SMESH::SMESH_Gen Interface Reference
import"SMESH_Gen.idl";
Inheritance diagram for SMESH::SMESH_Gen:
void SetGeomEngine (in GEOM::GEOM_Gen geomcompo)
FilterManager CreateFilterManager ()
SMESH_Pattern GetPattern ()
Measurements CreateMeasurements ()
void SetEmbeddedMode (in boolean theMode)
 Set the current mode. More...
boolean IsEmbeddedMode ()
 Get the current mode. More...
void UpdateStudy ()
 Update the study. More...
void SetEnablePublish (in boolean theIsEnablePublish)
 Set enable publishing in the study. More...
boolean IsEnablePublish ()
 Get enable publishing in the study. More...
SMESH_Hypothesis CreateHypothesis (in string theHypName, in string theLibName) raises ( SALOME::SALOME_Exception )
 Create a hypothesis that can be shared by different parts of the mesh. More...
SMESH_Hypothesis CreateHypothesisByAverageLength (in string theHypName, in string theLibName, in double theAverageLength, in boolean theQuadDominated) raises ( SALOME::SALOME_Exception )
 Create a hypothesis and initialize it by average length. More...
SMESH_Hypothesis GetHypothesisParameterValues (in string theHypName, in string theLibName, in SMESH_Mesh theMesh, in GEOM::GEOM_Object theGeom, in HypInitParams theWay) raises ( SALOME::SALOME_Exception )
 Return a hypothesis holding parameter values corresponding either to the mesh existing on the given geometry or to size of the geometry. More...
boolean GetSoleSubMeshUsingHyp (in SMESH_Hypothesis theHyp, out SMESH_Mesh theMesh, out GEOM::GEOM_Object theShape)
 Returns True if a hypothesis is assigned to a sole sub-mesh in a current Study. More...
void SetBoundaryBoxSegmentation (in long theNbSegments) raises ( SALOME::SALOME_Exception )
 Sets number of segments per diagonal of boundary box of geometry by which default segment length of appropriate 1D hypotheses is defined. More...
void SetDefaultNbSegments (in long theNbSegments) raises ( SALOME::SALOME_Exception )
 Sets default number of segments per edge. More...
void SetName (in string theObjectIOR, in string theObjectName) raises ( SALOME::SALOME_Exception )
 Set the object name. More...
void PausePythonDumpRecording ()
 Pauses the Python dump recording. More...
void ResumePythonDumpRecording ()
 Resumes Python dump recording. More...
void AddToPythonScript (in string theCommand)
 Manually add a command to the Python dump script. More...
SMESH_Mesh CreateMesh (in GEOM::GEOM_Object theObject) raises ( SALOME::SALOME_Exception )
 Create a Mesh object, given a geometry shape. More...
SMESH_ParallelMesh CreateParallelMesh (in GEOM::GEOM_Object theObject) raises ( SALOME::SALOME_Exception )
SMESH_Mesh CreateEmptyMesh () raises ( SALOME::SALOME_Exception )
 Create an empty mesh object. More...
SMESH_Mesh ReloadMeshFromFile (in SMESH_Mesh sourceMesh) raises (SALOME::SALOME_Exception)
SMESH_Mesh CreateMeshesFromUNV (in string theFileName) raises ( SALOME::SALOME_Exception )
 Create Mesh object importing data from given UNV file (UNV supported version is I-DEAS 10) More...
mesh_array CreateMeshesFromMED (in string theFileName, out SMESH::DriverMED_ReadStatus theStatus) raises ( SALOME::SALOME_Exception )
 Create Mesh object(s) importing data from given MED file. More...
mesh_array CreateMeshesFromMAIL (in string theFileName, out SMESH::DriverMED_ReadStatus theStatus) raises ( SALOME::SALOME_Exception )
 Create Mesh object(s) importing data from given MAIL file. More...
mesh_array CreateMeshesFromINP (in string theFileName, out SMESH::DriverMED_ReadStatus theStatus) raises ( SALOME::SALOME_Exception )
 Create Mesh object(s) importing data from given INP (abaqus) file. More...
mesh_array CreateMeshesFromCDB (in string theFileName, out SMESH::DriverMED_ReadStatus theStatus) raises ( SALOME::SALOME_Exception )
 Create Mesh object(s) importing data from given CDB (ansys) file. More...
mesh_array CreateMeshesFromASC (in string theFileName, out SMESH::DriverMED_ReadStatus theStatus) raises ( SALOME::SALOME_Exception )
 Create Mesh object(s) importing data from given ASC (systus) file. More...
mesh_array CreateMeshesFromGEOF (in string theFileName, out SMESH::DriverMED_ReadStatus theStatus) raises ( SALOME::SALOME_Exception )
 Create Mesh object(s) importing data from given GEOF (zset) file. More...
