SMESH::SMESH_MeshEditor Interface Reference
This interface makes modifications on the Mesh - removing elements and nodes etc. More...
import"SMESH_MeshEditor.idl";
enum  Smooth_Method { LAPLACIAN_SMOOTH , CENTROIDAL_SMOOTH }
enum  Extrusion_Error {
  EXTR_OK , EXTR_NO_ELEMENTS , EXTR_PATH_NOT_EDGE , EXTR_BAD_PATH_SHAPE ,
  EXTR_BAD_STARTING_NODE , EXTR_BAD_ANGLES_NUMBER , EXTR_CANT_GET_TANGENT
enum  MirrorType { POINT , AXIS , PLANE }
enum  Sew_Error {
  SEW_OK , SEW_BORDER1_NOT_FOUND , SEW_BORDER2_NOT_FOUND , SEW_BOTH_BORDERS_NOT_FOUND ,
  SEW_BAD_SIDE_NODES , SEW_VOLUMES_TO_SPLIT , SEW_DIFF_NB_OF_ELEMENTS , SEW_TOPO_DIFF_SETS_OF_ELEMENTS ,
  SEW_BAD_SIDE1_NODES , SEW_BAD_SIDE2_NODES , SEW_INTERNAL_ERROR
SMESH_Mesh GetMesh ()
 Returns a mesh subject to edition. More...
MeshPreviewStruct GetPreviewData () raises (SALOME::SALOME_Exception)
 Return data of mesh edition preview which is computed provided that the editor was obtained through SMESH_Mesh::GetMeshEditPreviewer() More...
smIdType_array GetLastCreatedNodes () raises (SALOME::SALOME_Exception)
 If during last operation of MeshEditor some nodes were created, this method returns list of their IDs, if new nodes not created - returns empty list. More...
smIdType_array GetLastCreatedElems () raises (SALOME::SALOME_Exception)
 If during last operation of MeshEditor some elements were created, this method returns list of their IDs, if new elements not created - returns empty list. More...
void ClearLastCreated () raises (SALOME::SALOME_Exception)
 Clears sequences of last created elements and nodes. More...
ComputeError GetLastError () raises (SALOME::SALOME_Exception)
 Returns description of an error/warning occurred during the last operation. More...
SMESH_IDSource MakeIDSource (in smIdType_array IDsOfElements, in ElementType type)
 Wrap a sequence of ids in a SMESH_IDSource. More...
boolean RemoveElements (in smIdType_array IDsOfElements) raises (SALOME::SALOME_Exception)
 Remove mesh elements specified by their identifiers. More...
boolean RemoveNodes (in smIdType_array IDsOfNodes) raises (SALOME::SALOME_Exception)
 Remove mesh nodes specified by their identifiers. More...
smIdType RemoveOrphanNodes () raises (SALOME::SALOME_Exception)
 Remove all orphan nodes. More...
void RemoveNodeWithReconnection (in smIdType nodeID) raises (SALOME::SALOME_Exception)
 Remove a mesh node and change surrounding faces to close a hole. More...
smIdType AddNode (in double x, in double y, in double z) raises (SALOME::SALOME_Exception)
 Add a new node. More...
smIdType Add0DElement (in smIdType IDOfNode, in boolean DuplicateElements) raises (SALOME::SALOME_Exception)
 Create a 0D element on the given node. More...
smIdType AddBall (in smIdType IDOfNode, in double diameter) raises (SALOME::SALOME_Exception)
 Create a ball element on the given node. More...
smIdType AddEdge (in smIdType_array IDsOfNodes) raises (SALOME::SALOME_Exception)
 Create an edge, either linear and quadratic (this is determed by number of given nodes, two or three). More...
smIdType AddFace (in smIdType_array IDsOfNodes) raises (SALOME::SALOME_Exception)
 Create face, either linear and quadratic (this is determed by number of given nodes). More...
smIdType AddPolygonalFace (in smIdType_array IdsOfNodes) raises (SALOME::SALOME_Exception)
smIdType AddQuadPolygonalFace (in smIdType_array IdsOfNodes) raises (SALOME::SALOME_Exception)
 Create a quadratic polygonal face. More...
smIdType AddVolume (in smIdType_array IDsOfNodes) raises (SALOME::SALOME_Exception)
 Create volume, either linear and quadratic (this is determed by number of given nodes). More...
smIdType AddPolyhedralVolume (in smIdType_array IdsOfNodes, in long_array Quantities) raises (SALOME::SALOME_Exception)
 Create volume of many faces, giving nodes for each face. More...
smIdType AddPolyhedralVolumeByFaces (in smIdType_array IdsOfFaces) raises (SALOME::SALOME_Exception)
 Create volume of many faces, giving IDs of existing faces. More...
SMESH_IDSource Create0DElementsOnAllNodes (in SMESH_IDSource theObject, in string theGroupName, in boolean theDuplicateElements) raises (SALOME::SALOME_Exception)
 Create 0D elements on all nodes of the given object. More...
void SetNodeOnVertex (in smIdType NodeID, in long VertexID) raises (SALOME::SALOME_Exception)
 Bind a node to a vertex. More...
void SetNodeOnEdge (in smIdType NodeID, in long EdgeID, in double paramOnEdge) raises (SALOME::SALOME_Exception)
 Store node position on an edge. More...
void SetNodeOnFace (in smIdType NodeID, in long FaceID, in double u, in double v) raises (SALOME::SALOME_Exception)
 Store node position on a face. More...
void SetNodeInVolume (in smIdType NodeID, in long SolidID) raises (SALOME::SALOME_Exception)
 Bind a node to a solid. More...
void SetMeshElementOnShape (in smIdType ElementID, in long ShapeID) raises (SALOME::SALOME_Exception)
 Bind an element to a shape. More...
boolean MoveNode (in smIdType NodeID, in double x, in double y, in double z) raises (SALOME::SALOME_Exception)
 Change node location. More...
boolean InverseDiag (in smIdType NodeID1, in smIdType NodeID2) raises (SALOME::SALOME_Exception)
 Swap a diagonal of a quadrangle formed by two adjacent triangles. More...
boolean DeleteDiag (in smIdType NodeID1, in smIdType NodeID2) raises (SALOME::SALOME_Exception)
 Delete a diagonal of a quadrangle formed by two adjacent triangles so that a new quadrangle appears in place of the triangles. More...
void AddNodeOnSegment (in smIdType Node1, in smIdType Node2, in double position) raises (SALOME::SALOME_Exception)
 Replace each triangle bound by Node1-Node2 segment with two triangles by connecting a node made on the segment with a node opposite to the segment. More...
void AddNodeOnFace (in smIdType triangle, in double x, in double y, in double z)
 Split a face into triangles by adding a new node onto the face and connecting the new node with face nodes. More...
boolean Reorient (in smIdType_array IDsOfElements) raises (SALOME::SALOME_Exception)
 Change orientation of cells. More...
boolean ReorientObject (in SMESH_IDSource theObject) raises (SALOME::SALOME_Exception)
long Reorient2D (in SMESH_IDSource the2Dgroup, in DirStruct theDirection, in long theFace, in PointStruct thePoint) raises (SALOME::SALOME_Exception)
 Reorient faces contained in the2Dgroup. More...
long Reorient2DByNeighbours (in SMESH::ListOfIDSources objectFaces, in SMESH::ListOfIDSources referenceFaces) raises (SALOME::SALOME_Exception)
 Reorient faces contained in a list of objectFaces equally to faces contained in a list of referenceFaces. More...
long Reorient2DBy3D (in ListOfIDSources faces, in SMESH_IDSource volumes, in boolean outsideNormal) raises (SALOME::SALOME_Exception)
 Reorient faces basing on orientation of adjacent volumes. More...
boolean TriToQuad (in smIdType_array IDsOfElements, in NumericalFunctor Criterion, in double MaxAngle) raises (SALOME::SALOME_Exception)
 Fuse neighbour triangles into quadrangles. More...
boolean TriToQuadObject (in SMESH_IDSource theObject, in NumericalFunctor Criterion, in double MaxAngle) raises (SALOME::SALOME_Exception)
boolean QuadToTri (in smIdType_array IDsOfElements, in NumericalFunctor Criterion) raises (SALOME::SALOME_Exception)
 Split quadrangles into triangles. More...
