26#ifndef _SMESH_HYPOTHESIS_IDL_
27#define _SMESH_HYPOTHESIS_IDL_
29#include "SALOME_Exception.idl"
30#include "SALOME_GenericObj.idl"
Definition: SMESH_Hypothesis.idl:111
Definition: SMESH_Hypothesis.idl:118
Definition: SMESH_Hypothesis.idl:125
Definition: SMESH_Hypothesis.idl:132
Definition: SMESH_Hypothesis.idl:102
ListOfHypothesisName GetCompatibleHypothesis()
Get list of hypothesis that can be used with this algorithm.
Definition: SMESH_Hypothesis.idl:45
string GetName()
Get the Hypothesis typeName.
void SetVarParameter(in string parameter, in string method)
Set the variable parameter.
short GetId()
Get the internal Id.
void SetHolderHypothesis(in SMESH::SMESH_Hypothesis hyp)
string GetVarParameter(in string methodName)
boolean IsDimSupported(in Dimension type)
string GetLibName()
boolean HasParameters()
Definition: SMESH_ControlsClassifier.cxx:39
sequence< string > ListOfParameters
Definition: SMESH_Hypothesis.idl:42
Dimension
@ DIM_2D
Definition: SMESH_Hypothesis.idl:38
@ DIM_1D
Definition: SMESH_Hypothesis.idl:37
@ DIM_3D
Definition: SMESH_Hypothesis.idl:39
@ DIM_0D
Definition: SMESH_Hypothesis.idl:36
sequence< string > ListOfHypothesisName
Definition: SMESH_Hypothesis.idl:99
