | |
| SMESH_GroupOnGeom | CreateGroupFromGEOM (in ElementType elemType, in string name, in GEOM::GEOM_Object geomObject) raises (SALOME::SALOME_Exception) |
| Create a group from geometry. More... | |
| SMESH_GroupOnFilter | CreateGroupFromFilter (in ElementType elemType, in string name, in SMESH::Filter filter) raises (SALOME::SALOME_Exception) |
| Create a group from filter. More... | |
| void | RemoveGroup (in SMESH_GroupBase aGroup) raises (SALOME::SALOME_Exception) |
| Remove a group. More... | |
| void | RemoveGroupWithContents (in SMESH_GroupBase aGroup) raises (SALOME::SALOME_Exception) |
| Remove group with its contents. More... | |
| boolean | IsComputedOK () raises (SALOME::SALOME_Exception) |
| Return True if all the submeshes are computed. More... | |
| ListOfGroups | GetGroups () raises (SALOME::SALOME_Exception) |
| Get the list of groups existing in the mesh. More... | |
| long | NbGroups () raises (SALOME::SALOME_Exception) |
| Get number of groups existing in the mesh. More... | |
| SMESH_Group | UnionGroups (in SMESH_GroupBase aGroup1, in SMESH_GroupBase aGroup2, in string name) raises (SALOME::SALOME_Exception) |
| Union of two groups New group is created. More... | |
| SMESH_Group | UnionListOfGroups (in ListOfGroups aListOfGroups, in string name) raises (SALOME::SALOME_Exception) |
| Union of list of groups New group is created. More... | |
| SMESH_Group | IntersectGroups (in SMESH_GroupBase aGroup1, in SMESH_GroupBase aGroup2, in string name) raises (SALOME::SALOME_Exception) |
| Intersection of two groups New group is created. More... | |
| SMESH_Group | IntersectListOfGroups (in ListOfGroups aListOfGroups, in string name) raises (SALOME::SALOME_Exception) |
| Intersection of list of groups New group is created. More... | |
| SMESH_Group | CutGroups (in SMESH_GroupBase aMainGroup, in SMESH_GroupBase aToolGroup, in string name) raises (SALOME::SALOME_Exception) |
| Cut of two groups New group is created. More... | |
| SMESH_Group | CutListOfGroups (in ListOfGroups aMainGroups, in ListOfGroups aToolGroups, in string name) raises (SALOME::SALOME_Exception) |
| Cut of lists of groups New group is created. More... | |
| SMESH_Group | CreateDimGroup (in ListOfIDSources aListOfGroups, in ElementType anElemType, in string name, in NB_COMMON_NODES_ENUM nbCommonNodes, in boolean underlyingOnly) raises (SALOME::SALOME_Exception) |
| Create a group of entities basing on nodes of other groups. More... | |
| ListOfGroups | FaceGroupsSeparatedByEdges (in double sharpAngle, in boolean createEdges, in boolean useExistingEdges) raises (SALOME::SALOME_Exception) |
| Distribute all faces of the mesh among groups using sharp edges and optionally existing 1D elements as group boundaries. More... | |
| SMESH_Group | ConvertToStandalone (in SMESH_GroupBase theGroupOn) raises (SALOME::SALOME_Exception) |
| Convert group on geometry or on filter into standalone group. More... | |
| Hypothesis_Status | AddHypothesis (in GEOM::GEOM_Object aSubObject, in SMESH_Hypothesis anHyp, out string anErrorText) raises (SALOME::SALOME_Exception) |
| Add hypothesis to the mesh, under a particular sub-shape (or the main shape itself) This method is only used to prepare the build of the mesh and store the algorithms and associated parameters. More... | |
| Hypothesis_Status | RemoveHypothesis (in GEOM::GEOM_Object aSubObject, in SMESH_Hypothesis anHyp) raises (SALOME::SALOME_Exception) |
| Remove an hypothesis previously added with AddHypothesis. More... | |
| ListOfHypothesis | GetHypothesisList (in GEOM::GEOM_Object aSubObject) raises (SALOME::SALOME_Exception) |
| Get the list of hypothesis added on a sub-shape. More... | |
| log_array | GetLog (in boolean clearAfterGet) raises (SALOME::SALOME_Exception) |
| Get the log of nodes and elements added or removed since previous clear of the log. More... | |
| void | ClearLog () raises (SALOME::SALOME_Exception) |
| Clear the log of nodes and elements added or removed since previous clear. More... | |
