MG_ADAPT::MgAdapt Class Reference
#include <MG_ADAPT.hxx>
struct  family
struct  group
enum  Status {
  DRS_OK , DRS_EMPTY , DRS_WARN_RENUMBER , DRS_WARN_SKIP_ELEM ,
  DRS_WARN_DESCENDING , DRS_FAIL , DRS_NO_TIME_STEP
 MgAdapt ()
 MgAdapt (MgAdaptHypothesisData *)
 MgAdapt (const MgAdapt &)
 ~MgAdapt ()
void buildModel ()
void setData (MgAdaptHypothesisData *data)
void setMedFileIn (std::string fileName)
std::string getMedFileIn ()
void setMedFileOut (std::string fileOut)
std::string getMedFileOut ()
void setMeshName (std::string name)
std::string getMeshName ()
void setMeshNameOut (std::string name)
std::string getMeshNameOut ()
void setMeshOutMed (bool mybool)
bool getMeshOutMed ()
void setPublish (bool mybool)
bool getPublish ()
void setFieldName (std::string myFieldName)
std::string getFieldName ()
void setTimeStep (int time)
int getTimeStep () const
void setRankTimeStep (int time, int myRank)
int getRank ()
void setTimeStepRankLast ()
void setNoTimeStep ()
void setChosenTimeStepRank ()
void updateTimeStepRank ()
void setLogFile (std::string)
std::string getLogFile ()
void setVerbosityLevel (int verbosity)
int getVerbosityLevel ()
void setRemoveOnSuccess (bool mybool)
bool getRemoveOnSuccess ()
MgAdaptHypothesisData * getData () const
void setUseLocalMap (bool mybool)
bool getUseLocalMap ()
void setUseBackgroundMap (bool mybool)
bool getUseBackgroundMap ()
void setUseConstantValue (bool mybool)
bool getUseConstantValue ()
void setConstantValue (double cnst)
double getConstantValue () const
void setSizeMapFile (std::string mapFile)
std::string getSizeMapFile ()
void setFromMedFile (bool mybool)
bool isFromMedFile ()
void setKeepWorkingFiles (bool mybool)
bool getKeepWorkingFiles ()
void setPrintLogInFile (bool mybool)
bool getPrintLogInFile ()
void setWorkingDir (std::string dir)
std::string getWorkingDir () const
bool setAll ()
std::string getCommandToRun ()
 Return command to run MG-Tetra mesher excluding file prefix (-f) More...
int compute (std::string &errStr)
std::string getFileName () const
 Return a unique file name. More...
void copyMgAdaptHypothesisData (const MgAdaptHypothesisData *from)
void checkDirPath (std::string &dirPath)
bool hasOptionDefined (const std::string &optionName) const
void setOptionValue (const std::string &optionName, const std::string &optionValue)
std::string getOptionValue (const std::string &optionName, bool *isDefault=0) const
 Return option value. If isDefault provided, it can be a default value,. More...
std::vector< std::string > getCustomOptionValuesStrVec () const
std::vector< std::string > getOptionValuesStrVec () const
TOptionValues getOptionValues () const
const TOptionValues & getCustomOptionValues () const
static std::string getCommandToRun (MgAdapt *)
 Return command to run MG-Adapt mesher excluding file prefix (-f) More...
static std::string getExeName ()
static double toDbl (const std::string &, bool *isOk=0)
 Converts a string to a real value. More...
static bool toBool (const std::string &, bool *isOk=0)
 Converts a string to a bool. More...
static int toInt (const std::string &, bool *isOk=0)
 Converts a string to a integer value. More...
static std::string toLowerStr (const std::string &str)
 Converts a string to a lower. More...
