SMESH::SMESH_Hypothesis Interface Reference
import"SMESH_Hypothesis.idl";
Inheritance diagram for SMESH::SMESH_Hypothesis:
string GetName ()
string GetLibName ()
short GetId ()
 Get the internal Id. More...
boolean HasParameters ()
◆ GetId()
◆ GetLibName()
◆ GetName()
◆ GetVarParameter()
◆ HasParameters()
◆ IsDimSupported()
◆ SetHolderHypothesis()
◆ SetVarParameter()
in string  method
