DriverMED_W_Field_Mem Class Reference
#include <DriverMED_W_Field.h>
Inheritance diagram for DriverMED_W_Field_Mem:
enum  Status {
  DRS_OK , DRS_EMPTY , DRS_WARN_RENUMBER , DRS_WARN_SKIP_ELEM ,
  DRS_WARN_DESCENDING , DRS_FAIL , DRS_TOO_LARGE_MESH
 DriverMED_W_Field_Mem (MEDCoupling::MCAuto< MEDCoupling::DataArrayByte > data)
Status Perform () override
 Writes a field to a chunk of memory. More...
MEDCoupling::MCAuto< MEDCoupling::DataArrayByte > getData () const
void AddODOnVertices (bool toAdd)
bool Set (SMESHDS_Mesh *mesh, const std::string &fieldName, SMDSAbs_ElementType type, const int nbComps, const bool isIntData)
 Sets basic data. More...
void SetCompName (const int iComp, const char *name)
 Set a name of a component countered from zero. More...
void SetDtIt (const int dt, const int it)
 Sets numdt and numit field features. More...
void AddValue (double val)
 Adds a float field value. More...
void AddValue (int val)
 Adds an integer field value. More...
SMDS_ElemIteratorPtr GetOrderedElems ()
 Returns elements in the order they are written in MED file. More...
void SetMesh (SMESHDS_Mesh *theMesh)
void SetMeshId (int theMeshId)
virtual void SetFile (const std::string &theFileName)
virtual void SetMeshName (const std::string &theMeshName)
virtual std::string GetMeshName () const
virtual void SetOption (const std::string &, const std::string &)
virtual SMESH_ComputeErrorPtr GetError ()
 Return a structure containing description of errors. More...
template<typename IDTYPE >
static bool IsMeshTooLarge (const SMDS_Mesh *mesh, bool checkIDs)
Status PerformInternal (MED::PWrapper &medFile)
Status addMessage (const std::string &msg, const bool isFatal=false)
 Stores an error message. More...
static std::string fixUTF8 (const std::string &s)
 Assure a string is UTF-8 valid by replacing invalid chars. More...
SMESHDS_Mesh * myMesh
std::string myFile
std::string myMeshName
int myMeshId
std::vector< std::string > myErrorMessages
Status myStatus
MEDCoupling::MCAuto< MEDCoupling::DataArrayByte > _data
std::string _fieldName
SMDSAbs_ElementType _elemType
std::vector< std::string > _compNames
std::vector< double > _dblValues
std::vector< int > _intValues
int _dt
int _it
bool _addODOnVertices
std::vector< const SMDS_MeshElement * > _elemsByGeom [SMDSEntity_Last]
std::vector< std::pair< SMDSAbs_EntityType, int > > _nbElemsByGeom
◆ Status
enum Driver_Mesh::Status
DRS_OK
DRS_EMPTY
DRS_WARN_RENUMBER
DRS_WARN_SKIP_ELEM
DRS_WARN_DESCENDING
DRS_FAIL
DRS_TOO_LARGE_MESH
◆ DriverMED_W_Field_Mem()
DriverMED_W_Field_Mem::DriverMED_W_Field_Mem ( MEDCoupling::MCAuto< MEDCoupling::DataArrayByte >  data)
◆ addMessage()
◆ AddODOnVertices()
void DriverMED_W_Field::AddODOnVertices ( bool  toAdd)
◆ AddValue() [1/2]
void DriverMED_W_Field::AddValue ( double  val)
References DriverMED_W_Field::_dblValues.
Referenced by SMESH_Mesh_i::exportMEDFields().
◆ AddValue() [2/2]
void DriverMED_W_Field::AddValue ( int  val)
References DriverMED_W_Field::_intValues.
◆ fixUTF8()
std::string Driver_Mesh::fixUTF8 ( const std::string &  s)
staticprotectedinherited
Referenced by DriverMED_R_SMESHDS_Mesh::Perform().
◆ getData()
MEDCoupling::MCAuto< MEDCoupling::DataArrayByte > DriverMED_W_Field_Mem::getData ( ) const
◆ GetError()
◆ GetMeshName()
std::string Driver_Mesh::GetMeshName ( ) const
◆ GetOrderedElems()
SMDS_ElemIteratorPtr DriverMED_W_Field::GetOrderedElems ( )
◆ IsMeshTooLarge()
static bool Driver_Mesh::IsMeshTooLarge ( const SMDS_Mesh *  mesh,
bool  checkIDs
◆ Perform()
Driver_Mesh::Status DriverMED_W_Field_Mem::Perform ( )
overridevirtual
Reimplemented from DriverMED_W_Field.
References _data, MED::CrWrapperW(), Driver_Mesh::DRS_OK, EXCEPTION, Driver_Mesh::myFile, and DriverMED_W_Field::PerformInternal().
◆ PerformInternal()
◆ Set()
◆ SetCompName()
void DriverMED_W_Field::SetCompName ( const int  iComp,
const char *  name
References DriverMED_W_Field::_compNames.
◆ SetDtIt()
void DriverMED_W_Field::SetDtIt ( const int  dt,
const int  it
Call this fun before AddValue()!
References DriverMED_W_Field::_dblValues, DriverMED_W_Field::_dt, DriverMED_W_Field::_intValues, and DriverMED_W_Field::_it.
◆ SetFile()
◆ SetMesh()
◆ SetMeshId()
◆ SetMeshName()
void Driver_Mesh::SetMeshName ( const std::string &  theMeshName)
◆ SetOption()
virtual void Driver_Mesh::SetOption ( const std::string &  ,
const std::string &
◆ _addODOnVertices
bool DriverMED_W_Field::_addODOnVertices
privateinherited
Referenced by DriverMED_W_Field::Set().
◆ _compNames
std::vector< std::string > DriverMED_W_Field::_compNames
privateinherited
◆ _data
MEDCoupling::MCAuto<MEDCoupling::DataArrayByte> DriverMED_W_Field_Mem::_data
Referenced by Perform().
◆ _dblValues
std::vector< double > DriverMED_W_Field::_dblValues
privateinherited
◆ _dt
int DriverMED_W_Field::_dt
privateinherited
◆ _elemsByGeom
std::vector< const SMDS_MeshElement* > DriverMED_W_Field::_elemsByGeom[SMDSEntity_Last]
privateinherited
◆ _elemType
◆ _fieldName
std::string DriverMED_W_Field::_fieldName
privateinherited
◆ _intValues
std::vector< int > DriverMED_W_Field::_intValues
privateinherited
◆ _it
int DriverMED_W_Field::_it
privateinherited
◆ _nbElemsByGeom
std::vector< std::pair< SMDSAbs_EntityType, int > > DriverMED_W_Field::_nbElemsByGeom
privateinherited
◆ myErrorMessages
std::vector< std::string > Driver_Mesh::myErrorMessages
◆ myFile
◆ myMesh
◆ myMeshId
◆ myMeshName
◆ myStatus
Status Driver_Mesh::myStatus