static std::string defaultWorkingDirectory ()
static std::string defaultLogFile ()
static bool defaultKeepFiles ()
static bool defaultRemoveLogOnSuccess ()
static int defaultVerboseLevel ()
static bool defaultPrintLogInFile ()
static bool defaultFromMedFile ()
static bool defaultMeshOutMed ()
static bool defaultPublish ()
static bool defaultUseLocalMap ()
static bool defaultUseBackgroundMap ()
static bool defaultUseConstantValue ()
static bool defaultUseNoTimeStep ()
static bool defaultUseLastTimeStep ()
static bool defaultUseChosenTimeStep ()
static double defaultMaximumMemory ()
void convertMedFile (std::string &meshIn, std::string &solFileIn, std::string &sizeMapIn)
void storeGroups (MEDCoupling::MEDFileMesh *fileMesh)
void restoreGroups (MEDCoupling::MEDFileMesh *fileMesh) const
void storefams (MEDCoupling::MEDFileMesh *fileMesh)
void restorefams (MEDCoupling::MEDFileMesh *fileMesh) const
void storeGroupsAndFams (MEDCoupling::MEDFileMesh *fileMesh)
void restoreGroupsAndFams (MEDCoupling::MEDFileMesh *fileMesh) const
void convertMeshFile (std::string &meshFormatIn, std::vector< std::string > &solFieldFileNames) const
void buildConstantSizeMapSolFile (const std::string &solFormatFieldFileName, const int dim, const int version, const size_t nbNodes) const
void buildBackGroundMeshAndSolFiles (const std::vector< std::string > &fieldFileNames, const std::string &meshFormatsizeMapFile) const
Status addMessage (const std::string &msg, const bool isFatal=false)
void execCmd (const char *cmd, int &err)
void cleanUp ()
void appendMsgToLogFile (std::string &msg)
std::vector< std::string > getListFieldsNames (std::string fileIn)
void checkDimensionOptionAdaptation ()
void checkFieldName (std::string fileIn)
void checkTimeStepRank (std::string fileIn)
bool fromMedFile
std::string medFileIn
std::string medFileOut
std::string meshName
std::string meshNameOut
bool publish
bool meshOutMed
bool useLocalMap
bool useBackgroundMap
bool useConstantValue
bool myUseLastTimeStep
bool myUseNoTimeStep
bool myUseChosenTimeStep
std::string sizeMapFile
std::string fieldName
double constantValue
int rank
int timeStep
std::string logFile
std::string workingDir
int verbosityLevel
bool removeOnSuccess
bool toKeepWorkingFiles
bool printLogInFile
MgAdaptHypothesisData * data
TOptionValues _option2value
TOptionValues _customOption2value
TOptionValues _defaultOptionValues
TOptionNames _doubleOptions
TOptionNames _charOptions
TOptionNames _boolOptions
std::vector< std::string > _errorMessages
Status _status
std::string meshFormatOutputMesh
std::vector< std::string > solFormatOutput
std::vector< group > groupVec
std::vector< family > famVec
std::vector< std::string > tmpFilesToBeDeleted
◆ Status
DRS_OK
DRS_EMPTY
DRS_WARN_RENUMBER
DRS_WARN_SKIP_ELEM
DRS_WARN_DESCENDING
DRS_FAIL
DRS_NO_TIME_STEP
◆ MgAdapt() [1/3]
MgAdapt::MgAdapt ( )
References buildModel(), data, defaultFromMedFile(), defaultKeepFiles(), defaultLogFile(), defaultMeshOutMed(), defaultPrintLogInFile(), defaultPublish(), defaultRemoveLogOnSuccess(), defaultUseBackgroundMap(), defaultUseChosenTimeStep(), defaultUseConstantValue(), defaultUseLastTimeStep(), defaultUseLocalMap(), defaultUseNoTimeStep(), defaultVerboseLevel(), defaultWorkingDirectory(), MG_ADAPT::MgAdaptHypothesisData::fromMedFile, MG_ADAPT::MgAdaptHypothesisData::myConstantValue, MG_ADAPT::MgAdaptHypothesisData::myFieldName, MG_ADAPT::MgAdaptHypothesisData::myFileInDir, MG_ADAPT::MgAdaptHypothesisData::myFileOutDir, MG_ADAPT::MgAdaptHypothesisData::myFileSizeMapDir, MG_ADAPT::MgAdaptHypothesisData::myInMeshName, MG_ADAPT::MgAdaptHypothesisData::myKeepFiles, MG_ADAPT::MgAdaptHypothesisData::myLogFile, MG_ADAPT::MgAdaptHypothesisData::myMeshFileBackground, MG_ADAPT::MgAdaptHypothesisData::myMeshFileIn, MG_ADAPT::MgAdaptHypothesisData::myMeshFileOut, MG_ADAPT::MgAdaptHypothesisData::myMeshOutMed, MG_ADAPT::MgAdaptHypothesisData::myOutMeshName, MG_ADAPT::MgAdaptHypothesisData::myPrintLogInFile, MG_ADAPT::MgAdaptHypothesisData::myPublish, MG_ADAPT::MgAdaptHypothesisData::myRank, MG_ADAPT::MgAdaptHypothesisData::myRemoveLogOnSuccess, MG_ADAPT::MgAdaptHypothesisData::myTimeStep, MG_ADAPT::MgAdaptHypothesisData::myUseBackgroundMap, MG_ADAPT::MgAdaptHypothesisData::myUseChosenTimeStep, MG_ADAPT::MgAdaptHypothesisData::myUseConstantValue, MG_ADAPT::MgAdaptHypothesisData::myUseLastTimeStep, MG_ADAPT::MgAdaptHypothesisData::myUseLocalMap, MG_ADAPT::MgAdaptHypothesisData::myUseNoTimeStep, MG_ADAPT::MgAdaptHypothesisData::myVerboseLevel, MG_ADAPT::MgAdaptHypothesisData::myWorkingDir, and setAll().