boolean QuadToTriObject (in SMESH_IDSource theObject, in NumericalFunctor Criterion) raises (SALOME::SALOME_Exception)
void QuadTo4Tri (in SMESH_IDSource theQuads) raises (SALOME::SALOME_Exception)
 Split each of quadrangles into 4 triangles. More...
boolean SplitQuad (in smIdType_array IDsOfElements, in boolean Diag13) raises (SALOME::SALOME_Exception)
boolean SplitQuadObject (in SMESH_IDSource theObject, in boolean Diag13) raises (SALOME::SALOME_Exception)
short BestSplit (in smIdType IDOfQuad, in NumericalFunctor Criterion) raises (SALOME::SALOME_Exception)
 Find better splitting of the given quadrangle. More...
void SplitVolumesIntoTetra (in SMESH_IDSource elems, in short methodFlags) raises (SALOME::SALOME_Exception)
 Split volumic elements into tetrahedrons. More...
void SplitVolumesIntoTetraAvoidOverConstrainedVolumes (in SMESH_IDSource elems, in short methodFlags) raises (SALOME::SALOME_Exception)
 Split volumic elements into tetrahedrons \and choose variants that comply with no over-constrained volumes. More...
void SplitHexahedraIntoPrisms (in SMESH_IDSource elems, in SMESH::PointStruct startHexPoint, in SMESH::DirStruct facetToSplitNormal, in short methodFlags, in boolean allDomains) raises (SALOME::SALOME_Exception)
 Split hexahedra into triangular prisms. More...
void SplitBiQuadraticIntoLinear (in ListOfIDSources elems) raises (SALOME::SALOME_Exception)
 Split bi-quadratic elements into linear ones without creation of additional nodes. More...
boolean Smooth (in smIdType_array IDsOfElements, in smIdType_array IDsOfFixedNodes, in short MaxNbOfIterations, in double MaxAspectRatio, in Smooth_Method Method) raises (SALOME::SALOME_Exception)
boolean SmoothObject (in SMESH_IDSource theObject, in smIdType_array IDsOfFixedNodes, in short MaxNbOfIterations, in double MaxAspectRatio, in Smooth_Method Method) raises (SALOME::SALOME_Exception)
boolean SmoothParametric (in smIdType_array IDsOfElements, in smIdType_array IDsOfFixedNodes, in short MaxNbOfIterations, in double MaxAspectRatio, in Smooth_Method Method) raises (SALOME::SALOME_Exception)
boolean SmoothParametricObject (in SMESH_IDSource theObject, in smIdType_array IDsOfFixedNodes, in short MaxNbOfIterations, in double MaxAspectRatio, in Smooth_Method Method) raises (SALOME::SALOME_Exception)
void ConvertToQuadratic (in boolean theForce3d) raises (SALOME::SALOME_Exception)
void ConvertToQuadraticObject (in boolean theForce3d, in SMESH_IDSource theObject) raises (SALOME::SALOME_Exception)
boolean ConvertFromQuadratic () raises (SALOME::SALOME_Exception)
void ConvertFromQuadraticObject (in SMESH_IDSource theObject) raises (SALOME::SALOME_Exception)
void ConvertToBiQuadratic (in boolean theForce3d, in SMESH_IDSource theObject) raises (SALOME::SALOME_Exception)
void RenumberNodes () raises (SALOME::SALOME_Exception)
void RenumberElements () raises (SALOME::SALOME_Exception)
ListOfGroups RotationSweepObjects (in ListOfIDSources Nodes, in ListOfIDSources Edges, in ListOfIDSources Faces, in AxisStruct Axis, in double AngleInRadians, in long NbOfSteps, in double Tolerance, in boolean ToMakeGroups) raises (SALOME::SALOME_Exception)
 Generate dim+1 elements by rotation of the object around axis. More...
ListOfGroups ExtrusionSweepObjects (in ListOfIDSources nodes, in ListOfIDSources edges, in ListOfIDSources faces, in DirStruct stepVector, in long nbOfSteps, in boolean toMakeGroups, in double_array scaleFactors, in boolean scaleVariation, in double_array basePoint, in double_array angles, in boolean angleVariation) raises (SALOME::SALOME_Exception)
 Generate dim+1 elements by extrusion of elements along vector. More...
ListOfGroups ExtrusionByNormal (in ListOfIDSources theObjects, in double stepSize, in long nbOfSteps, in boolean byAverageNormal, in boolean useInputElemsOnly, in boolean makeGroups, in short dim) raises (SALOME::SALOME_Exception)
 Generates new elements by extrusion along the normal to a discretized surface or wire. More...
ListOfGroups AdvancedExtrusion (in smIdType_array IDsOfElements, in DirStruct StepVector, in long NbOfSteps, in long ExtrFlags, in double SewTolerance, in boolean ToMakeGroups) raises (SALOME::SALOME_Exception)
 Generate new elements by extrusion of theElements by StepVector by NbOfSteps. More...
ListOfGroups ExtrusionAlongPathObjects (in ListOfIDSources Nodes, in ListOfIDSources Edges, in ListOfIDSources Faces, in SMESH_IDSource Path, in GEOM::GEOM_Object PathShape, in smIdType NodeStart, in boolean HasAngles, in double_array Angles, in boolean AnglesVariation, in boolean HasRefPoint, in PointStruct RefPoint, in boolean MakeGroups, in double_array ScaleFactors, in boolean ScaleVariation, out Extrusion_Error Error) raises (SALOME::SALOME_Exception)
double_array LinearAnglesVariation (in SMESH_Mesh PathMesh, in GEOM::GEOM_Object PathShape, in double_array Angles)
 Compute rotation angles for ExtrusionAlongPath as linear variation of given angles along path steps param PathMesh mesh containing a 1D sub-mesh on the edge, along which proceeds the extrusion param PathShape is shape(edge); as the mesh can be complex, the edge is used to define the sub-mesh for the path. More...
void Mirror (in smIdType_array IDsOfElements, in AxisStruct Mirror, in MirrorType Type, in boolean Copy) raises (SALOME::SALOME_Exception)
ListOfGroups MirrorMakeGroups (in smIdType_array IDsOfElements, in AxisStruct Mirror, in MirrorType Type) raises (SALOME::SALOME_Exception)
SMESH_Mesh MirrorMakeMesh (in smIdType_array IDsOfElements, in AxisStruct Mirror, in MirrorType Type, in boolean CopyGroups, in string MeshName) raises (SALOME::SALOME_Exception)
void MirrorObject (in SMESH_IDSource theObject, in AxisStruct Mirror, in MirrorType Type, in boolean Copy) raises (SALOME::SALOME_Exception)
ListOfGroups MirrorObjectMakeGroups (in SMESH_IDSource theObject, in AxisStruct Mirror, in MirrorType Type) raises (SALOME::SALOME_Exception)
SMESH_Mesh MirrorObjectMakeMesh (in SMESH_IDSource theObject, in AxisStruct Mirror, in MirrorType Type, in boolean CopyGroups, in string MeshName) raises (SALOME::SALOME_Exception)
void Translate (in smIdType_array IDsOfElements, in DirStruct Vector, in boolean Copy) raises (SALOME::SALOME_Exception)
ListOfGroups TranslateMakeGroups (in smIdType_array IDsOfElements, in DirStruct Vector) raises (SALOME::SALOME_Exception)
SMESH_Mesh TranslateMakeMesh (in smIdType_array IDsOfElements, in DirStruct Vector, in boolean CopyGroups, in string MeshName) raises (SALOME::SALOME_Exception)
void TranslateObject (in SMESH_IDSource theObject, in DirStruct Vector, in boolean Copy) raises (SALOME::SALOME_Exception)
ListOfGroups TranslateObjectMakeGroups (in SMESH_IDSource theObject, in DirStruct Vector) raises (SALOME::SALOME_Exception)