SMESH_Mesh CreateMeshesFromSTL (in string theFileName) raises ( SALOME::SALOME_Exception )
 Create Mesh object importing data from given STL file. More...
mesh_array CreateMeshesFromCGNS (in string theFileName, out SMESH::DriverMED_ReadStatus theStatus) raises ( SALOME::SALOME_Exception )
 Create Mesh object(s) importing data from given CGNS file. More...
SMESH_Mesh CreateMeshesFromGMF (in string theFileName, in boolean theMakeRequiredGroups, out SMESH::ComputeError theError) raises ( SALOME::SALOME_Exception )
 Create Mesh object importing data from given GMF file. More...
mesh_array CreateMeshesFromMESHIO (in string theFileName, out SMESH::DriverMED_ReadStatus theStatus, in string selectedFilter, in string converter) raises (SALOME::SALOME_Exception)
 Create a mesh and import data from any file supported by meshio library. More...
SMESH_Mesh CreateDualMesh (in SMESH_IDSource mesh, in string meshName, in boolean adaptToShape) raises ( SALOME::SALOME_Exception )
 Create a dual mesh of a Tetrahedron mesh. More...
SMESH_Mesh CopyMesh (in SMESH_IDSource meshPart, in string meshName, in boolean toCopyGroups, in boolean toKeepIDs) raises ( SALOME::SALOME_Exception )
 Create a mesh by copying a part of another mesh. More...
boolean CopyMeshWithGeom (in SMESH_Mesh sourceMesh, in GEOM::GEOM_Object newGeometry, in string meshName, in boolean toCopyGroups, in boolean toReuseHypotheses, in boolean toCopyElements, out SMESH_Mesh newMesh, out ListOfGroups newGroups, out submesh_array newSubmeshes, out ListOfHypothesis newHypotheses, out string_array invalidEntries) raises ( SALOME::SALOME_Exception )
 Create a mesh by copying definitions of another mesh to a given geometry. More...
SMESH_Mesh Concatenate (in ListOfIDSources theMeshesArray, in boolean theUniteIdenticalGroups, in boolean theMergeNodesAndElements, in double theMergeTolerance, in SMESH_Mesh theMeshToAppendTo) raises ( SALOME::SALOME_Exception )
 Concatenate the given meshes or groups into one mesh, optionally to theMeshToAppendTo. More...
SMESH_Mesh ConcatenateWithGroups (in ListOfIDSources theMeshesArray, in boolean theUniteIdenticalGroups, in boolean theMergeNodesAndElements, in double theMergeTolerance, in SMESH_Mesh theMeshToAppendTo) raises ( SALOME::SALOME_Exception )
 Concatenate the given meshes into one mesh, optionally to theMeshToAppendTo. More...
boolean Compute (in SMESH_Mesh theMesh, in GEOM::GEOM_Object theSubObject) raises ( SALOME::SALOME_Exception )
 Mesh a subShape. More...
void CancelCompute (in SMESH_Mesh theMesh, in GEOM::GEOM_Object theSubObject)
 Cancel a computation. More...
boolean IsReadyToCompute (in SMESH_Mesh theMesh, in GEOM::GEOM_Object theSubObject) raises ( SALOME::SALOME_Exception )
 Return true if hypotheses are defined well. More...
smIdType_array Evaluate (in SMESH_Mesh theMesh, in GEOM::GEOM_Object theSubObject) raises ( SALOME::SALOME_Exception )
 Evaluates size of prospective mesh on a shape. More...
MeshPreviewStruct Precompute (in SMESH_Mesh theMesh, in GEOM::GEOM_Object theSubObject, in Dimension theDimension, inout long_array theShapesId) raises ( SALOME::SALOME_Exception )
 Calculate Mesh as preview till indicated dimension First, verify list of hypothesis associated with the Sub-shape. More...
algo_error_array GetAlgoState (in SMESH_Mesh theMesh, in GEOM::GEOM_Object theSubObject) raises ( SALOME::SALOME_Exception )
 Return errors of hypotheses definition algo_error_array is empty if everything is OK. More...
compute_error_array GetComputeErrors (in SMESH_Mesh theMesh, in GEOM::GEOM_Object theSubObject) raises ( SALOME::SALOME_Exception )
 Return errors of mesh computation compute_error_array is empty if everything is OK. More...