◆ MgAdapt() [2/3]
MgAdapt::MgAdapt ( MgAdaptHypothesisData *  myData)
References buildModel(), data, and setData().
◆ MgAdapt() [3/3]
◆ ~MgAdapt()
MgAdapt::~MgAdapt ( )
References data.
◆ addMessage()
MgAdapt::Status MgAdapt::addMessage ( const std::string &  msg,
const bool  isFatal = false
◆ appendMsgToLogFile()
void MgAdapt::appendMsgToLogFile ( std::string &  msg)
References logFile.
Referenced by cleanUp().
◆ buildBackGroundMeshAndSolFiles()
void MgAdapt::buildBackGroundMeshAndSolFiles ( const std::vector< std::string > &  fieldFileNames,
const std::string &  meshFormatsizeMapFile
References fieldName, rank, sizeMapFile, and timeStep.
Referenced by convertMedFile().
◆ buildConstantSizeMapSolFile()
void MgAdapt::buildConstantSizeMapSolFile ( const std::string &  solFormatFieldFileName,
const int  dim,
const int  version,
References constantValue, GmfSca, GmfSolAtVertices, and GmfWrite.
◆ buildModel()
void MgAdapt::buildModel ( )
◆ checkDimensionOptionAdaptation()
void MgAdapt::checkDimensionOptionAdaptation ( )
◆ checkDirPath()
void MgAdapt::checkDirPath ( std::string &  dirPath)
Referenced by setAll().
◆ checkFieldName()
void MgAdapt::checkFieldName ( std::string  fileIn)
References fieldName, and getListFieldsNames().
◆ checkTimeStepRank()
void MgAdapt::checkTimeStepRank ( std::string  fileIn)
References fieldName, rank, and timeStep.
◆ cleanUp()
void MgAdapt::cleanUp ( )
◆ compute()
int MgAdapt::compute ( std::string &  errStr)
◆ convertMedFile()
void MgAdapt::convertMedFile ( std::string &  meshIn,
std::string &  solFileIn,
std::string &  sizeMapIn
◆ convertMeshFile()
void MgAdapt::convertMeshFile ( std::string &  meshFormatIn,
std::vector< std::string > &  solFieldFileNames
References medFileOut, meshNameOut, and restoreGroupsAndFams().
Referenced by compute().
◆ copyMgAdaptHypothesisData()
◆ defaultFromMedFile()
bool MgAdapt::defaultFromMedFile ( )
Referenced by MgAdapt().
◆ defaultKeepFiles()
bool MgAdapt::defaultKeepFiles ( )
◆ defaultLogFile()
std::string MgAdapt::defaultLogFile ( )
Referenced by MgAdapt(), and setAll().
◆ defaultMaximumMemory()
double MgAdapt::defaultMaximumMemory ( )
Referenced by buildModel().