SMESH_Mesh TranslateObjectMakeMesh (in SMESH_IDSource theObject, in DirStruct Vector, in boolean CopyGroups, in string MeshName) raises (SALOME::SALOME_Exception)
void Scale (in SMESH_IDSource theObject, in PointStruct thePoint, in double_array theScaleFact, in boolean Copy) raises (SALOME::SALOME_Exception)
ListOfGroups ScaleMakeGroups (in SMESH_IDSource theObject, in PointStruct thePoint, in double_array theScaleFact) raises (SALOME::SALOME_Exception)
SMESH_Mesh ScaleMakeMesh (in SMESH_IDSource theObject, in PointStruct thePoint, in double_array theScaleFact, in boolean CopyGroups, in string MeshName) raises (SALOME::SALOME_Exception)
void Rotate (in smIdType_array IDsOfElements, in AxisStruct Axis, in double AngleInRadians, in boolean Copy) raises (SALOME::SALOME_Exception)
ListOfGroups RotateMakeGroups (in smIdType_array IDsOfElements, in AxisStruct Axis, in double AngleInRadians) raises (SALOME::SALOME_Exception)
SMESH_Mesh RotateMakeMesh (in smIdType_array IDsOfElements, in AxisStruct Axis, in double AngleInRadians, in boolean CopyGroups, in string MeshName) raises (SALOME::SALOME_Exception)
void RotateObject (in SMESH_IDSource theObject, in AxisStruct Axis, in double AngleInRadians, in boolean Copy) raises (SALOME::SALOME_Exception)
ListOfGroups RotateObjectMakeGroups (in SMESH_IDSource theObject, in AxisStruct Axis, in double AngleInRadians) raises (SALOME::SALOME_Exception)
SMESH_Mesh RotateObjectMakeMesh (in SMESH_IDSource theObject, in AxisStruct Axis, in double AngleInRadians, in boolean CopyGroups, in string MeshName) raises (SALOME::SALOME_Exception)
SMESH_Mesh Offset (in SMESH_IDSource theObject, in double Value, in boolean CopyGroups, in boolean CopyElements, in string MeshName, out ListOfGroups Groups) raises (SALOME::SALOME_Exception)
void FindCoincidentNodes (in double Tolerance, out array_of_long_array GroupsOfNodes, in boolean SeparateCornersAndMedium) raises (SALOME::SALOME_Exception)
void FindCoincidentNodesOnPart (in SMESH_IDSource SubMeshOrGroup, in double Tolerance, out array_of_long_array GroupsOfNodes, in boolean SeparateCornersAndMedium) raises (SALOME::SALOME_Exception)
void FindCoincidentNodesOnPartBut (in ListOfIDSources SubMeshOrGroup, in double Tolerance, out array_of_long_array GroupsOfNodes, in ListOfIDSources ExceptSubMeshOrGroups, in boolean SeparateCornersAndMedium) raises (SALOME::SALOME_Exception)
void MergeNodes (in array_of_long_array GroupsOfNodes, in SMESH::ListOfIDSources NodesToKeep, in boolean AvoidMakingHoles) raises (SALOME::SALOME_Exception)
void FindEqualElements (in ListOfIDSources MeshOrSubMeshOrGroup, in ListOfIDSources ExceptSubMeshOrGroups, out array_of_long_array GroupsOfElementsID) raises (SALOME::SALOME_Exception)
 Find elements built on the same nodes. More...
void MergeElements (in array_of_long_array GroupsOfElementsID, in SMESH::ListOfIDSources ElementsToKeep) raises (SALOME::SALOME_Exception)
 Merge elements in each given group. More...
void MergeEqualElements () raises (SALOME::SALOME_Exception)
 Merge equal elements in the whole mesh. More...
smIdType MoveClosestNodeToPoint (in double x, in double y, in double z, in smIdType nodeID) raises (SALOME::SALOME_Exception)
 If the given ID is a valid node ID (nodeID > 0), just move this node, else move the node closest to the point to point's location and return ID of the node. More...
smIdType FindNodeClosestTo (in double x, in double y, in double z) raises (SALOME::SALOME_Exception)
 Return ID of node closest to a given point. More...
smIdType_array FindElementsByPoint (in double x, in double y, in double z, in ElementType type) raises (SALOME::SALOME_Exception)
 Return elements of given type where the given point is IN or ON. More...
smIdType_array FindAmongElementsByPoint (in SMESH_IDSource elements, in double x, in double y, in double z, in ElementType type) raises (SALOME::SALOME_Exception)
 Searching among the given elements, return elements of given type where the given point is IN or ON. More...
smIdType ProjectPoint (in double x, in double y, in double z, in ElementType type, in SMESH_IDSource meshObject, out double_array projecton) raises (SALOME::SALOME_Exception)
 Project a point to a mesh object. More...
short GetPointState (in double x, in double y, in double z) raises (SALOME::SALOME_Exception)
 Return point state in a closed 2D mesh in terms of TopAbs_State enumeration. More...
boolean IsManifold () raises (SALOME::SALOME_Exception)
 Check if a 2D mesh is manifold. More...
boolean IsCoherentOrientation2D () raises (SALOME::SALOME_Exception)
 Check if orientation of 2D elements is coherent. More...
array_of_long_array Get1DBranches (in SMESH_IDSource edges, in smIdType startNode, out array_of_long_array nodeGroups) raises (SALOME::SALOME_Exception)
 Partition given 1D elements into groups of contiguous edges. More...
ListOfEdges FindSharpEdges (in double angle, in boolean addExistingEdges) raises (SALOME::SALOME_Exception)
 Return sharp edges of faces and non-manifold ones. More...
ListOfFreeBorders FindFreeBorders (in boolean closedOnly) raises (SALOME::SALOME_Exception)
 Returns all or only closed FreeBorder's. More...
SMESH_Group FillHole (in FreeBorder hole, in string groupName) raises (SALOME::SALOME_Exception)
 Fill with 2D elements a hole defined by a FreeBorder. More...
CoincidentFreeBorders FindCoincidentFreeBorders (in double tolerance)
 Returns groups of FreeBorder's coincident within the given tolerance. More...
short SewCoincidentFreeBorders (in CoincidentFreeBorders freeBorders, in boolean createPolygons, in boolean createPolyedrs) raises (SALOME::SALOME_Exception)
 Sew FreeBorder's of each group. More...
Sew_Error SewFreeBorders (in smIdType FirstNodeID1, in smIdType SecondNodeID1, in smIdType LastNodeID1, in smIdType FirstNodeID2, in smIdType SecondNodeID2, in smIdType LastNodeID2, in boolean CreatePolygons, in boolean CreatePolyedrs) raises (SALOME::SALOME_Exception)
Sew_Error SewConformFreeBorders (in smIdType FirstNodeID1, in smIdType SecondNodeID1, in smIdType LastNodeID1, in smIdType FirstNodeID2, in smIdType SecondNodeID2) raises (SALOME::SALOME_Exception)
Sew_Error SewBorderToSide (in smIdType FirstNodeIDOnFreeBorder, in smIdType SecondNodeIDOnFreeBorder, in smIdType LastNodeIDOnFreeBorder, in smIdType FirstNodeIDOnSide, in smIdType LastNodeIDOnSide, in boolean CreatePolygons, in boolean CreatePolyedrs) raises (SALOME::SALOME_Exception)
Sew_Error SewSideElements (in smIdType_array IDsOfSide1Elements, in smIdType_array IDsOfSide2Elements, in smIdType NodeID1OfSide1ToMerge, in smIdType NodeID1OfSide2ToMerge, in smIdType NodeID2OfSide1ToMerge, in smIdType NodeID2OfSide2ToMerge) raises (SALOME::SALOME_Exception)
boolean ChangeElemNodes (in smIdType id, in smIdType_array newIDs) raises (SALOME::SALOME_Exception)
 Set new nodes for given element. More...