| void | SetAutoColor (in boolean theAutoColor) raises (SALOME::SALOME_Exception) |
| Toggle auto color mode on the object. More... | |
| boolean | GetAutoColor () raises (SALOME::SALOME_Exception) |
| Get flag of object's auto color mode. More... | |
| long | GetId () |
| Get the internal Id. More... | |
| SMESH_MeshEditor | GetMeshEditor () raises (SALOME::SALOME_Exception) |
| Obtain instance of SMESH_MeshEditor. More... | |
| SMESH_MeshEditor | GetMeshEditPreviewer () raises (SALOME::SALOME_Exception) |
| Return SMESH_MeshEditor that would not modify the mesh but fill MeshPreviewStruct. More... | |
| boolean | HasModificationsToDiscard () raises (SALOME::SALOME_Exception) |
| Return true if the mesh has been edited since a total re-compute and those modifications may prevent successful partial re-compute. More... | |
| boolean | HasDuplicatedGroupNamesMED () |
| Check group names for duplications. More... | |
| void | ExportMED (in string fileName, in boolean auto_groups, in long version, in boolean overwrite, in boolean autoDimension) raises (SALOME::SALOME_Exception) |
| Export a Mesh to MED file. More... | |
| long long | ExportMEDCoupling (in boolean auto_groups, in boolean autoDimension) raises (SALOME::SALOME_Exception) |
| void | ExportPartToMED (in SMESH_IDSource meshPart, in string fileName, in boolean auto_groups, in long version, in boolean overwrite, in boolean autoDimension, in GEOM::ListOfFields fields, in string geomAssocFields, in double ZTolerance, in boolean saveNumbers) raises (SALOME::SALOME_Exception) |
| Export a [part of] Mesh into a MED file @params. More... | |
| void | ExportPartToMESHIO (in SMESH_IDSource meshPart, in string fileName, in string selectedFilter, in string converter) raises (SALOME::SALOME_Exception) |
| Export a [part of] Mesh to a file with meshio library using an intermediate MED file @params. More... | |
| long long | ExportPartToMEDCoupling (in SMESH_IDSource meshPart, in boolean auto_groups, in boolean autoDimension, in GEOM::ListOfFields fields, in string geomAssocFields, in double ZTolerance, in boolean saveNumbers) raises (SALOME::SALOME_Exception) |
| string | GetVersionString (in long minor, in short nbDigits) |
| Return string representation of a MED file version comprising nbDigits. More... | |
| long_array | GetMEDVersionsCompatibleForAppend () |
| Return the list of med versions compatibles for write/append, encoded in 10*major+minor (for instance, code for med 3.2.1 is 32) More... | |
| void | ExportDAT (in string file, in boolean renumer) raises (SALOME::SALOME_Exception) |
| Export Mesh to different Formats (UNV supported version is I-DEAS 10) More... | |
| void | ExportUNV (in string file, in boolean renumer) raises (SALOME::SALOME_Exception) |
| void | ExportSTL (in string file, in boolean isascii) raises (SALOME::SALOME_Exception) |
| void | ExportCGNS (in SMESH_IDSource meshPart, in string file, in boolean overwrite, in boolean groupElemsByType) raises (SALOME::SALOME_Exception) |
| void | ExportStructuredCGNS (in SMESH_IDSource meshPart, in string file, in boolean overwrite) raises (SALOME::SALOME_Exception) |
| void | ExportGMF (in SMESH_IDSource meshPart, in string file, in boolean withRequiredGroups) raises (SALOME::SALOME_Exception) |
| void | ExportPartToDAT (in SMESH_IDSource meshPart, in string file, in boolean renumer) raises (SALOME::SALOME_Exception) |
| void | ExportPartToUNV (in SMESH_IDSource meshPart, in string file, in boolean renumer) raises (SALOME::SALOME_Exception) |
| void | ExportPartToSTL (in SMESH_IDSource meshPart, in string file, in boolean isascii) raises (SALOME::SALOME_Exception) |
| double | GetComputeProgress () |
| Return computation progress [0.,1]. More... | |
| smIdType | NbNodes () raises (SALOME::SALOME_Exception) |
| Get information about mesh contents. More... | |
| smIdType | NbElements () raises (SALOME::SALOME_Exception) |
| smIdType | Nb0DElements () raises (SALOME::SALOME_Exception) |
| smIdType | NbBalls () raises (SALOME::SALOME_Exception) |