◆ defaultMeshOutMed()
bool MgAdapt::defaultMeshOutMed ( )
◆ defaultPrintLogInFile()
bool MgAdapt::defaultPrintLogInFile ( )
◆ defaultPublish()
bool MgAdapt::defaultPublish ( )
◆ defaultRemoveLogOnSuccess()
bool MgAdapt::defaultRemoveLogOnSuccess ( )
◆ defaultUseBackgroundMap()
bool MgAdapt::defaultUseBackgroundMap ( )
◆ defaultUseChosenTimeStep()
bool MgAdapt::defaultUseChosenTimeStep ( )
◆ defaultUseConstantValue()
bool MgAdapt::defaultUseConstantValue ( )
◆ defaultUseLastTimeStep()
bool MgAdapt::defaultUseLastTimeStep ( )
◆ defaultUseLocalMap()
bool MgAdapt::defaultUseLocalMap ( )
◆ defaultUseNoTimeStep()
bool MgAdapt::defaultUseNoTimeStep ( )
◆ defaultVerboseLevel()
int MgAdapt::defaultVerboseLevel ( )
Referenced by getCommandToRun(), and MgAdapt().
◆ defaultWorkingDirectory()
std::string MgAdapt::defaultWorkingDirectory ( )
◆ execCmd()
void MgAdapt::execCmd ( const char *  cmd,
int &  err
References logFile, and printLogInFile.
◆ getCommandToRun() [1/2]
◆ getCommandToRun() [2/2]
std::string MgAdapt::getCommandToRun ( MgAdapt *  hyp)
References getCommandToRun().
Referenced by SMESH::MG_ADAPT_i::getCommandToRun(), and getCommandToRun().
◆ getConstantValue()
double MgAdapt::getConstantValue ( ) const
◆ getCustomOptionValues()
const TOptionValues & MgAdapt::getCustomOptionValues ( ) const
References _customOption2value.
◆ getCustomOptionValuesStrVec()
std::vector< std::string > MgAdapt::getCustomOptionValuesStrVec ( ) const
◆ getData()
MgAdaptHypothesisData * MgAdapt::getData ( ) const
References data.
Referenced by SMESH::MG_ADAPT_i::getData(), and MgAdapt().
◆ getExeName()
std::string MgAdapt::getExeName ( )
◆ getFieldName()
std::string MgAdapt::getFieldName ( )
◆ getFileName()
std::string MgAdapt::getFileName ( ) const
References workingDir.
Referenced by convertMedFile(), getCommandToRun(), and SMESH::MG_ADAPT_i::getFileName().
◆ getKeepWorkingFiles()
bool MgAdapt::getKeepWorkingFiles ( )
◆ getListFieldsNames()
std::vector< std::string > MgAdapt::getListFieldsNames ( std::string  fileIn)
Referenced by checkFieldName().
◆ getLogFile()
std::string MgAdapt::getLogFile ( )
References logFile.
Referenced by SMESH::MG_ADAPT_i::getLogFile().
◆ getMedFileIn()
std::string MgAdapt::getMedFileIn ( )
References medFileIn.
Referenced by SMESH::MG_ADAPT_i::getMedFileIn().
◆ getMedFileOut()
std::string MgAdapt::getMedFileOut ( )
◆ getMeshName()
std::string MgAdapt::getMeshName ( )
References meshName.
Referenced by SMESH::MG_ADAPT_i::getMeshName().
◆ getMeshNameOut()
std::string MgAdapt::getMeshNameOut ( )
◆ getMeshOutMed()
bool MgAdapt::getMeshOutMed ( )
References meshOutMed.
Referenced by SMESH::MG_ADAPT_i::getMeshOutMed().
◆ getOptionValue()
std::string MgAdapt::getOptionValue ( const std::string &  optionName,
bool *  isDefault = 0
◆ getOptionValues()
TOptionValues MgAdapt::getOptionValues ( ) const
References _option2value, and getOptionValue().
◆ getOptionValuesStrVec()
std::vector< std::string > MgAdapt::getOptionValuesStrVec ( ) const
◆ getPrintLogInFile()
bool MgAdapt::getPrintLogInFile ( )
◆ getPublish()
bool MgAdapt::getPublish ( )
◆ getRank()
int MgAdapt::getRank ( )
References rank.
Referenced by SMESH::MG_ADAPT_i::getRank().
◆ getRemoveOnSuccess()
bool MgAdapt::getRemoveOnSuccess ( )
◆ getSizeMapFile()
std::string MgAdapt::getSizeMapFile ( )
◆ getTimeStep()
int MgAdapt::getTimeStep ( ) const
References timeStep.
