SMESH::TPythonDump Class Reference
Utility helping in storing SMESH engine calls as python commands. More...
#include <SMESH_PythonDump.hxx>
 TPythonDump (SMESH_Gen_i *smesh)
 TPythonDump ()
virtual ~TPythonDump ()
 Destroy the TPythonDump object. More...
TPythonDump & operator<< (const TVar &theVariableValue)
 < store a variable value. Write either a value or '$varID$' More...
TPythonDump & operator<< (long int theArg)
TPythonDump & operator<< (int theArg)
TPythonDump & operator<< (long long theArg)
TPythonDump & operator<< (double theArg)
TPythonDump & operator<< (float theArg)
TPythonDump & operator<< (const void *theArg)
TPythonDump & operator<< (const char *theArg)
TPythonDump & operator<< (const SMESH::ElementType &theArg)
TPythonDump & operator<< (const SMESH::GeometryType &theArg)
TPythonDump & operator<< (const SMESH::EntityType &theArg)
TPythonDump & operator<< (const SMESH::long_array &theArg)
TPythonDump & operator<< (const SMESH::smIdType_array &theArg)
TPythonDump & operator<< (const SMESH::double_array &theArg)
TPythonDump & operator<< (const SMESH::string_array &theArg)
TPythonDump & operator<< (const SMESH::nodes_array &theArg)
TPythonDump & operator<< (SMESH::SMESH_Hypothesis_ptr theArg)
TPythonDump & operator<< (SMESH::SMESH_IDSource_ptr theArg)
TPythonDump & operator<< (SALOMEDS::SObject_ptr theArg)
TPythonDump & operator<< (CORBA::Object_ptr theArg)
TPythonDump & operator<< (SMESH::FilterLibrary_i *theArg)
TPythonDump & operator<< (SMESH::FilterManager_i *theArg)
TPythonDump & operator<< (SMESH::Filter_i *theArg)
TPythonDump & operator<< (SMESH::Functor_i *theArg)
TPythonDump & operator<< (SMESH::Measurements_i *theArg)
TPythonDump & operator<< (SMESH_Gen_i *theArg)
TPythonDump & operator<< (SMESH_MeshEditor_i *theArg)
TPythonDump & operator<< (const SMESH::AxisStruct &theAxis)
TPythonDump & operator<< (const SMESH::DirStruct &theDir)
TPythonDump & operator<< (const SMESH::PointStruct &P)
TPythonDump & operator<< (const TCollection_AsciiString &theArg)
TPythonDump & operator<< (const SMESH::ListOfGroups &theList)
TPythonDump & operator<< (const SMESH::ListOfGroups *theList)
TPythonDump & operator<< (const GEOM::ListOfGO &theList)
TPythonDump & operator<< (const GEOM::ListOfGBO &theList)
TPythonDump & operator<< (const SMESH::ListOfIDSources &theList)
TPythonDump & operator<< (const SMESH::submesh_array &theList)
TPythonDump & operator<< (const SMESH::ListOfHypothesis &theList)
TPythonDump & operator<< (const SMESH::CoincidentFreeBorders &theCFB)
TPythonDump & operator<< (const std::string &theArg)
static void IncrementMyCounter ()
 Increment the myCounter member. More...
static void DecrementMyCounter ()
 Decrement the myCounter member. More...
template<class TArray , class TStream >
static TStream & DumpArray (const TArray &theArray, TStream &theStream)
static const char * SMESHGenName ()
static const char * MeshEditorName ()
static const char * NotPublishedObjectName ()
static TCollection_AsciiString LongStringStart (const char *type)
 Return marker of long string literal beginning. More...
static TCollection_AsciiString LongStringEnd ()
 Return marker of long string literal end. More...
static bool CutoutLongString (TCollection_AsciiString &theText, int &theFrom, TCollection_AsciiString &theLongString, TCollection_AsciiString &theStringType)
 Cut out a long string literal from a string. More...
std::ostringstream myStream
int myVarsCounter
SMESH_Gen_i * mySmesh = nullptr
Static Private Attributes
static size_t myCounter = 0
◆ TPythonDump() [1/2]
SMESH::TPythonDump::TPythonDump ( SMESH_Gen_i *  smesh)
References myCounter.