| smIdType | NbEdges () raises (SALOME::SALOME_Exception) |
| smIdType | NbEdgesOfOrder (in ElementOrder order) raises (SALOME::SALOME_Exception) |
| smIdType | NbFaces () raises (SALOME::SALOME_Exception) |
| smIdType | NbFacesOfOrder (in ElementOrder order) raises (SALOME::SALOME_Exception) |
| smIdType | NbTriangles () raises (SALOME::SALOME_Exception) |
| smIdType | NbTrianglesOfOrder (in ElementOrder order) raises (SALOME::SALOME_Exception) |
| smIdType | NbBiQuadTriangles () raises (SALOME::SALOME_Exception) |
| smIdType | NbQuadrangles () raises (SALOME::SALOME_Exception) |
| smIdType | NbQuadranglesOfOrder (in ElementOrder order) raises (SALOME::SALOME_Exception) |
| smIdType | NbBiQuadQuadrangles () raises (SALOME::SALOME_Exception) |
| smIdType | NbPolygons () raises (SALOME::SALOME_Exception) |
| smIdType | NbPolygonsOfOrder (in ElementOrder order) raises (SALOME::SALOME_Exception) |
| smIdType | NbVolumes () raises (SALOME::SALOME_Exception) |
| smIdType | NbVolumesOfOrder (in ElementOrder order) raises (SALOME::SALOME_Exception) |
| smIdType | NbTetras () raises (SALOME::SALOME_Exception) |
| smIdType | NbTetrasOfOrder (in ElementOrder order) raises (SALOME::SALOME_Exception) |
| smIdType | NbHexas () raises (SALOME::SALOME_Exception) |
| smIdType | NbHexasOfOrder (in ElementOrder order) raises (SALOME::SALOME_Exception) |
| smIdType | NbTriQuadraticHexas () raises (SALOME::SALOME_Exception) |
| smIdType | NbPyramids () raises (SALOME::SALOME_Exception) |
| smIdType | NbPyramidsOfOrder (in ElementOrder order) raises (SALOME::SALOME_Exception) |
| smIdType | NbPrisms () raises (SALOME::SALOME_Exception) |
| smIdType | NbPrismsOfOrder (in ElementOrder order) raises (SALOME::SALOME_Exception) |
| smIdType | NbHexagonalPrisms () raises (SALOME::SALOME_Exception) |
| smIdType | NbPolyhedrons () raises (SALOME::SALOME_Exception) |
| smIdType | NbSubMesh () raises (SALOME::SALOME_Exception) |
| smIdType_array | GetElementsId () raises (SALOME::SALOME_Exception) |
| smIdType_array | GetElementsByType (in ElementType theType) raises (SALOME::SALOME_Exception) |
| smIdType_array | GetNodesId () raises (SALOME::SALOME_Exception) |
| ElementType | GetElementType (in smIdType id, in boolean iselem) raises (SALOME::SALOME_Exception) |
| Returns type of mesh element. More... | |
| EntityType | GetElementGeomType (in smIdType id) raises (SALOME::SALOME_Exception) |
| GeometryType | GetElementShape (in smIdType id) raises (SALOME::SALOME_Exception) |
| smIdType_array | GetSubMeshElementsId (in long ShapeID) raises (SALOME::SALOME_Exception) |
| smIdType_array | GetSubMeshNodesId (in long ShapeID, in boolean all) raises (SALOME::SALOME_Exception) |
| ElementType | GetSubMeshElementType (in long ShapeID) raises (SALOME::SALOME_Exception) |
| boolean | IsUnorderedSubMesh (in long submeshID) |
| Methods to set meshing order of submeshes. More... | |
| submesh_array_array | GetMeshOrder () |
| Return submesh objects list in meshing order. More... | |
| boolean | SetMeshOrder (in submesh_array_array theSubMeshArray) |
| Set submesh object order. More... | |
| string | Dump () |
| Get mesh description. More... | |
| long long | GetMeshPtr () |
| Get mesh pointer. More... | |
| double_array | GetNodeXYZ (in smIdType id) |
| Get XYZ coordinates of node as list of double If there is not node for given ID - returns empty list. More... | |
| smIdType_array | GetNodeInverseElements (in smIdType id, in ElementType elemType) |
| For given node returns list of IDs of inverse elements If there is not node for given ID - returns empty list. More... | |
| NodePosition | GetNodePosition (in smIdType NodeID) |
| Return position of a node on shape. More... | |
| ElementPosition | GetElementPosition (in smIdType ElemID) |
| Return position of an element on shape. More... | |
| long | GetShapeID (in smIdType id) |
| If given element is node returns IDs of shape from position If there is not node for given ID - returns -1. More... | |
| long | GetShapeIDForElem (in smIdType id) |
