SMESH_Pattern.hxx
23// File : SMESH_Pattern.hxx
24// Created : Mon Aug 2 10:30:00 2004
25// Author : Edward AGAPOV (eap)
26//
27#ifndef SMESH_Pattern_HeaderFile
28#define SMESH_Pattern_HeaderFile
30#include "SMESH_SMESH.hxx"
31
32#include <vector>
33#include <list>
34#include <map>
35#include <set>
36#include <iostream>
37
38#include <TopoDS_Vertex.hxx>
39#include <TopTools_IndexedMapOfOrientedShape.hxx>
40#include <gp_XYZ.hxx>
41#include <gp_XY.hxx>
42#include <gp_Pnt.hxx>
43
45class SMDS_MeshFace;
46class SMDS_MeshVolume;
47class SMDS_MeshNode;
48class SMESH_Mesh;
49class SMESHDS_SubMesh;
50class TopoDS_Shell;
51class TopoDS_Face;
52class TopoDS_Edge;
53
54//
55// Class allowing meshing by mapping of pre-defined patterns: it generates
56// a 2D mesh on a geometrical face or a 3D mesh inside a geometrical block
57// of 6 faces.
58//
59
61 public:
62
64
65 void Clear();
66 // clear fields
67
68 bool Load (const char* theFileContents);
69 // Load a pattern from <theFileContents>
70
71 bool Load (SMESH_Mesh* theMesh,
72 const TopoDS_Face& theFace,
73 bool theProject = false,
74 TopoDS_Vertex the1stVertex=TopoDS_Vertex(),
75 bool theKeepNodes = false );
76 // Create a pattern from the mesh built on <theFace>.
77 // <theProject>==true makes override nodes positions
78 // on <theFace> computed by mesher
79
80 bool Load (SMESH_Mesh* theMesh,
81 const TopoDS_Shell& theBlock,
82 bool theKeepNodes = false);
83 // Create a pattern from the mesh built on <theBlock>
84
85 bool Save (std::ostream& theFile);
86 // Save the loaded pattern into theFile
87
88 bool Apply (const TopoDS_Face& theFace,
89 const TopoDS_Vertex& theVertexOnKeyPoint1,
90 const bool theReverse);
91 // Compute nodes coordinates applying
92 // the loaded pattern to <theFace>. The first key-point
93 // will be mapped into <theVertexOnKeyPoint1>, which must
94 // be in the outer wire of theFace
95
96 bool Apply (const TopoDS_Shell& theBlock,
97 const TopoDS_Vertex& theVertex000,
98 const TopoDS_Vertex& theVertex001);
99 // Compute nodes coordinates applying
100 // the loaded pattern to <theBlock>. The (0,0,0) key-point
101 // will be mapped into <theVertex000>. The
102 // (0,0,1) key-point will be mapped into <theVertex001>.
103
104 bool Apply (const SMDS_MeshFace* theFace,
105 const int theNodeIndexOnKeyPoint1,
106 const bool theReverse);
107 // Compute nodes coordinates applying
108 // the loaded pattern to <theFace>. The first key-point
109 // will be mapped into <theNodeIndexOnKeyPoint1>-th node
110
111 bool Apply (SMESH_Mesh* theMesh,
112 const SMDS_MeshFace* theFace,
113 const TopoDS_Shape& theSurface,
114 const int theNodeIndexOnKeyPoint1,
115 const bool theReverse);
116 // Compute nodes coordinates applying
117 // the loaded pattern to <theFace>. The first key-point
118 // will be mapped into <theNodeIndexOnKeyPoint1>-th node
119
120 bool Apply (SMESH_Mesh* theMesh,
121 std::set<const SMDS_MeshFace*>& theFaces,
122 const int theNodeIndexOnKeyPoint1,
123 const bool theReverse);
124 // Compute nodes coordinates applying
125 // the loaded pattern to <theFaces>. The first key-point
126 // will be mapped into <theNodeIndexOnKeyPoint1>-th node
127
128 bool Apply (const SMDS_MeshVolume* theVolume,
129 const int theNode000Index,
130 const int theNode001Index);
131 // Compute nodes coordinates applying
132 // the loaded pattern to <theVolume>. The (0,0,0) key-point
133 // will be mapped into <theNode000Index>-th node. The
134 // (0,0,1) key-point will be mapped into <theNode000Index>-th
135 // node.