SMESH_Group DoubleElements (in SMESH_IDSource theElements, in string theGroupName) raises (SALOME::SALOME_Exception)
 Duplicates given elements, i.e. More...
boolean DoubleNodes (in smIdType_array theNodes, in smIdType_array theModifiedElems) raises (SALOME::SALOME_Exception)
 Creates a hole in a mesh by doubling the nodes of some particular elements. More...
boolean DoubleNode (in smIdType theNodeId, in smIdType_array theModifiedElems) raises (SALOME::SALOME_Exception)
 Creates a hole in a mesh by doubling the nodes of some particular elements This method provided for convenience works as DoubleNodes() described above. More...
boolean DoubleNodeGroup (in SMESH_GroupBase theNodes, in SMESH_GroupBase theModifiedElems) raises (SALOME::SALOME_Exception)
SMESH_Group DoubleNodeGroupNew (in SMESH_GroupBase theNodes, in SMESH_GroupBase theModifiedElems) raises (SALOME::SALOME_Exception)
boolean DoubleNodeGroups (in ListOfGroups theNodes, in ListOfGroups theModifiedElems) raises (SALOME::SALOME_Exception)
SMESH_Group DoubleNodeGroupsNew (in ListOfGroups theNodes, in ListOfGroups theModifiedElems) raises (SALOME::SALOME_Exception)
 Creates a hole in a mesh by doubling the nodes of some particular elements Works as DoubleNodeGroups() described above, but returns a new group with newly created nodes. More...
boolean DoubleNodeElem (in smIdType_array theElems, in smIdType_array theNodesNot, in smIdType_array theAffectedElems) raises (SALOME::SALOME_Exception)
boolean DoubleNodeElemInRegion (in smIdType_array theElems, in smIdType_array theNodesNot, in GEOM::GEOM_Object theShape) raises (SALOME::SALOME_Exception)
boolean DoubleNodeElemGroup (in SMESH_GroupBase theElems, in SMESH_GroupBase theNodesNot, in SMESH_GroupBase theAffectedElems) raises (SALOME::SALOME_Exception)
SMESH_Group DoubleNodeElemGroupNew (in SMESH_GroupBase theElems, in SMESH_GroupBase theNodesNot, in SMESH_GroupBase theAffectedElems) raises (SALOME::SALOME_Exception)
ListOfGroups DoubleNodeElemGroup2New (in SMESH_GroupBase theElems, in SMESH_GroupBase theNodesNot, in SMESH_GroupBase theAffectedElems, in boolean theElemGroupNeeded, in boolean theNodeGroupNeeded) raises (SALOME::SALOME_Exception)
boolean DoubleNodeElemGroupInRegion (in SMESH_GroupBase theElems, in SMESH_GroupBase theNodesNot, in GEOM::GEOM_Object theShape) raises (SALOME::SALOME_Exception)
boolean DoubleNodeElemGroups (in ListOfGroups theElems, in ListOfGroups theNodesNot, in ListOfGroups theAffectedElems) raises (SALOME::SALOME_Exception)
SMESH_Group DoubleNodeElemGroupsNew (in ListOfGroups theElems, in ListOfGroups theNodesNot, in ListOfGroups theAffectedElems) raises (SALOME::SALOME_Exception)
ListOfGroups DoubleNodeElemGroups2New (in ListOfGroups theElems, in ListOfGroups theNodesNot, in ListOfGroups theAffectedElems, in boolean theElemGroupNeeded, in boolean theNodeGroupNeeded) raises (SALOME::SALOME_Exception)
boolean DoubleNodeElemGroupsInRegion (in ListOfGroups theElems, in ListOfGroups theNodesNot, in GEOM::GEOM_Object theShape) raises (SALOME::SALOME_Exception)
ListOfGroups AffectedElemGroupsInRegion (in ListOfGroups theElems, in ListOfGroups theNodesNot, in GEOM::GEOM_Object theShape) raises (SALOME::SALOME_Exception)
 Identify the elements that will be affected by node duplication (actual duplication is not performed). More...
boolean Make2DMeshFrom3D () raises (SALOME::SALOME_Exception)
 Generates skin mesh (containing 2D cells) from 3D mesh The created 2D mesh elements based on nodes of free faces of boundary volumes. More...
SMESH_Mesh MakeBoundaryMesh (in SMESH_IDSource elements, in Bnd_Dimension dimension, in string groupName, in string meshName, in boolean toCopyElements, in boolean toCopyExistingBondary, out SMESH_Group group) raises (SALOME::SALOME_Exception)
 Creates missing boundary elements. More...
long MakeBoundaryElements (in Bnd_Dimension dimension, in string groupName, in string meshName, in boolean toCopyAll, in boolean toCreateAllElements, in ListOfIDSources groups, out SMESH_Mesh mesh, out SMESH_Group group) raises (SALOME::SALOME_Exception)
 Creates missing boundary elements around either the whole mesh or groups of 2D elements. More...
boolean DoubleNodesOnGroupBoundaries (in ListOfGroups theDomains, in boolean createJointElems, in boolean onAllBoundaries) raises (SALOME::SALOME_Exception)
 Double nodes on shared faces between groups of volumes and create flat elements on demand. More...
boolean CreateFlatElementsOnFacesGroups (in ListOfGroups theGroupsOfFaces) raises (SALOME::SALOME_Exception)
 Double nodes on some external faces and create flat elements. More...
void CreateHoleSkin (in double radius, in GEOM::GEOM_Object theShape, in string groupName, in double_array theNodesCoords, out array_of_long_array GroupsOfNodes) raises (SALOME::SALOME_Exception)
 identify all the elements around a geom shape, get the faces delimiting the hole Build groups of volume to remove, groups of faces to replace on the skin of the object, groups of faces to remove insidethe object, (idem edges). More...
void MakePolyLine (inout ListOfPolySegments segments, in string groupName) raises (SALOME::SALOME_Exception)
 Create a polyline consisting of 1D mesh elements each lying on a 2D element of the initial triangle mesh. More...
ListOfEdges MakeSlot (in SMESH_GroupBase segments, in double width) raises (SALOME::SALOME_Exception)
 Create a slot of given width around given 1D elements lying on a triangle mesh. More...
Also provides some analysis functions.
◆ Extrusion_Error
EXTR_OK
EXTR_NO_ELEMENTS
EXTR_PATH_NOT_EDGE
EXTR_BAD_PATH_SHAPE
◆ MirrorType
POINT
AXIS
PLANE
◆ Sew_Error
SEW_OK
SEW_BAD_SIDE_NODES
SEW_BAD_SIDE1_NODES
SEW_BAD_SIDE2_NODES
SEW_INTERNAL_ERROR
◆ Smooth_Method
LAPLACIAN_SMOOTH
CENTROIDAL_SMOOTH
◆ Add0DElement()
smIdType SMESH::SMESH_MeshEditor::Add0DElement ( in smIdType  IDOfNode,
IdOfNodeNode IDs for creation of element.
DuplicateElementsto add one more 0D element to a node or not
◆ AddBall()
smIdType SMESH::SMESH_MeshEditor::AddBall ( in smIdType  IDOfNode,
in double  diameter
◆ AddEdge()
smIdType SMESH::SMESH_MeshEditor::AddEdge ( in smIdType_array  IDsOfNodes)
IdsOfNodesList of node IDs for creation of element. Needed order of nodes in this list corresponds to description of MED. This description is located by the following link: http://www.salome-platform.org/salome2/web_med_internet/logiciels/medV2.2.2_doc_html/html/modele_de_donnees.html#3.
◆ AddFace()
smIdType SMESH::SMESH_MeshEditor::AddFace ( in smIdType_array  IDsOfNodes)
◆ AddNode()
smIdType SMESH::SMESH_MeshEditor::AddNode ( in double  x,
in double  y,
in double  z
Add a new node.
xX coordinate of new node
yY coordinate of new node
zZ coordinate of new node
integer identifier of new node
◆ AddNodeOnFace()
void SMESH::SMESH_MeshEditor::AddNodeOnFace ( in smIdType  triangle,
in double  x,
in double  y,
in double  z
◆ AddNodeOnSegment()
void SMESH::SMESH_MeshEditor::AddNodeOnSegment ( in smIdType  Node1,
in smIdType  Node2,
in double  position
◆ AddPolygonalFace()
smIdType SMESH::SMESH_MeshEditor::AddPolygonalFace ( in smIdType_array  IdsOfNodes)
◆ AddPolyhedralVolume()
smIdType SMESH::SMESH_MeshEditor::AddPolyhedralVolume ( in smIdType_array  IdsOfNodes,
IdsOfNodesList of node IDs for volume creation face by face.
QuantitiesList of integer values, Quantities[i] gives quantity of nodes in face number i.
◆ AddPolyhedralVolumeByFaces()
smIdType SMESH::SMESH_MeshEditor::AddPolyhedralVolumeByFaces ( in smIdType_array  IdsOfFaces)
IdsOfFacesList of face IDs for volume creation.
The created volume will refer only to nodes of the given faces, not to the faces itself.
