SMESH::SMESH_subMesh Interface Reference
import"SMESH_Mesh.idl";
Inheritance diagram for SMESH::SMESH_subMesh:
smIdType GetNumberOfElements () raises (SALOME::SALOME_Exception)
smIdType GetNumberOfNodes (in boolean all) raises (SALOME::SALOME_Exception)
smIdType_array GetElementsId () raises (SALOME::SALOME_Exception)
smIdType_array GetElementsByType (in ElementType theType) raises (SALOME::SALOME_Exception)
ElementType GetElementType (in smIdType id, in boolean iselem) raises (SALOME::SALOME_Exception)
 Returns type of mesh element (same as SMESH_Mesh::GetElementType() ) More...
smIdType_array GetNodesId () raises (SALOME::SALOME_Exception)
GEOM::GEOM_Object GetSubShape () raises (SALOME::SALOME_Exception)
 Get geom shape the submesh is dedicated to. More...
SMESH_Mesh GetFather () raises (SALOME::SALOME_Exception)
 Get SMESH_Mesh which stores nodes coordinates & elements definition. More...
long GetId ()
 Get the internal persistent Id. More...
smIdType_array GetIDs ()
smIdType_array GetMeshInfo ()
 Returns number of mesh elements of each EntityType. More...
smIdType_array GetNbElementsByType ()
array_of_ElementType GetTypes ()
SMESH_Mesh GetMesh ()
 Returns the mesh. More...
boolean IsMeshInfoCorrect ()
SALOMEDS::TMPFile GetVtkUgStream ()
◆ GetElementsByType()
smIdType_array SMESH::SMESH_subMesh::GetElementsByType ( in ElementType  theType)
◆ GetElementsId()
smIdType_array SMESH::SMESH_subMesh::GetElementsId ( )
◆ GetElementType()
ElementType SMESH::SMESH_subMesh::GetElementType ( in smIdType  id,
in boolean  iselem
◆ GetFather()
SMESH_Mesh SMESH::SMESH_subMesh::GetFather ( )
◆ GetId()
long SMESH::SMESH_subMesh::GetId ( )
◆ GetIDs()
smIdType_array SMESH::SMESH_IDSource::GetIDs ( )
◆ GetMesh()
SMESH_Mesh SMESH::SMESH_IDSource::GetMesh ( )
Returns the mesh.
◆ GetMeshInfo()
smIdType_array SMESH::SMESH_IDSource::GetMeshInfo ( )
array of number of elements per EntityType
◆ GetNbElementsByType()
smIdType_array SMESH::SMESH_IDSource::GetNbElementsByType ( )
array of number of elements per ElementType
◆ GetNodesId()
smIdType_array SMESH::SMESH_subMesh::GetNodesId ( )
◆ GetNumberOfElements()
smIdType SMESH::SMESH_subMesh::GetNumberOfElements ( )
◆ GetNumberOfNodes()
smIdType SMESH::SMESH_subMesh::GetNumberOfNodes ( in boolean  all)
◆ GetSubShape()
GEOM::GEOM_Object SMESH::SMESH_subMesh::GetSubShape ( )
◆ GetTypes()
array_of_ElementType SMESH::SMESH_IDSource::GetTypes ( )
It's empty if the SMESH_IDSource contains no IDs
◆ GetVtkUgStream()
SALOMEDS::TMPFile SMESH::SMESH_IDSource::GetVtkUgStream ( )
◆ IsMeshInfoCorrect()
boolean SMESH::SMESH_IDSource::IsMeshInfoCorrect ( )
