SMESHDS_GroupOnFilter Class Reference
Groups whose contents is dynamically updated using the filter. More...
#include <SMESHDS_GroupOnFilter.hxx>
Inheritance diagram for SMESHDS_GroupOnFilter:
 SMESHDS_GroupOnFilter (const int theID, const SMESHDS_Mesh *theMesh, const SMDSAbs_ElementType theType, const SMESH_PredicatePtr &thePredicate)
 Creates a group based on thePredicate. More...
void SetPredicate (const SMESH_PredicatePtr &thePredicate)
 Sets a new predicate. More...
SMESH_PredicatePtr GetPredicate () const
std::vector< smIdType > GetMeshInfo () const
 Return info on sub-types of elements. More...
template<typename IDTYPE >
smIdType GetElementIds (IDTYPE *ids) const
virtual smIdType Extent () const
 Returns nb of elements. More...
virtual bool IsEmpty ()
 Checks emptyness. More...
virtual bool Contains (const smIdType theID)
 Checks if the element belongs to the group. More...
virtual bool Contains (const SMDS_MeshElement *elem)
virtual SMDS_ElemIteratorPtr GetElements () const
 Return iterator on all elements. More...
virtual int GetTic () const
 Return a value allowing to find out if a group has changed or not. More...
bool IsUpToDate () const
 Return false if update() is needed. More...
int GetID () const
virtual smIdType GetID (const int theIndex)
 Don't use it! More...
const SMESHDS_Mesh * GetMesh () const
virtual void SetType (SMDSAbs_ElementType theType)
SMDSAbs_ElementType GetType () const
void SetStoreName (const char *theName)
const char * GetStoreName () const
void SetColor (const Quantity_Color &theColor)
Quantity_Color GetColor () const
void SetColorGroup (int theColorGroup)
int GetColorGroup () const
static void SetDefaultColor (const Quantity_Color &theColor)
virtual SMDS_ElemIteratorPtr getElements ()
 Return elements before mesh compacting. More...
virtual void tmpClear ()
 clear myElements before re-filling after mesh compacting More...
virtual void add (const SMDS_MeshElement *element)
 Re-fill myElements after mesh compacting. More...
virtual void compact ()
 allow the descendant treat its elements before mesh clearing More...
const SMDS_MeshElement * findInMesh (const smIdType theID) const
void resetIterator ()
 Internal method: resets cached iterator, should be called by ancestors when they are modified (ex: Add() or Remove() ) More...
void update () const
 Updates myElements if necessary. More...
bool updateParallel () const
 Updates myElements in parallel. More...
void setChanged (bool changed=true)
 Sets myMeshModifTime and clear fields according to modification state. More...
const SMDS_MeshElement * setNbElemToSkip (SMDS_ElemIteratorPtr &elIt)
 Sets myNbElemToSkip. More...
int getElementIds (void *ids, size_t idSize) const
 Fill ids of elements. More...
virtual void clear ()
void beforeCompacting ()
 store vtkIDs of elements More...
void restoreElements (const std::vector< smIdType > &idNodessOldToNew, const std::vector< smIdType > &idCellsOldToNew)
 restore pointers to elements More...
SMESH_PredicatePtr myPredicate
std::vector< smIdType > myMeshInfo
std::vector< const SMDS_MeshElement * > myElements
bool myElementsOK
size_t myMeshModifTime
int myPredicateTic
size_t myNbElemToSkip
int myID
const SMESHDS_Mesh * myMesh
SMDSAbs_ElementType myType
std::string myStoreName
Quantity_Color myColor
smIdType myCurIndex
smIdType myCurID
SMDS_ElemIteratorPtr myIterator
SMDS_Mesh * myMesh
std::vector< const SMDS_MeshElement * > myExternalElems
 elements not contained in the mesh More...
std::vector< vtkIdType > myVtkIDs
 vtk IDs of elements More...
std::vector< bool > myIsNode
std::set< SMDS_ElementHolder * >::iterator myPtrInMesh
Static Private Attributes
static Quantity_Color myDefaultColor = Quantity_Color( 0.0, 0.0, 0.0, Quantity_TOC_RGB )
◆ SMESHDS_GroupOnFilter()
SMESHDS_GroupOnFilter::SMESHDS_GroupOnFilter ( const int  theID,
const SMESHDS_Mesh *  theMesh,
const SMESH_PredicatePtr &  thePredicate
References SetPredicate().