MeshPreviewStruct GetBadInputElements (in SMESH_Mesh theMesh, in short theSubShapeID) raises ( SALOME::SALOME_Exception )
 Return mesh elements preventing computation of a sub-shape. More...
SMESH::ListOfGroups MakeGroupsOfBadInputElements (in SMESH_Mesh theMesh, in short theSubShapeID, in string theGroupName) raises ( SALOME::SALOME_Exception )
 Create groups of elements preventing computation of a sub-shape. More...
long_array GetSubShapesId (in GEOM::GEOM_Object theMainObject, in object_array theListOfSubObjects) raises ( SALOME::SALOME_Exception )
 Return indices of faces, edges and vertices of given sub-shapes within theMainObject. More...
GEOM::GEOM_Object GetGeometryByMeshElement (in SMESH_Mesh theMesh, in smIdType theElementID, in string theGeomName) raises ( SALOME::SALOME_Exception )
 Return geometrical object the given element is built on. More...
GEOM::GEOM_Object FindGeometryByMeshElement (in SMESH_Mesh theMesh, in smIdType theElementID) raises ( SALOME::SALOME_Exception )
long GetObjectId (in Object theObject)
 Return id of object, registered in current study context. More...
string GetMEDFileVersion ()
 Get version of MED format being used. More...
string GetMEDVersion (in string theFileName)
 Get MED version of the file by its name. More...
boolean CheckCompatibility (in string theFileName)
 Check compatibility of file with MED format being used, for read only. More...
boolean CheckWriteCompatibility (in string theFileName)
 Check compatibility of file with MED format being used, for append on write. More...
string_array GetMeshNames (in string theFileName)
 Get names of meshes defined in file with the specified name. More...
void Move (in sobject_list what, in SALOMEDS::SObject where, in long row)
 Moves objects to the specified position. More...
boolean IsApplicable (in string theAlgoType, in string theLibName, in GEOM::GEOM_Object theShapeObject, in boolean toCheckAll)
 Returns true if algorithm can be used to mesh a given geometry. More...
long_array GetInsideSphere (in SMESH_IDSource theSource, in ElementType theElemType, in double theX, in double theY, in double theZ, in double theR)
 Return indices of elements, which are located inside the sphere. More...
long_array GetInsideBox (in SMESH_IDSource theSource, in ElementType theElemType, in double theX1, in double theY1, in double theZ1, in double theX2, in double theY2, in double theZ2)
 Return indices of elements, which are located inside the box. More...
long_array GetInsideCylinder (in SMESH_IDSource theSource, in ElementType theElemType, in double theX, in double theY, in double theZ, in double theDX, in double theDY, in double theDZ, in double theH, in double theR)
long_array GetInside (in SMESH_IDSource theSource, in ElementType theElemType, in GEOM::GEOM_Object theGeom, in double theTolerance)
 Return indices of elements, which are located inside the geometry. More...
MG_ADAPT CreateMG_ADAPT ()
SMESHHOMARD::HOMARD_Gen CreateHOMARD_ADAPT () raises ( SALOME::SALOME_Exception )
SALOME::GenericObj Adaptation (in string adaptType) raises ( SALOME::SALOME_Exception )
MG_ADAPT CreateAdaptationHypothesis ()
◆ Adaptation()
SALOME::GenericObj SMESH::SMESH_Gen::Adaptation ( in string  adaptType)
◆ AddToPythonScript()
void SMESH::SMESH_Gen::AddToPythonScript ( in string  theCommand)
Used for Python plugins and scripts that need to record their operations in Python dump. Example: smesh.AddToPythonScript("# Some operation") smesh.AddToPythonScript("result = myPlugin.Process(mesh1, mesh2)")
theCommandThe Python command to add (valid Python statement)
No automatic newlines are added - include them if needed.
◆ CancelCompute()
void SMESH::SMESH_Gen::CancelCompute ( in SMESH_Mesh  theMesh,
◆ CheckCompatibility()
boolean SMESH::SMESH_Gen::CheckCompatibility ( in string  theFileName)
◆ CheckWriteCompatibility()
boolean SMESH::SMESH_Gen::CheckWriteCompatibility ( in string  theFileName)
◆ Compute()
boolean SMESH::SMESH_Gen::Compute ( in SMESH_Mesh  theMesh,
Mesh a subShape.