Referenced by SMESH::MG_ADAPT_i::getTimeStep().
◆ getUseBackgroundMap()
bool MgAdapt::getUseBackgroundMap ( )
◆ getUseConstantValue()
bool MgAdapt::getUseConstantValue ( )
◆ getUseLocalMap()
bool MgAdapt::getUseLocalMap ( )
◆ getVerbosityLevel()
int MgAdapt::getVerbosityLevel ( )
◆ getWorkingDir()
std::string MgAdapt::getWorkingDir ( ) const
Referenced by SMESH::MG_ADAPT_i::getWorkingDir().
◆ hasOptionDefined()
bool MgAdapt::hasOptionDefined ( const std::string &  optionName) const
◆ isFromMedFile()
bool MgAdapt::isFromMedFile ( )
References fromMedFile.
Referenced by SMESH::MG_ADAPT_i::isFromMedFile().
◆ restorefams()
void MgAdapt::restorefams ( MEDCoupling::MEDFileMesh *  fileMesh) const
References famVec.
Referenced by restoreGroupsAndFams().
◆ restoreGroups()
void MgAdapt::restoreGroups ( MEDCoupling::MEDFileMesh *  fileMesh) const
References groupVec.
◆ restoreGroupsAndFams()
void MgAdapt::restoreGroupsAndFams ( MEDCoupling::MEDFileMesh *  fileMesh) const
References restorefams(), and restoreGroups().
Referenced by convertMeshFile().
◆ setAll()
bool MgAdapt::setAll ( )
References checkDirPath(), data, defaultLogFile(), MG_ADAPT::MgAdaptHypothesisData::fromMedFile, MG_ADAPT::MgAdaptHypothesisData::myConstantValue, MG_ADAPT::MgAdaptHypothesisData::myFieldName, MG_ADAPT::MgAdaptHypothesisData::myFileInDir, MG_ADAPT::MgAdaptHypothesisData::myFileOutDir, MG_ADAPT::MgAdaptHypothesisData::myFileSizeMapDir, MG_ADAPT::MgAdaptHypothesisData::myInMeshName, MG_ADAPT::MgAdaptHypothesisData::myKeepFiles, MG_ADAPT::MgAdaptHypothesisData::myMeshFileBackground, MG_ADAPT::MgAdaptHypothesisData::myMeshFileIn, MG_ADAPT::MgAdaptHypothesisData::myMeshFileOut, MG_ADAPT::MgAdaptHypothesisData::myMeshOutMed, MG_ADAPT::MgAdaptHypothesisData::myOutMeshName, MG_ADAPT::MgAdaptHypothesisData::myPrintLogInFile, MG_ADAPT::MgAdaptHypothesisData::myPublish, MG_ADAPT::MgAdaptHypothesisData::myRank, MG_ADAPT::MgAdaptHypothesisData::myRemoveLogOnSuccess, MG_ADAPT::MgAdaptHypothesisData::myTimeStep, MG_ADAPT::MgAdaptHypothesisData::myUseBackgroundMap, MG_ADAPT::MgAdaptHypothesisData::myUseConstantValue, MG_ADAPT::MgAdaptHypothesisData::myUseLastTimeStep, MG_ADAPT::MgAdaptHypothesisData::myUseLocalMap, MG_ADAPT::MgAdaptHypothesisData::myUseNoTimeStep, MG_ADAPT::MgAdaptHypothesisData::myVerboseLevel, MG_ADAPT::MgAdaptHypothesisData::myWorkingDir, setChosenTimeStepRank(), setConstantValue(), setFieldName(), setFromMedFile(), setKeepWorkingFiles(), setLogFile(), setMedFileIn(), setMedFileOut(), setMeshName(), setMeshNameOut(), setMeshOutMed(), setNoTimeStep(), setPrintLogInFile(), setPublish(), setRankTimeStep(), setRemoveOnSuccess(), setSizeMapFile(), setTimeStepRankLast(), setUseBackgroundMap(), setUseConstantValue(), setUseLocalMap(), setVerbosityLevel(), setWorkingDir(), useBackgroundMap, and useConstantValue.
