SMDS_MeshGroup Class Reference
#include <SMDS_MeshGroup.hxx>
Inheritance diagram for SMDS_MeshGroup:
 SMDS_MeshGroup (const SMDS_Mesh *theMesh, const SMDSAbs_ElementType theType=SMDSAbs_All)
void SetType (const SMDSAbs_ElementType theType)
void Clear ()
void Reserve (size_t)
bool Add (const SMDS_MeshElement *theElem)
bool Remove (const SMDS_MeshElement *theElem)
bool IsEmpty () const
smIdType Extent () const
int Tic () const
bool Contains (const SMDS_MeshElement *theElem) const
const SMDS_Mesh * GetMesh () const
SMDSAbs_ElementType GetType () const
SMDS_ElemIteratorPtr GetElements () const
void operator= (SMDS_MeshGroup &&other)
virtual SMDS_ElemIteratorPtr getElements ()
 < the descendant object return its elements just before the mesh compacting More...
virtual void tmpClear ()
 the descendant object re-add its elements after the mesh compacting More...
virtual void add (const SMDS_MeshElement *element)
 the descendant squeeze its element storage after re-adding elements More...
virtual void compact ()
 allow the descendant treat its elements before mesh clearing More...
Private Types
typedef std::set< const SMDS_MeshElement * > TElementSet
typedef TElementSet::const_iterator TIterator
virtual void clear ()
void beforeCompacting ()
 store vtkIDs of elements More...
void restoreElements (const std::vector< smIdType > &idNodessOldToNew, const std::vector< smIdType > &idCellsOldToNew)
 restore pointers to elements More...
const SMDS_Mesh * myMesh
SMDSAbs_ElementType myType
TElementSet myElements
int myTic
std::vector< const SMDS_MeshElement * > myExternalElems
 elements not contained in the mesh More...
std::vector< vtkIdType > myVtkIDs
 vtk IDs of elements More...
std::vector< bool > myIsNode
std::set< SMDS_ElementHolder * >::iterator myPtrInMesh
◆ TElementSet
typedef std::set< const SMDS_MeshElement* > SMDS_MeshGroup::TElementSet
◆ TIterator
typedef TElementSet::const_iterator SMDS_MeshGroup::TIterator
◆ SMDS_MeshGroup()
SMDS_MeshGroup::SMDS_MeshGroup ( const SMDS_Mesh *  theMesh,
const SMDSAbs_ElementType  theType = SMDSAbs_All
◆ add()
virtual void SMDS_MeshGroup::add ( const SMDS_MeshElement *  element)
Implements SMDS_ElementHolder.
References SMESHUtils::Add().
◆ Add()
◆ beforeCompacting()
◆ clear()
virtual void SMDS_ElementHolder::clear ( )
◆ Clear()
void SMDS_MeshGroup::Clear ( )
References myElements, myTic, myType, and SMDSAbs_All.
Referenced by SMESHDS_Group::Clear().
◆ compact()
virtual void SMDS_MeshGroup::compact ( )
◆ Contains()
bool SMDS_MeshGroup::Contains ( const SMDS_MeshElement *  theElem) const
◆ Extent()
smIdType SMDS_MeshGroup::Extent ( ) const
Referenced by SMESHDS_Group::Extent().
◆ getElements()
virtual SMDS_ElemIteratorPtr SMDS_MeshGroup::getElements ( )
the descendant object temporary remove its elements
◆ GetElements()
SMDS_ElemIteratorPtr SMDS_MeshGroup::GetElements ( ) const
References myElements.
Referenced by SMESHDS_Group::GetElements().
◆ GetMesh()
const SMDS_Mesh * SMDS_MeshGroup::GetMesh ( ) const
◆ GetType()
◆ IsEmpty()
bool SMDS_MeshGroup::IsEmpty ( ) const
◆ operator=()
void SMDS_MeshGroup::operator= ( SMDS_MeshGroup &&  other)
References myElements, myMesh, myTic, and myType.
◆ Remove()
◆ Reserve()
void SMDS_MeshGroup::Reserve ( size_t  )
◆ restoreElements()
void SMDS_ElementHolder::restoreElements ( const std::vector< smIdType > &  idNodessOldToNew,
const std::vector< smIdType > &  idCellsOldToNew
privateinherited
◆ SetType()
void SMDS_MeshGroup::SetType ( const SMDSAbs_ElementType  theType)
References IsEmpty(), and myType.
Referenced by SMESHDS_Group::SetType().
◆ Tic()
int SMDS_MeshGroup::Tic ( ) const
Referenced by SMESHDS_Group::GetTic().
◆ tmpClear()
void SMDS_MeshGroup::tmpClear ( )
◆ myElements
TElementSet SMDS_MeshGroup::myElements
◆ myExternalElems
std::vector<const SMDS_MeshElement*> SMDS_ElementHolder::myExternalElems
privateinherited
Referenced by SMDS_ElementHolder::beforeCompacting(), and SMDS_ElementHolder::restoreElements().
◆ myIsNode
std::vector< bool > SMDS_ElementHolder::myIsNode
privateinherited
◆ myMesh
const SMDS_Mesh* SMDS_MeshGroup::myMesh
Referenced by operator=().
◆ myPtrInMesh
std::set<SMDS_ElementHolder*>::iterator SMDS_ElementHolder::myPtrInMesh
privateinherited
◆ myTic
int SMDS_MeshGroup::myTic
Referenced by Add(), Clear(), operator=(), and Remove().
◆ myType
SMDSAbs_ElementType SMDS_MeshGroup::myType
Referenced by Add(), Clear(), operator=(), Remove(), and SetType().
◆ myVtkIDs
std::vector< vtkIdType > SMDS_ElementHolder::myVtkIDs
privateinherited