136
137 bool Apply (std::set<const SMDS_MeshVolume*>& theVolumes,
138 const int theNode000Index,
139 const int theNode001Index);
140 // Compute nodes coordinates applying
141 // the loaded pattern to <theVolumes>. The (0,0,0) key-point
142 // will be mapped into <theNode000Index>-th node. The
143 // (0,0,1) key-point will be mapped into <theNode000Index>-th
144 // node.
145
146 bool GetMappedPoints ( std::list<const gp_XYZ *> & thePoints ) const;
147 // Return nodes coordinates computed by Apply() method
148
149 bool MakeMesh(SMESH_Mesh* theMesh,
150 const bool toCreatePolygons = false,
151 const bool toCreatePolyedrs = false);
152 // Create nodes and elements in <theMesh> using nodes
153 // coordinates computed by either of Apply...() methods
154
155 // ----------
156 // Inquiries
157 // ----------
158
161 // Load(file)
162 ERR_READ_NB_POINTS, // couldn't read nb of points
163 ERR_READ_POINT_COORDS, // invalid nb of point coordinates
164 ERR_READ_TOO_FEW_POINTS, // too few points in a pattern
165 ERR_READ_3D_COORD, // coordinate of 3D point out of [0,1] range
166 ERR_READ_NO_KEYPOINT, // no key-points in 2D pattern
167 ERR_READ_BAD_INDEX, // invalid point index
168 ERR_READ_ELEM_POINTS, // invalid nb of points in element
169 ERR_READ_NO_ELEMS, // no elements in a pattern
170 ERR_READ_BAD_KEY_POINT, // a key-point not on a boundary
171 // Save(file)
172 ERR_SAVE_NOT_LOADED, // pattern was not loaded
173 // Load(shape)
174 ERR_LOAD_EMPTY_SUBMESH, // no elements to load
175 // Load(face)
176 ERR_LOADF_NARROW_FACE, // too narrow face
177 ERR_LOADF_CLOSED_FACE, // closed face
178 ERR_LOADF_CANT_PROJECT, // impossible to project nodes
179 // Load(volume)
180 ERR_LOADV_BAD_SHAPE, // volume is not a brick of 6 faces
181 ERR_LOADV_COMPUTE_PARAMS, // can't compute point parameters
182 // Apply(shape)
183 ERR_APPL_NOT_COMPUTED, // mapping failed
184 ERR_APPL_NOT_LOADED, // pattern was not loaded
185 ERR_APPL_BAD_DIMENTION, // wrong shape dimension
186 ERR_APPL_BAD_NB_VERTICES, // keypoints - vertices mismatch
187 // Apply(face)
188 ERR_APPLF_BAD_TOPOLOGY, // bad pattern topology
189 ERR_APPLF_BAD_VERTEX, // first vertex not on an outer face boundary
190 ERR_APPLF_INTERNAL_EEROR, // program error
191 // Apply(volume)
192 ERR_APPLV_BAD_SHAPE, // volume is not a brick of 6 faces
193 // Apply(mesh_face)
194 ERR_APPLF_BAD_FACE_GEOM, // bad face geometry
195 // MakeMesh
196 ERR_MAKEM_NOT_COMPUTED, // mapping failed
197 //Unexpected error
198 ERR_UNEXPECTED // Unexpected of the pattern mapping algorithm
199 };
200
201 ErrorCode GetErrorCode() const { return myErrorCode; }
202 // return ErrorCode of the last operation
203
204 bool IsLoaded() const { return !myPoints.empty() && !myElemPointIDs.empty(); }
205 // Return true if a pattern was successfully loaded
206
207 bool Is2D() const { return myIs2D; }
208 // Return true if the loaded pattern is a 2D one
209
210 bool GetPoints ( std::list<const gp_XYZ *> & thePoints ) const;
211 // Return nodes coordinates of the pattern
212
213 const std::list< int > & GetKeyPointIDs () const { return myKeyPointIDs; }
214 // Return indices of key-points within the sequences returned by
215 // GetPoints() and GetMappedPoints()
216
217 const std::list< std::list< int > >& GetElementPointIDs (bool applied) const
218 { return myElemXYZIDs.empty() || !applied ? myElemPointIDs : myElemXYZIDs; }
219 // Return nodal connectivity of the elements of the pattern
220
221 void GetInOutNodes( std::vector< const SMDS_MeshNode* > *& inNodes,
222 std::vector< const SMDS_MeshNode* > *& outNodes )
223 { inNodes = & myInNodes; outNodes = & myOutNodes; }
224 // Return loaded and just created nodes