Referenced by MgAdapt(), SMESH::MG_ADAPT_i::setAll(), and setData().
◆ setChosenTimeStepRank()
void MgAdapt::setChosenTimeStepRank ( )
◆ setConstantValue()
void MgAdapt::setConstantValue ( double  cnst)
◆ setData()
void MgAdapt::setData ( MgAdaptHypothesisData *  data)
◆ setFieldName()
void MgAdapt::setFieldName ( std::string  myFieldName)
◆ setFromMedFile()
void MgAdapt::setFromMedFile ( bool  mybool)
Referenced by setAll(), and SMESH::MG_ADAPT_i::setFromMedFile().
◆ setKeepWorkingFiles()
void MgAdapt::setKeepWorkingFiles ( bool  mybool)
◆ setLogFile()
void MgAdapt::setLogFile ( std::string  myLogFile)
References logFile.
Referenced by setAll(), and SMESH::MG_ADAPT_i::setLogFile().
◆ setMedFileIn()
void MgAdapt::setMedFileIn ( std::string  fileName)
◆ setMedFileOut()
void MgAdapt::setMedFileOut ( std::string  fileOut)
References medFileOut.
Referenced by setAll(), and SMESH::MG_ADAPT_i::setMedFileOut().
◆ setMeshName()
void MgAdapt::setMeshName ( std::string  name)
Referenced by setAll(), and SMESH::MG_ADAPT_i::setMeshName().
◆ setMeshNameOut()
void MgAdapt::setMeshNameOut ( std::string  name)
References meshNameOut.
Referenced by setAll(), and SMESH::MG_ADAPT_i::setMeshNameOut().
◆ setMeshOutMed()
void MgAdapt::setMeshOutMed ( bool  mybool)
Referenced by setAll(), and SMESH::MG_ADAPT_i::setMeshOutMed().
◆ setNoTimeStep()
void MgAdapt::setNoTimeStep ( )
◆ setOptionValue()
void MgAdapt::setOptionValue ( const std::string &  optionName,
const std::string &  optionValue
◆ setPrintLogInFile()
void MgAdapt::setPrintLogInFile ( bool  mybool)
◆ setPublish()
void MgAdapt::setPublish ( bool  mybool)
References publish.
Referenced by setAll(), and SMESH::MG_ADAPT_i::setPublish().
◆ setRankTimeStep()
void MgAdapt::setRankTimeStep ( int  time,
int  myRank
◆ setRemoveOnSuccess()
void MgAdapt::setRemoveOnSuccess ( bool  mybool)
◆ setSizeMapFile()
void MgAdapt::setSizeMapFile ( std::string  mapFile)
References sizeMapFile.
Referenced by setAll(), and SMESH::MG_ADAPT_i::setSizeMapFile().
◆ setTimeStep()
void MgAdapt::setTimeStep ( int  time)
Referenced by SMESH::MG_ADAPT_i::setTimeStep().
◆ setTimeStepRankLast()
void MgAdapt::setTimeStepRankLast ( )
◆ setUseBackgroundMap()
void MgAdapt::setUseBackgroundMap ( bool  mybool)
◆ setUseConstantValue()
void MgAdapt::setUseConstantValue ( bool  mybool)
◆ setUseLocalMap()
void MgAdapt::setUseLocalMap ( bool  mybool)
References useLocalMap.
Referenced by setAll(), and SMESH::MG_ADAPT_i::setUseLocalMap().
◆ setVerbosityLevel()
void MgAdapt::setVerbosityLevel ( int  verbosity)
◆ setWorkingDir()
void MgAdapt::setWorkingDir ( std::string  dir)
Referenced by setAll(), and SMESH::MG_ADAPT_i::setWorkingDir().
◆ storefams()
void MgAdapt::storefams ( MEDCoupling::MEDFileMesh *  fileMesh)
References famVec.
Referenced by storeGroupsAndFams().
◆ storeGroups()
void MgAdapt::storeGroups ( MEDCoupling::MEDFileMesh *  fileMesh)
◆ storeGroupsAndFams()
void MgAdapt::storeGroupsAndFams ( MEDCoupling::MEDFileMesh *  fileMesh)
References storefams(), and storeGroups().