◆ add()
void SMESHDS_GroupOnFilter::add ( const SMDS_MeshElement *  element)
Implements SMDS_ElementHolder.
References myElements.
◆ beforeCompacting()
◆ clear()
virtual void SMDS_ElementHolder::clear ( )
◆ compact()
virtual void SMESHDS_GroupOnFilter::compact ( )
◆ Contains() [1/2]
bool SMESHDS_GroupOnFilter::Contains ( const SMDS_MeshElement *  elem)
Reimplemented from SMESHDS_GroupBase.
References SMDS_MeshElement::GetID(), and myPredicate.
◆ Contains() [2/2]
bool SMESHDS_GroupOnFilter::Contains ( const smIdType  theID)
References myPredicate.
◆ Extent()
smIdType SMESHDS_GroupOnFilter::Extent ( ) const
References myMeshInfo, and update().
Referenced by GetElements(), and IsEmpty().
◆ findInMesh()
◆ GetColor()
◆ GetColorGroup()
int SMESHDS_GroupBase::GetColorGroup ( ) const
◆ GetElementIds()
smIdType SMESHDS_GroupOnFilter::GetElementIds ( IDTYPE *  ids) const
◆ getElementIds()
int SMESHDS_GroupOnFilter::getElementIds ( void *  ids,
size_t  idSize
And return their number. ids must be pre-allocated using nb of elements of type == GetType()
References GetElements(), SMDS_MeshElement::GetEntityType(), SMDS_MeshElement::GetID(), IsUpToDate(), myMeshInfo, setChanged(), setNbElemToSkip(), and SMDSEntity_Last.
◆ getElements()
SMDS_ElemIteratorPtr SMESHDS_GroupOnFilter::getElements ( )
◆ GetElements()
◆ GetID() [1/2]
◆ GetID() [2/2]
smIdType SMESHDS_GroupBase::GetID ( const int  theIndex)
◆ GetMesh()
◆ GetMeshInfo()
std::vector< smIdType > SMESHDS_GroupOnFilter::GetMeshInfo ( ) const
◆ GetPredicate()
SMESH_PredicatePtr SMESHDS_GroupOnFilter::GetPredicate ( ) const
◆ GetStoreName()
◆ GetTic()
int SMESHDS_GroupOnFilter::GetTic ( ) const
Implements SMESHDS_GroupBase.
References SMESHDS_GroupBase::GetMesh(), SMDS_Mesh::GetMTime(), and myPredicateTic.
◆ GetType()
◆ IsEmpty()
bool SMESHDS_GroupOnFilter::IsEmpty ( )
Checks emptyness.
References Extent(), GetElements(), IsUpToDate(), and setChanged().
◆ IsUpToDate()
bool SMESHDS_GroupOnFilter::IsUpToDate ( ) const
◆ resetIterator()
void SMESHDS_GroupBase::resetIterator ( )
References SMESHDS_GroupBase::myCurID, and SMESHDS_GroupBase::myCurIndex.
Referenced by SMESHDS_Group::Add(), SMESHDS_Group::Clear(), and SMESHDS_Group::Remove().
◆ restoreElements()
void SMDS_ElementHolder::restoreElements ( const std::vector< smIdType > &  idNodessOldToNew,
const std::vector< smIdType > &  idCellsOldToNew
privateinherited
◆ setChanged()
void SMESHDS_GroupOnFilter::setChanged ( bool  changed = true)
References SMESHDS_GroupBase::GetMesh(), SMDS_Mesh::GetMTime(), myElements, myElementsOK, myMeshInfo, myMeshModifTime, myNbElemToSkip, and SMDSEntity_Last.
Referenced by getElementIds(), IsEmpty(), SetPredicate(), and update().
◆ SetColor()
void SMESHDS_GroupBase::SetColor ( const Quantity_Color &  theColor)
◆ SetColorGroup()
void SMESHDS_GroupBase::SetColorGroup ( int  theColorGroup)
◆ SetDefaultColor()
static void SMESHDS_GroupBase::SetDefaultColor ( const Quantity_Color &  theColor)
Referenced by SMESH_Gen_i::SetOption().