| For given element returns ID of result shape after ::FindShape() from SMESH_MeshEditor If there is not element for given ID - returns -1. More... | |
| short | GetElemNbNodes (in smIdType id) |
| Returns number of nodes for given element If there is not element for given ID - returns -1. More... | |
| smIdType_array | GetElemNodes (in smIdType id) |
| Returns IDs of nodes of given element. More... | |
| smIdType | GetElemNode (in smIdType id, in short index) |
| Returns ID of node by given index for given element If there is not element for given ID - returns -1 If there is not node for given index - returns -2. More... | |
| boolean | IsMediumNode (in smIdType ide, in smIdType idn) |
| Returns true if given node is medium node in given quadratic element. More... | |
| boolean | IsMediumNodeOfAnyElem (in smIdType idn, in ElementType elem_type) |
| Returns true if given node is medium node in one of quadratic elements. More... | |
| long | ElemNbEdges (in smIdType id) |
| Returns number of edges for given element. More... | |
| long | ElemNbFaces (in smIdType id) |
| Returns number of faces for given element. More... | |
| smIdType_array | GetElemFaceNodes (in smIdType elemId, in short faceIndex) |
| Returns nodes of given face (counted from zero) for given volumic element. More... | |
| double_array | GetFaceNormal (in long faceId, in boolean normalized) |
| Returns three components of normal of given mesh face (or an empty array in KO case) More... | |
| smIdType | FindElementByNodes (in smIdType_array nodes) |
| Returns an element based on all given nodes. More... | |
| smIdType_array | GetElementsByNodes (in smIdType_array nodes, in ElementType elem_type) |
| Return elements including all given nodes. More... | |
| boolean | IsPoly (in smIdType id) |
| Returns true if given element is polygon. More... | |
| boolean | IsQuadratic (in smIdType id) |
| Returns true if given element is quadratic. More... | |
| double | GetBallDiameter (in smIdType id) |
| Returns diameter of a ball discrete element or zero in case of an invalid id. More... | |
| double_array | BaryCenter (in smIdType id) |
| Returns XYZ coordinates of bary center for given element as list of double If there is not element for given ID - returns empty list. More... | |
| MedFileInfo | GetMEDFileInfo () |
| Gets information about imported MED file. More... | |
| void | SetParameters (in string theParameters) |
| Sets list of notebook variables used for Mesh operations separated by ":" symbol. More... | |
| string | GetParameters () |
| Returns list of notebook variables used for Mesh operations separated by ":" symbol. More... | |
| string_array | GetLastParameters () |
| Returns list of notebook variables used for last Mesh operation. More... | |
| smIdType_array | GetIDs () |
| Returns a sequence of all element IDs. More... | |
| smIdType_array | GetMeshInfo () |
| Returns number of mesh elements of each EntityType. More... | |
| smIdType_array | GetNbElementsByType () |
| Returns number of mesh elements of each ElementType. More... | |
| array_of_ElementType | GetTypes () |
| Returns types of elements it contains. More... | |
| SMESH_Mesh | GetMesh () |
| Returns the mesh. More... | |
| boolean | IsMeshInfoCorrect () |
| Returns false if GetMeshInfo() returns incorrect information that may happen if mesh data is not yet fully loaded from the file of study. More... | |
| SALOMEDS::TMPFile | GetVtkUgStream () |
| Returns mesh unstructed grid information. More... | |
| Hypothesis_Status SMESH::SMESH_Mesh::AddHypothesis | ( | in GEOM::GEOM_Object | aSubObject, |
| in SMESH_Hypothesis | anHyp, | ||
| out string | anErrorText | ||
| raises | ( | SALOME::SALOME_Exception | |
Actual job of meshing the shape is done by SMESH_Gen::Compute() @params
| double_array SMESH::SMESH_Mesh::BaryCenter | ( | in smIdType | id | ) |
| void SMESH::SMESH_Mesh::Clear | ( | ) | ||
| raises | ( | SALOME::SALOME_Exception | ||
| void SMESH::SMESH_Mesh::ClearLog | ( | ) | ||
Must be used immediately after GetLog if clearAfterGet is false.