◆ AddQuadPolygonalFace()
smIdType SMESH::SMESH_MeshEditor::AddQuadPolygonalFace ( in smIdType_array  IdsOfNodes)
IdsOfNodes- nodes of the polygon; corner nodes follow first
smIdType- ID of a new polygon
◆ AddVolume()
smIdType SMESH::SMESH_MeshEditor::AddVolume ( in smIdType_array  IDsOfNodes)
◆ AdvancedExtrusion()
ListOfGroups SMESH::SMESH_MeshEditor::AdvancedExtrusion ( in smIdType_array  IDsOfElements,
in long  NbOfSteps,
in long  ExtrFlags,
ExtrFlagsset flags for performing extrusion
SewTolerance- uses for comparing locations of nodes if flag EXTRUSION_FLAG_SEW is set
ToMakeGroups- if true, new elements will be included into new groups corresponding to groups the input elements included in.
ListOfGroups - new groups created if ToMakeGroups is true
◆ AffectedElemGroupsInRegion()
ListOfGroups SMESH::SMESH_MeshEditor::AffectedElemGroupsInRegion ( in ListOfGroups  theElems,
This method is the first step of DoubleNodeElemGroupsInRegion.
theElems- list of groups of elements (edges or faces) to be replicated
theNodesNot- list of groups of nodes not to replicated
theShape- shape to detect affected elements (element which geometric center located on or inside shape). The replicated nodes should be associated to affected elements.
groups of affected elements
See also
DoubleNodeElemGroupsInRegion()
◆ BestSplit()
short SMESH::SMESH_MeshEditor::BestSplit ( in smIdType  IDOfQuad,
IDOfQuadID of the quadrangle to be split.
CriterionA criterion to choose a diagonal for splitting.
1 if 1-3 diagonal is better, 2 if 2-4 diagonal is better, 0 if error occurs.
◆ ChangeElemNodes()
boolean SMESH::SMESH_MeshEditor::ChangeElemNodes ( in smIdType  id,
If number of nodes is not corresponded to type of element - returns false
◆ ClearLastCreated()
void SMESH::SMESH_MeshEditor::ClearLastCreated ( )
◆ ConvertFromQuadratic()
boolean SMESH::SMESH_MeshEditor::ConvertFromQuadratic ( )
◆ ConvertFromQuadraticObject()
void SMESH::SMESH_MeshEditor::ConvertFromQuadraticObject ( in SMESH_IDSource  theObject)
◆ ConvertToBiQuadratic()
void SMESH::SMESH_MeshEditor::ConvertToBiQuadratic ( in boolean  theForce3d,
◆ ConvertToQuadratic()
void SMESH::SMESH_MeshEditor::ConvertToQuadratic ( in boolean  theForce3d)
◆ ConvertToQuadraticObject()
void SMESH::SMESH_MeshEditor::ConvertToQuadraticObject ( in boolean  theForce3d,
◆ Create0DElementsOnAllNodes()
SMESH_IDSource SMESH::SMESH_MeshEditor::Create0DElementsOnAllNodes ( in SMESH_IDSource  theObject,
theObjectobject on whose nodes 0D elements will be created.
theGroupNameoptional name of a group to add 0D elements created and/or found on nodes of theObject.
theDuplicateElementsto add one more 0D element to a node or not
an object (a new group or a temporary SMESH_IDSource) holding ids of new and/or found 0D elements.
◆ CreateFlatElementsOnFacesGroups()
boolean SMESH::SMESH_MeshEditor::CreateFlatElementsOnFacesGroups ( in ListOfGroups  theGroupsOfFaces)
Flat elements are mainly used by some types of mechanic calculations.
Each group of the list must be constituted of faces. Triangles are transformed in prisms, and quadrangles in hexahedrons.
theGroupsOfFaces- list of groups of faces
TRUE if operation has been completed successfully, FALSE otherwise
◆ CreateHoleSkin()
void SMESH::SMESH_MeshEditor::CreateHoleSkin ( in double  radius,
Build ordered list of nodes at the border of each group of faces to replace (to be used to build a geom subshape)
◆ DeleteDiag()
boolean SMESH::SMESH_MeshEditor::DeleteDiag ( in smIdType  NodeID1,
in smIdType  NodeID2
◆ DoubleElements()
SMESH_Group SMESH::SMESH_MeshEditor::DoubleElements ( in SMESH_IDSource  theElements,
creates new elements based on the same nodes as the given ones.
theElements- container of elements to duplicate.
theGroupName- a name of group to contain the generated elements. If a group with such a name already exists, the new elements are added to the existing group, else a new group is created. If theGroupName is empty, new elements are not added in any group.
a group where the new elements are added. NULL if theGroupName == "".
See also
DoubleNode()
◆ DoubleNode()
boolean SMESH::SMESH_MeshEditor::DoubleNode ( in smIdType  theNodeId,
theNodeId- identifier of node to be doubled.
theModifiedElems- identifiers of elements to be updated.
See also
DoubleNodes(), DoubleNodeGroup(), DoubleNodeGroups()
◆ DoubleNodeElem()
boolean SMESH::SMESH_MeshEditor::DoubleNodeElem ( in smIdType_array  theElems,
theElems- the list of elements (edges or faces) to be replicated The nodes for duplication could be found from these elements
theNodesNot- list of nodes to NOT replicate
theAffectedElems- the list of elements (cells and edges) to which the replicated nodes should be associated to.
See also
◆ DoubleNodeElemGroup()
boolean SMESH::SMESH_MeshEditor::DoubleNodeElemGroup ( in SMESH_GroupBase  theElems,
theElems- group of of elements (edges or faces) to be replicated
theNodesNot- group of nodes not to replicated
theAffectedElems- group of elements to which the replicated nodes should be associated to.
See also
DoubleNodes(), DoubleNodeGroups(), DoubleNodeElemGroupNew()
◆ DoubleNodeElemGroup2New()
ListOfGroups SMESH::SMESH_MeshEditor::DoubleNodeElemGroup2New ( in SMESH_GroupBase  theElems,
Works as DoubleNodeElemGroup() described above, but returns two new groups: a group of newly created elements and a group of newly created nodes
theElemGroupNeeded- to create group of new elements or not
theNodeGroupNeeded- to create group of new nodes or not
two new groups of newly created elements (1st) and nodes (2nd)
See also
◆ DoubleNodeElemGroupInRegion()
boolean SMESH::SMESH_MeshEditor::DoubleNodeElemGroupInRegion ( in SMESH_GroupBase  theElems,
theElems- group of elements (edges or faces) to be replicated
See also
DoubleNodesInRegion(), DoubleNodeGroupsInRegion()
◆ DoubleNodeElemGroupNew()
SMESH_Group SMESH::SMESH_MeshEditor::DoubleNodeElemGroupNew ( in SMESH_GroupBase  theElems,
Works as DoubleNodeElemGroup() described above, but returns a new group with newly created elements.
See also
◆ DoubleNodeElemGroups()
boolean SMESH::SMESH_MeshEditor::DoubleNodeElemGroups ( in ListOfGroups  theElems,
See also
DoubleNodeGroup(), DoubleNodes(), DoubleNodeElemGroupsNew()
◆ DoubleNodeElemGroups2New()
ListOfGroups SMESH::SMESH_MeshEditor::DoubleNodeElemGroups2New ( in ListOfGroups  theElems,
Works as DoubleNodeElemGroups() described above, but returns two new groups: a group of newly created elements and a group of newly created nodes.
See also
◆ DoubleNodeElemGroupsInRegion()
boolean SMESH::SMESH_MeshEditor::DoubleNodeElemGroupsInRegion ( in ListOfGroups  theElems,
See also
DoubleNodeGroupInRegion(), DoubleNodesInRegion()
◆ DoubleNodeElemGroupsNew()
SMESH_Group SMESH::SMESH_MeshEditor::DoubleNodeElemGroupsNew ( in ListOfGroups  theElems,
Works as DoubleNodeElemGroups() described above, but returns a new group with newly created elements.
See also
◆ DoubleNodeElemInRegion()
boolean SMESH::SMESH_MeshEditor::DoubleNodeElemInRegion ( in smIdType_array  theElems,
See also
DoubleNodeGroupInRegion(), DoubleNodeGroupsInRegion()
◆ DoubleNodeGroup()
boolean SMESH::SMESH_MeshEditor::DoubleNodeGroup ( in SMESH_GroupBase  theNodes,
theNodes- group of nodes to be doubled.
theModifiedElems- group of elements to be updated.
See also
DoubleNode(), DoubleNodes(), DoubleNodeGroups(), DoubleNodeGroupNew()
◆ DoubleNodeGroupNew()
SMESH_Group SMESH::SMESH_MeshEditor::DoubleNodeGroupNew ( in SMESH_GroupBase  theNodes,
Works as DoubleNodeGroup() described above, but returns a new group with newly created nodes.