225
226 void DumpPoints() const;
227 // Debug
228
229 // -----------------------------
230 // Utilities for advanced usage
231 // -----------------------------
232
233 TopoDS_Shape GetSubShape( const int i ) const {
234 if ( i < 1 || i > myShapeIDMap.Extent() ) return TopoDS_Shape();
235 return myShapeIDMap( i );
236 }
237 // Return a shape from myShapeIDMap where shapes are indexed so that first go
238 // ordered vertices, then ordered edge, then faces and maybe a shell
239
240private:
241 // private methods
242
243 struct TPoint {
244 gp_XYZ myInitXYZ; // loaded position
245 gp_XY myInitUV;
246 double myInitU; // [0,1]
247 gp_Pnt myXYZ; // position to compute
248 gp_XY myUV;
249 double myU;
250 TPoint();
251 };
252 friend std::ostream & operator <<(std::ostream & OS, const TPoint& p);
253
254 bool setErrorCode( const ErrorCode theErrorCode );
255 // set ErrorCode and return true if it is Ok
256
257 bool setShapeToMesh(const TopoDS_Shape& theShape);
258 // Set a shape to be meshed. Return True if meshing is possible
259
260 std::list< TPoint* > & getShapePoints(const TopoDS_Shape& theShape);
261 // Return list of points located on theShape.
262 // A list of edge-points include vertex-points (for 2D pattern only).
263 // A list of face-points doesn't include edge-points.
264 // A list of volume-points doesn't include face-points.
265
266 std::list< TPoint* > & getShapePoints(const int theShapeID);
267 // Return list of points located on the shape
268
269 bool findBoundaryPoints();
270 // If loaded from file, find points to map on edges and faces and
271 // compute their parameters
272
273 void arrangeBoundaries (std::list< std::list< TPoint* > >& boundaryPoints);
274 // if there are several wires, arrange boundaryPoints so that
275 // the outer wire goes first and fix inner wires orientation;
276 // update myKeyPointIDs to correspond to the order of key-points
277 // in boundaries; sort internal boundaries by the nb of key-points
278
279 void computeUVOnEdge( const TopoDS_Edge& theEdge, const std::list< TPoint* > & ePoints );
280 // compute coordinates of points on theEdge
281
282 bool compUVByIsoIntersection (const std::list< std::list< TPoint* > >& boundaryPoints,
283 const gp_XY& theInitUV,
284 gp_XY& theUV,
285 bool & theIsDeformed);
286 // compute UV by intersection of iso-lines found by points on edges
287
288 bool compUVByElasticIsolines(const std::list< std::list< TPoint* > >& boundaryPoints,
289 const std::list< TPoint* >& pointsToCompute);
290 // compute UV as nodes of iso-poly-lines consisting of
291 // segments keeping relative size as in the pattern
292
293 double setFirstEdge (std::list< TopoDS_Edge > & theWire, int theFirstEdgeID);
294 // choose the best first edge of theWire; return the summary distance
295 // between point UV computed by isolines intersection and
296 // eventual UV got from edge p-curves
297
298 typedef std::list< std::list< TopoDS_Edge > > TListOfEdgesList;
299
300 bool sortSameSizeWires (TListOfEdgesList & theWireList,
301 const TListOfEdgesList::iterator& theFromWire,
302 const TListOfEdgesList::iterator& theToWire,
303 const int theFirstEdgeID,
304 std::list< std::list< TPoint* > >& theEdgesPointsList );
305 // sort wires in theWireList from theFromWire until theToWire,
306 // the wires are set in the order to correspond to the order
307 // of boundaries; after sorting, edges in the wires are put
308 // in a good order, point UVs on edges are computed and points
309 // are appended to theEdgesPointsList
310
311 typedef std::set<const SMDS_MeshNode*> TNodeSet;
312
313 void mergePoints (const bool uniteGroups);
314 // Merge XYZ on edges and/or faces.