| void SMESH::SMESH_Mesh::ClearSubMesh | ( | in long | ShapeID | ) | |
| raises | ( | SALOME::SALOME_Exception | |||
| SMESH_Group SMESH::SMESH_Mesh::ConvertToStandalone | ( | in SMESH_GroupBase | theGroupOn | ) | |
| SMESH_Group SMESH::SMESH_Mesh::CreateDimGroup | ( | in ListOfIDSources | aListOfGroups, |
| in ElementType | anElemType, | ||
| in string | name, | ||
| in NB_COMMON_NODES_ENUM | nbCommonNodes, | ||
| in boolean | underlyingOnly | ||
| [in] | aListOfGroups | - list of either groups, sub-meshes or filters. |
| [in] | anElemType | - a type of elements to include to the new group. |
| [in] | name | - a name of the new group. |
| [in] | nbCommonNodes | - criterion of inclusion of an element to the new group. |
| [in] | underlyingOnly | - if True, an element is included to the new group provided that it is based on nodes of an element of aListOfGroups |
| SMESH_Group SMESH::SMESH_Mesh::CreateGroup | ( | in ElementType | elem_type, |
| in string | name | ||
Create a group.
| SMESH_GroupOnFilter SMESH::SMESH_Mesh::CreateGroupFromFilter | ( | in ElementType | elemType, |
| in SMESH::Filter | filter | ||
| SMESH_GroupOnGeom SMESH::SMESH_Mesh::CreateGroupFromGEOM | ( | in ElementType | elemType, |
| in GEOM::GEOM_Object | geomObject | ||
| SMESH_Group SMESH::SMESH_Mesh::CutGroups | ( | in SMESH_GroupBase | aMainGroup, |
| in SMESH_GroupBase | aToolGroup, | ||
All mesh elements that are present in main group but do not present in tool group are added to the new one
| SMESH_Group SMESH::SMESH_Mesh::CutListOfGroups | ( | in ListOfGroups | aMainGroups, |
| in ListOfGroups | aToolGroups, | ||
All mesh elements that are present in main groups but do not present in tool groups are added to the new one
| string SMESH::SMESH_Mesh::Dump | ( | ) |
| long SMESH::SMESH_Mesh::ElemNbEdges | ( | in smIdType | id | ) |
| long SMESH::SMESH_Mesh::ElemNbFaces | ( | in smIdType | id | ) |
| void SMESH::SMESH_Mesh::ExportCGNS | ( | in SMESH_IDSource | meshPart, |
| in string | file, | ||
| in boolean | overwrite, | ||
| in boolean | groupElemsByType | ||
| void SMESH::SMESH_Mesh::ExportDAT | ( | in string | file, |
| in boolean | renumer | ||
| void SMESH::SMESH_Mesh::ExportGMF | ( | in SMESH_IDSource | meshPart, |
| in boolean | withRequiredGroups | ||
| void SMESH::SMESH_Mesh::ExportMED | ( | in string | fileName, |
| in boolean | auto_groups, | ||
| in long | version, | ||
| in boolean | autoDimension | ||
@params
true, a space dimension of a MED mesh can be either
| long long SMESH::SMESH_Mesh::ExportMEDCoupling | ( | in boolean | auto_groups, |
| void SMESH::SMESH_Mesh::ExportPartToDAT | ( | in SMESH_IDSource | meshPart, |
| void SMESH::SMESH_Mesh::ExportPartToMED | ( | in SMESH_IDSource | meshPart, |
| in string | fileName, | ||
| in boolean | autoDimension, | ||
| in GEOM::ListOfFields | fields, | ||
| in string | geomAssocFields, | ||
| in double | ZTolerance, | ||
| in boolean | saveNumbers | ||
True, a space dimension for export is defined by mesh configuration; for example a planar mesh lying on XOY plane will be exported as a mesh in 2D space. If autoDimension == False, the space dimension is 3.| long long SMESH::SMESH_Mesh::ExportPartToMEDCoupling | ( | in SMESH_IDSource | meshPart, |