See also
DoubleNodeGroup()
◆ DoubleNodeGroups()
boolean SMESH::SMESH_MeshEditor::DoubleNodeGroups ( in ListOfGroups  theNodes,
theNodes- list of groups of nodes to be doubled
theModifiedElems- list of groups of elements to be updated.
See also
DoubleNode(), DoubleNodeGroup(), DoubleNodes()
◆ DoubleNodeGroupsNew()
SMESH_Group SMESH::SMESH_MeshEditor::DoubleNodeGroupsNew ( in ListOfGroups  theNodes,
See also
DoubleNodeGroups()
◆ DoubleNodes()
boolean SMESH::SMESH_MeshEditor::DoubleNodes ( in smIdType_array  theNodes,
theNodes- identifiers of nodes to be doubled
theModifiedElems- identifiers of elements to be updated by the new (doubled) nodes. If list of element identifiers is empty then nodes are doubled but they not assigned to elements
See also
DoubleNode(), DoubleNodeGroup(), DoubleNodeGroups()
◆ DoubleNodesOnGroupBoundaries()
boolean SMESH::SMESH_MeshEditor::DoubleNodesOnGroupBoundaries ( in ListOfGroups  theDomains,
The list of groups must describe a partition of the mesh volumes. The nodes of the internal faces at the boundaries of the groups are doubled. In option, the internal faces are replaced by flat elements. Triangles are transformed in prisms, and quadrangles in hexahedrons.
theDomains- list of groups of volumes
createJointElems- if TRUE, create the elements
onAllBoundaries- if TRUE, the nodes and elements are also created on the boundary between theDomains and the rest mesh
◆ ExtrusionAlongPathObjects()
ListOfGroups SMESH::SMESH_MeshEditor::ExtrusionAlongPathObjects ( in ListOfIDSources  Nodes,
◆ ExtrusionByNormal()
ListOfGroups SMESH::SMESH_MeshEditor::ExtrusionByNormal ( in ListOfIDSources  theObjects,
in double  stepSize,
in long  nbOfSteps,
in short  dim
◆ ExtrusionSweepObjects()
ListOfGroups SMESH::SMESH_MeshEditor::ExtrusionSweepObjects ( in ListOfIDSources  nodes,
in long  nbOfSteps,
nodes- nodes to extrude: a list including groups, sub-meshes or a mesh.
edges- edges to extrude: a list including groups, sub-meshes or a mesh.
faces- faces to extrude: a list including groups, sub-meshes or a mesh.
stepVector- vector giving direction and distance of an extrusion step.
nbOfSteps- number of elements to generate from one element.
toMakeGroups- if true, new elements will be included into new groups corresponding to groups the input elements included in.
scaleFactors- optional scale factors to apply during extrusion; it's usage depends on scalesVariation parameter.
scalesVariation- if True, scaleFactors are spread over all NbOfSteps, otherwise scaleFactors[i] is applied to nodes at the i-th extrusion step.
angles- optional rotation angles to apply during extrusion; it's usage depends on anglesVariation parameter.
anglesVariation- if True, angles are spread over all NbOfSteps, otherwise angle[i] is applied to nodes at the i-th extrusion step.
ListOfGroups - new groups created if toMakeGroups is true
◆ FillHole()
SMESH_Group SMESH::SMESH_MeshEditor::FillHole ( in FreeBorder  hole,
in string  groupName
Optionally add new faces to a given group, which is returned.
◆ FindAmongElementsByPoint()
smIdType_array SMESH::SMESH_MeshEditor::FindAmongElementsByPoint ( in SMESH_IDSource  elements,
in double  x,
in double  y,
in double  z,
in ElementType  type
'ALL' type means elements of any type excluding nodes and 0D elements
◆ FindCoincidentFreeBorders()
CoincidentFreeBorders SMESH::SMESH_MeshEditor::FindCoincidentFreeBorders ( in double  tolerance)
If the tolerance <= 0.0 then one tenth of an average size of elements adjacent to free borders being compared is used.
◆ FindCoincidentNodes()
void SMESH::SMESH_MeshEditor::FindCoincidentNodes ( in double  Tolerance,
◆ FindCoincidentNodesOnPart()
void SMESH::SMESH_MeshEditor::FindCoincidentNodesOnPart ( in SMESH_IDSource  SubMeshOrGroup,
◆ FindCoincidentNodesOnPartBut()
void SMESH::SMESH_MeshEditor::FindCoincidentNodesOnPartBut ( in ListOfIDSources  SubMeshOrGroup,
◆ FindElementsByPoint()
smIdType_array SMESH::SMESH_MeshEditor::FindElementsByPoint ( in double  x,
in double  y,
in double  z,
in ElementType  type
◆ FindEqualElements()
void SMESH::SMESH_MeshEditor::FindEqualElements ( in ListOfIDSources  MeshOrSubMeshOrGroup,
MeshOrSubMeshOrGroupMesh or SubMesh, or Group of elements for searching.
List of groups of equal elements.
◆ FindFreeBorders()
ListOfFreeBorders SMESH::SMESH_MeshEditor::FindFreeBorders ( in boolean  closedOnly)
◆ FindNodeClosestTo()
smIdType SMESH::SMESH_MeshEditor::FindNodeClosestTo ( in double  x,
in double  y,
in double  z
◆ FindSharpEdges()
ListOfEdges SMESH::SMESH_MeshEditor::FindSharpEdges ( in double  angle,
Optionally add existing edges. Angle is in degrees.
◆ Get1DBranches()
array_of_long_array SMESH::SMESH_MeshEditor::Get1DBranches ( in SMESH_IDSource  edges,
A node where number of meeting edges != 2 is a group end. An optional startNode is used to orient groups it belongs to.
a list of edge groups and a list of corresponding node groups. If a group is closed, the first and last nodes of the group are same.
◆ GetLastCreatedElems()
smIdType_array SMESH::SMESH_MeshEditor::GetLastCreatedElems ( )
◆ GetLastCreatedNodes()
smIdType_array SMESH::SMESH_MeshEditor::GetLastCreatedNodes ( )
◆ GetLastError()
ComputeError SMESH::SMESH_MeshEditor::GetLastError ( )
◆ GetMesh()
SMESH_Mesh SMESH::SMESH_MeshEditor::GetMesh ( )
◆ GetPointState()
short SMESH::SMESH_MeshEditor::GetPointState ( in double  x,
in double  y,
in double  z
TopAbs_UNKNOWN state means that either mesh is wrong or the analysis fails.
◆ GetPreviewData()
MeshPreviewStruct SMESH::SMESH_MeshEditor::GetPreviewData ( )
◆ InverseDiag()
boolean SMESH::SMESH_MeshEditor::InverseDiag ( in smIdType  NodeID1,
in smIdType  NodeID2
◆ IsCoherentOrientation2D()
boolean SMESH::SMESH_MeshEditor::IsCoherentOrientation2D ( )
◆ IsManifold()
boolean SMESH::SMESH_MeshEditor::IsManifold ( )
◆ LinearAnglesVariation()
double_array SMESH::SMESH_MeshEditor::LinearAnglesVariation ( in SMESH_Mesh  PathMesh,
◆ Make2DMeshFrom3D()
boolean SMESH::SMESH_MeshEditor::Make2DMeshFrom3D ( )
◆ MakeBoundaryElements()
long SMESH::SMESH_MeshEditor::MakeBoundaryElements ( in Bnd_Dimension  dimension,
in string  meshName,
dimension- defines type of boundary elements to create
groupName- a name of group to store all boundary elements in, "" means not to create the group
meshName- a name of a new mesh, which is a copy of the initial mesh + created boundary elements; "" means not to create the new mesh
toCopyAll- if true, the whole initial mesh will be copied into the new mesh else only the new elements will be copied into the new mesh
toCreateAllElements- if true, all the boundary elements of the mesh are computed.
groups- optional groups of 2D elements to make boundary around
mesh- returns the mesh where elements were added to
group- returns the created group, if any
long- number of added boundary elements
◆ MakeBoundaryMesh()
SMESH_Mesh SMESH::SMESH_MeshEditor::MakeBoundaryMesh ( in SMESH_IDSource  elements,
in string  meshName,
elements- elements whose boundary is to be checked
dimension- defines type of boundary elements to create BND_1DFROM3D creates mesh edges on all borders of free facets of 3D elements.