First, verify list of hypothesis associated with the Sub-shape, return NOK if hypothesis are not sufficient
◆ Concatenate()
SMESH_Mesh SMESH::SMESH_Gen::Concatenate ( in ListOfIDSources  theMeshesArray,
Union groups with the same name and type if theUniteIdenticalGroups flag is true. Merge coincident nodes and elements if theMergeNodesAndElements flag is true.
◆ ConcatenateWithGroups()
SMESH_Mesh SMESH::SMESH_Gen::ConcatenateWithGroups ( in ListOfIDSources  theMeshesArray,
Union groups with the same name and type if theUniteIdenticalGroups flag is true. Merge coincident nodes and elements if theMergeNodesAndElements flag is true. Create the groups of all elements from initial meshes.
◆ CopyMesh()
SMESH_Mesh SMESH::SMESH_Gen::CopyMesh ( in SMESH_IDSource  meshPart,
in string  meshName,
meshPart- a part of mesh to copy
meshName- a name of the new mesh
toCopyGroups- to create in the new mesh groups the copied elements belongs to
toKeepIDs- to preserve IDs of the copied elements or not
◆ CopyMeshWithGeom()
boolean SMESH::SMESH_Gen::CopyMeshWithGeom ( in SMESH_Mesh  sourceMesh,
in string  meshName,
sourceMesh- a mesh to copy
newGeometry- a new geometry
toCopyGroups- to create groups in the new mesh
toReuseHypotheses- if True, existing hypothesis will be used by the new mesh, otherwise new hypotheses with the same parameters will be created for the new mesh.
toCopyElements- to copy mesh elements of same sub-shapes of the two geometries
newMesh- return a new mesh
newGroups- return new groups
newSubmeshes- return new sub-meshes
newHypotheses- return new algorithms and hypotheses
invalidEntries- return study entries of objects whose counterparts are not found in the newGeometry, followed by entries of mesh sub-objects that are invalid because they depend on a not found preceding sub-shape
◆ CreateAdaptationHypothesis()
MG_ADAPT SMESH::SMESH_Gen::CreateAdaptationHypothesis ( )
◆ CreateDualMesh()
SMESH_Mesh SMESH::SMESH_Gen::CreateDualMesh ( in SMESH_IDSource  mesh,
in string  meshName,
mesh- TetraHedron mesh to create dual from
adaptToShape- if True project boundary point on shape
◆ CreateEmptyMesh()
SMESH_Mesh SMESH::SMESH_Gen::CreateEmptyMesh ( )
◆ CreateFilterManager()
FilterManager SMESH::SMESH_Gen::CreateFilterManager ( )
◆ CreateHOMARD_ADAPT()
SMESHHOMARD::HOMARD_Gen SMESH::SMESH_Gen::CreateHOMARD_ADAPT ( )
◆ CreateHypothesis()
SMESH_Hypothesis SMESH::SMESH_Gen::CreateHypothesis ( in string  theHypName,
An hypothesis is either:
  • a method used to generate or modify a part of the mesh (algorithm).
  • a parameter or a law used by an algorithm. Algorithms are 1D, 2D or 3D.
◆ CreateHypothesisByAverageLength()
SMESH_Hypothesis SMESH::SMESH_Gen::CreateHypothesisByAverageLength ( in string  theHypName,
◆ CreateMeasurements()
Measurements SMESH::SMESH_Gen::CreateMeasurements ( )
◆ CreateMesh()
SMESH_Mesh SMESH::SMESH_Gen::CreateMesh ( in GEOM::GEOM_Object  theObject)
Mesh is created empty (no points, no elements). Shape is explored via GEOM_Client to create local copies. of TopoDS_Shapes and bind CORBA references of shape & subshapes with TopoDS_Shapes
◆ CreateMeshesFromASC()
mesh_array SMESH::SMESH_Gen::CreateMeshesFromASC ( in string  theFileName,
◆ CreateMeshesFromCDB()
mesh_array SMESH::SMESH_Gen::CreateMeshesFromCDB ( in string  theFileName,
◆ CreateMeshesFromCGNS()
mesh_array SMESH::SMESH_Gen::CreateMeshesFromCGNS ( in string  theFileName,
◆ CreateMeshesFromGEOF()
mesh_array SMESH::SMESH_Gen::CreateMeshesFromGEOF ( in string  theFileName,
◆ CreateMeshesFromGMF()
SMESH_Mesh SMESH::SMESH_Gen::CreateMeshesFromGMF ( in string  theFileName,
theFileName- a name of file to import
theMakeRequiredGroups- if true, groups of required entities will be created
◆ CreateMeshesFromINP()
mesh_array SMESH::SMESH_Gen::CreateMeshesFromINP ( in string  theFileName,
◆ CreateMeshesFromMAIL()
mesh_array SMESH::SMESH_Gen::CreateMeshesFromMAIL ( in string  theFileName,
◆ CreateMeshesFromMED()
