SMESH::SMESH_1D_Algo Interface Reference
import"SMESH_Hypothesis.idl";
Inheritance diagram for SMESH::SMESH_1D_Algo:
ListOfHypothesisName GetCompatibleHypothesis ()
 Get list of hypothesis that can be used with this algorithm. More...
string GetName ()
string GetLibName ()
short GetId ()
 Get the internal Id. More...
boolean HasParameters ()
◆ GetCompatibleHypothesis()
ListOfHypothesisName SMESH::SMESH_Algo::GetCompatibleHypothesis ( )
◆ GetId()
◆ GetLibName()
◆ GetName()
◆ GetVarParameter()
◆ HasParameters()
◆ IsDimSupported()
◆ SetHolderHypothesis()
◆ SetVarParameter()
in string  method