315
316 void makePolyElements(const std::vector< const SMDS_MeshNode* >& theNodes,
317 const bool toCreatePolygons,
318 const bool toCreatePolyedrs);
319 // prepare intermediate data to create Polygons and Polyhedrons
320
321 void createElements(SMESH_Mesh* theMesh,
322 const std::vector<const SMDS_MeshNode* >& theNodesVector,
323 const std::list< std::list< int > > & theElemNodeIDs,
324 const std::vector<const SMDS_MeshElement*>& theElements);
325 // add elements to the mesh
326
327 bool getFacesDefinition(const SMDS_MeshNode** theBndNodes,
328 const int theNbBndNodes,
329 const std::vector< const SMDS_MeshNode* >& theNodes,
330 std::list< int >& theFaceDefs,
331 std::vector<int>& theQuantity);
332 // fill faces definition for a volume face defined by theBndNodes
333 // return true if a face definition changes
334
335
336 bool isReversed(const SMDS_MeshNode* theFirstNode,
337 const std::list< int >& theIdsList) const;
338 // check xyz ids order in theIdsList taking into account
339 // theFirstNode on a link
340
341 void clearMesh(SMESH_Mesh* theMesh) const;
342 // clear mesh elements existing on myShape in theMesh
343
344 bool findExistingNodes( SMESH_Mesh* mesh,
345 const TopoDS_Shape& S,
346 const std::list< TPoint* > & points,
347 std::vector< const SMDS_MeshNode* > & nodes);
348 // fills nodes vector with nodes existing on a given shape
349
350 static SMESHDS_SubMesh * getSubmeshWithElements(SMESH_Mesh* theMesh,
351 const TopoDS_Shape& theShape);
352 // return submesh containing elements bound to theShape in theMesh
353
354 private:
355 // fields
356
357 typedef std::list< int > TElemDef; // element definition is its nodes ids
358
359 bool myIs2D;
360 std::vector< TPoint > myPoints;
361 std::list< int > myKeyPointIDs;
362 std::list< TElemDef > myElemPointIDs;
363
367
368 TopoDS_Shape myShape;
369 // all functions assure that shapes are indexed so that first go
370 // ordered vertices, then ordered edge, then faces and maybe a shell
371 TopTools_IndexedMapOfOrientedShape myShapeIDMap;
372 std::map< int, std::list< TPoint*> > myShapeIDToPointsMap;
373
374 // for the 2d case:
375 // nb of key-points in each of pattern boundaries
376 std::list< int > myNbKeyPntInBoundary;
377
378 // nodes corresponding to myPoints
379 bool myToKeepNodes; // to keep these data
380 std::vector< const SMDS_MeshNode* > myInNodes; // loaded nodes
381 std::vector< const SMDS_MeshNode* > myOutNodes; // created nodes
382
383 // to compute while applying to mesh elements, not to shapes
384
385 std::vector<gp_XYZ> myXYZ; // XYZ of nodes to create
386 std::list< TElemDef > myElemXYZIDs; // new elements definitions
