SMESH::SMESH_GroupOnGeom Interface Reference
SMESH_GroupOnGeom: interface of a group object linked to geometry. More...
import"SMESH_Group.idl";
Inheritance diagram for SMESH::SMESH_GroupOnGeom:
GEOM::GEOM_Object GetShape ()
void SetName (in string name)
 Sets group name. More...
string GetName ()
 Returns group name. More...
ElementType GetType ()
 Returns group type (type of elements in the group) More...
smIdType Size ()
 Returns the number of elements in the group. More...
boolean IsEmpty ()
 Returns true if the group does not contain any elements. More...
boolean Contains (in smIdType elem_id)
 returns true if the group contains an element with ID == <elem_id> More...
smIdType GetID (in smIdType elem_index)
 Returns ID of an element at position <elem_index> counted from 1. More...
smIdType_array GetListOfID ()
 Returns a sequence of all element IDs in the group. More...
smIdType GetNumberOfNodes ()
 Get the number of nodes of cells included to the group For a nodal group returns the same value as Size() function. More...
smIdType_array GetNodeIDs ()
 Get IDs of nodes of cells included to the group For a nodal group returns result of GetListOfID() function. More...
boolean IsNodeInfoAvailable ()
 Return true if GetNumberOfNodes() won't take a long time for computation. More...
void SetColor (in SALOMEDS::Color theColor)
 Sets group color. More...
SALOMEDS::Color GetColor ()
 Returns group color. More...
void SetColorNumber (in long color)
 Sets group color number (corresponds to the "hue" parameter of the color - must be in range [0, 360]) More...
long GetColorNumber ()
 Returns group color number (obsolete - use GetColor instead) (corresponds to the "hue" parameter of the color - must be in range [0, 360]) More...
boolean IsInDependency (in SMESH_GroupBase other)
 Returns true if this group depends on the other via FT_BelongToMeshGroup predicate or vice versa. More...
smIdType_array GetIDs ()
smIdType_array GetMeshInfo ()
 Returns number of mesh elements of each EntityType. More...
smIdType_array GetNbElementsByType ()
array_of_ElementType GetTypes ()
SMESH_Mesh GetMesh ()
 Returns the mesh. More...
boolean IsMeshInfoCorrect ()
SALOMEDS::TMPFile GetVtkUgStream ()
◆ Contains()
boolean SMESH::SMESH_GroupBase::Contains ( in smIdType  elem_id)
◆ GetColor()
SALOMEDS::Color SMESH::SMESH_GroupBase::GetColor ( )
◆ GetColorNumber()
long SMESH::SMESH_GroupBase::GetColorNumber ( )
◆ GetID()
smIdType SMESH::SMESH_GroupBase::GetID ( in smIdType  elem_index)
◆ GetIDs()
smIdType_array SMESH::SMESH_IDSource::GetIDs ( )
◆ GetListOfID()
smIdType_array SMESH::SMESH_GroupBase::GetListOfID ( )
◆ GetMesh()
SMESH_Mesh SMESH::SMESH_IDSource::GetMesh ( )
Returns the mesh.
◆ GetMeshInfo()
smIdType_array SMESH::SMESH_IDSource::GetMeshInfo ( )
array of number of elements per EntityType
◆ GetName()
string SMESH::SMESH_GroupBase::GetName ( )
Returns group name.
◆ GetNbElementsByType()
smIdType_array SMESH::SMESH_IDSource::GetNbElementsByType ( )
array of number of elements per ElementType
◆ GetNodeIDs()
smIdType_array SMESH::SMESH_GroupBase::GetNodeIDs ( )
◆ GetNumberOfNodes()
smIdType SMESH::SMESH_GroupBase::GetNumberOfNodes ( )
◆ GetShape()
GEOM::GEOM_Object SMESH::SMESH_GroupOnGeom::GetShape ( )
◆ GetType()
ElementType SMESH::SMESH_GroupBase::GetType ( )
◆ GetTypes()
array_of_ElementType SMESH::SMESH_IDSource::GetTypes ( )
It's empty if the SMESH_IDSource contains no IDs
◆ GetVtkUgStream()
SALOMEDS::TMPFile SMESH::SMESH_IDSource::GetVtkUgStream ( )
◆ IsEmpty()
boolean SMESH::SMESH_GroupBase::IsEmpty ( )
◆ IsInDependency()
boolean SMESH::SMESH_GroupBase::IsInDependency ( in SMESH_GroupBase  other)
◆ IsMeshInfoCorrect()
boolean SMESH::SMESH_IDSource::IsMeshInfoCorrect ( )
◆ IsNodeInfoAvailable()
boolean SMESH::SMESH_GroupBase::IsNodeInfoAvailable ( )
◆ SetColor()
void SMESH::SMESH_GroupBase::SetColor ( in SALOMEDS::Color  theColor)
Sets group color.
◆ SetColorNumber()
void SMESH::SMESH_GroupBase::SetColorNumber ( in long  color)
◆ SetName()
void SMESH::SMESH_GroupBase::SetName ( in string  name)
Sets group name.
◆ Size()
smIdType SMESH::SMESH_GroupBase::Size ( )