◆ setNbElemToSkip()
const SMDS_MeshElement * SMESHDS_GroupOnFilter::setNbElemToSkip ( SMDS_ElemIteratorPtr &  okElemIt)
okElemIt- iterator on OK elements
constSMDS_MeshElement* - the first OK element
References SMDS_Mesh::elementsIterator(), SMESHDS_GroupBase::GetMesh(), SMESHDS_GroupBase::GetType(), and myNbElemToSkip.
Referenced by getElementIds(), and update().
◆ SetPredicate()
void SMESHDS_GroupOnFilter::SetPredicate ( const SMESH_PredicatePtr &  thePredicate)
References SMESHDS_GroupBase::GetMesh(), myPredicate, myPredicateTic, and setChanged().
Referenced by SMESHDS_GroupOnFilter().
◆ SetStoreName()
◆ SetType()
void SMESHDS_GroupBase::SetType ( SMDSAbs_ElementType  theType)
Reimplemented in SMESHDS_Group.
References SMESHDS_GroupBase::myType.
Referenced by SMESHDS_Group::SetType().
◆ tmpClear()
void SMESHDS_GroupOnFilter::tmpClear ( )
◆ update()
void SMESHDS_GroupOnFilter::update ( ) const
◆ updateParallel()
bool SMESHDS_GroupOnFilter::updateParallel ( ) const
Referenced by GetElements(), and update().
◆ myColor
Quantity_Color SMESHDS_GroupBase::myColor
privateinherited
◆ myCurID
smIdType SMESHDS_GroupBase::myCurID
privateinherited
◆ myCurIndex
smIdType SMESHDS_GroupBase::myCurIndex
privateinherited
◆ myDefaultColor
Quantity_Color SMESHDS_GroupBase::myDefaultColor = Quantity_Color( 0.0, 0.0, 0.0, Quantity_TOC_RGB )
staticprivateinherited
◆ myElements
std::vector< const SMDS_MeshElement*> SMESHDS_GroupOnFilter::myElements
◆ myElementsOK
bool SMESHDS_GroupOnFilter::myElementsOK
Referenced by GetElements(), and setChanged().
◆ myExternalElems
std::vector<const SMDS_MeshElement*> SMDS_ElementHolder::myExternalElems
privateinherited
Referenced by SMDS_ElementHolder::beforeCompacting(), and SMDS_ElementHolder::restoreElements().
◆ myID
int SMESHDS_GroupBase::myID
privateinherited
◆ myIsNode
std::vector< bool > SMDS_ElementHolder::myIsNode
privateinherited
◆ myIterator
SMDS_ElemIteratorPtr SMESHDS_GroupBase::myIterator
privateinherited
◆ myMesh [1/2]
◆ myMesh [2/2]
const SMESHDS_Mesh* SMESHDS_GroupBase::myMesh
privateinherited
◆ myMeshInfo
std::vector< smIdType > SMESHDS_GroupOnFilter::myMeshInfo
◆ myMeshModifTime
size_t SMESHDS_GroupOnFilter::myMeshModifTime
Referenced by IsUpToDate(), and setChanged().
◆ myNbElemToSkip
size_t SMESHDS_GroupOnFilter::myNbElemToSkip
◆ myPredicate
SMESH_PredicatePtr SMESHDS_GroupOnFilter::myPredicate
Referenced by Contains(), GetElements(), and SetPredicate().
◆ myPredicateTic
int SMESHDS_GroupOnFilter::myPredicateTic
Referenced by GetTic(), and SetPredicate().
◆ myPtrInMesh
std::set<SMDS_ElementHolder*>::iterator SMDS_ElementHolder::myPtrInMesh
privateinherited
◆ myStoreName
std::string SMESHDS_GroupBase::myStoreName
privateinherited
◆ myType
SMDSAbs_ElementType SMESHDS_GroupBase::myType
privateinherited
◆ myVtkIDs
std::vector< vtkIdType > SMDS_ElementHolder::myVtkIDs
privateinherited