mesh_array SMESH::SMESH_Gen::CreateMeshesFromMED ( in string  theFileName,
◆ CreateMeshesFromMESHIO()
mesh_array SMESH::SMESH_Gen::CreateMeshesFromMESHIO ( in string  theFileName,
in string  converter
◆ CreateMeshesFromSTL()
SMESH_Mesh SMESH::SMESH_Gen::CreateMeshesFromSTL ( in string  theFileName)
◆ CreateMeshesFromUNV()
SMESH_Mesh SMESH::SMESH_Gen::CreateMeshesFromUNV ( in string  theFileName)
◆ CreateMG_ADAPT()
MG_ADAPT SMESH::SMESH_Gen::CreateMG_ADAPT ( )
◆ CreateParallelMesh()
SMESH_ParallelMesh SMESH::SMESH_Gen::CreateParallelMesh ( in GEOM::GEOM_Object  theObject)
Mesh is created empty (no points, no elements). Shape is explored via GEOM_Client to create local copies. of TopoDS_Shapes and bind CORBA references of shape & subshapes with TopoDS_Shapes The mesh is a parallel one
◆ Evaluate()
smIdType_array SMESH::SMESH_Gen::Evaluate ( in SMESH_Mesh  theMesh,
◆ FindGeometryByMeshElement()
GEOM::GEOM_Object SMESH::SMESH_Gen::FindGeometryByMeshElement ( in SMESH_Mesh  theMesh,
The returned geometrical object not published in study by this method.
◆ GetAlgoState()
algo_error_array SMESH::SMESH_Gen::GetAlgoState ( in SMESH_Mesh  theMesh,
◆ GetBadInputElements()
MeshPreviewStruct SMESH::SMESH_Gen::GetBadInputElements ( in SMESH_Mesh  theMesh,
◆ GetComputeErrors()
compute_error_array SMESH::SMESH_Gen::GetComputeErrors ( in SMESH_Mesh  theMesh,
◆ GetGeometryByMeshElement()
GEOM::GEOM_Object SMESH::SMESH_Gen::GetGeometryByMeshElement ( in SMESH_Mesh  theMesh,
The returned geometrical object, if not nil, is either found in the study or is published by this method with the given name
◆ GetHypothesisParameterValues()
SMESH_Hypothesis SMESH::SMESH_Gen::GetHypothesisParameterValues ( in string  theHypName,
The returned hypothesis may be the one existing in a study and used to compute the mesh, or a temporary one created just to pass parameter values.
◆ GetInside()
long_array SMESH::SMESH_Gen::GetInside ( in SMESH_IDSource  theSource,
theSource- mesh, sub-mesh or group
theElemType- mesh element type
theGeom- geometrical object
theTolerance- tolerance for selection.
◆ GetInsideBox()
long_array SMESH::SMESH_Gen::GetInsideBox ( in SMESH_IDSource  theSource,
in double  theX1,
in double  theY1,
in double  theZ1,
in double  theX2,
in double  theY2,
in double  theZ2
theX1- x coordinate of the first opposite point
theY1- y coordinate of the first opposite point
theZ1- y coordinate of the first opposite point
theX2- x coordinate of the second opposite point
theY2- y coordinate of the second opposite point
theZ2- y coordinate of the second opposite point
◆ GetInsideCylinder()
long_array SMESH::SMESH_Gen::GetInsideCylinder ( in SMESH_IDSource  theSource,
in double  theX,
in double  theY,
in double  theZ,
in double  theDX,
in double  theDY,
in double  theDZ,
in double  theH,
in double  theR
theX- x coordinate of the cented of the bottom face
theY- y coordinate of the cented of the bottom face
theZ- y coordinate of the cented of the bottom face
theDX- x coordinate of the cented of the base vector
theDY- y coordinate of the cented of the base vector
theDZ- z coordinate of the cented of the base vector
theH- height of the cylinder
theR- radius of the cylinder
◆ GetInsideSphere()
long_array SMESH::SMESH_Gen::GetInsideSphere ( in SMESH_IDSource  theSource,
in double  theX,
in double  theY,
in double  theZ,
in double  theR
theX- x coordinate of the center of the sphere
theY- y coordinate of the center of the sphere
theZ- y coordinate of the center of the sphere
theR- radius of the sphere
◆ GetMEDFileVersion()
string SMESH::SMESH_Gen::GetMEDFileVersion ( )
◆ GetMEDVersion()
string SMESH::SMESH_Gen::GetMEDVersion ( in string  theFileName)
◆ GetMeshNames()
string_array SMESH::SMESH_Gen::GetMeshNames ( in string  theFileName)
◆ GetObjectId()
long SMESH::SMESH_Gen::GetObjectId ( in Object  theObject)
Can be used to check if the object was created in the same container, as this engine.
