SMESH_MeshAlgos::Intersector Class Reference
Cut faces of a triangular mesh. More...
#include <SMESH_MeshAlgos.hxx>
struct  Algo
 Intersect faces of a mesh. More...
typedef std::vector< SMESH_NodeXYZ > TFace
 Intersector (SMDS_Mesh *mesh, double tol, const std::vector< gp_XYZ > &normals)
 ~Intersector ()
void Cut (const SMDS_MeshElement *face1, const SMDS_MeshElement *face2, const int nbCommonNodes=-1)
 Compute cut of two faces of the mesh. More...
void Cut (const SMDS_MeshElement *face, SMESH_NodeXYZ &lineEnd1, int edgeIndex1, SMESH_NodeXYZ &lineEnd2, int edgeIndex2)
 Store a face cut by a line given by its ends lying either on face edges or inside the face. More...
void MakeNewFaces (SMESH_MeshAlgos::TElemIntPairVec &theNew2OldFaces, SMESH_MeshAlgos::TNodeIntPairVec &theNew2OldNodes, const double theSign=1., const bool theOptimize=false)
 Split all faces intersected by Cut() methods. More...
static bool CutByPlanes (const SMDS_MeshElement *face, const std::vector< gp_Ax1 > &planes, const double tol, std::vector< TFace > &newFaceConnectivity)
 Cut a face by planes, whose normals point to parts to keep. More...
Algo * myAlgo
Usage work-flow: 1) call Cut() methods as many times as needed 2) call MakeNewFaces() to really modify the mesh faces
◆ TFace
◆ Intersector()
SMESH_MeshAlgos::Intersector::Intersector ( SMDS_Mesh *  mesh,
double  tol,
const std::vector< gp_XYZ > &  normals
References myAlgo.
◆ ~Intersector()
SMESH_MeshAlgos::Intersector::~Intersector ( )
References myAlgo.
◆ Cut() [1/2]
void SMESH_MeshAlgos::Intersector::Cut ( const SMDS_MeshElement *  face,
SMESH_NodeXYZ &  lineEnd1,
int  edgeIndex1,
SMESH_NodeXYZ &  lineEnd2,
int  edgeIndex2
store a face cut by a line given by its ends
References SMESH_MeshAlgos::Intersector::Algo::Cut(), and myAlgo.
◆ Cut() [2/2]
void SMESH_MeshAlgos::Intersector::Cut ( const SMDS_MeshElement *  face1,
const SMDS_MeshElement *  face2,
const int  nbCommonNodes = -1
compute cut of two faces of the mesh
Referenced by SMESH_MeshAlgos::MakeOffset(), and SMESH_MeshAlgos::MakeSlot().
◆ CutByPlanes()
◆ MakeNewFaces()
void SMESH_MeshAlgos::Intersector::MakeNewFaces ( SMESH_MeshAlgos::TElemIntPairVec &  theNew2OldFaces,
SMESH_MeshAlgos::TNodeIntPairVec &  theNew2OldNodes,
const double  theSign = 1.,
const bool  theOptimize = false
split all face intersected by Cut() methods
References SMESH_MeshAlgos::Intersector::Algo::MakeNewFaces(), and myAlgo.
◆ myAlgo
Algo* SMESH_MeshAlgos::Intersector::myAlgo