◆ TPythonDump() [2/2]
SMESH::TPythonDump::TPythonDump ( )
◆ ~TPythonDump()
SMESH::TPythonDump::~TPythonDump ( )
Generates the content of the dumped Python script through a call to SMESH_Gen_i::AddToPythonScript() when myCounter = 0. It induces a pattern where we can avoid dumping intermediate steps by simply instanciating a new TPythonDump object.
References SMESH_Gen_i::AddToPythonScript(), SMESH_Gen_i::GetLastObjEntry(), SMESH_Gen_i::GetSMESHGen(), MESSAGE, myCounter, myStream, SMESH::TVar::ObjPrefix(), and SMESH_Gen_i::UpdateParameters().
◆ CutoutLongString()
bool SMESH::TPythonDump::CutoutLongString ( TCollection_AsciiString &  theText,
int &  theFrom,
TCollection_AsciiString &  theLongString,
TCollection_AsciiString &  theStringType
theText- text possibly containing string literals
theFrom- position in the text to search from
theLongString- the retrieved literal
theStringType- a name of functionality produced the literal
bool- true if a string literal found
The literal is removed from theText; theFrom points position right after the removed literal
References SMESH::myLongStringEnd(), and SMESH::myLongStringStart().
Referenced by SMESH_Gen_i::DumpPython_impl().
◆ DecrementMyCounter()
void SMESH::TPythonDump::DecrementMyCounter ( )
To use paired with IncrementMyCounter().
When counter returns to 0, TPythonDump recording resumes. This method will be used by Python plugins through SMESH_Gen_i::ResumePythonDumpRecording() to resume Python recording.
References MESSAGE, and myCounter.
Referenced by SMESH_Gen_i::ResumePythonDumpRecording().
◆ DumpArray()
static TStream & SMESH::TPythonDump::DumpArray ( const TArray &  theArray,
TStream &  theStream
Referenced by operator<<().
◆ IncrementMyCounter()
void SMESH::TPythonDump::IncrementMyCounter ( )
To use paired with DecrementMyCounter().
While myCounter > 0, TPythonDump commands are not recorded. This method will be used by Python plugins through SMESH_Gen_:PausePythonDumpRecording() to suppress intermediate operations.
Referenced by SMESH_Gen_i::PausePythonDumpRecording().
◆ LongStringEnd()
TCollection_AsciiString SMESH::TPythonDump::LongStringEnd ( )
TCollection_AsciiString- the marker string to be written into a raw python script
References SMESH::myLongStringEnd().
◆ LongStringStart()
TCollection_AsciiString SMESH::TPythonDump::LongStringStart ( const char *  type)
type- a name of functionality producing the string literal
References SMESH::myLongStringStart().
◆ MeshEditorName()
static const char * SMESH::TPythonDump::MeshEditorName ( )
◆ NotPublishedObjectName()
const char * SMESH::TPythonDump::NotPublishedObjectName ( )
◆ operator<<() [1/40]
TPythonDump & SMESH::TPythonDump::operator<< ( const char *  theArg)
References myStream.
◆ operator<<() [2/40]
TPythonDump & SMESH::TPythonDump::operator<< ( const GEOM::ListOfGBO &  theList)
References DumpArray().
