SMESH_GroupOnFilter: interface of a group object defined by filter.
More...
import"SMESH_Group.idl";
◆ Contains()
| boolean SMESH::SMESH_GroupBase::Contains |
in smIdType |
elem_id | ) |
returns true if the group contains an element with ID == <elem_id>
◆ GetColor()
| SALOMEDS::Color SMESH::SMESH_GroupBase::GetColor |
◆ GetColorNumber()
| long SMESH::SMESH_GroupBase::GetColorNumber |
Returns group color number (obsolete - use GetColor instead) (corresponds to the "hue" parameter of the color - must be in range [0, 360])
◆ GetFilter()
| Filter SMESH::SMESH_GroupOnFilter::GetFilter |
◆ GetID()
| smIdType SMESH::SMESH_GroupBase::GetID |
in smIdType |
elem_index | ) |
Returns ID of an element at position <elem_index> counted from 1.
◆ GetIDs()
Returns a sequence of all element IDs.
◆ GetListOfID()
Returns a sequence of all element IDs in the group.
◆ GetMesh()
◆ GetMeshInfo()
Returns number of mesh elements of each EntityType.
- Returns
- array of number of elements per EntityType
◆ GetName()
| string SMESH::SMESH_GroupBase::GetName |
◆ GetNbElementsByType()
Returns number of mesh elements of each ElementType.
- Returns
- array of number of elements per ElementType
◆ GetNodeIDs()
Get IDs of nodes of cells included to the group For a nodal group returns result of GetListOfID() function.
◆ GetNumberOfNodes()
| smIdType SMESH::SMESH_GroupBase::GetNumberOfNodes |
Get the number of nodes of cells included to the group For a nodal group returns the same value as Size() function.
◆ GetType()
Returns group type (type of elements in the group)
◆ GetTypes()
Returns types of elements it contains.
It's empty if the SMESH_IDSource contains no IDs
◆ GetVtkUgStream()
| SALOMEDS::TMPFile SMESH::SMESH_IDSource::GetVtkUgStream |
Returns mesh unstructed grid information.
◆ IsEmpty()
| boolean SMESH::SMESH_GroupBase::IsEmpty |
Returns true if the group does not contain any elements.
◆ IsInDependency()
Returns true if this group depends on the other via FT_BelongToMeshGroup predicate or vice versa.
◆ IsMeshInfoCorrect()
| boolean SMESH::SMESH_IDSource::IsMeshInfoCorrect |
Returns false if GetMeshInfo() returns incorrect information that may happen if mesh data is not yet fully loaded from the file of study.
◆ IsNodeInfoAvailable()
| boolean SMESH::SMESH_GroupBase::IsNodeInfoAvailable |
◆ IsUpToDate()
| boolean SMESH::SMESH_GroupOnFilter::IsUpToDate |
- Returns
- True if group contents is computed
◆ SetColor()
| void SMESH::SMESH_GroupBase::SetColor |
in SALOMEDS::Color |
theColor | ) |
◆ SetColorNumber()
| void SMESH::SMESH_GroupBase::SetColorNumber |
in long |
color | ) |
Sets group color number (corresponds to the "hue" parameter of the color - must be in range [0, 360])
◆ SetFilter()
| void SMESH::SMESH_GroupOnFilter::SetFilter |
in Filter |
theFilter | ) |
| raises | ( | SALOME::SALOME_Exception |
◆ SetName()
| void SMESH::SMESH_GroupBase::SetName |
in string |
name | ) |
◆ Size()
| smIdType SMESH::SMESH_GroupBase::Size |
Returns the number of elements in the group.
