SMESHUtils_MGLicenseKeyGen Namespace Reference
Manage loading libSalomeMeshGemsKeyGenerator. More...
bool SignCAD_After (void *meshgems_cad, std::string &error)
 Sign a CAD. More...
bool UnlockProduct (const std::string &product, std::string &error)
 Unlock a specific MeshGems product (for products called as a library) More...
bool SignCAD (void *meshgems_cad, std::string &error)
 Sign a CAD (or don't do it if env MESHGEMS_OLD_STYLE is set) More...
bool SignMesh_After (void *meshgems_mesh, std::string &error)
 Sign a mesh. More...
bool SignMesh (void *meshgems_mesh, const std::string &product, std::string &error)
 Sign a mesh (or don't do it if env MESHGEMS_OLD_STYLE is set) More...
std::string GetKey_After (const std::string &gmfFile, int nbVertex, int nbEdge, int nbFace, int nbVol, std::string &error)
 Return a license key to pass as argument to a MG mesher executable. More...
std::string GetKey_After (std::string &error)
 Return a license key to pass as argument to a MG mesher executable (>2.15) More...
int GetMGVersionFromEnv (const char *env_variable)
 Get MeshGems version major/minor/patch from the environment variables. More...
int GetMGVersionFromFunction (const char *function_name)
 Get MeshGems version major/minor/patch from the keygen library and meshgems built-in functions. More...
int GetMGVersionHex (std::string &error)
 Get MeshGems version from the keygen library or meshgems built-in functions. More...
bool NeedsMGSpatialEnvLicense (std::string &error)
 Guess if the Spatial license is needed (if MeshGems is > 2.15.0) More...
bool SetMGSpatialEnvLicense (std::string &error)
 Set the SPATIAL_LICENSE environment variable. More...
std::string GetKey (const std::string &gmfFile, int nbVertex, int nbEdge, int nbFace, int nbVol, std::string &error)
 Get the license key from libMeshGemsKeyGenerator.so or $SPATIAL_LICENSE Called by plugins calling MG products as executables. More...
std::string GetKey (std::string &error)
 Get the license key from libMeshGemsKeyGenerator.so or $SPATIAL_LICENSE Called for MG 2.15 by CADSurf and MG plugins calling MG products as library, i.e. More...
bool CheckKeyGenLibrary (std::string &error)
 Return false if libMeshGemsKeyGenerator.so is not functional. More...
std::string GetLibraryName ()
 Return KeyGenerator library name. More...
[so|dll] and sing MeshGems CAD or mesh
◆ CheckKeyGenLibrary()
bool SMESHUtils_MGLicenseKeyGen::CheckKeyGenLibrary ( std::string &  error)
[out]error- return error description
bool - is a success
References GetKey().
◆ GetKey() [1/2]
std::string SMESHUtils_MGLicenseKeyGen::GetKey ( const std::string &  gmfFile,
int  nbVertex,
int  nbEdge,
int  nbFace,
int  nbVol,
std::string &  error
If MESHGEMS_OLD_STYLE is set, return "0", to use old DLIM8 server license instead of the key.
[in]gmfFile- path to an input mesh file
[in]nb*- nb of entities in the input mesh
std::string - the key
References GetKey_After(), MESHGEMS_OLD_STYLE, MESSAGE, NeedsMGSpatialEnvLicense(), SetMGSpatialEnvLicense(), and SPATIAL_LICENSE.
Referenced by CheckKeyGenLibrary(), MG_ADAPT::MgAdapt::getCommandToRun(), GetMGLicenseKeyImpl(), and SetMGSpatialEnvLicense().
◆ GetKey() [2/2]
std::string SMESHUtils_MGLicenseKeyGen::GetKey ( std::string &  error)
compiled as library with -DSALOME_USE_MG_LIBS=ON
References GetKey_After(), MESHGEMS_OLD_STYLE, MESSAGE, and SPATIAL_LICENSE.
◆ GetKey_After() [1/2]
std::string SMESHUtils_MGLicenseKeyGen::GetKey_After ( const std::string &  gmfFile,
int  nbVertex,
int  nbEdge,
int  nbFace,
int  nbVol,
std::string &  error
References GetProc.
Referenced by GetKey().
◆ GetKey_After() [2/2]
std::string SMESHUtils_MGLicenseKeyGen::GetKey_After ( std::string &  error)
References GetProc.
◆ GetLibraryName()
std::string SMESHUtils_MGLicenseKeyGen::GetLibraryName ( )
◆ GetMGVersionFromEnv()
int SMESHUtils_MGLicenseKeyGen::GetMGVersionFromEnv ( const char *  env_variable)
int - the version
References MESSAGE.
Referenced by GetMGVersionHex().
◆ GetMGVersionFromFunction()
int SMESHUtils_MGLicenseKeyGen::GetMGVersionFromFunction ( const char *  function_name)
int - the function implemented in the library
References GetProc, and MESSAGE.
◆ GetMGVersionHex()
int SMESHUtils_MGLicenseKeyGen::GetMGVersionHex ( std::string &  error)
int - the version
References GetMGVersionFromEnv(), GetMGVersionFromFunction(), and MESSAGE.
Referenced by NeedsMGSpatialEnvLicense().
◆ NeedsMGSpatialEnvLicense()
bool SMESHUtils_MGLicenseKeyGen::NeedsMGSpatialEnvLicense ( std::string &  error)
bool - true if MeshGems is > 2.15.0
References GetMGVersionHex(), MESHGEMS_215, and MESSAGE.
Referenced by GetKey(), SignCAD(), and SignMesh().
◆ SetMGSpatialEnvLicense()
bool SMESHUtils_MGLicenseKeyGen::SetMGSpatialEnvLicense ( std::string &  error)
bool - true in case of success
References GetKey(), MESSAGE, and SPATIAL_LICENSE.
◆ SignCAD()
bool SMESHUtils_MGLicenseKeyGen::SignCAD ( void *  meshgems_cad,
std::string &  error
[in]meshgems_cad- pointer to a MG CAD object (meshgems_cad_t)
bool - is a success
References MESHGEMS_OLD_STYLE, NeedsMGSpatialEnvLicense(), SignCAD_After(), and UnlockProduct().
◆ SignCAD_After()
bool SMESHUtils_MGLicenseKeyGen::SignCAD_After ( void *  meshgems_cad,
std::string &  error
Sign a CAD.
bool - is a success
References GetProc, SMESH::returnError(), SMESH_CATCH, and SMESH_TRY.
Referenced by SignCAD().
◆ SignMesh()
bool SMESHUtils_MGLicenseKeyGen::SignMesh ( void *  meshgems_mesh,
const std::string &  product,
std::string &  error
[in]meshgems_mesh- pointer to a MG mesh (meshgems_mesh_t)
[in]product- product of MeshGems to unlock
bool - is a success
References MESHGEMS_OLD_STYLE, NeedsMGSpatialEnvLicense(), SignMesh_After(), and UnlockProduct().
◆ SignMesh_After()
bool SMESHUtils_MGLicenseKeyGen::SignMesh_After ( void *  meshgems_mesh,
std::string &  error
Sign a mesh.
bool - is a success
Referenced by SignMesh().
◆ UnlockProduct()
bool SMESHUtils_MGLicenseKeyGen::UnlockProduct ( const std::string &  product,
std::string &  error
bool - is a success
References GetProc, MESSAGE, SMESH::returnError(), SMESH_CATCH, and SMESH_TRY.
Referenced by SignCAD(), and SignMesh().