groupName- a name of group to store created boundary elements in, "" means not to create the group
meshName- a name of new mesh to store created boundary elements in, "" means not to create the new mesh
toCopyElements- if true, the checked elements will be copied into the new mesh else only boundary elements will be copied into the new mesh
toCopyExistingBondary- if true, not only new but also pre-existing boundary elements will be copied into the new mesh
group- returns the create group, if any
SMESH::SMESH_Mesh- the mesh where elements were added to
◆ MakeIDSource()
SMESH_IDSource SMESH::SMESH_MeshEditor::MakeIDSource ( in smIdType_array  IDsOfElements,
in ElementType  type
IDsOfElementslist of mesh elements identifiers
new ID source object
◆ MakePolyLine()
void SMESH::SMESH_MeshEditor::MakePolyLine ( inout ListOfPolySegments  segments,
in string  groupName
Positions of new nodes are found by cutting the mesh by the plane passing through pairs of points specified by each PolySegment structure. If there are several paths connecting a pair of points, the shortest path is selected by the module. Position of the cutting plane is defined by the two points and an optional vector lying on the plane specified by a PolySegment. By default the vector is defined by Mesh module as following. A middle point of the two given points is computed. The middle point is projected to the mesh. The vector goes from the middle point to the projection point. In case of planar mesh, the vector is normal to the mesh.
[in,out]segments- PolySegment's defining positions of cutting planes. Return the used vector which goes from the middle point to its projection.
[in]groupName- optional name of a group where created mesh segments will be added.
◆ MakeSlot()
ListOfEdges SMESH::SMESH_MeshEditor::MakeSlot ( in SMESH_GroupBase  segments,
in double  width
The slot is constructed by cutting faces by cylindrical surfaces made around each segment. Segments are expected to be created by MakePolyLine().
Edges located at the slot boundary
◆ MergeElements()
void SMESH::SMESH_MeshEditor::MergeElements ( in array_of_long_array  GroupsOfElementsID,
GroupsOfElementsIDGroups of elements for merging.
◆ MergeEqualElements()
void SMESH::SMESH_MeshEditor::MergeEqualElements ( )
◆ MergeNodes()
void SMESH::SMESH_MeshEditor::MergeNodes ( in array_of_long_array  GroupsOfNodes,
◆ Mirror()
void SMESH::SMESH_MeshEditor::Mirror ( in smIdType_array  IDsOfElements,
in MirrorType  Type,
in boolean  Copy
◆ MirrorMakeGroups()
ListOfGroups SMESH::SMESH_MeshEditor::MirrorMakeGroups ( in smIdType_array  IDsOfElements,
in MirrorType  Type
◆ MirrorMakeMesh()
SMESH_Mesh SMESH::SMESH_MeshEditor::MirrorMakeMesh ( in smIdType_array  IDsOfElements,
in MirrorType  Type,
in string  MeshName
◆ MirrorObject()
void SMESH::SMESH_MeshEditor::MirrorObject ( in SMESH_IDSource  theObject,
in MirrorType  Type,
in boolean  Copy
◆ MirrorObjectMakeGroups()
ListOfGroups SMESH::SMESH_MeshEditor::MirrorObjectMakeGroups ( in SMESH_IDSource  theObject,
in MirrorType  Type
◆ MirrorObjectMakeMesh()
SMESH_Mesh SMESH::SMESH_MeshEditor::MirrorObjectMakeMesh ( in SMESH_IDSource  theObject,
in MirrorType  Type,
in string  MeshName
◆ MoveClosestNodeToPoint()
smIdType SMESH::SMESH_MeshEditor::MoveClosestNodeToPoint ( in double  x,
in double  y,
in double  z,
in smIdType  nodeID
◆ MoveNode()
boolean SMESH::SMESH_MeshEditor::MoveNode ( in smIdType  NodeID,
in double  x,
in double  y,
in double  z
◆ Offset()
SMESH_Mesh SMESH::SMESH_MeshEditor::Offset ( in SMESH_IDSource  theObject,
in double  Value,
in string  MeshName,
◆ ProjectPoint()
smIdType SMESH::SMESH_MeshEditor::ProjectPoint ( in double  x,
in double  y,
in double  z,
Return ID of an element of given type where the given point is projected and coordinates of the projection point. In the case if nothing found, return -1 and []
◆ QuadTo4Tri()
void SMESH::SMESH_MeshEditor::QuadTo4Tri ( in SMESH_IDSource  theQuads)
theQuadsContainer of quadrangles to split.
◆ QuadToTri()
boolean SMESH::SMESH_MeshEditor::QuadToTri ( in smIdType_array  IDsOfElements,
IDsOfElementsIds of quadrangles to split.
theCriterionIs used to choose a diagonal for splitting.
TRUE in case of success, FALSE otherwise.
◆ QuadToTriObject()
boolean SMESH::SMESH_MeshEditor::QuadToTriObject ( in SMESH_IDSource  theObject,
Behaves like the above method, taking a list of elements from theObject
◆ RemoveElements()
boolean SMESH::SMESH_MeshEditor::RemoveElements ( in smIdType_array  IDsOfElements)
true if elements are correctly removed or false otherwise
◆ RemoveNodes()
boolean SMESH::SMESH_MeshEditor::RemoveNodes ( in smIdType_array  IDsOfNodes)
IDsOfNodeslist of mesh nodes identifiers
true if nodes are correctly removed or false otherwise
◆ RemoveNodeWithReconnection()
void SMESH::SMESH_MeshEditor::RemoveNodeWithReconnection ( in smIdType  nodeID)
nodeIDnode identifier
Exceptions
ifmesh is not a triangle one
◆ RemoveOrphanNodes()
smIdType SMESH::SMESH_MeshEditor::RemoveOrphanNodes ( )
number of removed nodes
◆ RenumberElements()
void SMESH::SMESH_MeshEditor::RenumberElements ( )
◆ RenumberNodes()
void SMESH::SMESH_MeshEditor::RenumberNodes ( )
◆ Reorient()
boolean SMESH::SMESH_MeshEditor::Reorient ( in smIdType_array  IDsOfElements)
◆ Reorient2D()
long SMESH::SMESH_MeshEditor::Reorient2D ( in SMESH_IDSource  the2Dgroup,
in long  theFace,
the2Dgroup- the mesh or its part to reorient
theDirection- desired direction of normal of theFace
theFace- ID of face whose orientation is checked. It can be < 1 then thePoint is used to find a face.
thePoint- is used to find a face if theFace < 1.
number of reoriented faces.
Referenced by StdMeshers::Cartesian3D::Hexahedron::addFaces().
◆ Reorient2DBy3D()
long SMESH::SMESH_MeshEditor::Reorient2DBy3D ( in ListOfIDSources  faces,
faces- a list of objects containing face to reorient
volumes- an object containing volumes.
outsideNormal- to orient faces to have their normal pointing either outside or inside the adjacent volumes.
◆ Reorient2DByNeighbours()
long SMESH::SMESH_MeshEditor::Reorient2DByNeighbours ( in SMESH::ListOfIDSources  objectFaces,
objectFaces- faces to reorient in a list including either the whole mesh or groups and/or sub-meshes.
referenceFaces- correctly oriented faces in a list of groups and/or sub-meshes. It can be empty, then the 1st face in objectFaces is used as the reference.