387 std::map< int, const SMDS_MeshNode*> myXYZIdToNodeMap; // map XYZ id to node of a refined element
388 std::vector<const SMDS_MeshElement*> myElements; // refined elements
389 std::vector<const SMDS_MeshNode*> myOrderedNodes;
390
391 // elements to replace with polygon or polyhedron
392 std::vector<const SMDS_MeshElement*> myPolyElems;
393 // definitions of new poly elements
394 std::list< TElemDef > myPolyElemXYZIDs;
395 std::list< std::vector<int> > myPolyhedronQuantities;
396
397 // map a boundary to XYZs on it;
398 // a boundary (edge or face) is defined as a set of its nodes,
399 // XYZs on a boundary are indices of myXYZ s
400 std::map<TNodeSet,std::list<std::list<int> > > myIdsOnBoundary;
401 // map XYZ id to element it is in
402 std::map< int, std::list< TElemDef* > > myReverseConnectivity;
403};
404
405
406#endif
ostream & operator<<(ostream &OS, const SMDS_MeshElement *e)
Definition: SMDS_MeshElement.cxx:212
#define SMESH_EXPORT
Definition: SMESH_SMESH.hxx:37
Base class for elements.
Definition: SMDS_MeshElement.hxx:56
Mesh face.
Definition: SMDS_MeshFace.hxx:41
Definition: SMDS_MeshNode.hxx:36
Mesh volume.
Definition: SMDS_MeshVolume.hxx:40
Definition: SMESHDS_SubMesh.hxx:48
Definition: SMESH_Mesh.hxx:80
Definition: SMESH_Pattern.hxx:60
Definition: SMESH_Pattern.hxx:362
Definition: SMESH_Pattern.hxx:357
std::vector< const SMDS_MeshElement * > myPolyElems
Definition: SMESH_Pattern.hxx:392
Definition: SMESH_Pattern.hxx:201
Definition: SMESH_Pattern.hxx:371
ErrorCode myErrorCode
Definition: SMESH_Pattern.hxx:364
std::set< const SMDS_MeshNode * > TNodeSet
Definition: SMESH_Pattern.hxx:311
const std::list< int > & GetKeyPointIDs() const
Definition: SMESH_Pattern.hxx:213
bool myIsBoundaryPointsFound
Definition: SMESH_Pattern.hxx:366
std::map< TNodeSet, std::list< std::list< int > > > myIdsOnBoundary
Definition: SMESH_Pattern.hxx:400
ErrorCode
Definition: SMESH_Pattern.hxx:159
@ ERR_APPL_NOT_LOADED
Definition: SMESH_Pattern.hxx:184
@ ERR_APPLF_BAD_VERTEX
Definition: SMESH_Pattern.hxx:189
@ ERR_READ_BAD_INDEX
Definition: SMESH_Pattern.hxx:167
@ ERR_READ_POINT_COORDS
Definition: SMESH_Pattern.hxx:163
@ ERR_LOADV_BAD_SHAPE
Definition: SMESH_Pattern.hxx:180
@ ERR_LOADF_NARROW_FACE
Definition: SMESH_Pattern.hxx:176
@ ERR_READ_TOO_FEW_POINTS
Definition: SMESH_Pattern.hxx:164
@ ERR_READ_NB_POINTS
Definition: SMESH_Pattern.hxx:162
@ ERR_MAKEM_NOT_COMPUTED
Definition: SMESH_Pattern.hxx:196
@ ERR_APPL_BAD_NB_VERTICES
Definition: SMESH_Pattern.hxx:186
@ ERR_READ_NO_KEYPOINT
Definition: SMESH_Pattern.hxx:166
@ ERR_LOADV_COMPUTE_PARAMS
Definition: SMESH_Pattern.hxx:181
@ ERR_APPLF_INTERNAL_EEROR
Definition: SMESH_Pattern.hxx:190
@ ERR_OK
