SMESH_Group: interface of a standalone group object. More...
import"SMESH_Group.idl";
| void | Clear () |
| Clears the group's contents. More... | |
| smIdType | Add (in smIdType_array elem_ids) |
| Adds elements or nodes with specified identifiers to the group. More... | |
| smIdType | AddByPredicate (in Predicate thePredicate) |
| Adds elements or nodes that match specified predicate to the group. More... | |
| smIdType | AddFrom (in SMESH_IDSource theSource) |
| Add all elements or nodes from the specified source to the group. More... | |
| smIdType | Remove (in smIdType_array elem_ids) |
| Removes elements or nodes with specified identifiers from the group. More... | |
| smIdType | RemoveByPredicate (in Predicate thePredicate) |
| Removes elements or nodes that match specified predicate from the group. More... | |
| void | SetName (in string name) |
| Sets group name. More... | |
| string | GetName () |
| Returns group name. More... | |
| ElementType | GetType () |
| Returns group type (type of elements in the group) More... | |
| smIdType | Size () |
| Returns the number of elements in the group. More... | |
| boolean | IsEmpty () |
| Returns true if the group does not contain any elements. More... | |
| boolean | Contains (in smIdType elem_id) |
| returns true if the group contains an element with ID == <elem_id> More... | |
| smIdType | GetID (in smIdType elem_index) |
| Returns ID of an element at position <elem_index> counted from 1. More... | |
| smIdType_array | GetListOfID () |
| Returns a sequence of all element IDs in the group. More... | |
| smIdType | GetNumberOfNodes () |
| Get the number of nodes of cells included to the group For a nodal group returns the same value as Size() function. More... | |
| smIdType_array | GetNodeIDs () |
| Get IDs of nodes of cells included to the group For a nodal group returns result of GetListOfID() function. More... | |
| boolean | IsNodeInfoAvailable () |
| Return true if GetNumberOfNodes() won't take a long time for computation. More... | |
| void | SetColor (in SALOMEDS::Color theColor) |
| Sets group color. More... | |
| SALOMEDS::Color | GetColor () |
| Returns group color. More... | |
| void | SetColorNumber (in long color) |
| Sets group color number (corresponds to the "hue" parameter of the color - must be in range [0, 360]) More... | |
| long | GetColorNumber () |
| Returns group color number (obsolete - use GetColor instead) (corresponds to the "hue" parameter of the color - must be in range [0, 360]) More... | |
| boolean | IsInDependency (in SMESH_GroupBase other) |
Returns true if this group depends on the other via FT_BelongToMeshGroup predicate or vice versa. More... | |
| smIdType_array | GetIDs () |
| Returns a sequence of all element IDs. More... | |
| smIdType_array | GetMeshInfo () |
| Returns number of mesh elements of each EntityType. More... | |
| smIdType_array | GetNbElementsByType () |
| Returns number of mesh elements of each ElementType. More... | |
| array_of_ElementType | GetTypes () |
| Returns types of elements it contains. More... | |
| SMESH_Mesh | GetMesh () |
| Returns the mesh. More... | |
| boolean | IsMeshInfoCorrect () |
| Returns false if GetMeshInfo() returns incorrect information that may happen if mesh data is not yet fully loaded from the file of study. More... | |
| SALOMEDS::TMPFile | GetVtkUgStream () |
| Returns mesh unstructed grid information. More... | |
| smIdType SMESH::SMESH_Group::Add | ( | in smIdType_array | elem_ids | ) |
| smIdType SMESH::SMESH_Group::AddByPredicate | ( | in Predicate | thePredicate | ) |
| smIdType SMESH::SMESH_Group::AddFrom | ( | in SMESH_IDSource | theSource | ) |
| void SMESH::SMESH_Group::Clear | ( | ) |
Returns the mesh.
Returns group name.
It's empty if the SMESH_IDSource contains no IDs
| smIdType SMESH::SMESH_Group::Remove | ( | in smIdType_array | elem_ids | ) |
| smIdType SMESH::SMESH_Group::RemoveByPredicate | ( | in Predicate | thePredicate | ) |
Sets group color.
Sets group name.
