DriverMED_W_Field Class Reference
#include <DriverMED_W_Field.h>
Inheritance diagram for DriverMED_W_Field:
enum  Status {
  DRS_OK , DRS_EMPTY , DRS_WARN_RENUMBER , DRS_WARN_SKIP_ELEM ,
  DRS_WARN_DESCENDING , DRS_FAIL , DRS_TOO_LARGE_MESH
 DriverMED_W_Field ()
void AddODOnVertices (bool toAdd)
bool Set (SMESHDS_Mesh *mesh, const std::string &fieldName, SMDSAbs_ElementType type, const int nbComps, const bool isIntData)
 Sets basic data. More...
void SetCompName (const int iComp, const char *name)
 Set a name of a component countered from zero. More...
void SetDtIt (const int dt, const int it)
 Sets numdt and numit field features. More...
void AddValue (double val)
 Adds a float field value. More...
void AddValue (int val)
 Adds an integer field value. More...
SMDS_ElemIteratorPtr GetOrderedElems ()
 Returns elements in the order they are written in MED file. More...
Status Perform () override
 Writes a field to the file. More...
void SetMesh (SMESHDS_Mesh *theMesh)
void SetMeshId (int theMeshId)
virtual void SetFile (const std::string &theFileName)
virtual void SetMeshName (const std::string &theMeshName)
virtual std::string GetMeshName () const
virtual void SetOption (const std::string &, const std::string &)
virtual SMESH_ComputeErrorPtr GetError ()
 Return a structure containing description of errors. More...
template<typename IDTYPE >
static bool IsMeshTooLarge (const SMDS_Mesh *mesh, bool checkIDs)
Status PerformInternal (MED::PWrapper &medFile)
Status addMessage (const std::string &msg, const bool isFatal=false)
 Stores an error message. More...
static std::string fixUTF8 (const std::string &s)
 Assure a string is UTF-8 valid by replacing invalid chars. More...
SMESHDS_Mesh * myMesh
std::string myFile
std::string myMeshName
int myMeshId
std::vector< std::string > myErrorMessages
Status myStatus
std::string _fieldName
SMDSAbs_ElementType _elemType
std::vector< std::string > _compNames
std::vector< double > _dblValues
std::vector< int > _intValues
int _dt
int _it
bool _addODOnVertices
std::vector< const SMDS_MeshElement * > _elemsByGeom [SMDSEntity_Last]
std::vector< std::pair< SMDSAbs_EntityType, int > > _nbElemsByGeom
◆ Status
enum Driver_Mesh::Status
DRS_OK
DRS_EMPTY
DRS_WARN_RENUMBER
DRS_WARN_SKIP_ELEM
DRS_WARN_DESCENDING
DRS_FAIL
DRS_TOO_LARGE_MESH
◆ DriverMED_W_Field()
DriverMED_W_Field::DriverMED_W_Field ( )
◆ addMessage()
◆ AddODOnVertices()
void DriverMED_W_Field::AddODOnVertices ( bool  toAdd)
◆ AddValue() [1/2]
void DriverMED_W_Field::AddValue ( double  val)
References _dblValues.
Referenced by SMESH_Mesh_i::exportMEDFields().
◆ AddValue() [2/2]
void DriverMED_W_Field::AddValue ( int  val)
References _intValues.
◆ fixUTF8()
std::string Driver_Mesh::fixUTF8 ( const std::string &  s)
staticprotectedinherited
Referenced by DriverMED_R_SMESHDS_Mesh::Perform().
◆ GetError()
◆ GetMeshName()
std::string Driver_Mesh::GetMeshName ( ) const
◆ GetOrderedElems()
SMDS_ElemIteratorPtr DriverMED_W_Field::GetOrderedElems ( )
References _elemsByGeom, _elemType, _nbElemsByGeom, begin(), SMDS_Mesh::elementsIterator(), end(), and Driver_SMESHDS_Mesh::myMesh.
◆ IsMeshTooLarge()
static bool Driver_Mesh::IsMeshTooLarge ( const SMDS_Mesh *  mesh,
bool  checkIDs
◆ Perform()
Driver_Mesh::Status DriverMED_W_Field::Perform ( )
overridevirtual
◆ PerformInternal()
◆ Set()
bool DriverMED_W_Field::Set ( SMESHDS_Mesh *  mesh,
const std::string &  fieldName,
const int  nbComps,
◆ SetCompName()
void DriverMED_W_Field::SetCompName ( const int  iComp,
const char *  name
References _compNames.
◆ SetDtIt()
void DriverMED_W_Field::SetDtIt ( const int  dt,
const int  it
Call this fun before AddValue()!
References _dblValues, _dt, _intValues, and _it.
◆ SetFile()
◆ SetMesh()
◆ SetMeshId()
◆ SetMeshName()
void Driver_Mesh::SetMeshName ( const std::string &  theMeshName)
◆ SetOption()
virtual void Driver_Mesh::SetOption ( const std::string &  ,
const std::string &
◆ _addODOnVertices
bool DriverMED_W_Field::_addODOnVertices
Referenced by Set().
◆ _compNames
std::vector< std::string > DriverMED_W_Field::_compNames
Referenced by PerformInternal(), Set(), and SetCompName().
◆ _dblValues
std::vector< double > DriverMED_W_Field::_dblValues
◆ _dt
int DriverMED_W_Field::_dt
Referenced by PerformInternal(), and SetDtIt().
◆ _elemsByGeom
std::vector< const SMDS_MeshElement* > DriverMED_W_Field::_elemsByGeom[SMDSEntity_Last]
Referenced by GetOrderedElems(), and Set().
◆ _elemType
SMDSAbs_ElementType DriverMED_W_Field::_elemType
◆ _fieldName
std::string DriverMED_W_Field::_fieldName
Referenced by PerformInternal(), and Set().
◆ _intValues
std::vector< int > DriverMED_W_Field::_intValues
◆ _it
int DriverMED_W_Field::_it
◆ _nbElemsByGeom
std::vector< std::pair< SMDSAbs_EntityType, int > > DriverMED_W_Field::_nbElemsByGeom
◆ myErrorMessages
std::vector< std::string > Driver_Mesh::myErrorMessages
◆ myFile
◆ myMesh
◆ myMeshId
◆ myMeshName
◆ myStatus
Status Driver_Mesh::myStatus