◆ toBool()
bool MgAdapt::toBool ( const std::string &  str,
bool *  isOk = 0
Referenced by getCommandToRun(), and setOptionValue().
◆ toDbl()
double MgAdapt::toDbl ( const std::string &  str,
bool *  isOk = 0
Referenced by setOptionValue().
◆ toInt()
int MgAdapt::toInt ( const std::string &  str,
bool *  isOk = 0
◆ toLowerStr()
std::string MgAdapt::toLowerStr ( const std::string &  str)
◆ updateTimeStepRank()
void MgAdapt::updateTimeStepRank ( )
◆ _boolOptions
TOptionNames MG_ADAPT::MgAdapt::_boolOptions
Referenced by buildModel(), MgAdapt(), and setOptionValue().
◆ _charOptions
TOptionNames MG_ADAPT::MgAdapt::_charOptions
◆ _customOption2value
◆ _defaultOptionValues
TOptionValues MG_ADAPT::MgAdapt::_defaultOptionValues
◆ _doubleOptions
TOptionNames MG_ADAPT::MgAdapt::_doubleOptions
◆ _errorMessages
std::vector<std::string> MG_ADAPT::MgAdapt::_errorMessages
Referenced by addMessage().
◆ _option2value
◆ _status
Status MG_ADAPT::MgAdapt::_status
◆ constantValue
double MG_ADAPT::MgAdapt::constantValue
◆ data
MgAdaptHypothesisData* MG_ADAPT::MgAdapt::data
◆ famVec
std::vector<family> MG_ADAPT::MgAdapt::famVec
Referenced by restorefams(), and storefams().
◆ fieldName
◆ fromMedFile
bool MG_ADAPT::MgAdapt::fromMedFile
Referenced by isFromMedFile(), and setFromMedFile().
◆ groupVec
std::vector<group> MG_ADAPT::MgAdapt::groupVec
Referenced by restoreGroups(), and storeGroups().
◆ logFile
std::string MG_ADAPT::MgAdapt::logFile
◆ medFileIn
std::string MG_ADAPT::MgAdapt::medFileIn
◆ medFileOut
std::string MG_ADAPT::MgAdapt::medFileOut
◆ meshFormatOutputMesh
std::string MG_ADAPT::MgAdapt::meshFormatOutputMesh
Referenced by compute(), and getCommandToRun().
◆ meshName
std::string MG_ADAPT::MgAdapt::meshName
Referenced by getMeshName(), and setMeshName().
◆ meshNameOut
std::string MG_ADAPT::MgAdapt::meshNameOut
◆ meshOutMed
bool MG_ADAPT::MgAdapt::meshOutMed
Referenced by getMeshOutMed(), and setMeshOutMed().
◆ myUseChosenTimeStep
bool MG_ADAPT::MgAdapt::myUseChosenTimeStep
◆ myUseLastTimeStep
bool MG_ADAPT::MgAdapt::myUseLastTimeStep
◆ myUseNoTimeStep
bool MG_ADAPT::MgAdapt::myUseNoTimeStep
◆ printLogInFile
bool MG_ADAPT::MgAdapt::printLogInFile
◆ publish
bool MG_ADAPT::MgAdapt::publish
Referenced by getPublish(), and setPublish().
◆ rank
int MG_ADAPT::MgAdapt::rank
◆ removeOnSuccess
bool MG_ADAPT::MgAdapt::removeOnSuccess
◆ sizeMapFile
◆ solFormatOutput
std::vector< std::string> MG_ADAPT::MgAdapt::solFormatOutput
◆ timeStep
◆ tmpFilesToBeDeleted
std::vector< std::string> MG_ADAPT::MgAdapt::tmpFilesToBeDeleted
Referenced by cleanUp(), and getCommandToRun().
◆ toKeepWorkingFiles
bool MG_ADAPT::MgAdapt::toKeepWorkingFiles
◆ useBackgroundMap
bool MG_ADAPT::MgAdapt::useBackgroundMap
◆ useConstantValue
bool MG_ADAPT::MgAdapt::useConstantValue
◆ useLocalMap
bool MG_ADAPT::MgAdapt::useLocalMap
◆ verbosityLevel
int MG_ADAPT::MgAdapt::verbosityLevel
◆ workingDir
std::string MG_ADAPT::MgAdapt::workingDir