◆ ReorientObject()
boolean SMESH::SMESH_MeshEditor::ReorientObject ( in SMESH_IDSource  theObject)
◆ Rotate()
void SMESH::SMESH_MeshEditor::Rotate ( in smIdType_array  IDsOfElements,
in AxisStruct  Axis,
in boolean  Copy
◆ RotateMakeGroups()
ListOfGroups SMESH::SMESH_MeshEditor::RotateMakeGroups ( in smIdType_array  IDsOfElements,
in AxisStruct  Axis,
◆ RotateMakeMesh()
SMESH_Mesh SMESH::SMESH_MeshEditor::RotateMakeMesh ( in smIdType_array  IDsOfElements,
in AxisStruct  Axis,
in string  MeshName
◆ RotateObject()
void SMESH::SMESH_MeshEditor::RotateObject ( in SMESH_IDSource  theObject,
in AxisStruct  Axis,
in boolean  Copy
◆ RotateObjectMakeGroups()
ListOfGroups SMESH::SMESH_MeshEditor::RotateObjectMakeGroups ( in SMESH_IDSource  theObject,
in AxisStruct  Axis,
◆ RotateObjectMakeMesh()
SMESH_Mesh SMESH::SMESH_MeshEditor::RotateObjectMakeMesh ( in SMESH_IDSource  theObject,
in AxisStruct  Axis,
in string  MeshName
◆ RotationSweepObjects()
ListOfGroups SMESH::SMESH_MeshEditor::RotationSweepObjects ( in ListOfIDSources  Nodes,
in AxisStruct  Axis,
in long  NbOfSteps,
Nodes- nodes to revolve: a list including groups, sub-meshes or a mesh
Edges- edges to revolve: a list including groups, sub-meshes or a mesh
Faces- faces to revolve: a list including groups, sub-meshes or a mesh
Axis- rotation axis
AngleInRadians- rotation angle
NbOfSteps- number of elements to generate from one element
◆ Scale()
void SMESH::SMESH_MeshEditor::Scale ( in SMESH_IDSource  theObject,
in boolean  Copy
◆ ScaleMakeGroups()
ListOfGroups SMESH::SMESH_MeshEditor::ScaleMakeGroups ( in SMESH_IDSource  theObject,
◆ ScaleMakeMesh()
SMESH_Mesh SMESH::SMESH_MeshEditor::ScaleMakeMesh ( in SMESH_IDSource  theObject,
in string  MeshName
◆ SetMeshElementOnShape()
void SMESH::SMESH_MeshEditor::SetMeshElementOnShape ( in smIdType  ElementID,
in long  ShapeID
ElementID- element ID
ShapeID- shape ID available through GEOM_Object.GetSubShapeIndices()[0]
◆ SetNodeInVolume()
void SMESH::SMESH_MeshEditor::SetNodeInVolume ( in smIdType  NodeID,
in long  SolidID
NodeID- node ID
SolidID- vertex ID available through GEOM_Object.GetSubShapeIndices()[0]
◆ SetNodeOnEdge()
void SMESH::SMESH_MeshEditor::SetNodeOnEdge ( in smIdType  NodeID,
in long  EdgeID,
NodeID- node ID
EdgeID- edge ID available through GEOM_Object.GetSubShapeIndices()[0]
paramOnEdge- parameter on edge where the node is located
◆ SetNodeOnFace()
void SMESH::SMESH_MeshEditor::SetNodeOnFace ( in smIdType  NodeID,
in long  FaceID,
in double  u,
in double  v
NodeID- node ID
FaceID- face ID available through GEOM_Object.GetSubShapeIndices()[0]
u- U parameter on face where the node is located
v- V parameter on face where the node is located
◆ SetNodeOnVertex()
void SMESH::SMESH_MeshEditor::SetNodeOnVertex ( in smIdType  NodeID,
in long  VertexID
NodeID- node ID
VertexID- vertex ID available through GEOM_Object.GetSubShapeIndices()[0]
◆ SewBorderToSide()
Sew_Error SMESH::SMESH_MeshEditor::SewBorderToSide ( in smIdType  FirstNodeIDOnFreeBorder,
◆ SewCoincidentFreeBorders()
short SMESH::SMESH_MeshEditor::SewCoincidentFreeBorders ( in CoincidentFreeBorders  freeBorders,
◆ SewConformFreeBorders()
Sew_Error SMESH::SMESH_MeshEditor::SewConformFreeBorders ( in smIdType  FirstNodeID1,
◆ SewFreeBorders()
Sew_Error SMESH::SMESH_MeshEditor::SewFreeBorders ( in smIdType  FirstNodeID1,
◆ SewSideElements()
Sew_Error SMESH::SMESH_MeshEditor::SewSideElements ( in smIdType_array  IDsOfSide1Elements,
◆ Smooth()
boolean SMESH::SMESH_MeshEditor::Smooth ( in smIdType_array  IDsOfElements,
◆ SmoothObject()
boolean SMESH::SMESH_MeshEditor::SmoothObject ( in SMESH_IDSource  theObject,
◆ SmoothParametric()
boolean SMESH::SMESH_MeshEditor::SmoothParametric ( in smIdType_array  IDsOfElements,
◆ SmoothParametricObject()
boolean SMESH::SMESH_MeshEditor::SmoothParametricObject ( in SMESH_IDSource  theObject,
◆ SplitBiQuadraticIntoLinear()
void SMESH::SMESH_MeshEditor::SplitBiQuadraticIntoLinear ( in ListOfIDSources  elems)
  • bi-quadratic triangle will be split into 3 linear quadrangles;
  • bi-quadratic quadrangle will be split into 4 linear quadrangles;
  • tri-quadratic hexahedron will be split into 8 linear hexahedra; Quadratic elements of lower dimension adjacent to the split bi-quadratic element will be split in order to keep the mesh conformal.
    elems- elements to split
◆ SplitHexahedraIntoPrisms()
void SMESH::SMESH_MeshEditor::SplitHexahedraIntoPrisms ( in SMESH_IDSource  elems,
startHexPoint- a point used to find a hexahedron for which facetToSplitNormal gives a normal vector defining facets to split into triangles.
facetToSplitNormal- normal used to find a facet of hexahedron to split into triangles.
methodFlags- flags passing splitting method: 1 - split the hexahedron into 2 prisms 2 - split the hexahedron into 4 prisms
allDomains- if False, only hexahedra adjacent to one closest to facetToSplitNormal location are split, else facetToSplitNormal is used to find the facet to split in all domains present in elems.
◆ SplitQuad()
boolean SMESH::SMESH_MeshEditor::SplitQuad ( in smIdType_array  IDsOfElements,
in boolean  Diag13
theElemsThe faces to be split.
the13DiagIs used to choose a diagonal for splitting.
◆ SplitQuadObject()
boolean SMESH::SMESH_MeshEditor::SplitQuadObject ( in SMESH_IDSource  theObject,
in boolean  Diag13
Behaves like the above method, taking list of elements from theObject
◆ SplitVolumesIntoTetra()
void SMESH::SMESH_MeshEditor::SplitVolumesIntoTetra ( in SMESH_IDSource  elems,
methodFlags- flags passing splitting method: 1 - split the hexahedron into 5 tetrahedrons 2 - split the hexahedron into 6 tetrahedrons 3 - split the hexahedron into 24 tetrahedrons
◆ SplitVolumesIntoTetraAvoidOverConstrainedVolumes()
void SMESH::SMESH_MeshEditor::SplitVolumesIntoTetraAvoidOverConstrainedVolumes ( in SMESH_IDSource  elems,
◆ Translate()
void SMESH::SMESH_MeshEditor::Translate ( in smIdType_array  IDsOfElements,
in boolean  Copy
◆ TranslateMakeGroups()
ListOfGroups SMESH::SMESH_MeshEditor::TranslateMakeGroups ( in smIdType_array  IDsOfElements,
in DirStruct  Vector
◆ TranslateMakeMesh()
SMESH_Mesh SMESH::SMESH_MeshEditor::TranslateMakeMesh ( in smIdType_array  IDsOfElements,
in string  MeshName
◆ TranslateObject()
void SMESH::SMESH_MeshEditor::TranslateObject ( in SMESH_IDSource  theObject,
in boolean  Copy
◆ TranslateObjectMakeGroups()
ListOfGroups SMESH::SMESH_MeshEditor::TranslateObjectMakeGroups ( in SMESH_IDSource  theObject,
in DirStruct  Vector
◆ TranslateObjectMakeMesh()
SMESH_Mesh SMESH::SMESH_MeshEditor::TranslateObjectMakeMesh ( in SMESH_IDSource  theObject,
in string  MeshName
◆ TriToQuad()
boolean SMESH::SMESH_MeshEditor::TriToQuad ( in smIdType_array  IDsOfElements,
in double  MaxAngle
IDsOfElementsIds of triangles to be fused.
theCriterionIs used to choose a neighbour to fuse with.
theMaxAngleIs a max angle between element normals at which fusion is still performed; theMaxAngle is measured in radians.
true in case of success, FALSE otherwise.
◆ TriToQuadObject()
boolean SMESH::SMESH_MeshEditor::TriToQuadObject ( in SMESH_IDSource  theObject,
in double  MaxAngle
