SMESHDS_GroupOnFilter.hxx
22// File : SMESHDS_GroupOnFilter.hxx
23// Module : SMESH
24//
25#ifndef _SMESHDS_GroupOnFilter_HeaderFile
26#define _SMESHDS_GroupOnFilter_HeaderFile
27
28#include "SMESH_SMESHDS.hxx"
31#include "SMESHDS_GroupBase.hxx"
32#include "SMESH_Controls.hxx"
33
38{
39 public:
40
41 SMESHDS_GroupOnFilter (const int theID,
42 const SMESHDS_Mesh* theMesh,
43 const SMDSAbs_ElementType theType,
44 const SMESH_PredicatePtr& thePredicate);
45
46 void SetPredicate( const SMESH_PredicatePtr& thePredicate);
47
48 SMESH_PredicatePtr GetPredicate() const { return myPredicate; }
49
50 std::vector< smIdType > GetMeshInfo() const;
51
52 template< typename IDTYPE >
53 smIdType GetElementIds( IDTYPE* ids ) const
54 {
55 return getElementIds( (void*)ids, sizeof(IDTYPE));
56 }
57
58
59 virtual smIdType Extent() const;
60
61 virtual bool IsEmpty();
62
63 virtual bool Contains (const smIdType theID);
64
65 virtual bool Contains (const SMDS_MeshElement* elem);
66
67 virtual SMDS_ElemIteratorPtr GetElements() const;
68
69 virtual int GetTic() const;
70
71 bool IsUpToDate() const;
72
73 protected: // methods of SMDS_ElementHolder
74
76 virtual void tmpClear();
77 virtual void add( const SMDS_MeshElement* element );
78 virtual void compact() {};
79
80 private:
81
82 void update() const;
83 bool updateParallel() const;
84 void setChanged(bool changed=true);
85 const SMDS_MeshElement* setNbElemToSkip( SMDS_ElemIteratorPtr& elIt );
86 int getElementIds( void* ids, size_t idSize ) const;
87
88 // We use two ways of optimaization:
89 // 1) The case of little free memory. Remember nb of KO elements (myNbElemToSkip)
90 // to skip before the first OK element. As well remember total nb of OK
91 // elements (myMeshInfo) to stop iteration as all OK elements are found.
92 // 2) The case of enough free memory. Remember all OK elements (myElements).
93
95 std::vector< smIdType > myMeshInfo;
96 std::vector< const SMDS_MeshElement*> myElements;
98 size_t myMeshModifTime; // when myMeshInfo was updated
101};
102
103#endif
SMDSAbs_ElementType
Type (node, edge, face or volume) of elements.
Definition: SMDSAbs_ElementType.hxx:34
boost::shared_ptr< SMDS_Iterator< const SMDS_MeshElement * > > SMDS_ElemIteratorPtr
Definition: SMDS_ElemIterator.hxx:43
SMESH::Controls::PredicatePtr SMESH_PredicatePtr
Definition: SMESH_Controls.hxx:81
#define SMESHDS_EXPORT
Definition: SMESH_SMESHDS.hxx:37
Base class of object holding SMDS_MeshElement pointers.
Definition: SMDS_ElementHolder.hxx:48
virtual void add(const SMDS_MeshElement *element)=0
the descendant squeeze its element storage after re-adding elements
virtual SMDS_ElemIteratorPtr getElements()=0
< the descendant object return its elements just before the mesh compacting
virtual void tmpClear()=0
the descendant object re-add its elements after the mesh compacting
Base class for elements.
Definition: SMDS_MeshElement.hxx:56
Definition: SMESHDS_GroupBase.hxx:42
virtual SMDS_ElemIteratorPtr GetElements() const =0
virtual int GetTic() const =0
virtual bool Contains(const smIdType theID)
Definition: SMESHDS_GroupBase.cxx:139
Definition: SMESHDS_GroupBase.cxx:110
Definition: SMESHDS_GroupBase.cxx:125
Groups whose contents is dynamically updated using the filter.
Definition: SMESHDS_GroupOnFilter.hxx:38
size_t myNbElemToSkip
Definition: SMESHDS_GroupOnFilter.hxx:100
smIdType GetElementIds(IDTYPE *ids) const
Definition: SMESHDS_GroupOnFilter.hxx:53
std::vector< const SMDS_MeshElement * > myElements
Definition: SMESHDS_GroupOnFilter.hxx:96
Definition: SMESHDS_GroupOnFilter.hxx:95
bool myElementsOK
Definition: SMESHDS_GroupOnFilter.hxx:97
Definition: SMESHDS_GroupOnFilter.hxx:98
Definition: SMESHDS_GroupOnFilter.hxx:48
allow the descendant treat its elements before mesh clearing
Definition: SMESHDS_GroupOnFilter.hxx:78
int myPredicateTic
Definition: SMESHDS_GroupOnFilter.hxx:99
SMESH_PredicatePtr myPredicate
Definition: SMESHDS_GroupOnFilter.hxx:94
Definition: SMESHDS_Mesh.hxx:98