| void SMESH::SMESH_Mesh::ExportPartToMESHIO | ( | in SMESH_IDSource | meshPart, |
| in string | selectedFilter, | ||
| in string | converter | ||
| void SMESH::SMESH_Mesh::ExportPartToSTL | ( | in SMESH_IDSource | meshPart, |
| in boolean | isascii | ||
| void SMESH::SMESH_Mesh::ExportPartToUNV | ( | in SMESH_IDSource | meshPart, |
| void SMESH::SMESH_Mesh::ExportSTL | ( | in string | file, |
| void SMESH::SMESH_Mesh::ExportStructuredCGNS | ( | in SMESH_IDSource | meshPart, |
| in boolean | overwrite | ||
| void SMESH::SMESH_Mesh::ExportUNV | ( | in string | file, |
| ListOfGroups SMESH::SMESH_Mesh::FaceGroupsSeparatedByEdges | ( | in double | sharpAngle, |
| in boolean | createEdges, | ||
| in boolean | useExistingEdges | ||
| [in] | sharpAngle | - edge is considered sharp if an angle between normals of adjacent faces is more than sharpAngle in degrees. |
| [in] | createEdges | - to create 1D elements for detected sharp edges. |
| [in] | useExistingEdges | - to use existing edges as group boundaries |
| smIdType SMESH::SMESH_Mesh::FindElementByNodes | ( | in smIdType_array | nodes | ) |
| boolean SMESH::SMESH_Mesh::GetAutoColor | ( | ) | ||
| double SMESH::SMESH_Mesh::GetBallDiameter | ( | in smIdType | id | ) |
| double SMESH::SMESH_Mesh::GetComputeProgress | ( | ) |
| EntityType SMESH::SMESH_Mesh::GetElementGeomType | ( | in smIdType | id | ) | |
| ElementPosition SMESH::SMESH_Mesh::GetElementPosition | ( | in smIdType | ElemID | ) |
| smIdType_array SMESH::SMESH_Mesh::GetElementsByNodes | ( | in smIdType_array | nodes, |
| in ElementType | elem_type | ||
| smIdType_array SMESH::SMESH_Mesh::GetElementsByType | ( | in ElementType | theType | ) | |
| GeometryType SMESH::SMESH_Mesh::GetElementShape | ( | in smIdType | id | ) | |
| smIdType_array SMESH::SMESH_Mesh::GetElementsId | ( | ) | ||
| ElementType SMESH::SMESH_Mesh::GetElementType | ( | in smIdType | id, |
| in boolean | iselem | ||
| smIdType_array SMESH::SMESH_Mesh::GetElemFaceNodes | ( | in smIdType | elemId, |
| in short | faceIndex | ||
| short SMESH::SMESH_Mesh::GetElemNbNodes | ( | in smIdType | id | ) |
| smIdType SMESH::SMESH_Mesh::GetElemNode | ( | in smIdType | id, |
| in short | index | ||
| smIdType_array SMESH::SMESH_Mesh::GetElemNodes | ( | in smIdType | id | ) |
| double_array SMESH::SMESH_Mesh::GetFaceNormal | ( | in long | faceId, |
| in boolean | normalized | ||
| ListOfGroups SMESH::SMESH_Mesh::GetGroups | ( | ) | ||
| ListOfHypothesis SMESH::SMESH_Mesh::GetHypothesisList | ( | in GEOM::GEOM_Object | aSubObject | ) | |
| long SMESH::SMESH_Mesh::GetId | ( | ) |
Referenced by findCommonFace().
| string_array SMESH::SMESH_Mesh::GetLastParameters | ( | ) |
| log_array SMESH::SMESH_Mesh::GetLog | ( | in boolean | clearAfterGet | ) | |
@params
| MedFileInfo SMESH::SMESH_Mesh::GetMEDFileInfo | ( | ) |
| long_array SMESH::SMESH_Mesh::GetMEDVersionsCompatibleForAppend | ( | ) |
Returns the mesh.
| SMESH_MeshEditor SMESH::SMESH_Mesh::GetMeshEditor | ( | ) | ||
| SMESH_MeshEditor SMESH::SMESH_Mesh::GetMeshEditPreviewer | ( | ) | ||
| submesh_array_array SMESH::SMESH_Mesh::GetMeshOrder | ( | ) |
| long long SMESH::SMESH_Mesh::GetMeshPtr | ( | ) |
Get mesh pointer.
