SMESH_Pattern_i Class Reference
#include <SMESH_Pattern_i.hxx>
Inheritance diagram for SMESH_Pattern_i:
 SMESH_Pattern_i (SMESH_Gen_i *theGen_i)
CORBA::Boolean LoadFromFile (const char *theFileContents)
CORBA::Boolean LoadFromFace (SMESH::SMESH_Mesh_ptr theMesh, GEOM::GEOM_Object_ptr theFace, CORBA::Boolean theProject)
CORBA::Boolean LoadFrom3DBlock (SMESH::SMESH_Mesh_ptr theMesh, GEOM::GEOM_Object_ptr theBlock)
SMESH::point_array * ApplyToFace (GEOM::GEOM_Object_ptr theFace, GEOM::GEOM_Object_ptr theVertexOnKeyPoint1, CORBA::Boolean theReverse)
SMESH::point_array * ApplyTo3DBlock (GEOM::GEOM_Object_ptr theBlock, GEOM::GEOM_Object_ptr theVertex000, GEOM::GEOM_Object_ptr theVertex001)
SMESH::point_array * ApplyToMeshFaces (SMESH::SMESH_Mesh_ptr theMesh, const SMESH::smIdType_array &theFacesIDs, CORBA::Short theNodeIndexOnKeyPoint1, CORBA::Boolean theReverse)
SMESH::point_array * ApplyToHexahedrons (SMESH::SMESH_Mesh_ptr theMesh, const SMESH::smIdType_array &theVolumesIDs, CORBA::Short theNode000Index, CORBA::Short theNode001Index)
CORBA::Boolean MakeMesh (SMESH::SMESH_Mesh_ptr theMesh, CORBA::Boolean CreatePolygons, CORBA::Boolean CreatePolyedrs)
SMESH::SMESH_Pattern::ErrorCode GetErrorCode ()
char * GetString ()
CORBA::Boolean Is2D ()
SMESH::point_array * GetPoints ()
SMESH::long_array * GetKeyPoints ()
SMESH::array_of_long_array * GetElementPoints (CORBA::Boolean applied)
::SMESH_Mesh * getMesh (SMESH::SMESH_Mesh_ptr &theMesh)
::SMESH_Pattern myPattern
SMESH_Gen_i * myGen
◆ SMESH_Pattern_i()
SMESH_Pattern_i::SMESH_Pattern_i ( SMESH_Gen_i *  theGen_i)
◆ ApplyTo3DBlock()
SMESH::point_array * SMESH_Pattern_i::ApplyTo3DBlock ( GEOM::GEOM_Object_ptr  theBlock,
◆ ApplyToFace()
SMESH::point_array * SMESH_Pattern_i::ApplyToFace ( GEOM::GEOM_Object_ptr  theFace,
◆ ApplyToHexahedrons()
SMESH::point_array * SMESH_Pattern_i::ApplyToHexahedrons ( SMESH::SMESH_Mesh_ptr  theMesh,
const SMESH::smIdType_array &  theVolumesIDs,
◆ ApplyToMeshFaces()
SMESH::point_array * SMESH_Pattern_i::ApplyToMeshFaces ( SMESH::SMESH_Mesh_ptr  theMesh,
const SMESH::smIdType_array &  theFacesIDs,
◆ GetElementPoints()
SMESH::array_of_long_array * SMESH_Pattern_i::GetElementPoints ( CORBA::Boolean  applied)
◆ GetErrorCode()
◆ GetKeyPoints()
SMESH::long_array * SMESH_Pattern_i::GetKeyPoints ( )
◆ getMesh()
SMESH_Mesh * SMESH_Pattern_i::getMesh ( SMESH::SMESH_Mesh_ptr &  theMesh)
◆ GetPoints()
◆ GetString()
char * SMESH_Pattern_i::GetString ( )
References myPattern, and SMESH_Pattern::Save().
◆ Is2D()
CORBA::Boolean SMESH_Pattern_i::Is2D ( )
References SMESH_Pattern::Is2D(), and myPattern.
◆ LoadFrom3DBlock()
CORBA::Boolean SMESH_Pattern_i::LoadFrom3DBlock ( SMESH::SMESH_Mesh_ptr  theMesh,
◆ LoadFromFace()
CORBA::Boolean SMESH_Pattern_i::LoadFromFace ( SMESH::SMESH_Mesh_ptr  theMesh,
◆ LoadFromFile()
CORBA::Boolean SMESH_Pattern_i::LoadFromFile ( const char *  theFileContents)
◆ MakeMesh()
CORBA::Boolean SMESH_Pattern_i::MakeMesh ( SMESH::SMESH_Mesh_ptr  theMesh,
◆ myGen
SMESH_Gen_i* SMESH_Pattern_i::myGen
◆ myPattern