◆ operator<<() [3/40]
TPythonDump & SMESH::TPythonDump::operator<< ( const GEOM::ListOfGO &  theList)
◆ operator<<() [4/40]
◆ operator<<() [5/40]
◆ operator<<() [6/40]
TPythonDump & SMESH::TPythonDump::operator<< ( const SMESH::DirStruct &  theDir)
◆ operator<<() [7/40]
TPythonDump & SMESH::TPythonDump::operator<< ( const SMESH::double_array &  theArg)
◆ operator<<() [8/40]
TPythonDump & SMESH::TPythonDump::operator<< ( const SMESH::ElementType &  theArg)
◆ operator<<() [9/40]
◆ operator<<() [10/40]
◆ operator<<() [11/40]
TPythonDump & SMESH::TPythonDump::operator<< ( const SMESH::ListOfGroups &  theList)
◆ operator<<() [12/40]
TPythonDump & SMESH::TPythonDump::operator<< ( const SMESH::ListOfGroups *  theList)
◆ operator<<() [13/40]
TPythonDump & SMESH::TPythonDump::operator<< ( const SMESH::ListOfHypothesis &  theList)
◆ operator<<() [14/40]
TPythonDump & SMESH::TPythonDump::operator<< ( const SMESH::ListOfIDSources &  theList)
◆ operator<<() [15/40]
TPythonDump & SMESH::TPythonDump::operator<< ( const SMESH::long_array &  theArg)
◆ operator<<() [16/40]
TPythonDump & SMESH::TPythonDump::operator<< ( const SMESH::nodes_array &  theArg)
◆ operator<<() [17/40]
TPythonDump & SMESH::TPythonDump::operator<< ( const SMESH::PointStruct &  P)
◆ operator<<() [18/40]
TPythonDump & SMESH::TPythonDump::operator<< ( const SMESH::smIdType_array &  theArg)
◆ operator<<() [19/40]
TPythonDump & SMESH::TPythonDump::operator<< ( const SMESH::string_array &  theArg)
◆ operator<<() [20/40]
TPythonDump & SMESH::TPythonDump::operator<< ( const SMESH::submesh_array &  theList)
◆ operator<<() [21/40]
TPythonDump & SMESH::TPythonDump::operator<< ( const std::string &  theArg)
◆ operator<<() [22/40]
TPythonDump & SMESH::TPythonDump::operator<< ( const TCollection_AsciiString &  theArg)
◆ operator<<() [23/40]
TPythonDump & SMESH::TPythonDump::operator<< ( const TVar &  theVariableValue)
◆ operator<<() [24/40]
TPythonDump & SMESH::TPythonDump::operator<< ( const void *  theArg)
◆ operator<<() [25/40]
◆ operator<<() [26/40]
TPythonDump & SMESH::TPythonDump::operator<< ( double  theArg)
◆ operator<<() [27/40]
TPythonDump & SMESH::TPythonDump::operator<< ( float  theArg)
◆ operator<<() [28/40]
TPythonDump & SMESH::TPythonDump::operator<< ( int  theArg)
◆ operator<<() [29/40]
TPythonDump & SMESH::TPythonDump::operator<< ( long int  theArg)
◆ operator<<() [30/40]
TPythonDump & SMESH::TPythonDump::operator<< ( long long  theArg)
◆ operator<<() [31/40]
TPythonDump & SMESH::TPythonDump::operator<< ( SALOMEDS::SObject_ptr  theArg)
◆ operator<<() [32/40]
TPythonDump & SMESH::TPythonDump::operator<< ( SMESH::Filter_i *  theArg)
◆ operator<<() [33/40]
TPythonDump & SMESH::TPythonDump::operator<< ( SMESH::FilterLibrary_i *  theArg)
◆ operator<<() [34/40]
TPythonDump & SMESH::TPythonDump::operator<< ( SMESH::FilterManager_i *  theArg)
◆ operator<<() [35/40]
◆ operator<<() [36/40]
TPythonDump & SMESH::TPythonDump::operator<< ( SMESH::Measurements_i *  theArg)
◆ operator<<() [37/40]
TPythonDump & SMESH::TPythonDump::operator<< ( SMESH::SMESH_Hypothesis_ptr  theArg)
◆ operator<<() [38/40]
TPythonDump & SMESH::TPythonDump::operator<< ( SMESH::SMESH_IDSource_ptr  theArg)
◆ operator<<() [39/40]
TPythonDump & SMESH::TPythonDump::operator<< ( SMESH_Gen_i *  theArg)
References myStream, and SMESHGenName().
◆ operator<<() [40/40]
TPythonDump & SMESH::TPythonDump::operator<< ( SMESH_MeshEditor_i *  theArg)
◆ SMESHGenName()
static const char * SMESH::TPythonDump::SMESHGenName ( )
◆ myCounter
size_t SMESH::TPythonDump::myCounter = 0
staticprivate
◆ mySmesh
SMESH_Gen_i* SMESH::TPythonDump::mySmesh = nullptr
◆ myStream
std::ostringstream SMESH::TPythonDump::myStream
Referenced by operator<<(), and ~TPythonDump().
◆ myVarsCounter
int SMESH::TPythonDump::myVarsCounter