| smIdType_array SMESH::SMESH_Mesh::GetNodeInverseElements | ( | in smIdType | id, |
| in ElementType | elemType | ||
| NodePosition SMESH::SMESH_Mesh::GetNodePosition | ( | in smIdType | NodeID | ) |
| smIdType_array SMESH::SMESH_Mesh::GetNodesId | ( | ) | ||
| double_array SMESH::SMESH_Mesh::GetNodeXYZ | ( | in smIdType | id | ) |
| string SMESH::SMESH_Mesh::GetParameters | ( | ) |
| long SMESH::SMESH_Mesh::GetShapeID | ( | in smIdType | id | ) |
| long SMESH::SMESH_Mesh::GetShapeIDForElem | ( | in smIdType | id | ) |
| GEOM::GEOM_Object SMESH::SMESH_Mesh::GetShapeToMesh | ( | ) | ||
A result should not be nil. Use HasShapeToMesh() to know if a returned shape
Referenced by StdMeshers::Cartesian3D::Grid::GetEdgesToImplement(), and StdMeshers::Cartesian3D::Grid::InitGeometry().
| SMESH_subMesh SMESH::SMESH_Mesh::GetSubMesh | ( | in GEOM::GEOM_Object | aSubObject, |
The subMesh object gives access to nodes and elements IDs. SubMesh will be used instead of Sub-shape in a next idl version to address a specific subMesh...
Referenced by StdMeshers_Cartesian_3D::Compute(), and StdMeshers_Cartesian_3D::setSubmeshesComputed().
| smIdType_array SMESH::SMESH_Mesh::GetSubMeshElementsId | ( | in long | ShapeID | ) | |
| ElementType SMESH::SMESH_Mesh::GetSubMeshElementType | ( | in long | ShapeID | ) | |
| submesh_array SMESH::SMESH_Mesh::GetSubMeshes | ( | ) | ||
| smIdType_array SMESH::SMESH_Mesh::GetSubMeshNodesId | ( | in long | ShapeID, |
| in boolean | all | ||
It's empty if the SMESH_IDSource contains no IDs
| string SMESH::SMESH_Mesh::GetVersionString | ( | in long | minor, |
| in short | nbDigits | ||
| boolean SMESH::SMESH_Mesh::HasDuplicatedGroupNamesMED | ( | ) |
Consider maximum group name length stored in MED file.
| boolean SMESH::SMESH_Mesh::HasModificationsToDiscard | ( | ) | ||
| boolean SMESH::SMESH_Mesh::HasShapeToMesh | ( | ) | ||
| SMESH_Group SMESH::SMESH_Mesh::IntersectGroups | ( | in SMESH_GroupBase | aGroup1, |
| in SMESH_GroupBase | aGroup2, | ||
All mesh elements that are present in both initial groups are added to the new one.
| SMESH_Group SMESH::SMESH_Mesh::IntersectListOfGroups | ( | in ListOfGroups | aListOfGroups, |
All mesh elements that are present in all initial groups simultaneously are added to the new one.
| boolean SMESH::SMESH_Mesh::IsComputedOK | ( | ) | ||
| boolean SMESH::SMESH_Mesh::IsLoaded | ( | ) | ||
| boolean SMESH::SMESH_Mesh::IsMediumNode | ( | in smIdType | ide, |
| in smIdType | idn | ||
| boolean SMESH::SMESH_Mesh::IsMediumNodeOfAnyElem | ( | in smIdType | idn, |
| boolean SMESH::SMESH_Mesh::IsPoly | ( | in smIdType | id | ) |
| boolean SMESH::SMESH_Mesh::IsQuadratic | ( | in smIdType | id | ) |
| boolean SMESH::SMESH_Mesh::IsUnorderedSubMesh | ( | in long | submeshID | ) |
Return true if a meshing order not yet set for a concurrent sub-mesh
| void SMESH::SMESH_Mesh::Load | ( | ) | ||
| smIdType SMESH::SMESH_Mesh::Nb0DElements | ( | ) | ||
| smIdType SMESH::SMESH_Mesh::NbBalls | ( | ) | ||
| smIdType SMESH::SMESH_Mesh::NbBiQuadQuadrangles | ( | ) | ||
| smIdType SMESH::SMESH_Mesh::NbBiQuadTriangles | ( | ) | ||
| smIdType SMESH::SMESH_Mesh::NbEdges | ( | ) | ||
| smIdType SMESH::SMESH_Mesh::NbEdgesOfOrder | ( | in ElementOrder | order | ) | |
| smIdType SMESH::SMESH_Mesh::NbElements | ( | ) | ||
| smIdType SMESH::SMESH_Mesh::NbFaces | ( | ) | ||
| smIdType SMESH::SMESH_Mesh::NbFacesOfOrder | ( | in ElementOrder | order | ) | |
| long SMESH::SMESH_Mesh::NbGroups | ( | ) | ||
| smIdType SMESH::SMESH_Mesh::NbHexagonalPrisms | ( | ) | ||
| smIdType SMESH::SMESH_Mesh::NbHexas | ( | ) | ||
| smIdType SMESH::SMESH_Mesh::NbHexasOfOrder | ( | in ElementOrder | order | ) | |
| smIdType SMESH::SMESH_Mesh::NbNodes | ( | ) | ||
Referenced by StdMeshers::Cartesian3D::Grid::InitGeometry().