◆ GetPattern()
SMESH_Pattern SMESH::SMESH_Gen::GetPattern ( )
◆ GetSoleSubMeshUsingHyp()
boolean SMESH::SMESH_Gen::GetSoleSubMeshUsingHyp ( in SMESH_Hypothesis  theHyp,
[in]theHyp- the hypothesis of interest
[out]theMesh- the sole mesh using theHyp
[out]theShape- the sole geometry theHyp is assigned to
boolean - True if theMesh and theShape are sole using theHyp
◆ GetSubShapesId()
long_array SMESH::SMESH_Gen::GetSubShapesId ( in GEOM::GEOM_Object  theMainObject,
◆ IsApplicable()
boolean SMESH::SMESH_Gen::IsApplicable ( in string  theAlgoType,
theAlgoType- the algorithm type
theLibName- a name of the Plug-in library implementing the algorithm
theShapeObject- the geometry to mesh
toCheckAll- if True, returns True if all shapes are meshable, else, returns True if at least one shape is meshable
◆ IsEmbeddedMode()
boolean SMESH::SMESH_Gen::IsEmbeddedMode ( )
◆ IsEnablePublish()
boolean SMESH::SMESH_Gen::IsEnablePublish ( )
◆ IsReadyToCompute()
boolean SMESH::SMESH_Gen::IsReadyToCompute ( in SMESH_Mesh  theMesh,
◆ MakeGroupsOfBadInputElements()
SMESH::ListOfGroups SMESH::SMESH_Gen::MakeGroupsOfBadInputElements ( in SMESH_Mesh  theMesh,
◆ Move()
void SMESH::SMESH_Gen::Move ( in sobject_list  what,
in long  row
whatobjects being moved
whereparent object where objects are moved to
rowposition in the parent object's children list at which objects are moved
This function is used in the drag-n-drop functionality.
◆ PausePythonDumpRecording()
void SMESH::SMESH_Gen::PausePythonDumpRecording ( )
Increments internal counter (TPythonDump::myCounter) While myCounter > 0, SMESH operations are not recorded to the Python dump.
Must be paired with ResumePythonDumpRecording(). Can be nested - each Pause must have corresponding Resume.
Used by SMESH Python plugins to hide intermediate operations and record only high-level commands.
◆ Precompute()
MeshPreviewStruct SMESH::SMESH_Gen::Precompute ( in SMESH_Mesh  theMesh,
Return mesh preview structure
◆ ReloadMeshFromFile()
SMESH_Mesh SMESH::SMESH_Gen::ReloadMeshFromFile ( in SMESH_Mesh  sourceMesh)
◆ ResumePythonDumpRecording()
void SMESH::SMESH_Gen::ResumePythonDumpRecording ( )
Decrements internal counter (TPythonDump::myCounter) When counter reaches 0, recording resumes. Must be paired with PausePythonDumpRecording()(). If called when counter is already 0, logs warning and does nothing.
◆ SetBoundaryBoxSegmentation()
void SMESH::SMESH_Gen::SetBoundaryBoxSegmentation ( in long  theNbSegments)
◆ SetDefaultNbSegments()
void SMESH::SMESH_Gen::SetDefaultNbSegments ( in long  theNbSegments)
◆ SetEmbeddedMode()
void SMESH::SMESH_Gen::SetEmbeddedMode ( in boolean  theMode)
◆ SetEnablePublish()
void SMESH::SMESH_Gen::SetEnablePublish ( in boolean  theIsEnablePublish)
◆ SetGeomEngine()
void SMESH::SMESH_Gen::SetGeomEngine ( in GEOM::GEOM_Gen  geomcompo)
◆ SetName()
void SMESH::SMESH_Gen::SetName ( in string  theObjectIOR,
◆ UpdateStudy()
void SMESH::SMESH_Gen::UpdateStudy ( )
Update the study.
