SMESH::SMESH_Pattern Interface Reference
SMESH_Pattern: interface of mesh pattern. More...
import"SMESH_Pattern.idl";
enum  ErrorCode {
  ERR_OK , ERR_READ_NB_POINTS , ERR_READ_POINT_COORDS , ERR_READ_TOO_FEW_POINTS ,
  ERR_READ_3D_COORD , ERR_READ_NO_KEYPOINT , ERR_READ_BAD_INDEX , ERR_READ_ELEM_POINTS ,
  ERR_READ_NO_ELEMS , ERR_READ_BAD_KEY_POINT , ERR_SAVE_NOT_LOADED , ERR_LOAD_EMPTY_SUBMESH ,
  ERR_LOADF_NARROW_FACE , ERR_LOADF_CLOSED_FACE , ERR_LOADF_CANT_PROJECT , ERR_LOADV_BAD_SHAPE ,
  ERR_LOADV_COMPUTE_PARAMS , ERR_APPL_NOT_LOADED , ERR_APPL_BAD_DIMENTION , ERR_APPL_BAD_NB_VERTICES ,
  ERR_APPLF_BAD_TOPOLOGY , ERR_APPLF_BAD_VERTEX , ERR_APPLF_INTERNAL_EEROR , ERR_APPLV_BAD_SHAPE ,
  ERR_MAKEM_NOT_COMPUTED
 error code of the last of one of above operations More...
boolean LoadFromFile (in string theFileContents)
 Load a pattern from the string <theFileContents> More...
boolean LoadFromFace (in SMESH_Mesh theMesh, in GEOM::GEOM_Object theFace, in boolean theProject)
 Create a pattern from the mesh built on <theFace>. More...
boolean LoadFrom3DBlock (in SMESH_Mesh theMesh, in GEOM::GEOM_Object theBlock)
 Create a pattern from the mesh built on <theBlock> More...
point_array ApplyToFace (in GEOM::GEOM_Object theFace, in GEOM::GEOM_Object theVertexOnKeyPoint1, in boolean theReverse)
 Compute nodes coordinates applying the loaded pattern to <theFace>. More...
point_array ApplyTo3DBlock (in GEOM::GEOM_Object theBlock, in GEOM::GEOM_Object theVertex000, in GEOM::GEOM_Object theVertex001)
 Compute nodes coordinates applying the loaded pattern to <theBlock>. More...
point_array ApplyToMeshFaces (in SMESH_Mesh theMesh, in smIdType_array theFacesIDs, in short theNodeIndexOnKeyPoint1, in boolean theReverse)
 Compute nodes coordinates applying the loaded pattern to mesh faces. More...
point_array ApplyToHexahedrons (in SMESH_Mesh theMesh, in smIdType_array theVolumesIDs, in short theNode000Index, in short theNode001Index)
 Compute nodes coordinates applying the loaded pattern to hexahedrons. More...
boolean MakeMesh (in SMESH_Mesh theMesh, in boolean CreatePolygons, in boolean CreatePolyedrs)
 Create nodes and elements in <theMesh> using nodes coordinates computed by either of Apply...() methods. More...
string GetString ()
 Return the loaded pattern in the string form to be saved in file. More...
ErrorCode GetErrorCode ()
 Return error code of the last operation. More...
boolean Is2D ()
 Return true if the loaded pattern is a 2D one. More...
point_array GetPoints ()
 Return coordinates of pattern points. More...
long_array GetKeyPoints ()
 Return indices of key-points within the arrays returned by GetPoints() More...
array_of_long_array GetElementPoints (in boolean all)
 Return nodal connectivity of the elements of the pattern or of all elements to be created. More...
◆ ErrorCode
ERR_OK
ERR_READ_NB_POINTS
ERR_READ_3D_COORD
ERR_READ_BAD_INDEX
ERR_READ_NO_ELEMS
ERR_SAVE_NOT_LOADED
ERR_LOADV_BAD_SHAPE
ERR_APPL_NOT_LOADED
ERR_APPLV_BAD_SHAPE
◆ ApplyTo3DBlock()
point_array SMESH::SMESH_Pattern::ApplyTo3DBlock ( in GEOM::GEOM_Object  theBlock,
The (0,0,0) key-point will be mapped into <theVertex000>. The (0,0,1) key-point will be mapped into <theVertex001>.
◆ ApplyToFace()
point_array SMESH::SMESH_Pattern::ApplyToFace ( in GEOM::GEOM_Object  theFace,
The first key-point will be mapped into <theVertexOnKeyPoint1>, which must be in the outer wire of theFace
◆ ApplyToHexahedrons()
point_array SMESH::SMESH_Pattern::ApplyToHexahedrons ( in SMESH_Mesh  theMesh,
The (0,0,0) key-point will be mapped into <theNode000Index>-th node of each volume. The (0,0,1) key-point will be mapped into <theNode001Index>-th node of each volume.
◆ ApplyToMeshFaces()
point_array SMESH::SMESH_Pattern::ApplyToMeshFaces ( in SMESH_Mesh  theMesh,
The first key-point will be mapped into <theNodeIndexOnKeyPoint1>-th node of each face
◆ GetElementPoints()
array_of_long_array SMESH::SMESH_Pattern::GetElementPoints ( in boolean  all)
◆ GetErrorCode()
ErrorCode SMESH::SMESH_Pattern::GetErrorCode ( )
◆ GetKeyPoints()
long_array SMESH::SMESH_Pattern::GetKeyPoints ( )
◆ GetPoints()
point_array SMESH::SMESH_Pattern::GetPoints ( )
◆ GetString()
string SMESH::SMESH_Pattern::GetString ( )
◆ Is2D()
boolean SMESH::SMESH_Pattern::Is2D ( )
◆ LoadFrom3DBlock()
boolean SMESH::SMESH_Pattern::LoadFrom3DBlock ( in SMESH_Mesh  theMesh,
◆ LoadFromFace()
boolean SMESH::SMESH_Pattern::LoadFromFace ( in SMESH_Mesh  theMesh,
<theProject>==true makes override nodes positions on <theFace> computed by mesher
◆ LoadFromFile()
boolean SMESH::SMESH_Pattern::LoadFromFile ( in string  theFileContents)
◆ MakeMesh()
boolean SMESH::SMESH_Pattern::MakeMesh ( in SMESH_Mesh  theMesh,
If CreatePolygons is TRUE, replace adjacent faces by polygons to keep mesh conformity. If CreatePolyedrs is TRUE, replace adjacent volumes by polyedrs to keep mesh conformity.