Definition: SMESH_Pattern.hxx:160
@ ERR_READ_BAD_KEY_POINT
Definition: SMESH_Pattern.hxx:170
@ ERR_APPLF_BAD_TOPOLOGY
Definition: SMESH_Pattern.hxx:188
@ ERR_LOADF_CLOSED_FACE
Definition: SMESH_Pattern.hxx:177
@ ERR_READ_NO_ELEMS
Definition: SMESH_Pattern.hxx:169
@ ERR_READ_3D_COORD
Definition: SMESH_Pattern.hxx:165
@ ERR_LOADF_CANT_PROJECT
Definition: SMESH_Pattern.hxx:178
@ ERR_READ_ELEM_POINTS
Definition: SMESH_Pattern.hxx:168
@ ERR_SAVE_NOT_LOADED
Definition: SMESH_Pattern.hxx:172
@ ERR_APPL_BAD_DIMENTION
Definition: SMESH_Pattern.hxx:185
@ ERR_APPLV_BAD_SHAPE
Definition: SMESH_Pattern.hxx:192
@ ERR_APPLF_BAD_FACE_GEOM
Definition: SMESH_Pattern.hxx:194
@ ERR_LOAD_EMPTY_SUBMESH
Definition: SMESH_Pattern.hxx:174
@ ERR_APPL_NOT_COMPUTED
Definition: SMESH_Pattern.hxx:183
std::map< int, std::list< TPoint * > > myShapeIDToPointsMap
Definition: SMESH_Pattern.hxx:372
Definition: SMESH_Pattern.hxx:394
Definition: SMESH_Pattern.hxx:298
std::vector< gp_XYZ > myXYZ
Definition: SMESH_Pattern.hxx:385
const std::list< std::list< int > > & GetElementPointIDs(bool applied) const
Definition: SMESH_Pattern.hxx:217
TopoDS_Shape GetSubShape(const int i) const
Definition: SMESH_Pattern.hxx:233
bool myIs2D
Definition: SMESH_Pattern.hxx:359
Definition: SMESH_Pattern.hxx:361
std::vector< const SMDS_MeshNode * > myOutNodes
Definition: SMESH_Pattern.hxx:381
bool myIsComputed
Definition: SMESH_Pattern.hxx:365
std::vector< const SMDS_MeshElement * > myElements
Definition: SMESH_Pattern.hxx:388
std::vector< const SMDS_MeshNode * > myInNodes
Definition: SMESH_Pattern.hxx:380
bool myToKeepNodes
Definition: SMESH_Pattern.hxx:379
bool Is2D() const
Definition: SMESH_Pattern.hxx:207
std::map< int, const SMDS_MeshNode * > myXYZIdToNodeMap
Definition: SMESH_Pattern.hxx:387
Definition: SMESH_Pattern.hxx:360
std::list< std::vector< int > > myPolyhedronQuantities
Definition: SMESH_Pattern.hxx:395
Definition: SMESH_Pattern.hxx:204
std::vector< const SMDS_MeshNode * > myOrderedNodes
Definition: SMESH_Pattern.hxx:389
Definition: SMESH_Pattern.hxx:386
void GetInOutNodes(std::vector< const SMDS_MeshNode * > *&inNodes, std::vector< const SMDS_MeshNode * > *&outNodes)
Definition: SMESH_Pattern.hxx:221
Definition: SMESH_Pattern.hxx:368
std::map< int, std::list< TElemDef * > > myReverseConnectivity
Definition: SMESH_Pattern.hxx:402
Definition: SMESH_Pattern.hxx:376
Definition: SMESH_Pattern.hxx:243
gp_XY myUV
Definition: SMESH_Pattern.hxx:248
gp_XYZ myInitXYZ
Definition: SMESH_Pattern.hxx:244
gp_XY myInitUV
Definition: SMESH_Pattern.hxx:245
double myU
Definition: SMESH_Pattern.hxx:249
gp_Pnt myXYZ
Definition: SMESH_Pattern.hxx:247
double myInitU
Definition: SMESH_Pattern.hxx:246