| smIdType SMESH::SMESH_Mesh::NbPolygons | ( | ) | ||
| smIdType SMESH::SMESH_Mesh::NbPolygonsOfOrder | ( | in ElementOrder | order | ) | |
| smIdType SMESH::SMESH_Mesh::NbPolyhedrons | ( | ) | ||
| smIdType SMESH::SMESH_Mesh::NbPrisms | ( | ) | ||
| smIdType SMESH::SMESH_Mesh::NbPrismsOfOrder | ( | in ElementOrder | order | ) | |
| smIdType SMESH::SMESH_Mesh::NbPyramids | ( | ) | ||
| smIdType SMESH::SMESH_Mesh::NbPyramidsOfOrder | ( | in ElementOrder | order | ) | |
| smIdType SMESH::SMESH_Mesh::NbQuadrangles | ( | ) | ||
| smIdType SMESH::SMESH_Mesh::NbQuadranglesOfOrder | ( | in ElementOrder | order | ) | |
| smIdType SMESH::SMESH_Mesh::NbSubMesh | ( | ) | ||
| smIdType SMESH::SMESH_Mesh::NbTetras | ( | ) | ||
| smIdType SMESH::SMESH_Mesh::NbTetrasOfOrder | ( | in ElementOrder | order | ) | |
| smIdType SMESH::SMESH_Mesh::NbTriangles | ( | ) | ||
| smIdType SMESH::SMESH_Mesh::NbTrianglesOfOrder | ( | in ElementOrder | order | ) | |
| smIdType SMESH::SMESH_Mesh::NbTriQuadraticHexas | ( | ) | ||
| smIdType SMESH::SMESH_Mesh::NbVolumes | ( | ) | ||
| smIdType SMESH::SMESH_Mesh::NbVolumesOfOrder | ( | in ElementOrder | order | ) | |
| void SMESH::SMESH_Mesh::RemoveGroup | ( | in SMESH_GroupBase | aGroup | ) | |
Remove a group.
| void SMESH::SMESH_Mesh::RemoveGroupWithContents | ( | in SMESH_GroupBase | aGroup | ) | |
| Hypothesis_Status SMESH::SMESH_Mesh::RemoveHypothesis | ( | in GEOM::GEOM_Object | aSubObject, |
| in SMESH_Hypothesis | anHyp | ||
| void SMESH::SMESH_Mesh::RemoveSubMesh | ( | in SMESH_subMesh | aSubMesh | ) | |
Remove a submesh.
| void SMESH::SMESH_Mesh::ReplaceShape | ( | in GEOM::GEOM_Object | theNewGeom | ) | |
| void SMESH::SMESH_Mesh::SetAutoColor | ( | in boolean | theAutoColor | ) | |
@params
| boolean SMESH::SMESH_Mesh::SetMeshOrder | ( | in submesh_array_array | theSubMeshArray | ) |
| void SMESH::SMESH_Mesh::SetParameters | ( | in string | theParameters | ) |
| theParameters | is a string containing the notebook variables |
| SMESH_Group SMESH::SMESH_Mesh::UnionGroups | ( | in SMESH_GroupBase | aGroup1, |
All mesh elements that are present in initial groups are added to the new one
| SMESH_Group SMESH::SMESH_Mesh::UnionListOfGroups | ( | in ListOfGroups | aListOfGroups, |
